hi everyone,
I am a new leaner of Roms.I run the oceanS after,and I got the problem :
./oceanS < ROMS/External/sediment_test_chan.in
Output Diagnostics File: ocean_dia.nc
READ_PHYPAR - Grid 01, could not find input file: ocean_bry.nc
Found Error: 04 Line: 5933 Source: ROMS/Utility/read_phypar.F
Found Error: 04 Line: 153 Source: ROMS/Utility/inp_par.F
Found Error: 04 Line: 111 Source: ROMS/Drivers/nl_ocean.h
Dynamic and Automatic memory (MB) usage for Grid 01: 100x3x20 tiling: 1x1
tile Dynamic Automatic USAGE
0 0.96 0.17 1.13
TOTAL 0.96 0.17 1.13
Found Error: 04 Line: 350 Source: ROMS/Utility/close_io.F
ERROR: I/O related problem.
test case
Re: test case
Hello
You need to do the boundary files of your domain
- Location: Ha Noi University Sience and Technology, Vietnam
Re: test case
thanks for your replieslalvarez wrote:Hello
now i run sediment by oceanS
Backtrace for this error:
#0 0x7F2AA2924E08
#1 0x7F2AA2923F90
#2 0x7F2AA226B4AF
#3 0x436659 in read_phypar_
#4 0x406A8C in inp_par_
#5 0x403481 in __ocean_control_mod_MOD_roms_initialize
Segmentation fault (core dumped)
and i run oceanG again:
mpirun -np 4 ./oceanG ROMS/External/sediment_test_chan.in
Sunday - December 16, 2018 - 4:28:40 PM
At line 303 of file read_phypar.f90At line 303 of file read_phypar.f90
Fortran runtime error: Index '1' of dimension 1 of array 'istvar' above upper bound of 0
i saw your post about this problem but i don't know how to fix it.
please help me! thank you so much!
- (48.6 KiB) Downloaded 539 times
Re: test case
sorry i did not get back to you on this earlier.
i am using coawst, which i just updated to the latest roms into our system, and this test case works.
The i saw what you were doing:
Sorry but you need to point to the ocean.in! well, now it is called roms.in so try this:
./oceanS < ROMS/External/roms_test_chan.in
let me know if that works.
-john
-john
Re: test case
thank you! it's working!jcwarner wrote:sorry i did not get back to you on this earlier.
-john
