variable not properly initialized in ROMS svn978 ?
backkom
#1 Unread post by backkom »
I am trying the latest ROMS svn978 code, by a ROMS + SWAN coupling application, activated by CPP option " #define SWAN_COUPLING, #define NEARSHORE_MELLOR08", but got a error message as follows:
$ mpirun -np 20 ./romsM ./Input/coupling_eams_20190730.in > log.20190730
forrtl: severe (194): Run-Time Check Failure. The variable 'lsplit_$RITM' is being used in 'ocpmix.f90(2220,24)' without being defined
Image PC Routine Line Source
romsM 000000000096671B lsplit_ 2220 ocpmix.f90
romsM 00000000008A6CC2 rbfile_ 5038 swanmain.f90
romsM 00000000008A53D1 snexti_ 4374 swanmain.f90
romsM 00000000008A0EAC swan_run_ 455 swanmain.f90
romsM 00000000004055F5 MAIN__ 91 master.f90
romsM 0000000000404B3E Unknown Unknown Unknown
libc-2.17.so 00007FA4C82A53D5 __libc_start_main Unknown Unknown
romsM 0000000000404A49 Unknown Unknown Unknown
The reported ocpmix.f90 (SWAN code) code is as follows:
 2141 !
2142       INTEGER   ICR1, IENT, ILL, IITM, LENLIN, RITM
2143 !
2144 !     LCHSTR : if True, program is reading a string (enclosed in quotes)
2145 !
2146       LOGICAL   LCHSTR
2147 !
2148 !  8. SUBROUTINE USED
2149 !
2150 !     ------
2151 !
2152 !  9. SUBROUTINES CALLING
2153 !
2154 !     SWBOUN
2155 !
2156 ! 10. ERROR MESSAGES
2157 !
2158 !     Too many data items on input line
2159 !
2160 ! 11. REMARKS
2161 !
2162 ! 12. STRUCTURE
2163 !
2164 ! 13. SOURCE TEXT
2165 !
2166       SAVE      IENT, QUOTE
2167       DATA      IENT /0/, QUOTE /''''/
2168       CALL STRACE (IENT, 'LSPLIT')
2169 !
2170       LENLIN = LEN(RELINE)
2171       LCHSTR = .FALSE.
2172       DO IITM = 1, NUMITM
2173         DATITM(IITM) = '    '
2174       ENDDO
2175       IF (ITEST.GE.150) WRITE (PRTEST,*) ' test LSPLIT ', RELINE
2176 !
2177 !     free format: separate the line into data items
2178 !     blanks and commas serve as separation between data items
2179 !     DATITM is string containing one data item
2180 !
2181       IITM = 0
2182       DO 170 ILL = 1, LENLIN
2183          CRL = RELINE(ILL:ILL)
2184          IF (LCHSTR) THEN
2185 !           reading a character string enclosed in quotes
2186             IF (CRL.EQ.QUOTE) THEN
2187 !              closing quote
2188                LCHSTR = .FALSE.
2189                RITM   = 2
2190                IF (IITM.GT.NUMITM) THEN
2191                  CALL MSGERR (2, 'too many items on input line')
2192                  WRITE (PRINTF, *) ' -> ', TRIM(RELINE)
2193                ENDIF
2194                DATITM(IITM) = RELINE (ICR1:ILL-1)
2195             ENDIF
2196          ELSE
2197             IF (CRL.EQ.',') THEN
2198                IF (RITM.EQ.0) THEN
2199 !                 empty item
2200                   IITM = IITM + 1
2201                   IF (IITM.GT.NUMITM) THEN
2202                     CALL MSGERR (2, 'too many items on input line')
2203                     WRITE (PRINTF, *) ' -> ', TRIM(RELINE)                40.03
2204                   ENDIF
2205                   DATITM(IITM) = '    '
2206                ELSE
2207                   IF (RITM.EQ.1) DATITM(IITM) = RELINE(ICR1:ILL)
2208                   RITM = 0
2209                ENDIF
2210             ELSE IF (CRL.EQ.' ' .OR. CRL.EQ.TABC) THEN
2211                IF (RITM.EQ.1) THEN
2212                   IF (IITM.GT.NUMITM) THEN
2213                     CALL MSGERR (2, 'too many items on input line')
2214                     WRITE (PRINTF, *) ' -> ', TRIM(RELINE)                40.03
2215                   ENDIF
2216                   DATITM(IITM) = RELINE(ICR1:ILL)
2217                   RITM = 2
2218                ENDIF
2219             ELSE
2220                IF (RITM.NE.1) THEN
2221                   IITM = IITM + 1
2222                   IF (IITM.GT.NUMITM) THEN
2223                     CALL MSGERR (2, 'too many items on input line')
2224                     WRITE (PRINTF, *) ' -> ', TRIM(RELINE)                40.03
2225                   ENDIF
2226                   IF (CRL.EQ.QUOTE) THEN
2227                      ICR1 = ILL+1
2228                      LCHSTR = .TRUE.
2229                   ELSE
2230                      ICR1 = ILL
2231                      RITM = 1
2232                   ENDIF
2233                ENDIF
2234             ENDIF
2235          ENDIF
2236          IF (ITEST.GE.250) WRITE (PRTEST, 165) CRL, RITM,
2237      &                IITM, ICR1
2238  165     FORMAT (' test LSPLIT ', A1, 3I3, 2X, A20)
2239  170  CONTINUE
The errors occurs when dealing with 1st data line "20190720.00 0.1047 0.9145 75.4095 20" in my wave lateral OBCs TPAR input file.
TPAR
20190720.03 0.0923 0.8901 74.8351 20
20190720.06 0.0927 0.8433 73.8963 20
20190720.09 0.0990 0.8544 69.3413 20
20190720.12 0.1358 0.9314 70.2427 20
The traceback option locates the line of 2220, which trigger the error.
The variable "RITM" seems not initialized properly (assign a initial value), and somehow it works for svn 902 but report error in svn 978. Could someone give me some advice on this?
BTW, I am using intel ifort compiler 18.0.2 20180210 with openmpi setting.
Best,
Yao
Re: variable not properly initialized in ROMS svn978 ?
if you are using roms+swan, you should use our coawst system. We also do not use the Mellor option anymore, we use vortex force.
if you need access to coawst you can send me an email.
jcwarner@usgs.gov
