compling COAWST error
okami_zxh
#1 Unread post by okami_zxh »
Hi all friends,
I am try to compile coawst by using gfortran. When I tried to compile SCRIP_COAWST, there is one error about flags,did someone have the same error before? Here is the error:
/usr/bin/gfortran -frepack-arrays -O3 -ffast-math -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian -c ./kinds_mod.f
/usr/bin/gfortran -frepack-arrays -O3 -ffast-math -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian -c ./constants.f
/usr/bin/gfortran -frepack-arrays -O3 -ffast-math -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian -c ./iounits.f
/usr/bin/gfortran -frepack-arrays -O3 -ffast-math -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian -c ./netcdf.f
/usr/bin/gfortran -frepack-arrays -O3 -ffast-math -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian -c ./scripwrap_mod.f
./scripwrap_mod.f:38.48:
        integer(int_kind), allocatable :: istr_w, jstr_w,               &
                                                1
Error: Allocatable component at (1) must be an array
./scripwrap_mod.f:55.48:
        integer(int_kind), allocatable :: istr_o, jstr_o,               &
                                                1
./scripwrap_mod.f:72.48:
        integer(int_kind), allocatable :: istr_a, jstr_a,               &
                                                1
make: *** [scripwrap_mod.o] Error 1
Re: compling COAWST error
a few other people had similar issues. they were using older version of gfortran that did not allow a value that was a single integer to be allocatable. we suggested to them to upgrade their gfortran and have not herd back so that most likely worked for them. can you try the same?
the posts were at
https://coawstmodel-trac.sourcerepo.com ... ssion/2/56
please post future coawst issues on that trac site.
thanks,
john
