Dear ROMS Users,
I am running ROMS with a nested domain and when I am trying to restart this, I am getting an error message - PUT_REFINE2D - unbounded contact points temporal: interpolation:
cr = 01 dg = 01 ng = 02
iic(dg) = 0215137 told = 1 tnew = 2
iic(ng) = 1727137 Wold = ******** Wnew = ********
time(ng) = ******* time(told) = ******* time(tnew) = *******
Can anyone help me to resolve this issue?
Refined Nested Grid(s) Information:
Refined Donor Refined Timestep Refined
Grid Grid Scale Ratio Timesteps
02 01 07 8.00000 08
WARNING: Usually the number of Refined Timesteps must be the same
as the Refined Scale for numerical stability.
NLM: GET_STATE - Warning - NetCDF global attribute: NLM_LBC
for lateral boundary conditions not checked
in restart file: /scratch/cas/phd/asz138020/exp_42_interannual_seagrid_output_low/sponge/1994_2014/2615std/ocean_rst1.nc
NLM: GET_STATE - Read state initial conditions, t = 498 00:00:00
(Grid 01, File: ocean_rst1.nc, Rec=0001, Index=1)
- free-surface
(Min = -3.29810612E+02 Max = 6.99368508E-01)
(Min = -3.04265007E-01 Max = 5.17692142E-01)
(Min = -3.06206154E-01 Max = 7.18321466E-01)
- u-momentum component
(Min = -8.10229258E-01 Max = 2.24729959E+00)
- v-momentum component
(Min = -7.30916320E-01 Max = 1.41168187E+00)
- potential temperature
(Min = -1.23746844E+01 Max = 3.89554673E+01)
- salinity
(Min = 3.12657523E+01 Max = 3.96058976E+01)
- vertical viscosity coefficient
(Min = 0.00000000E+00 Max = 4.74480187E-02)
- temperature vertical diffusion coefficient
(Min = 0.00000000E+00 Max = 7.67006905E-02)
- salinity vertical diffusion coefficient
in restart file: /scratch/cas/phd/asz138020/exp_42_interannual_seagrid_output_low/sponge/1994_2014/2615std/ocean_rst2.nc
NLM: GET_STATE - Read state initial conditions, t = 499 18:00:00
(Grid 02, File: ocean_rst2.nc, Rec=0001, Index=1)
- free-surface
(Min = -7.90757579E+02 Max = 5.85304819E-01)
(Min = -2.79960741E-01 Max = 3.80608380E-01)
(Min = -3.13837783E-01 Max = 3.73446099E-01)
(Min = -7.27145999E-01 Max = 1.37499041E+00)
(Min = -7.79263716E-01 Max = 9.14873632E-01)
(Min = 1.23479497E+00 Max = 3.55378689E+01)
- salinity
(Min = 3.39678836E+01 Max = 3.63443394E+01)
(Min = 0.00000000E+00 Max = 7.67088792E-02)
(Min = 0.00000000E+00 Max = 8.83516031E-02)
GET_2DFLD - surface u-momentum stress, t = 498 00:00:00
(Rec=0000499, Index=1, File: roms_taux_1994_2014.nc)
(Tmin= 0.0000 Tmax= 7669.0000)
(Min = -1.41414938E-04 Max = 2.57174801E-04)
GET_2DFLD - surface v-momentum stress, t = 498 00:00:00
(Rec=0000499, Index=1, File: roms_tauy_1994_2014.nc)
(Min = -5.93120288E-05 Max = 2.80125368E-04)
GET_2DFLD - solar shortwave radiation flux, t = 498 00:00:00
(Rec=0000499, Index=1, File: roms_swrad_1994_2014.nc)
(Min = 0.00000000E+00 Max = 7.18823534E-05)
GET_2DFLD - surface net heat flux, t = 498 00:00:00
(Rec=0000499, Index=1, File: roms_net_heat_1994_2014.nc)
(Min = -4.36837048E-05 Max = 3.78414078E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 498 00:00:00
(Rec=0000499, Index=1, File: roms_swflux_1994_2010.nc)
(Tmin= 0.0000 Tmax= 6208.0000)
(Min = 1.00000000E+35 Max = -1.00000000E+35)
GET_NGFLD - free-surface eastern boundary condition, t = 497 00:00:00
(Rec=0000167, Index=2, File: BOB_bry_ECCO2_19940101_to_20141231.nc)
(Tmin= 0.0000 Tmax= 7667.0000)
(Min = 0.00000000E+00 Max = 5.83045781E-01)
GET_NGFLD - free-surface southern boundary condition, t = 497 00:00:00
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 497 00:00:00
(Min = -3.82484794E-02 Max = 3.34040448E-02)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 497 00:00:00
(Min = -3.02057378E-02 Max = 2.16157269E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 497 00:00:00
(Min = -1.03746697E-01 Max = 3.46482582E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 497 00:00:00
(Min = -3.51824835E-02 Max = 1.73783183E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 497 00:00:00
(Min = -4.71881509E-01 Max = 3.09891582E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 497 00:00:00
(Min = -2.50033349E-01 Max = 7.44837970E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 497 00:00:00
(Min = -3.81222904E-01 Max = 1.27717227E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 497 00:00:00
(Min = -3.31239194E-01 Max = 3.22665662E-01)
GET_NGFLD - temperature eastern boundary condition, t = 497 00:00:00
(Min = 0.00000000E+00 Max = 3.21398544E+01)
GET_NGFLD - salinity eastern boundary condition, t = 497 00:00:00
(Min = 0.00000000E+00 Max = 3.51651306E+01)
GET_NGFLD - temperature southern boundary condition, t = 497 00:00:00
(Min = 0.00000000E+00 Max = 2.96034508E+01)
GET_NGFLD - salinity southern boundary condition, t = 497 00:00:00
(Min = 0.00000000E+00 Max = 3.54035835E+01)
GET_2DFLD - surface u-momentum stress, t = 499 00:00:00
(Rec=0000500, Index=1, File: roms_taux_1994_2014.nc)
(Min = -8.21695669E-06 Max = 2.44007038E-04)
GET_2DFLD - surface v-momentum stress, t = 499 00:00:00
(Rec=0000500, Index=1, File: roms_tauy_1994_2014.nc)
(Min = -4.89055677E-05 Max = 1.90158518E-04)
GET_2DFLD - solar shortwave radiation flux, t = 499 00:00:00
(Rec=0000500, Index=1, File: roms_swrad_1994_2014.nc)
(Min = 0.00000000E+00 Max = 7.12604232E-05)
GET_2DFLD - surface net heat flux, t = 499 00:00:00
(Rec=0000500, Index=1, File: roms_net_heat_1994_2014.nc)
(Min = -4.18917040E-05 Max = 3.37754802E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 499 00:00:00
(Rec=0000500, Index=1, File: roms_swflux_1994_2010.nc)
Maximum grid stiffness ratios: rx0 = 2.377801E-01 (Beckmann and Haidvogel)
rx1 = 3.605019E+00 (Haney)
Initial basin volumes: TotVolume = 5.6924338560E+16 m3
MinVolume = 2.0166755687E+08 m3
MaxVolume = 1.9908617883E+12 m3
Max/Min = 9.8719983479E+03
Basin information for Grid 02:
Maximum grid stiffness ratios: rx0 = 4.695308E-02 (Beckmann and Haidvogel)
rx1 = 7.591104E-01 (Haney)
Initial basin volumes: TotVolume = 1.4868578684E+16 m3
MinVolume = 4.9251558583E+06 m3
MaxVolume = 3.9904567274E+10 m3
Max/Min = 8.1021938030E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00215137 - 02680560)
NL ROMS/TOMS: started time-stepping: (Grid: 02 TimeSteps: 01727137 - 21444480)
(Rec=0000500, Index=2, File: roms_taux_1994_2014.nc)
(Min = -1.69680072E-04 Max = 2.65966131E-04)
(Rec=0000500, Index=2, File: roms_tauy_1994_2014.nc)
(Min = -4.45910806E-05 Max = 3.44429020E-04)
(Rec=0000500, Index=2, File: roms_swrad_1994_2014.nc)
(Min = 0.00000000E+00 Max = 7.21665659E-05)
(Rec=0000500, Index=2, File: roms_net_heat_1994_2014.nc)
(Min = -4.13800478E-05 Max = 3.79212483E-05)
(Rec=0000500, Index=2, File: roms_swflux_1994_2010.nc)
GET_NGFLD - free-surface eastern boundary condition, t = 500 00:00:00
(Rec=0000168, Index=1, File: BOB_bry_ECCO2_19940101_to_20141231.nc)
(Min = 0.00000000E+00 Max = 6.44841969E-01)
GET_NGFLD - free-surface southern boundary condition, t = 500 00:00:00
(Min = 0.00000000E+00 Max = 6.17798448E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 500 00:00:00
(Min = -4.18499224E-02 Max = 3.81873734E-02)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 500 00:00:00
(Min = -2.60102600E-02 Max = 1.15682837E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 500 00:00:00
(Min = -1.15085654E-01 Max = 3.43290828E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 500 00:00:00
(Min = -3.55290361E-02 Max = 1.93747088E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 500 00:00:00
(Min = -5.45368373E-01 Max = 4.48457479E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 500 00:00:00
(Min = -3.42171550E-01 Max = 2.73424070E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 500 00:00:00
(Min = -4.28782344E-01 Max = 1.05949715E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 500 00:00:00
(Min = -4.06100243E-01 Max = 3.51559550E-01)
GET_NGFLD - temperature eastern boundary condition, t = 500 00:00:00
(Min = 0.00000000E+00 Max = 3.19771233E+01)
GET_NGFLD - salinity eastern boundary condition, t = 500 00:00:00
(Min = 0.00000000E+00 Max = 3.51681023E+01)
GET_NGFLD - temperature southern boundary condition, t = 500 00:00:00
(Min = 0.00000000E+00 Max = 2.95191574E+01)
GET_NGFLD - salinity southern boundary condition, t = 500 00:00:00
(Min = 0.00000000E+00 Max = 3.54046822E+01)
STEP Day HH:MM:SS KINETIC_ENRG POTEN_ENRG TOTAL_ENRG NET_VOLUME Grid
215136 498 00:00:00 4.279791E-03 1.943790E+04 1.943790E+04 5.714181E+16 01
(114,20,40) 7.584836E-03 1.066058E-03 0.000000E+00 2.235694E+00
DEF_HIS - inquiring history file, Grid 01: /scratch/cas/phd/asz138020/exp_42_interannual_seagrid_output_low/sponge/1994_2014/2615std/ocean_his1_0002.nc
DEF_AVG - inquiring average file, Grid 01: /scratch/cas/phd/asz138020/exp_42_interannual_seagrid_output_low/sponge/1994_2014/2615std/ocean_avg1_0002.nc
GET_2DFLD - surface u-momentum stress, t = 500 00:00:00
(Rec=0000501, Index=2, File: roms_taux_1994_2014.nc)
(Min = -6.56028106E-06 Max = 1.41517519E-04)
GET_2DFLD - surface v-momentum stress, t = 500 00:00:00
(Rec=0000501, Index=2, File: roms_tauy_1994_2014.nc)
(Min = -3.07200819E-05 Max = 1.41943950E-04)
GET_2DFLD - solar shortwave radiation flux, t = 500 00:00:00
(Rec=0000501, Index=2, File: roms_swrad_1994_2014.nc)
(Min = 0.00000000E+00 Max = 7.14540403E-05)
GET_2DFLD - surface net heat flux, t = 500 00:00:00
(Rec=0000501, Index=2, File: roms_net_heat_1994_2014.nc)
(Min = -3.76402158E-05 Max = 3.30954385E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 500 00:00:00
(Rec=0000501, Index=2, File: roms_swflux_1994_2010.nc)
1727136 499 18:00:00 3.727630E-03 1.738790E+04 1.738791E+04 1.495038E+16 02
(010,152,40) 3.366968E-03 2.793695E-03 0.000000E+00 1.461034E+00
DEF_HIS - inquiring history file, Grid 02: /scratch/cas/phd/asz138020/exp_42_interannual_seagrid_output_low/sponge/1994_2014/2615std/ocean_his2_0002.nc
DEF_AVG - inquiring average file, Grid 02: /scratch/cas/phd/asz138020/exp_42_interannual_seagrid_output_low/sponge/1994_2014/2615std/ocean_avg2_0002.nc
PUT_REFINE3D - unbounded contact points temporal: interpolation:
Elapsed CPU time (seconds):
Node # 0 CPU: 151.505
Total: 151.505
Nonlinear model elapsed time profile, Grid: 01
Allocation and array initialization .............. 20.719 (13.6754 %)
Ocean state initialization ....................... 0.287 ( 0.1894 %)
Reading of input data ............................ 33.876 (22.3596 %)
Processing of input data ......................... 0.001 ( 0.0007 %)
Processing of output time averaged data .......... 0.023 ( 0.0152 %)
Computation of global information integrals ...... 0.006 ( 0.0040 %)
Writing of output data ........................... 0.039 ( 0.0257 %)
Model 2D kernel .................................. 0.181 ( 0.1195 %)
2D/3D coupling, vertical metrics ................. 0.029 ( 0.0191 %)
Omega vertical velocity .......................... 0.006 ( 0.0040 %)
Equation of state for seawater ................... 0.038 ( 0.0251 %)
KPP vertical mixing parameterization ............. 0.118 ( 0.0779 %)
3D equations right-side terms .................... 0.026 ( 0.0172 %)
3D equations predictor step ...................... 3.707 ( 2.4471 %)
Pressure gradient ................................ 0.015 ( 0.0099 %)
Harmonic mixing of tracers, S-surfaces ........... 0.016 ( 0.0106 %)
Biharmonic mixing of tracers, S-surfaces ......... 0.019 ( 0.0125 %)
Biharmonic mixing of tracers, geopotentials ...... 0.009 ( 0.0059 %)
Harmonic stress tensor, S-surfaces ............... 0.021 ( 0.0139 %)
Biharmonic stress tensor, S-surfaces ............. 0.021 ( 0.0139 %)
Corrector time-step for 3D momentum .............. 0.034 ( 0.0224 %)
Corrector time-step for tracers .................. 0.028 ( 0.0185 %)
Total: 59.219 39.0872
Message Passage: 2D halo exchanges ............... 0.002 ( 0.0013 %)
Message Passage: data broadcast .................. 0.005 ( 0.0033 %)
Message Passage: data scattering.................. 0.011 ( 0.0073 %)
Message Passage: point data gathering ............ 0.064 ( 0.0422 %)
Total: 0.082 0.0541
All percentages are with respect to total time = 151.505
Nonlinear model elapsed time profile, Grid: 02
Allocation and array initialization .............. 20.719 (13.6753 %)
Ocean state initialization ....................... 0.376 ( 0.2481 %)
Reading of input data ............................ 14.133 ( 9.3282 %)
Processing of input data ......................... 0.003 ( 0.0020 %)
Processing of output time averaged data .......... 0.328 ( 0.2165 %)
Computation of vertical boundary conditions ...... 0.003 ( 0.0020 %)
Computation of global information integrals ...... 0.083 ( 0.0548 %)
Writing of output data ........................... 0.042 ( 0.0277 %)
Model 2D kernel .................................. 3.108 ( 2.0511 %)
2D/3D coupling, vertical metrics ................. 0.215 ( 0.1419 %)
Omega vertical velocity .......................... 0.074 ( 0.0488 %)
Equation of state for seawater ................... 0.480 ( 0.3168 %)
KPP vertical mixing parameterization ............. 1.660 ( 1.0955 %)
3D equations right-side terms .................... 0.343 ( 0.2264 %)
3D equations predictor step ...................... 4.616 ( 3.0469 %)
Pressure gradient ................................ 0.243 ( 0.1604 %)
Harmonic mixing of tracers, S-surfaces ........... 0.209 ( 0.1379 %)
Biharmonic mixing of tracers, S-surfaces ......... 0.241 ( 0.1590 %)
Biharmonic mixing of tracers, geopotentials ...... 0.166 ( 0.1096 %)
Harmonic stress tensor, S-surfaces ............... 0.282 ( 0.1861 %)
Biharmonic stress tensor, S-surfaces ............. 0.274 ( 0.1808 %)
Corrector time-step for 3D momentum .............. 0.406 ( 0.2679 %)
Corrector time-step for tracers .................. 0.390 ( 0.2574 %)
Total: 48.393 31.9411
Nonlinear model message Passage profile, Grid: 02
Message Passage: data broadcast .................. 0.002 ( 0.0013 %)
Message Passage: data scattering.................. 44.377 (29.2908 %)
Message Passage: point data gathering ............ 0.025 ( 0.0165 %)
Total: 44.404 29.3086
All percentages are with respect to total time = 151.506
ROMS/TOMS - Output NetCDF summary for Grid 02:
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_sponge.h
ROMS/TOMS - Fatal algorithm result .. exit_flag: 8
ERROR: Fatal algorithm result.
