Blowing up problem when using sediment
zip
#1 Unread post by zip »
hello everyone
I use ROMS to simulate the sandwaves in a ideal flume by change the parameters in ana_grid.h and ana_m2obc.h file,but the work blow up immediately when i use a large timestep(dt):10s. Then i use a small dt :1s but it just delay the blow up, it computes for 600000 steps then blowing up, after that, i use 0.5s dt ,but it waste too much time to compute one step, so i want to ask how to deal with this problem.
Thank you for your help!
Best
Zip
The log file is listed as follows:
Tuesday - March 26, 2019 - 5:39:34 PM
Suspended Sediment Test in an Estuary
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /vol6/home/zhipeng/software/openmpi/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script :
SVN Revision : 853M
Local Root : /vol6/home/zhipeng/ROMS/chenkai/trunk_853
Header Dir : /vol6/home/zhipeng/ROMS/chenkai/test2
Header file : estuary_test.h
Analytical Dir: /vol6/home/zhipeng/ROMS/chenkai/test2
Resolution, Grid 01: 0600x0005x030, Parallel Nodes: 6, Tiling: 006x001
525960 ntimes Number of timesteps for 3-D equations.
10.000 dt Timestep size (s) for 3-D equations.
10000 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
100 nHIS Number of timesteps between the writing fields
into history file.
into quicksave file.
time-averaged data.
100000 nAVG Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
0.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
2.0000E-03 rdrg2 Quadratic bottom drag coefficient.
1.5000E-02 Zob Bottom roughness (m).
5.0000E-03 Zos Surface roughness (m).
3 Vstretching S-coordinate stretching function.
1.0000E+00 theta_s S-coordinate surface control parameter.
3.0000E+00 theta_b S-coordinate bottom control parameter.
1.000 Tcline S-coordinate surface/bottom layer width (m) used
1028.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
1.2500E-01 Tnudg(01) Nudging/relaxation time scale (days)
1.2500E-01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
1.0000E-03 Znudg Nudging/relaxation time scale (days)
1.0000E-03 M2nudg Nudging/relaxation time scale (days)
1.0000E-03 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.0000E+00 obcfac Factor between passive and active
of State.
T Hout(idBath) Write out time-dependent bathymetry.
T Aout(idUbms) Write out averaged bottom U-momentum stress.
Tile partition information for Grid 01: 0600x0005x0030 tiling: 006x001
tile Istr Iend Jstr Jend Npts
0 1 100 1 5 15000
1 101 200 1 5 15000
2 201 300 1 5 15000
3 301 400 1 5 15000
4 401 500 1 5 15000
5 501 600 1 5 15000
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 100.50 0.50 5.50 RHO-points
1 100.50 200.50 0.50 5.50 RHO-points
2 200.50 300.50 0.50 5.50 RHO-points
3 300.50 400.50 0.50 5.50 RHO-points
4 400.50 500.50 0.50 5.50 RHO-points
5 500.50 600.50 0.50 5.50 RHO-points
0 1.00 100.50 0.50 5.50 U-points
1 100.50 200.50 0.50 5.50 U-points
2 200.50 300.50 0.50 5.50 U-points
3 300.50 400.50 0.50 5.50 U-points
4 400.50 500.50 0.50 5.50 U-points
5 500.50 600.00 0.50 5.50 U-points
0 0.50 100.50 1.00 5.00 V-points
1 100.50 200.50 1.00 5.00 V-points
2 200.50 300.50 1.00 5.00 V-points
3 300.50 400.50 1.00 5.00 V-points
4 400.50 500.50 1.00 5.00 V-points
5 500.50 600.50 1.00 5.00 V-points
HaloSizeI(1) = 224
HaloSizeJ(1) = 30
TileSide(1) = 106
TileSize(1) = 954
Sediment Parameters, Grid: 01
1 2.0000E-01 0.0000E+00 2.6500E+03 1.5000E+01 5.0000E-03 5.0000E-01
1 1.5000E-01 1.5000E-01 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.2000E+01
New bed layer formed when deposition exceeds 0.10000E+00 (m).
Two first layers are combined when 2nd layer smaller than 0.00000E+00 (m).
Rate coefficient for bed load transport = 0.15000E+01
F LtracerSponge(03Turning OFF sponge on tracer 03: sand_01
F LtracerSrc(03) Turning OFF point sources/Sink on tracer 03: sand_01
F LtracerCLM(03) Turning OFF processing of climatology tracer 03: sand_01
F LnudgeTCLM(03) Turning OFF nudging of climatology tracer 03: sand_01
T Hout(idTvar) Write out sediment01: sand_01
T Hout(idfrac) Write out mass, sediment 01: sandmass_01
T Hout(idBott) Write out BOTTOM property 01: grain_diameter
T Hout(idBott) Write out BOTTOM property 05: ripple_length
T Hout(idBott) Write out BOTTOM property 06: ripple_height
T Aout(idTvar) Write out averaged sediment01: sand_01
T Aout(idUbld) Write out U-bedload, sediment 01: bedload_Usand_01
T Aout(idVbld) Write out V-bedload, sediment 01: bedload_Vsand_01
zeta 1 Radiation Closed Radiation Closed
ubar 1 Clamped Closed Clamped Closed
vbar 1 Clamped Closed Clamped Closed
u 1 Radiation Closed Radiation Closed
v 1 Radiation Closed Radiation Closed
temp 1 Radiation Closed Radiation Closed
salt 1 Radiation Closed Radiation Closed
sand_01 1 Radiation Closed Radiation Closed
tke 1 Gradient Closed Gradient Closed
ESTUARY_TEST Suspended Sediment Test in an Estuary
ANA_SEDIMENT Analytical sediment initial conditions.
ANA_WWAVE Analytical wind induced waves.
BEDLOAD_SOULSBY Activate bed load sediment transport Soulsby formula.
NONLINEAR Nonlinear Model.
SED_MORPH Allow bottom model elevation to evolve.
SSW_BBL Styles and Glenn Bottom Boundary Layer - modified.
SSW_CALC_ZNOT Internal computation of bottom roughness.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Node # 5 (pid= 5807) is active.
Process Information:
Node # 0 (pid= 5797) is active.
Node # 1 (pid= 5799) is active.
Node # 2 (pid= 5801) is active.
Node # 3 (pid= 5803) is active.
Node # 4 (pid= 5805) is active.
30 0.0000000 0.0000000 0.000 0.000 0.000 0.000
29 -0.0333333 -0.0091908 -0.294 -0.021 -0.307 -0.320
28 -0.0666667 -0.0246480 -0.766 -0.046 -0.801 -0.835
27 -0.1000000 -0.0465229 -1.420 -0.073 -1.486 -1.552
26 -0.1333333 -0.0748645 -2.259 -0.104 -2.365 -2.470
25 -0.1666667 -0.1096016 -3.279 -0.138 -3.434 -3.589
24 -0.2000000 -0.1505193 -4.476 -0.175 -4.688 -4.901
23 -0.2333333 -0.1972327 -5.837 -0.215 -6.115 -6.394
22 -0.2666667 -0.2491614 -7.346 -0.258 -7.698 -8.050
21 -0.3000000 -0.3055125 -8.982 -0.303 -9.413 -9.845
20 -0.3333333 -0.3652803 -10.714 -0.349 -11.230 -11.746
19 -0.3666667 -0.4272698 -12.510 -0.397 -13.114 -13.717
18 -0.4000000 -0.4901463 -14.331 -0.445 -15.023 -15.716
17 -0.4333333 -0.5525108 -16.138 -0.493 -16.918 -17.698
16 -0.4666667 -0.6129904 -17.890 -0.540 -18.756 -19.622
15 -0.5000000 -0.6703344 -19.554 -0.585 -20.501 -21.447
14 -0.5333333 -0.7234995 -21.099 -0.628 -22.121 -23.142
13 -0.5666667 -0.7717134 -22.503 -0.669 -23.593 -24.682
12 -0.6000000 -0.8145063 -23.752 -0.707 -24.903 -26.053
11 -0.6333333 -0.8517082 -24.843 -0.743 -26.046 -27.248
10 -0.6666667 -0.8834166 -25.777 -0.775 -27.025 -28.272
9 -0.7000000 -0.9099419 -26.564 -0.805 -27.849 -29.134
8 -0.7333333 -0.9317437 -27.217 -0.833 -28.533 -29.848
7 -0.7666667 -0.9493675 -27.750 -0.858 -29.091 -30.432
6 -0.8000000 -0.9633892 -28.181 -0.882 -29.542 -30.903
5 -0.8333333 -0.9743731 -28.526 -0.904 -29.902 -31.278
4 -0.8666667 -0.9828430 -28.799 -0.925 -30.187 -31.576
3 -0.9000000 -0.9892666 -29.014 -0.945 -30.412 -31.809
2 -0.9333333 -0.9940485 -29.183 -0.964 -30.587 -31.991
1 -0.9666667 -0.9975313 -29.314 -0.982 -30.723 -32.132
0 -1.0000000 -1.0000000 -29.416 -1.000 -30.829 -32.241
Time Splitting Weights for Grid 01: ndtfast = 20 nfast = 29
3-0.0011514592651645 0.0501156998674241-0.0034654566136460 0.1501639558342179
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649002
5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792858
6 0.0029141799764308 0.0501428056118168 0.0000580677400948 0.3006719858911026
7 0.0054132615310267 0.0499970966129952 0.0054713292711215 0.3506690825040978
8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405417
9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876600
10 0.0161716623600090 0.0486998273761630 0.0421751148367486 0.4983983377638230
11 0.0207585511322367 0.0478912442581626 0.0629336659689853 0.5462895820219856
12 0.0257765478740990 0.0468533167015507 0.0887102138430843 0.5931428987235363
13 0.0311633730493853 0.0455644893078458 0.1198735868924696 0.6387073880313821
14 0.0368391158442262 0.0440063206553765 0.1567127027366958 0.6827137086867585
15 0.0427031802506397 0.0421643648631652 0.1994158829873354 0.7248780735499237
16 0.0486309868367616 0.0400292058506332 0.2480468698240970 0.7649072794005569
17 0.0544704302037591 0.0375976565087951 0.3025173000278562 0.8025049359093520
18 0.0600380921294285 0.0348741349986072 0.3625553921572847 0.8373790709079592
19 0.0651152103984763 0.0318722303921358 0.4276706025557610 0.8692513013000949
20 0.0694434033194839 0.0286164698722119 0.4971140058752449 0.8978677711723068
21 0.0727201499285569 0.0251442997062377 0.5698341558038018 0.9230120708785445
22 0.0745940258796570 0.0215082922098099 0.6444281816834588 0.9445203630883544
23 0.0746596950216180 0.0177785909158270 0.7190878767050768 0.9622989540041814
24 0.0724526566618460 0.0140456061647461 0.7915405333669228 0.9763445601689276
25 0.0674437485167025 0.0104229733316538 0.8589842818836253 0.9867675335005814
26 0.0590334053485720 0.0070507859058187 0.9180176872321973 0.9938183194064002
27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447904
28 0.0292219798521905 0.0017718319739095 0.9937853403740005 0.9996892670186999
29 0.0062146596259994 0.0003107329813000 0.9999999999999999 0.9999999999999999
Minimum X-grid spacing, DXmin = 2.00000000E-03 km
Maximum X-grid spacing, DXmax = 2.00000000E-03 km
Minimum Y-grid spacing, DYmin = 2.00000000E-03 km
Maximum Y-grid spacing, DYmax = 2.00000000E-03 km
Minimum Z-grid spacing, DZmin = 1.02470447E-01 m
Maximum Z-grid spacing, DZmax = 1.99857522E+00 m
Minimum barotropic Courant Number = 6.00599151E+00
Maximum barotropic Courant Number = 6.28777113E+00
Maximum Coriolis Courant Number = 0.00000000E+00
Maximum grid stiffness ratios: rx0 = 6.523764E-03 (Beckmann and Haidvogel)
rx1 = 3.771659E+00 (Haney)
Initial basin volumes: TotVolume = 3.7398438720E+05 m3
MinVolume = 4.0988178890E-01 m3
MaxVolume = 7.9943008726E+00 m3
Max/Min = 1.9503918176E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00525960)
0 0001-01-01 00:00:00.00 0.000000E+00 1.527725E+02 1.527725E+02 3.739844E+05
(000,0,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_HIS - creating history file, Grid 01: ocean_his.nc
WRT_HIS - wrote history fields (Index=1,1) in record = 0000001
DEF_AVG - creating average file, Grid 01: ocean_avg.nc
1 0001-01-01 00:00:10.00 NaN NaN NaN NaN
(600,5,01) NaN NaN NaN NaN
WRT_RST - wrote re-start fields (Index=2,2) in record = 0000001
Node # 0 CPU: 0.172
Total: 1.255
Allocation and array initialization .............. 0.055 ( 4.3824 %)
Ocean state initialization ....................... 0.123 ( 9.8008 %)
Reading of input data ............................ 0.001 ( 0.0797 %)
Processing of input data ......................... 0.051 ( 4.0636 %)
Computation of global information integrals ...... 0.011 ( 0.8766 %)
Writing of output data ........................... 0.412 (32.8287 %)
Model 2D kernel .................................. 0.029 ( 2.3107 %)
2D/3D coupling, vertical metrics ................. 0.018 ( 1.4342 %)
Omega vertical velocity .......................... 0.002 ( 0.1594 %)
Equation of state for seawater ................... 0.013 ( 1.0359 %)
Sediment tranport module, source/sink terms ...... 0.102 ( 8.1275 %)
GLS vertical mixing parameterization ............. 0.098 ( 7.8089 %)
3D equations right-side terms .................... 0.005 ( 0.3983 %)
3D equations predictor step ...................... 0.009 ( 0.7172 %)
Harmonic mixing of tracers, S-surfaces ........... 0.006 ( 0.4780 %)
Corrector time-step for 3D momentum .............. 0.007 ( 0.5578 %)
Corrector time-step for tracers .................. 0.012 ( 0.9562 %)
Bottom boundary layer module ..................... 0.010 ( 0.7969 %)
Total: 0.964 76.8128
Message Passage: 2D halo exchanges ............... 0.024 ( 1.9126 %)
Message Passage: 3D halo exchanges ............... 0.017 ( 1.3545 %)
Message Passage: 4D halo exchanges ............... 0.001 ( 0.0797 %)
Message Passage: data broadcast .................. 0.500 (39.8408 %)
Message Passage: data reduction .................. 0.001 ( 0.0797 %)
Message Passage: data gathering .................. 0.030 ( 2.3903 %)
Total: 0.573 45.6575
All percentages are with respect to total time = 1.255
Node # 4 CPU: 0.216
Node # 1 CPU: 0.215
Node # 2 CPU: 0.217
Node # 3 CPU: 0.216
Node # 5 CPU: 0.219
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_fsobc.h
ROMS/Functionals/ana_grid.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_sediment.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
ROMS/Functionals/ana_wwave.h
ROMS/TOMS: DONE... Tuesday - March 26, 2019 - 5:39:35 PM
Re: Blowing up problem when using sediment
How about you look at the history file for these 600000 steps and see what is happening. is the model blowing up at the boundary (upstream or downstream), somewhere in the domain, what does the flow look like, etc. you may have to dig in and see how the solution looks to help figure out what is going on.
c.drinkorn
Maybe look at the rho, temp and sal values right before blow up.
bjhaupt
#4 Unread post by bjhaupt »
Check out your barotropic time step.
Do you have any channels in your model where you erode sediment and then create dense fast turbidity flows?
Go back to a run that has more output and check where it happens.
luhputria
#5 Unread post by luhputria »
Hi everyone,
My question is not related to blowing problem, but for modelling sandwave in ROMS.
I used estuary test case as a domain with flat seabed and tidal forcing condition.
I try to check whether I can activate ripple geometry or not. I hope if ripple can generate in this test case, I can model sand wave that has bigger dimension compare to ripple.
My question is:
1. Why ROMS generates only 1 ripple along the length of channel?
2. Why the results of ripple geometry have similar value with initial ripple geometry that we define in ana_sediment? And the shape is symmetry?
My expectation is ROMS generates several ripples in different locations.
Attached I sent picture of ripple height and length that I got.
3. Can we model starting from flat seabed condition (without any bottom perturbation) and expect for ROMS to automatically generate ripples?
4. Is it correct that ripple can be formed only in ssw_bbl bottom stress formulation? Because in ROMS, ripple formulation valid for wave-dominated conditions only as stated in https://www.myroms.org/wiki/SSW_BBL. And I also tried to model using 4 different bottom stress formulation such as ldrag, logdrag, qdrag and ssw_bbl. And only ssw_bbl can able to generate ripple.
ripple geometry
ripple geometry
#6 Unread post by jcwarner »
I am not really clear what you are trying to do but here are some thoughts.
The estuary test case has grid cells on the order of 100m (or so, i dont remember exactly). So therefore it can not generate ripples that are on the order of 10's of cm. Instead, we have coded different methods to 'predict' what the ripple geometry would be based on grain size, currents, waves, etc. Those estimated values are computed, used to enhance bottom roughness, and written to output (if you look in ssw_bbl.h you can see the different methods in there). There are many in the literature, and they are not that hard to code. Here is a paper that has several methods in it
https://agupubs.onlinelibrary.wiley.com ... jgrc.20241
Nelson, T. R., G. Voulgaris, and P. Traykovski (2013), Predicting wave-induced ripple equilibrium geometry, J. Geophys.Res. Oceans, 118, 3202–3220, doi:10.1002/jgrc.20241
If you want to resolve ripples, then ROMS may not be the correct model, as non-hydrostatic effects may be important with flow separation off the ripple crests, etc. there are other efforts that have done that for example
https://agupubs.onlinelibrary.wiley.com ... jgrc.20120
Penko, Calantoni, Foster, Slinn, etc
If you start out roms with perfect flat and periodic, roms will stay that way - i mean that is is very accurate and small scale variations will not develop on their own. you would need to put them in. that is another set of studies but people like Nnafie, de Swart, Calvete etc. have shown how small scale perturbations can grow to produce large scale bedforms.
if you want to study flow over sand waves (order meters to 10's of meters to 100's of meters) then ROMS is ok. We have done this
Ocean Dynamics 64(12):1767
DOI: 10.1007/s10236-014-0781-y
hope that helps.
luhputria
#7 Unread post by luhputria »
Thank you very much John.
Your feedback is very helpful.
I will check article that you recommend.
Regards,
Luh
luhputria
#8 Unread post by luhputria »
Hi John,
Thanks before for your previous email regarding paper of shoreface-connected ridges in Fire Island.
Actually, I want to investigate sandwave migration in detail. I made a rectangular domain with size 1200x300x30 m and sandwave seabed with 2m height and 300m wave length in ana_grid. My dx=dy= 5m and ds=0.5m. For boundary condition, I defined closed boundary on North and South and open boundary condition in west and east. I defined tidal force with ubar 1m/s in ana_m2obc and tidal amplitude 1 m in ana_fsobc. After 6hours of simulation, there is changing in my seabed and i also tried to change morphological factor, I got the changing as shown in attachment.
But I always failed and got a blow up after 6.6hours simulation with the reason maximum density. I read FAQ in wikiroms, and stated that if a blow up after longer simulation, I need to dig more deeply. Do you have a suggestion for this issue?
Thanks before.
Regards,
Luh
sandwavemigration
sandwavemigration
#9 Unread post by jcwarner »
with any blowup, you need to look at the rst file, his file, and stdout to see what information it is telling you.
if you look at the rst file, where is the problem? at the boundary? at the wet/dry masking (for example).
try to restart it before the solution occurred. you can typically restart from rst files or from his files.
hard to tell you what to do with limited info on what went wrong.
luhputria
#10 Unread post by luhputria »
Hi John,
Thank you for your reply.
I check roms_rst.nc file using ncview, what I got is a suspicious contour in the bottom right of bathymetry (bath.png picture).
And when I checked in this location and plot the graph with xi_rho as the horizontal direction, bathymetry is suddenly dropped as shown in the figure below (xi.jpg).
I defined bathymetry using ana_grid, so I didn't expect any problem in the bathymetry input file.
Regards,
Luh
#11 Unread post by jcwarner »
time to put on your investigator hat. keep digging.
what else is weird there? what is forcing this? winds? tides? what did bottom stress look like? ubar? zeta?
the answer is in there.
luhputria
#12 Unread post by luhputria »
Hi John,
Thanks for your suggestion, my model is able to run without blow up again.
I also want to ask you regarding the surface erosion rate. I read your paper "Development of a three-dimensional, regional, coupled wave,current, and sediment-transport model" and from equation 23 in your paper, I know Es,m is a function of E0,m (bed erodibility constant), porosity and also bed shear stress. My question is "how you define this bed erodibility constant?" From your references, I see that may be you cite the paper by Ariathurai, C.R., Arulanandan, K., 1978. Erosion rates of cohesive soils. However, I can't access this paper, so I don't get the idea to calculate the surface erosion rate that we need to define in the sediment input file.
Thanks before.
Regards,
Luh
#13 Unread post by jcwarner »
this gets into a world of research. Suggest you spend a good bit of time looking thru literature, and doing some model sensitivity tests. this all depends on fractions of non-cohesive, cohesive, is it mixed, etc. There are other sediment bed options in the code now for mixed beds. Here is an example of a paper on erosion rates:
https://setac.onlinelibrary.wiley.com/d ... 5630020106
https://scholarworks.wm.edu/cgi/viewcon ... msarticles
https://www.researchgate.net/publicatio ... ensitivity
