List of analytical header files
m.hadfield
I'm putting this in ROMS Bugs, but it's really an oddity, not a bug.
In output from a ROMS non-linear model, there is a list of directories and files near the start of the output, just before the grid and tiling information. Eg. from one of my runs:
 Local Root    : /home/hadfield/ROMS/roms-trunk-mgh
 Header Dir    : /home/hadfield/mnt/kupe/nesi/nobackup/hadfield/work/cook/roms/sim35/run/tide-m2-3d/code
 Header file   : cook_tidal_3d.h
 Analytical Dir: /home/hadfield/mnt/kupe/nesi/nobackup/hadfield/work/cook/roms/sim35/run/tide-m2-3d/code
This is written by read_phypar.F at lines 3373-3383.
And then at the end of the run, there is a list of header files, eg:
 Analytical header files used:
     ROMS/Functionals/ana_btflux.h
     /home/hadfield/mnt/kupe/nesi/nobackup/hadfield/work/cook/roms/sim35/run/tide-m2-3d/code/ana_fsobc.h
     /home/hadfield/mnt/kupe/nesi/nobackup/hadfield/work/cook/roms/sim35/run/tide-m2-3d/code/ana_m2obc.h
     /home/hadfield/mnt/kupe/nesi/nobackup/hadfield/work/cook/roms/sim35/run/tide-m2-3d/code/ana_m3obc.h
     ROMS/Functionals/ana_smflux.h
     ROMS/Functionals/ana_stflux.h
     /home/hadfield/mnt/kupe/nesi/nobackup/hadfield/work/cook/roms/sim35/run/tide-m2-3d/code/ana_tobc.h
This is written by close_io.F at lines 313-324.
Why wait until the end of the run to write the list of header files?
Re: List of analytical header files
#2 Unread post by arango »
There is a reason for it that I need to remember exactly. It is not a bug, but why does it matter? I think that it has to do with with the global attributes of output NetCDF files and the fact that the user can overwrite the location of the code header files instead of using the ones distributed by ROMS. Notice that the global attribute is updated when closing the output NetCDF. See routine netcdf_close. Also, it is a good way to modify any of the ecosystem models, say fennel.h, without touching the distributed version. If you look the test repository for the upwelling toy problem, you will notice that I provide the logic how to do this via the build script, and I have a copy of the ecosystem model there.
#3 Unread post by arango »
It cannot be done during initialization because the CPP include syntax <*****.h> allows to use the header files from user's directories other than ROMS/Functionals. Notice that in analytical.F, we have
# ifdef SOLVE3D
#  if defined ANA_BIOLOGY && defined BIOLOGY
#   include <ana_biology.h>
#  endif
and any header file has something like:
! Set analytical header file name used.
#ifdef DISTRIBUTE
      IF (Lanafile) THEN
#else
      IF (Lanafile.and.(tile.eq.0)) THEN
        ANANAME( 1)=__FILE__
So the full path of ANANAME(:) for all the analytical header files used are only known during execution because of the __FILE__ syntax.
The header file for the ecosystem models is special. Notice that in def_info.F we have:
#ifdef BIOLOGY
!  Biology model header file used.
        IF (exit_flag.eq.NoError) THEN
          DO i=1,512
            bio_file(i:i)='-'
          status=nf90_put_att(ncid, nf90_global, 'bio_file',            &
     &                        bio_file)
          IF (FoundError(status, nf90_noerr, __LINE__,                  &
     &                   __FILE__)) THEN
            IF (Master) WRITE (stdout,20) 'bio_file', TRIM(ncname)
            exit_flag=3
            ioerror=status
The global attribute bio_file is set when closing the output NetCDF file in netcdf_close:
#ifdef BIOLOGY
!  Determine updating value of biology header files global attribute.
!  This is only possible in output files. An error occurs in input
!  files open for reading only. This allows to use ROMS input files
!  with the "bio_file" attribute.
        IF (.not.PRESENT(Lupdate)) THEN
          my_Lupdate=.TRUE.
        ELSE
          my_Lupdate=Lupdate
!  Update global attribute with the biology header files used.
        IF (my_Lupdate) THEN
          is=1
          status=nf90_inquire_attribute(ncid, nf90_global, 'bio_file',  &
     &                                  len = AttLen)
          IF (status.eq.nf90_noerr) THEN
            DO i=1,512
              bio_file(i:i)=' '
            DO i=1,4
              lstr=LEN_TRIM(BIONAME(i))
              IF (lstr.gt.0) THEN
                ie=is+lstr-1
                bio_file(is:ie)=TRIM(BIONAME(i))
                is=ie+1
                bio_file(is:is)=','
                is=is+2
            lstr=LEN_TRIM(bio_file)-1
            IF (lstr.gt.0) THEN
     &                            bio_file(1:lstr))
     &                       __FILE__ //                                &
     &                       ", netcdf_close")) THEN
                WRITE (stdout,10) 'bio_file', TRIM(my_ncname),          &
     &                            TRIM(SourceFile)
                exit_flag=3
                ioerror=status
So to report all the header files together, I decided to write its usage at the end when there are visible instead of the middle of time-stepping. So when you see weird things like that in ROMS, there is also a reason for it 8) I think that I mentioned this before in the documentation.
m.hadfield
arango wrote:So to report all the header files together, I decided to write its usage at the end when there are visible instead of the middle of time-stepping. So when you see weird things like that in ROMS, there is also a reason for it 8) I think that I mentioned this before in the documentation.
