Hi I have compiled my job successfully, but whenever I try to simulate it it gives the below error, which I am unable to understand
Thursday - August 16, 2018 - 3:48:04 PM
At line 951 of file inp_par.f90
Fortran runtime error: Bad real number in item 1 of list input
Primary job terminated normally, but 1 process returned
Process name: [[57528,1],0]
Exit code: 2
I tried running the sample test casees on my system these are workinf fine. Even with same I have simulated my job on HPC where it is working fine.
Error in running the job
build.bash
- (18.29 KiB) Downloaded 405 times
Re: Error in running the job
What is on this line?
The file is in your $SCRATCH_DIR.At line 951 of file inp_par.f90
! Processing numeric values. Check starting character to determine
! if numeric or character values. It is possible to have both when
! processing repetitions via the multiplication symbol.
Schar=ICHAR(Vstring(is:is))
IF (((48.le.Schar).and.(Schar.le.57)).or. &
& (Schar.eq.43).or.(Schar.eq.45)) THEN
IF ((Nmul.gt.0).and. &
& (is.lt.Imul(ic)).and.(Imul(ic).lt.ie)) THEN
READ (Vstring(is:Imul(ic)-1),*) copies
Schar=ICHAR(Vstring(Imul(ic)+1:Imul(ic)+1))
IF ((43.le.Schar).and.(Schar.le.57)) THEN
READ (Vstring(Imul(ic)+1:ie),*) Rval(Nval)
DO j=1,copies-1
Rval(Nval+j)=Rval(Nval)
ELSE
string=Vstring(Imul(ic)+1:ie)
LenS=LEN_TRIM(string)
Cval(Nval)=string(1:LenS)
DO j=1,copies-1
Cval(Nval+j)=Cval(Nval)
Nval=Nval+copies-1
ic=ic+1
ELSE
string=Vstring(is:ie)
READ (string(1:LenS),*) Rval(Nval) !<--- Here is the line 951
ELSE
It seems to be a problem related to compiler. I solved this problem by rediting ihe input file carefully and going through the below post
viewtopic.php?f=31&t=1334
Even after that I am unable to understand or figure out what exactly my mistake was.
Was that a typo or syntax error which I did.
DO j=1,copies-1
ELSE
DO j=1,copies-1
Nval=Nval+copies-1
ic=ic+1
ELSE
ELSE
