Doubts regarding strong surface currents
thiago.pdpaula
#1 Unread post by thiago.pdpaula »
I'm running ROMS (svn 836) in a realistic application in southeast of Brazil and I've noticed what appears to be an overestimation of surface currents, possibly due to wind stress.
I'am using bulk fluxes and hourly fields from CFSR reanalyses as forcing and 1/12 degree resolution grid nested to Mercator Global, which provides initial conditions and daily boundary fields. These are my boundary conditions:
 zeta                     1   Closed       Chapman Imp  Chapman Imp  Chapman Imp
 ubar                     1   Closed       Flather      Flather      Flather
 vbar                     1   Closed       Flather      Flather      Flather
 u                        1   Closed       Rad + Nud    Rad + Nud    Rad + Nud
 v                        1   Closed       Rad + Nud    Rad + Nud    Rad + Nud
 temp                     1   Closed       Rad + Nud    Rad + Nud    Rad + Nud
 salt                     1   Closed       Rad + Nud    Rad + Nud    Rad + Nud
 tke                      1   Closed       Gradient     Gradient     Gradient
And these are my CPP options:
 SSE                 ROMS SSE 112
 BULK_FLUXES         Surface bulk fluxes parameterization.
 DIFF_GRID           Horizontal diffusion coefficient scaled by grid size.
 EMINUSP             Compute Salt Flux using E-P.
 LONGWAVE_OUT        Compute outgoing longwave radiation internally.
 MIX_GEO_TS          Mixing of tracers along geopotential surfaces.
 MY25_MIXING         Mellor/Yamada Level-2.5 mixing closure.
 RADIATION_2D        Use tangential phase speed in radiation conditions.
 RI_SPLINES          Parabolic Spline Reconstruction for Richardson Number.
 SOLAR_SOURCE        Solar Radiation Source Term.
 SPLINES_VDIFF       Parabolic Spline Reconstruction for Vertical Diffusion.
 SPLINES_VVISC       Parabolic Spline Reconstruction for Vertical Viscosity.
 SPHERICAL           Spherical grid configuration.
 TS_C4HADVECTION     Fourth-order centered horizontal advection of tracers.
 VISC_GRID           Horizontal viscosity coefficient scaled by grid size.
I set up a sponge with 15 grid points width in all boundaries with visc_factor and diff_factor respectively equal to 20 and 10. My current timestep is 180 seconds and my bathymetry was smoothed using Mathieu's Matlab package giving maximum rx0 and rx1 factors of 0.15 and 7.6, which I believe to be quite conservative.
The problem can be seen in the attached pictures, which shows a snapshot of surface currents and SSH from ROMS and from global MERCATOR model, to which I nested my grid, a few days after initialization. A snapshot of wind velocity is also shown.
I was expecting a geostrophic flow where currents vectors would follow more or less elevation gradients, as it happens on MERCATOR and in situ measurements show. However, currents on ROMS are stronger and presents a drift at the same regions where wind speed is also stronger, suggesting a possible overestimation of wind stress in my model.
At the beginning I thought this behavior would be restricted to the very near surface layer. However, the drift can be seen in deeper layers down to a ~ 50 m depth or more, specially on shallower regions.
The average flow seems to be overestimated as well, as shown in the pictures of averaged surface currents. ROMS currents are stronger than MERCATOR and other global models such as HYCOM NCODA, specifically along the slope in the domain of Brazil Current.
I made a few tests altering vertical mixing scheme (MY25, GLS k-epsilon, LMD), increasing viscosity (from 4.0 to 25.0 m2/s) and changing CFSR hourly data to ERA INTERIM 6 hourly fields, but I'm not satisfied yet. Near surface currents remains stronger than expected for the region and I wouldn't like to have mesoscale features vanished by high viscosity values.
A few doubts I have:
1. Are my high velocities and currents drift due to strong wind stress or have I misinterpreted my results? What else could be causing this behavior?
2. I heard that bulk fluxes may overestimate wind stress, specially on gust situations, so what parameters could I tweak in order to reduce wind stress and obtain more consistent values of surface currents?
3. Should I increase viscosity and/or reduce wind momentum components?
4. Should I switch any of my boundary conditions?
5. Are my configuration parameters set properly (see below)? Is there anything weird in my setup?
Other information about my run are summarized below.
     219360  ntimes            Number of timesteps for 3-D equations.
    180.000  dt                Timestep size (s) for 3-D equations.
         30  ndtfast           Number of timesteps for 2-D equations between
        480  nRST              Number of timesteps between the writing of data
                                 into restart fields.
                                 to standard output.
        240  nHIS              Number of timesteps between the writing fields
                                 into history file.
          0  nQCK              Number of timesteps between the writing fields
                                 into quicksave file.
 5.0000E+00  nl_tnu2(01)       NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for tracer 01: temp
 5.0000E+00  nl_tnu2(02)       NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for tracer 02: salt
 5.0000E+00  nl_visc2          NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for momentum.
          T  LuvSponge         Turning ON  sponge on horizontal momentum.
          T  LtracerSponge(01) Turning ON  sponge on tracer 01: temp
          T  LtracerSponge(02) Turning ON  sponge on tracer 02: salt
 1.0000E-06  Akt_bak(01)       Background vertical mixing coefficient (m2/s)
 1.0000E-06  Akt_bak(02)       Background vertical mixing coefficient (m2/s)
                                 for tracer 02: salt
 1.0000E-05  Akv_bak           Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akk_bak           Background vertical mixing coefficient (m2/s)
                                 for turbulent energy.
 5.0000E-06  Akp_bak           Background vertical mixing coefficient (m2/s)
 3.0000E-03  rdrg2             Quadratic bottom drag coefficient.
 1.0000E-02  Zob               Bottom roughness (m).
 2.0000E+00  blk_ZQ            Height (m) of surface air humidity measurement.
 2.0000E+00  blk_ZT            Height (m) of surface air temperature measurement.
 1.0000E+01  blk_ZW            Height (m) of surface winds measurement.
          3  lmd_Jwt           Jerlov water type.
          2  Vtransform        S-coordinate transformation equation.
          4  Vstretching       S-coordinate stretching function.
 5.0000E+00  theta_s           S-coordinate surface control parameter.
 3.0000E-01  theta_b           S-coordinate bottom  control parameter.
     40.000  Tcline            S-coordinate surface/bottom layer width (m) used
  14153.000  dstart            Time-stamp assigned to model initialization (days).
19700101.00  time_ref          Reference time for units attribute (yyyymmdd.dd)
 3.0000E+01  Tnudg(01)         Nudging/relaxation time scale (days)
 3.0000E+01  Tnudg(02)         Nudging/relaxation time scale (days)
                                 for tracer 02: salt
 3.0000E+01  Znudg             Nudging/relaxation time scale (days)
 3.0000E+01  M2nudg            Nudging/relaxation time scale (days)
 3.0000E+01  M3nudg            Nudging/relaxation time scale (days)
                                 for 3D momentum.
 3.0000E+01  obcfac            Factor between passive and active
     14.000  T0                Background potential temperature (C) constant.
     35.000  S0                Background salinity (PSU) constant.
          F  LtracerSrc(01)    Turning OFF point Sources/Sinks on tracer 01: temp
          F  LtracerSrc(02)    Turning OFF point Sources/Sinks on tracer 02: salt
          T  Lm3CLM            Turning ON  processing of 3D momentum climatology.
          T  LtracerCLM(01)    Turning ON  processing of climatology tracer 01: temp
          T  LtracerCLM(02)    Turning ON  processing of climatology tracer 02: salt
          T  LnudgeM3CLM       Turning ON  nudging of 3D momentum climatology.
          T  LnudgeTCLM(01)    Turning ON  nudging of climatology tracer 01: temp
          T  LnudgeTCLM(02)    Turning ON  nudging of climatology tracer 02: salt
          T  Hout(idUbar)      Write out 2D U-momentum component.
          T  Hout(idVbar)      Write out 2D V-momentum component.
          T  Hout(idTvar)      Write out tracer 01: temp
          T  Hout(idTvar)      Write out tracer 02: salt
          T  Hout(idUsms)      Write out surface U-momentum stress.
          T  Hout(idVsms)      Write out surface V-momentum stress.
          T  Hout(idTsur)      Write out surface net heat flux.
          T  Hout(idTsur)      Write out surface net salt flux.
          T  Hout(idSrad)      Write out shortwave radiation flux.
          T  Hout(idLrad)      Write out longwave radiation flux.
          T  Hout(idLhea)      Write out latent heat flux.
          T  Hout(idShea)      Write out sensible heat flux.
          T  Hout(idEmPf)      Write out E-P flux.
          T  Hout(idevap)      Write out evaporation rate.
          T  Hout(idrain)      Write out rain rate.
 Minimum X-grid spacing, DXmin =  8.02032179E+00 km
 Maximum X-grid spacing, DXmax =  9.02554196E+00 km
 Minimum Y-grid spacing, DYmin =  8.02323505E+00 km
 Maximum Y-grid spacing, DYmax =  9.02110875E+00 km
 Minimum Z-grid spacing, DZmin =  1.11179822E-01 m
 Maximum Z-grid spacing, DZmax =  5.24095214E+02 m
 Minimum barotropic Courant Number =  7.89417705E-03
 Maximum barotropic Courant Number =  2.30942340E-01
 Maximum Coriolis   Courant Number =  1.30899694E-02
 Horizontal mixing scaled by grid size, GRDMAX =  9.02332508E+00 km
 Maximum grid stiffness ratios:  rx0 =   1.500002E-01 (Beckmann and Haidvogel)
                                 rx1 =   7.606897E+00 (Haney)
 Initial basin volumes: TotVolume =  6.3595735250E+15 m3
                        MinVolume =  1.1017982474E+07 m3
                        MaxVolume =  4.0811095033E+10 m3
                          Max/Min =  3.7040442866E+03
Thanks in advance for any help.
mainara
Re: Doubts regarding strong surface currents
#2 Unread post by mainara »
Were you able to solve the problem?
Mainara
thiago.pdpaula
#3 Unread post by thiago.pdpaula »
I don't remember the exact steps I took, but the flag WIND_MINUS_CURRENT (see: https://www.myroms.org/projects/src/ticket/758) along with a fine tweak in viscosity (nl_visc2) led me to better results.
Besides comparing to global models, I also made some comparisons with in situ data (with appropriate time filtering) and the modeled velocities were in a reasonable range.
mainara
#4 Unread post by mainara »
Thanks for your answer Thiago,
Would you answer me if you used 2 or 10 in blk_ZW and what was the value that you used for VISC2 or add_VISC2?
I'm studying the same region and I use:
blk_zw=10
VISC2=5000
add_VISC2=0
thiago.pdpaula wrote:I don't remember the exact steps I took, but the flag WIND_MINUS_CURRENT (see: https://www.myroms.org/projects/src/ticket/758) along with a fine tweak in viscosity (nl_visc2) led me to better results.
Mainara
thiago.pdpaula
#5 Unread post by thiago.pdpaula »
the BLK_ZW parameter refers to height of your surface wind. Mine is set to 10.0 m as this is the height of the wind momentum components I used to build my forcing files. I used this dataset:
"NCEP Climate Forecast System Reanalysis (CFSR) Selected Hourly Time-Series Products, January 1979 to December 2010" (https://rda.ucar.edu/datasets/ds093.1/).
Check the variable attributes of the datasets you used to build your forcing files to be sure about the correct value.
Regarding the horizontal viscosity, I think it really depends on your setup and grid resolution, thus, it is very unlike that my values will behave the same way for you. Anyway, in this application I used harmonic horizontal viscosity (UV_VIS2) with VISC2 == 20.0 m2/s.
You don't have to worry about ad_VISC2 if you're not running the Adjoint model.
mainara
#6 Unread post by mainara »
Thanks for your quickly answer and help.
Mainara
hpd14thu
#7 Unread post by hpd14thu »
Hello, I wonder that the magnitute of the wind speed you used.
I also met the problem that the currents were too strong. My wind speed is up tp 58m/s. I don't know that if the scheme in ROMS can adapt to the 58m/s-wind speed, or if there is something wrong in my cpps.
mainara
#8 Unread post by mainara »
Are you using COAWST or ROMS?
hpd14thu wrote:Hello, I wonder that the magnitute of the wind speed you used.
Mainara
hpd14thu
#9 Unread post by hpd14thu »
mainara wrote:Are you using COAWST or ROMS?
Mainara, Thank you for your reply. I am using COAWST, but I just use the ROMS part in COAWST.I don't difine the WRF or SWAN
jivica
#10 Unread post by jivica »
I suggest you first to read a few papers related to the wind stress formulations in extreme events like TC, many of them are John's papers using COAWST and many Hurricane cases etc. Not to just blindly run ROMS model and then expect to get result that is perfect.
For example:
Bryant & Akbar in JMSE 2016 doi:10.3390/jmse4030058 where you can see limits for drag formulations or
Hwang in JPO 2018 doi:10.1175/JPO-D-18-0107.1 for new formulation having more physical background and saturation of wind drag for TC at wind speeds > 30m/s
As you wrote, you are using COAWST, then it would make sense to use coupling and have better formulation coming from the wave model which is then fed back to WRF model providing forcing for ROMS model. This is the way to go, step by step.
Ivica
mainara
#11 Unread post by mainara »
But, are you only using ROMS why use the COAWST ?
I agree with Ivica, if you do not use the functions of a coupled model, it does not make sense to use it.
Do you use the tidal forcing and river data?
What atmospheric and ocean forcing are you using?
On what machine do you perform your simulations?
I noticed that you did not use some CPPs, such as:
#define SPLINES_VDIFF
#define SPLINES_VVISC
#define VISC_GRID
# define DIFF_GRID
# define LMD_CONVEC
# define LMD_SKPP
# define LMD_NONLOCAL
# define LMD_SHAPIRO
# define ALBEDO_CURVE
I do not have much modeling expertise, but I can attachment to you my .in and .h in the study area.
If you want, mainarabg@gmail.com
Mainara
hpd14thu
#12 Unread post by hpd14thu »
jivica wrote:I suggest you first to read a few papers related to the wind stress formulations in extreme events like TC, many of them are John's papers using COAWST and many Hurricane cases etc. Not to just blindly run ROMS model and then expect to get result that is perfect.
For example:
Ivica
Thank you for your reply, Ivica. You really help me a lot. Wind stress is the issue point, and I will read more papers to figure out this.
Peida[/quote]
hpd14thu
#13 Unread post by hpd14thu »
mainara wrote:But, are you only using ROMS why use the COAWST ?
#define VISC_GRID
# define DIFF_GRID
# define LMD_CONVEC
# define LMD_SKPP
Thank you for your reply and I have found that the problem is the wind stress. After I modified the wind stress formula, I got better result.
Thank you!
Peida
