ROMS-WRF coupling problem
hzh_1211
#1 Unread post by hzh_1211 »
I got a mistake when I do a coupled modelling IN WRF-ROMS.
The ROMS grid size is 274 by 224,as same as wrf grid.
 MCT::m_ExchangeMaps::ExGSMapGSMap_:: MCTERROR, Grid Size mismatch
 LocalMap Gsize =        61376  RemoteMap Gsize =        62376
 LocalMap Gsize =        62376  RemoteMap Gsize =        61376
MCT::m_ExchangeMaps::ExGSMapGSMap_: Map Grid Size mismatch error, stat =3
000.MCT(MPEU)::die.: from MCT::m_ExchangeMaps::ExGSMapGSMap_()
004.MCT(MPEU)::die.: from MCT::m_ExchangeMaps::ExGSMapGSMap_()
[cli_0]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 2) - process 0
[cli_4]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 2) - process 4
I down't know why the grid size mismatched.
Re: ROMS-WRF coupling problem
looks odd. if they are same grid, make sure you dont define MCT_INTERP_OC2AT.
did you try any of the cases distributed with the code?
-john
hzh_1211
#3 Unread post by hzh_1211 »
jcwarner wrote:looks odd. if they are same grid, make sure you dont define MCT_INTERP_OC2AT.
-john
Thanks for your apply, I dont difine MCT_INTERP_OC2AT,and take a successful JOE_TC_coupling case,
unsuccessful case:
wrf:	       		                        ROMS:
dimensions:                                    |dimensions:
        Time = UNLIMITED ; // (1 currently)    |        xi_psi = 273 ;
        DateStrLen = 19 ;                      |        xi_rho = 274 ;
        west_east = 274 ;                      |        xi_u = 273 ;
        south_north = 224 ;                    |        xi_v = 274 ;
        bottom_top = 29 ;                      |        eta_psi = 223 ;
        bottom_top_stag = 30 ;                 |        eta_rho = 224 ;
        soil_layers_stag = 4 ;                 |        eta_u = 224 ;
        west_east_stag = 275 ;                 |        eta_v = 223 ;
        south_north_stag = 225 ;               |        one = 1 ;
        DIM0009 = 5 ;                          |        two = 2 ;
        land_cat_stag = 24 ;                   |        bath = 1 ;
        soil_cat_stag = 16 ;                   |variables:
        num_ext_model_couple_dom_stag = 1 ;    |
successful case grid:
netcdf wrfinput_d01 {                          |netcdf joe_tc_grd {
        Time = UNLIMITED ; // (1 currently)    |        xi_psi = 198 ;
        DateStrLen = 19 ;                      |        xi_rho = 199 ;
        west_east = 199 ;                      |        xi_u = 198 ;
        south_north = 149 ;                    |        xi_v = 199 ;
        west_east_stag = 200 ;                 |        eta_psi = 148 ;
        bottom_top = 30 ;                      |        eta_rho = 149 ;
        south_north_stag = 150 ;               |        eta_u = 149 ;
        bottom_top_stag = 31 ;                 |        eta_v = 148 ;
        ext_scalar = 1 ;                       |        one = 1 ;
        soil_layers_stag = 4 ;                 |        bath = UNLIMITED ; // (0 currently)
        land_cat_stag = 24 ;                   |variables:
        soil_cat_stag = 16 ;                   |        double xl(one) ;
hzh_1211
#4 Unread post by hzh_1211 »
I found my mistake,should be that
LLm= x_rho - 2;
LLm= y_rho - 2;
