Error during compilation of build file
SivaHeramb
#1 Unread post by SivaHeramb »
I have downloaded the software trunk and trying to build the bash script. I have made the following changes in build_roms.bash:
(1)export USE_NETCDF4=on
(2)export NF_CONFIG=/usr/bin/nf-config
(3)export NETCDF_INCDIR=/usr/include
(4)export FC=gfortran
and also added netcdf.mod and typesizes.mod in /opt/gfortransoft/serial/netcdf3/include to avoid previous errors I got.
And then, when I tried to 'make' I got the following error:
svn: warning: W155010: The node '/home/siva/ocean/repository/trunk' was not found.
svn: E200009: Could not display info for all targets because some targets don't exist
cd Build; /usr/bin/gfortran -c -frepack-arrays -O3 -ffast-math u2dbc_im.f90
u2dbc_im.f90:171:23:
IF (FIRST_2D_STEP) THEN
1
Error: Symbol ‘first_2d_step’ at (1) has no IMPLICIT type
ROMS/Nonlinear/Module.mk:15: recipe for target 'Build/u2dbc_im.o' failed
make: *** [Build/u2dbc_im.o] Error 1
I am a beginner of this software and also to linux. Did I miss to do something else? Can somebody help me to move forward?
Re: Error during compilation of build file
I think you should have:
NETCEDF_INCDIR=/opt/gfortransoft/serial/netcdf3/include
if that's where the netcdf.mod and friends live.
The FIRST_2D_STEP is a cpp macro defined in globaldefs.h, not a regular Fortran variable. If the compile goes correctly, the compiler should never see it. Step one is a "make depend" to create the dependency list (MakeDepend), then each file gets processed with:
  • 1. cpp
    2. cpp_clean
    3. compiler
I don't know what went wrong for you.
