Hi, everyone!
When I run my IS4D-Var model, I got the error at the first inner loop. The log file shows:
<<<< Descent Algorithm >>>>
(001,000): Initial gradient norm, Gnorm = NaN
TLM: GET_STATE - Read state initial conditions, t = 1 00:00:00
(Grid 01, File: wc13_itl.nc, Rec=0001, Index=1)
- free-surface
(Min = NaN Max = NaN )
- free-surface, open boundaries
- vertically integrated u-momentum component, open boundaries
- vertically integrated v-momentum component, open boundaries
- surface u-momentum stress, adjusted tl_ustr
0 1 00:00:00 NaN NaN NaN 1.159856E+16
I don’t know why the initial gradient norms is NaN.
I attached my log file for your convenience.
Thank you for your help.
output.log
- (284.29 KiB) Downloaded 785 times
Re: Initial gradient norm, Gnorm = NaN
I'm wondering if you found the solution to this problem?
I'm having the same error.
