Turn off tracer advection
yz966445
#1 Unread post by yz966445 »
Hi everyone,
I want to run a experiment with the advection (horizontal and vertical) terms in the model temperature equation switched off. Does anyone know how to do that? Could I just set the temperature horizontal and vertical advection parameter to be zero? If I can, where the code I should modify. Thanks
Yi
Re: Turn off tracer advection
how about
#define TS_FIXED
yz966445
#3 Unread post by yz966445 »
jcwarner wrote:how about
#define TS_FIXED
Hi J,
I want to study the role of vertical mixing in the SST change.
Does the TS_FIXED just make the temperature to be constant? Thanks
Yi
The code as distributed doesn't have the switch you are looking for, but that doesn't mean you can't add it.
yz966445
#5 Unread post by yz966445 »
kate wrote:The code as distributed doesn't have the switch you are looking for, but that doesn't mean you can't add it.
Hi Kate,
Thanks for the reply. I am very new to Roms. I can not find the temperature tracer equation code. Do you know which code should I look at?
Yi
#6 Unread post by kate »
Yes, I do. You can use "grep" to find instances of TS_FIXED in pre_step3d.F, in rhs3d.F and in step3d_t.F.
yz966445
#7 Unread post by yz966445 »
kate wrote:Yes, I do. You can use "grep" to find instances of TS_FIXED in pre_step3d.F, in rhs3d.F and in step3d_t.F.
Hi Kate,
I really appreciate your helps. I think I found what I want in the step3d_t.F. Thanks again.
Yi
