Make files for Cray cluster
m.hadfield
Here in New Zealand we have access to a new Cray XC50 (whoopee!) and I have been working out how to build ROMS on it. As discussed in this thread
viewtopic.php?f=31&t=4086&p=15704&hilit ... ftn#p15704
it has 3 programming environments, PrgEnv-cray, PrgEnv-intel, PrgEnv-gnu, all using the ftn command to invoke the Fortran compiler, but with different options supported by the different back-ends. (It also has a tendency to switch from one programming environment to another when you don't intend it, but I digress...).
I have created files Linux-ftn-cray.mk and Linux-ftn-intel.mk for the cray and intel environments respectively. (I haven't done Gnu yet, as I expect performance to be lower.) I have also included, at the end of this message, Bash functions that load the modules and set the environment variables need to use these make files on our system. Note that you don't set USE_MPIF90
The existing Linux-ftn.mk seems to be a composite of the Cray options in the first half of the makefile and Gnu options (-free-form and -fixed-form) in the second. I think it's broken.
Perhaps the makefiles I've attached could be added to the repository?
function set-roms-cray ()
echo Setting environment variables for ROMS with PrgEnv-cray
module unload PrgEnv-gnu PrgEnv-intel
module load PrgEnv-cray craype-x86-skylake cray-netcdf
export FORT=ftn-cray
export USE_NETCDF4=on
function set-roms-intel ()
echo Setting environment variables for ROMS with PrgEnv-intel
module unload PrgEnv-cray PrgEnv-gnu
module load PrgEnv-intel craype-broadwell cray-netcdf cray-hdf5
export FORT=ftn-intel
On our system, these require the following
Linux-ftn-intel.mk
Makefile for Cray ftn with PrgEnv-intel
(4.54 KiB) Downloaded 345 times
Linux-ftn-cray.mk
Makefile for Cray ftn with PrgEnv-cray
(4.48 KiB) Downloaded 338 times
m.hadfield
Re: Make files for Cray cluster
Oops, forgot compiler options needed for OpenMP on the Intel variant. Corrected file attached.
Linux-ftn-intel.mk
Makefile for Cray ftn compiler with PrgEnv-intel. Corrected OpenMP options.
(4.57 KiB) Downloaded 321 times
#3 Unread post by kate »
Cool! I've been deleting the Compilers files I can no longer test on my branch. It's been many a year since I've had access to a Cray. That Linux-ftn thing you didn't like might have come from me for a cross-compiler running on Linux for a Cray, not necessarily the same sort of system you have now.
m.hadfield
Here, for completeness, is Linux-ftn-gnu.mk. Build time with the Gnu programming environment is much less than for the others; I conjecture this might be due to a lack of inter-procedural optimizations at link time. I expect run-time performance to be poor, but the Gnu option might be useful when debugging.
I'll test these for a bit longer and then submit them in a Trac ticket.
Linux-ftn-gnu.mk
Makefile for Cray ftn compiler with PrgEnv-gnu
(5.04 KiB) Downloaded 324 times
