Hii Folks
I have built pyroms using python2.7. All the libraries are installed successfully and I am being able to import pyroms and pyroms_toolbox. However, from bathy_smoother import shows a warning:
lpsolve55.so not found
Linear programming method will not be available.
again, while following the text example I am getting the error:
hgrd = pyroms.grid.Gridgen(lonp, latp, beta, (Mp+3,Lp+3), proj=map)
OSError: libgu.so: cannot open shared object file: No such file or directory
Please help me solve the error. Any lead in solving the error is appreciated.
Dhirendra
PYROMS : lpsolve55.so not found. & libgu.so not found
Re: PYROMS : lpsolve55.so not found. & libgu.so not found
I don't know how to fix lpsolve, but the README has this advice for libgu:
One of these needs to be in your LD_LIBRARY_PATH.You might
also need libgu.so to be in your LD_LIBRARY_PATH. I'm getting inconsistent
results with where the .so files need to be. Best results for me are if I go
to the site-packages directory where pyroms got installed and copy all the
.so files:
cp pyroms/*.so .
cp pyroms_toolbox/*.so .
cp bathy_smoother/*.so .
