Hi. Firstly thank you for your attention on my question.I am a green at the roms. Although i succeed in make files ——grd.nc, frc.nc, clm.nc , bry.nc and ini.nc , I am not sure if those files are right. I run my model ,but there are consistently Blowing Up problems.I tell what I have done in detail, hope you can point any mistake i have.
I have used NCEP daily data of 1980 to make forcing file. Because there are no SST and SSS daily data. so I added SODA monthly SST,SSS and dqdsst into the forcing file. I have to use this year to force my model for 10 years ,so I set my the time_cycle = 366 .DATA for clm.nc , bry.nc and ini.nc is coming from SODA 1980.time =12,time_cycle =366.
The model has bowled up for several times. The blowing up day and point is 1. 175 day (266,128,07 ); 2. 165 day (291,050,16);3. 193 day (211,273,16). For the first and second blowing up ,seeing the points in map are near narrow passageways,I closed the passageways and run again. I closed all narrow passageways,however it blowing up again.
I attach the third point in the map of my model, and output report of my model.
Thank you very much for any suggestion.
simulating SCS sea level ,set time_cycle =366 ,right?
- itf165.txt
- (14.35 MiB) Downloaded 488 times
