Unable to read restart file
chuning
#1 Unread post by chuning »
I need some help with restarting ROMS. I ran the model with a set of initial conditions for one model day and output the restart file in 'GB-TIDE_rst.nc'. When I restart the run, the restart file is loaded successfully as initial conditions, but when the timesteping begins it gives the following error message:
5760 2000-01-05 00:00:00.00 1.466319E-02 1.022372E+03 1.022387E+03 3.798799E+11
(288,0324,30) 8.445194E-02 1.510908E-01 0.000000E+00 2.041496E+00
/glade/scratch/chuning/tmpdir_GB-TIDE/GB-TIDE_rst.nc
call from: def_rst.F
NetCDF: HDF error
DEF_RST - unable to open restart NetCDF file: /glade/scratch/chuning/tmpdir_GB-TIDE/GB-TIDE_rst.nc
This is odd, since I don’t think the restart file is checked during timestepping (or is it)? I'm 100% sure that the restart file is there. I’ve ran a lot of cases with restart files but this never happened before. I pulled the trunk to update the model but no use. Attached is the log file containing the error message.
Chuning
log.txt
(119.05 KiB) Downloaded 335 times
