My model is blowing and I don't know why. This problem seems to have been discussed many times.
Reference before discussion,I changed my time step, cheaked the grid file, DxMIN,DYmin,DZmin,and boundary conditions.
However, the model is still blowing, I don't know how to solve this problem,
could you give me some useful advice.
Monday - June 26, 2017 - 2:28:18 AM
SHIYF
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /opt/sgi/mpt/mpt-2.08/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free -free
Input Script :
SVN Revision : exported
Local Root : /IS5000/users/shiyf/roms/trunk
Header Dir : /IS5000/users/shiyf/roms/test1
Header file : shiyf.h
Analytical Dir: /IS5000/users/shiyf/roms/test1
Resolution, Grid 01: 0199x0259x020, Parallel Nodes: 20, Tiling: 004x005
3144960 ntimes Number of timesteps for 3-D equations.
10.000 dt Timestep size (s) for 3-D equations.
15 ndtfast Number of timesteps for 2-D equations between
60 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
360 nHIS Number of timesteps between the writing fields
into history file.
8640 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
360 nAVG Number of timesteps between the writing of
8640 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
2.6500E-04 rdrg Linear bottom drag coefficient (m/s).
1 lmd_Jwt Jerlov water type.
7.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E-01 theta_b S-coordinate bottom control parameter.
200.000 Tcline S-coordinate surface/bottom layer width (m) used
0.125 dstart Time-stamp assigned to model initialization (days).
20160101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
2.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
2.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
for 3D momentum.
T VolCons(1) NLM western edge boundary volume conservation.
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
T VolCons(4) NLM northern edge boundary volume conservation.
5.000 T0 Background potential temperature (C) constant.
Prefix for History Files: ocean_his
Prefix for Averages Files: ocean_avg
Input Grid File: /IS5000/users/shiyf/roms/test1/roms_grid.nc
Input Nonlinear Initial File: /IS5000/users/shiyf/roms/test1/roms_ini_linear.nc
Input Forcing File 01: /IS5000/users/shiyf/roms/test1/gom_shflux_era.nc
Input Forcing File 02: /IS5000/users/shiyf/roms/test1/gom_sms_era.nc
Input Forcing File 03: /IS5000/users/shiyf/roms/test1/gom_SST_era.nc
Input Forcing File 04: /IS5000/users/shiyf/roms/test1/gom_swflux_era.nc
Input Forcing File 05: /IS5000/users/shiyf/roms/test1/gom_swrad_era.nc
Input Boundary File: /IS5000/users/shiyf/roms/test1/roms_bry.nc
Tile partition information for Grid 01: 0199x0259x0020 tiling: 004x005
tile Istr Iend Jstr Jend Npts
0 1 50 1 52 52000
1 51 100 1 52 52000
2 101 150 1 52 52000
3 151 199 1 52 50960
4 1 50 53 104 52000
5 51 100 53 104 52000
6 101 150 53 104 52000
7 151 199 53 104 50960
8 1 50 105 156 52000
9 51 100 105 156 52000
10 101 150 105 156 52000
11 151 199 105 156 50960
12 1 50 157 208 52000
13 51 100 157 208 52000
14 101 150 157 208 52000
15 151 199 157 208 50960
16 1 50 209 259 51000
17 51 100 209 259 51000
18 101 150 209 259 51000
19 151 199 209 259 49980
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 50.50 0.50 52.50 RHO-points
1 50.50 100.50 0.50 52.50 RHO-points
2 100.50 150.50 0.50 52.50 RHO-points
3 150.50 199.50 0.50 52.50 RHO-points
4 0.50 50.50 52.50 104.50 RHO-points
5 50.50 100.50 52.50 104.50 RHO-points
6 100.50 150.50 52.50 104.50 RHO-points
7 150.50 199.50 52.50 104.50 RHO-points
8 0.50 50.50 104.50 156.50 RHO-points
9 50.50 100.50 104.50 156.50 RHO-points
10 100.50 150.50 104.50 156.50 RHO-points
11 150.50 199.50 104.50 156.50 RHO-points
12 0.50 50.50 156.50 208.50 RHO-points
13 50.50 100.50 156.50 208.50 RHO-points
14 100.50 150.50 156.50 208.50 RHO-points
15 150.50 199.50 156.50 208.50 RHO-points
16 0.50 50.50 208.50 259.50 RHO-points
17 50.50 100.50 208.50 259.50 RHO-points
18 100.50 150.50 208.50 259.50 RHO-points
19 150.50 199.50 208.50 259.50 RHO-points
0 1.00 50.50 0.50 52.50 U-points
1 50.50 100.50 0.50 52.50 U-points
2 100.50 150.50 0.50 52.50 U-points
3 150.50 199.00 0.50 52.50 U-points
4 1.00 50.50 52.50 104.50 U-points
5 50.50 100.50 52.50 104.50 U-points
6 100.50 150.50 52.50 104.50 U-points
7 150.50 199.00 52.50 104.50 U-points
8 1.00 50.50 104.50 156.50 U-points
9 50.50 100.50 104.50 156.50 U-points
10 100.50 150.50 104.50 156.50 U-points
11 150.50 199.00 104.50 156.50 U-points
12 1.00 50.50 156.50 208.50 U-points
13 50.50 100.50 156.50 208.50 U-points
14 100.50 150.50 156.50 208.50 U-points
15 150.50 199.00 156.50 208.50 U-points
16 1.00 50.50 208.50 259.50 U-points
17 50.50 100.50 208.50 259.50 U-points
18 100.50 150.50 208.50 259.50 U-points
19 150.50 199.00 208.50 259.50 U-points
0 0.50 50.50 1.00 52.50 V-points
1 50.50 100.50 1.00 52.50 V-points
2 100.50 150.50 1.00 52.50 V-points
3 150.50 199.50 1.00 52.50 V-points
4 0.50 50.50 52.50 104.50 V-points
5 50.50 100.50 52.50 104.50 V-points
6 100.50 150.50 52.50 104.50 V-points
7 150.50 199.50 52.50 104.50 V-points
8 0.50 50.50 104.50 156.50 V-points
9 50.50 100.50 104.50 156.50 V-points
10 100.50 150.50 104.50 156.50 V-points
11 150.50 199.50 104.50 156.50 V-points
12 0.50 50.50 156.50 208.50 V-points
13 50.50 100.50 156.50 208.50 V-points
14 100.50 150.50 156.50 208.50 V-points
15 150.50 199.50 156.50 208.50 V-points
16 0.50 50.50 208.50 259.00 V-points
17 50.50 100.50 208.50 259.00 V-points
18 100.50 150.50 208.50 259.00 V-points
19 150.50 199.50 208.50 259.00 V-points
HaloSizeI(1) = 124
HaloSizeJ(1) = 128
TileSide(1) = 58
TileSize(1) = 3248
zeta 1 Closed Clamped Clamped Closed
ubar 1 Closed Clamped Clamped Closed
vbar 1 Closed Clamped Clamped Closed
u 1 Closed Clamped Clamped Closed
v 1 Closed Clamped Clamped Closed
temp 1 Closed Clamped Clamped Closed
salt 1 Closed Clamped Clamped Closed
tke 1 Closed Clamped Clamped Closed
SHIYF SHIYF
DIFF_GRID Horizontal diffusion coefficient scaled by grid size.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NO_WRITE_GRID Not Writing grid arrays into NetCDF ouput files.
RST_SINGLE Single precision fields in restart NetCDF file.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
VISC_GRID Horizontal viscosity coefficient scaled by grid size.
Process Information:
Node # 0 (pid= 70272) is active.
Node # 3 (pid= 70275) is active.
Node # 19 (pid= 70291) is active.
Node # 11 (pid= 70283) is active.
Node # 14 (pid= 70286) is active.
Node # 18 (pid= 70290) is active.
Node # 1 (pid= 70273) is active.
Node # 2 (pid= 70274) is active.
Node # 4 (pid= 70276) is active.
Node # 5 (pid= 70277) is active.
Node # 6 (pid= 70278) is active.
Node # 7 (pid= 70279) is active.
Node # 8 (pid= 70280) is active.
Node # 9 (pid= 70281) is active.
Node # 10 (pid= 70282) is active.
Node # 12 (pid= 70284) is active.
Node # 13 (pid= 70285) is active.
Node # 16 (pid= 70288) is active.
Node # 17 (pid= 70289) is active.
Node # 15 (pid= 70287) is active.
20 0.0000000 0.0000000 0.000 0.000 0.000 0.000
19 -0.0500000 -0.0001188 -0.909 -5.012 -9.914 -10.602
18 -0.1000000 -0.0004899 -1.819 -10.049 -20.723 -23.035
17 -0.1500000 -0.0011592 -2.729 -15.116 -32.590 -37.635
16 -0.2000000 -0.0022095 -3.640 -20.221 -45.809 -55.001
15 -0.2500000 -0.0037705 -4.552 -25.377 -60.841 -76.076
14 -0.3000000 -0.0060353 -5.466 -30.604 -78.370 -102.262
13 -0.3500000 -0.0092834 -6.381 -35.928 -99.389 -135.590
12 -0.4000000 -0.0139158 -7.298 -41.392 -125.320 -178.970
11 -0.4500000 -0.0205034 -8.219 -47.050 -158.189 -236.549
10 -0.5000000 -0.0298569 -9.145 -52.986 -200.874 -314.215
9 -0.5500000 -0.0431244 -10.078 -59.312 -257.448 -420.305
8 -0.6000000 -0.0619292 -11.022 -66.193 -333.671 -566.608
7 -0.6500000 -0.0885607 -11.979 -73.856 -437.669 -769.751
6 -0.7000000 -0.1262391 -12.957 -82.624 -580.869 -1053.118
5 -0.7500000 -0.1794756 -13.963 -92.948 -779.279 -1449.472
4 -0.8000000 -0.2545552 -15.008 -105.456 -1055.202 -2004.455
3 -0.8500000 -0.3601634 -16.109 -121.016 -1439.461 -2781.143
2 -0.9000000 -0.5081650 -17.288 -140.817 -1974.160 -3865.701
1 -0.9500000 -0.7144926 -18.572 -166.449 -2715.836 -5373.835
0 -1.0000000 -1.0000000 -20.000 -200.000 -3738.494 -7456.989
Time Splitting Weights for Grid 01: ndtfast = 15 nfast = 22
1-0.0006740978872509 0.0666666666666667-0.0006740978872509 0.0666666666666667
2-0.0001913161153518 0.0667116065258167-0.0008654140026027 0.1333782731924834
3 0.0014472038369421 0.0667243609335069 0.0005817898343395 0.2001026341259903
4 0.0042370228855824 0.0666278806777107 0.0048188127199218 0.2667305148037010
5 0.0081665994120431 0.0663454124853385 0.0129854121319649 0.3330759272890396
6 0.0132119623624627 0.0658009725245357 0.0261973744944276 0.3988768998135752
7 0.0193298623751124 0.0649201750337048 0.0455272368695400 0.4637970748472801
8 0.0264494009361902 0.0636315175420307 0.0719766378057303 0.5274285923893107
9 0.0344621375639418 0.0618682241462847 0.1064387753696720 0.5892968165355954
10 0.0432106750211074 0.0595707483086885 0.1496494503907794 0.6488675648442840
11 0.0524757225556949 0.0566900366406147 0.2021251729464743 0.7055576014848987
12 0.0619616371700794 0.0531916551369017 0.2640868101165537 0.7587492566218004
13 0.0712804429184289 0.0490608793255631 0.3353672530349826 0.8078101359473635
14 0.0799343282324558 0.0443088497976678 0.4153015812674384 0.8521189857450313
15 0.0872966212754959 0.0389798945821708 0.5025982025429343 0.8910988803272021
16 0.0925912433249121 0.0331601198304711 0.5951894458678464 0.9242590001576731
17 0.0948706401828253 0.0269873702754769 0.6900600860506717 0.9512463704331501
18 0.0929921916151718 0.0206626609299552 0.7830522776658435 0.9719090313631054
19 0.0855930988190858 0.0144631814889438 0.8686453764849293 0.9863722128520491
20 0.0710637499186094 0.0087569749010047 0.9397091264035388 0.9951291877530538
21 0.0475195634887281 0.0040193915730974 0.9872286898922669 0.9991485793261512
22 0.0127713101077333 0.0008514206738489 1.0000000000000002 1.0000000000000000
ndtfast, nfast = 15 22 nfast/ndtfast = 1.46667
1.000000000000 1.070450639131 0.535225319565 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.09467
Minimum X-grid spacing, DXmin = 8.39240211E+00 km
Maximum X-grid spacing, DXmax = 1.07411362E+01 km
Minimum Y-grid spacing, DYmin = 1.11200424E+01 km
Maximum Y-grid spacing, DYmax = 1.11200424E+01 km
Minimum Z-grid spacing, DZmin = 9.09306915E-01 m
Maximum Z-grid spacing, DZmax = 2.08315423E+03 m
Minimum barotropic Courant Number = 1.20930843E-03
Maximum barotropic Courant Number = 2.41567963E-02
Maximum Coriolis Courant Number = 9.56534064E-04
Horizontal mixing scaled by grid size, GRDMAX = 1.09289473E+01 km
NLM: GET_STATE - Read state initial conditions, t = 0 03:00:00
(Grid 01, File: roms_ini_linear.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 0.00000000E+00 Max = 2.84540166E+01)
- salinity
(Min = 0.00000000E+00 Max = 3.49894417E+01)
GET_2DFLD - surface u-momentum stress, t = 0 01:30:00
(Rec=0000001, Index=1, File: gom_sms_era.nc)
(Tmin= 0.0625 Tmax= 365.9375)
(Min = -7.72763229E-04 Max = 4.49069785E-04)
GET_2DFLD - surface v-momentum stress, t = 0 01:30:00
(Min = -4.32275935E-04 Max = 7.17418147E-04)
GET_2DFLD - solar shortwave radiation flux, t = 0 01:30:00
(Rec=0000001, Index=1, File: gom_swrad_era.nc)
(Min = 3.08818936E-05 Max = 1.46722456E-04)
GET_2DFLD - surface net heat flux, t = 0 01:30:00
(Rec=0000001, Index=1, File: gom_shflux_era.nc)
(Min = -4.02489277E-05 Max = 9.00919604E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 0 01:30:00
(Rec=0000001, Index=1, File: gom_swflux_era.nc)
(Min = -2.30701820E-07 Max = 1.71600979E-07)
GET_NGFLD - free-surface eastern boundary condition, t = 0 00:00:00
(Rec=0000001, Index=2, File: roms_bry.nc)
(Tmin= 0.0000 Tmax= 365.0000)
(Min = -2.64999811E-02 Max = 1.27974999E+00)
GET_NGFLD - free-surface southern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 7.58500040E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 0 00:00:00
(Min = -1.36086360E-01 Max = 3.23839605E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 0 00:00:00
(Min = -6.63492829E-02 Max = 1.19354643E-01)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 0 00:00:00
(Min = -7.26458132E-02 Max = 4.06116545E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 0 00:00:00
(Min = -6.86429963E-02 Max = 8.93137828E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 0 00:00:00
(Min = -9.17234361E-01 Max = 1.03719985E+00)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 0 00:00:00
(Min = -4.95005399E-01 Max = 4.40441459E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 0 00:00:00
(Min = -6.32066369E-01 Max = 3.68236303E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 0 00:00:00
(Min = -3.90926629E-01 Max = 4.29749966E-01)
GET_NGFLD - temperature eastern boundary condition, t = 0 00:00:00
(Min = -2.06360966E-01 Max = 2.80411301E+01)
GET_NGFLD - salinity eastern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 3.52298317E+01)
GET_NGFLD - temperature southern boundary condition, t = 0 00:00:00
(Min = -1.81017101E-01 Max = 2.85190125E+01)
GET_NGFLD - salinity southern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 3.56930046E+01)
Maximum grid stiffness ratios: rx0 = 9.636488E-01 (Beckmann and Haidvogel)
rx1 = 1.361918E+01 (Haney)
Initial basin volumes: TotVolume = 1.1284720359E+16 m3
MinVolume = 8.5117018506E+07 m3
MaxVolume = 2.3425697327E+11 m3
Max/Min = 2.7521755036E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 03144960)
GET_2DFLD - surface u-momentum stress, t = 0 04:30:00
(Rec=0000002, Index=2, File: gom_sms_era.nc)
(Min = -1.02063493E-03 Max = 8.13465144E-04)
GET_2DFLD - surface v-momentum stress, t = 0 04:30:00
(Min = -4.16719957E-04 Max = 1.03997598E-03)
GET_2DFLD - solar shortwave radiation flux, t = 0 04:30:00
(Rec=0000002, Index=2, File: gom_swrad_era.nc)
(Min = 3.71969539E-05 Max = 1.63637222E-04)
GET_2DFLD - surface net heat flux, t = 0 04:30:00
(Rec=0000002, Index=2, File: gom_shflux_era.nc)
(Min = -1.98255670E-05 Max = 1.29853056E-04)
GET_2DFLD - surface net freswater flux, (E-P), t = 0 04:30:00
(Rec=0000002, Index=2, File: gom_swflux_era.nc)
(Min = -2.94210686E-07 Max = 1.59138668E-07)
GET_NGFLD - free-surface eastern boundary condition, t = 1 00:00:00
(Rec=0000002, Index=1, File: roms_bry.nc)
(Min = 0.00000000E+00 Max = 1.29525006E+00)
GET_NGFLD - free-surface southern boundary condition, t = 1 00:00:00
(Min = 0.00000000E+00 Max = 7.86999702E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 1 00:00:00
(Min = -1.32524595E-01 Max = 3.17164749E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 1 00:00:00
(Min = -6.48542270E-02 Max = 9.82362702E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 1 00:00:00
(Min = -6.49622902E-02 Max = 3.82685363E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 1 00:00:00
(Min = -9.62820500E-02 Max = 9.34708491E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 1 00:00:00
(Min = -6.93626523E-01 Max = 1.17415941E+00)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 1 00:00:00
(Min = -4.41500038E-01 Max = 3.29676598E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 1 00:00:00
(Min = -5.44846058E-01 Max = 5.32745183E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 1 00:00:00
(Min = -3.51513118E-01 Max = 3.22937965E-01)
GET_NGFLD - temperature eastern boundary condition, t = 1 00:00:00
(Min = -2.06360966E-01 Max = 2.79875050E+01)
GET_NGFLD - salinity eastern boundary condition, t = 1 00:00:00
(Min = 0.00000000E+00 Max = 3.51747093E+01)
GET_NGFLD - temperature southern boundary condition, t = 1 00:00:00
(Min = -1.81132615E-01 Max = 2.84168167E+01)
GET_NGFLD - salinity southern boundary condition, t = 1 00:00:00
(Min = 0.00000000E+00 Max = 3.57525291E+01)
0 0 03:00:00 9.755565E-06 2.306463E+04 2.306463E+04 1.131373E+16
(199,180,20) 5.557101E-04 0.000000E+00 0.000000E+00 7.329277E-01
DEF_HIS - creating history file, Grid 01: ocean_his_0001.nc
DEF_AVG - creating average file, Grid 01: ocean_avg_0001.nc
1 0 03:00:10 1.259702E-03 2.306463E+04 2.306463E+04 1.131373E+16
(199,180,12) 5.835219E-04 1.257146E-06 5.050335E-03 1.288762E+00
2 0 03:00:20 4.658913E-03 2.306462E+04 2.306463E+04 1.131373E+16
(185,165,20) 1.745415E-05 2.990607E-05 8.671431E-01 2.423018E+00
3 0 03:00:30 9.407770E-03 2.306462E+04 2.306462E+04 1.131373E+16
(185,165,20) 5.332812E-05 9.564012E-05 1.524737E+00 3.294906E+00
4 0 03:00:40 1.466611E-02 2.306461E+04 2.306462E+04 1.131373E+16
(185,165,20) 1.145112E-04 2.117001E-04 1.830163E+00 3.864026E+00
5 0 03:00:50 1.994410E-02 2.306460E+04 2.306462E+04 1.131373E+16
(185,165,20) 1.993618E-04 3.810129E-04 1.729009E+00 4.163179E+00
6 0 03:01:00 2.522976E-02 2.306459E+04 2.306461E+04 1.131373E+16
(085,035,20) 5.850398E-04 2.208341E-04 1.295433E+00 4.310033E+00
7 0 03:01:10 3.083960E-02 2.306457E+04 2.306460E+04 1.131373E+16
(185,166,20) 1.166957E-03 7.500917E-04 1.074155E+00 5.084729E+00
8 0 03:01:20 3.714294E-02 2.306455E+04 2.306459E+04 1.131373E+16
(185,166,20) 1.558458E-03 9.072852E-04 9.010963E-01 6.331005E+00
9 0 03:01:30 4.434111E-02 2.306452E+04 2.306456E+04 1.131373E+16
(084,025,20) 1.487702E-03 6.875167E-05 9.478983E-01 7.402848E+00
10 0 03:01:40 5.240882E-02 2.306449E+04 2.306454E+04 1.131373E+16
(185,165,20) 6.468381E-04 1.710845E-03 1.215620E+00 8.248628E+00
11 0 03:01:50 6.117435E-02 2.306445E+04 2.306451E+04 1.131373E+16
(185,165,20) 6.712875E-04 1.987528E-03 1.281609E+00 8.876819E+00
12 0 03:02:00 7.045034E-02 2.306440E+04 2.306447E+04 1.131373E+16
(085,035,20) 2.105282E-03 3.678537E-04 1.280306E+00 9.346736E+00
13 0 03:02:10 8.012914E-02 2.306436E+04 2.306444E+04 1.131373E+16
(084,036,20) 2.289129E-03 2.694075E-03 1.308140E+00 9.747683E+00
14 0 03:02:20 9.020731E-02 2.306431E+04 2.306440E+04 1.131373E+16
(084,036,20) 2.524105E-03 2.958317E-03 1.164113E+00 1.017282E+01
15 0 03:02:30 1.007575E-01 2.306426E+04 2.306436E+04 1.131373E+16
(072,078,20) 1.260214E-03 7.331314E-04 9.014327E-01 1.069599E+01
16 0 03:02:40 1.118682E-01 2.306421E+04 2.306432E+04 1.131373E+16
(072,078,20) 1.418875E-03 8.514047E-04 9.218481E-01 1.135602E+01
17 0 03:02:50 1.235922E-01 2.306416E+04 2.306428E+04 1.131373E+16
(079,040,20) 3.397167E-03 3.012913E-03 8.764593E-01 1.215272E+01
18 0 03:03:00 1.359219E-01 2.306410E+04 2.306424E+04 1.131373E+16
(079,040,20) 3.586341E-03 3.186580E-03 8.709761E-01 1.305133E+01
19 0 03:03:10 1.487989E-01 2.306405E+04 2.306420E+04 1.131373E+16
(084,036,20) 3.741986E-03 4.064001E-03 1.009707E+00 1.399740E+01
20 0 03:03:20 1.621487E-01 2.306399E+04 2.306416E+04 1.131373E+16
(084,036,20) 3.984258E-03 4.296965E-03 1.204302E+00 1.493381E+01
21 0 03:03:30 1.759155E-01 2.306394E+04 2.306411E+04 1.131373E+16
(084,036,20) 4.220663E-03 4.543542E-03 1.195340E+00 1.581677E+01
22 0 03:03:40 1.900799E-01 2.306388E+04 2.306407E+04 1.131373E+16
(084,036,20) 4.451258E-03 4.801508E-03 9.934283E-01 1.662483E+01
23 0 03:03:50 2.046534E-01 2.306381E+04 2.306402E+04 1.131373E+16
(070,079,20) 1.063528E-03 1.024081E-03 7.611617E-01 1.736059E+01
24 0 03:04:00 2.196600E-01 2.306375E+04 2.306397E+04 1.131373E+16
(079,040,20) 4.985810E-03 4.319316E-03 8.383643E-01 1.804453E+01
25 0 03:04:10 2.351170E-01 2.306368E+04 2.306391E+04 1.131373E+16
(079,040,20) 5.251375E-03 4.513772E-03 8.581952E-01 1.870506E+01
26 0 03:04:20 2.510258E-01 2.306360E+04 2.306385E+04 1.131373E+16
(079,040,20) 5.510188E-03 4.705179E-03 7.382203E-01 1.936843E+01
27 0 03:04:30 2.673698E-01 2.306353E+04 2.306379E+04 1.131373E+16
(083,037,20) 5.755508E-03 5.568097E-03 8.896717E-01 2.005144E+01
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001
Node # 0 CPU: 4.660
Node # 3 CPU: 4.690
Node # 6 CPU: 4.690
Node # 7 CPU: 4.700
Node # 1 CPU: 4.680
Node # 2 CPU: 4.680
Node # 4 CPU: 4.690
Node # 5 CPU: 4.690
Node # 8 CPU: 4.690
Node # 9 CPU: 4.670
Node # 10 CPU: 4.690
Node # 11 CPU: 4.690
Node # 12 CPU: 4.690
Node # 13 CPU: 4.690
Node # 14 CPU: 4.690
Node # 15 CPU: 4.690
Node # 16 CPU: 4.700
Node # 17 CPU: 4.680
Node # 18 CPU: 4.690
Node # 19 CPU: 4.700
Total: 93.750
Allocation and array initialization .............. 0.830 ( 0.8853 %)
Ocean state initialization ....................... 0.090 ( 0.0960 %)
Reading of input data ............................ 6.110 ( 6.5173 %)
Processing of input data ......................... 0.410 ( 0.4373 %)
Processing of output time averaged data .......... 0.930 ( 0.9920 %)
Computation of vertical boundary conditions ...... 0.150 ( 0.1600 %)
Computation of global information integrals ...... 1.040 ( 1.1093 %)
Writing of output data ........................... 5.000 ( 5.3333 %)
Model 2D kernel .................................. 13.710 (14.6240 %)
2D/3D coupling, vertical metrics ................. 2.020 ( 2.1547 %)
Omega vertical velocity .......................... 1.210 ( 1.2907 %)
Equation of state for seawater ................... 3.200 ( 3.4133 %)
GLS vertical mixing parameterization ............. 25.570 (27.2747 %)
3D equations right-side terms .................... 2.940 ( 3.1360 %)
3D equations predictor step ...................... 6.240 ( 6.6560 %)
Pressure gradient ................................ 2.240 ( 2.3893 %)
Harmonic mixing of tracers, geopotentials ........ 3.740 ( 3.9893 %)
Harmonic stress tensor, S-surfaces ............... 1.780 ( 1.8987 %)
Corrector time-step for 3D momentum .............. 3.030 ( 3.2320 %)
Corrector time-step for tracers .................. 2.390 ( 2.5493 %)
Total: 82.630 88.1387
Message Passage: 2D halo exchanges ............... 3.360 ( 3.5840 %)
Message Passage: 3D halo exchanges ............... 2.900 ( 3.0933 %)
Message Passage: 4D halo exchanges ............... 0.920 ( 0.9813 %)
Message Passage: data broadcast .................. 11.990 (12.7893 %)
Message Passage: data reduction .................. 1.330 ( 1.4187 %)
Message Passage: data gathering .................. 1.860 ( 1.9840 %)
Message Passage: data scattering.................. 2.760 ( 2.9440 %)
Total: 25.120 26.7947
All percentages are with respect to total time = 93.750
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/TOMS: DONE... Monday - June 26, 2017 - 2:28:23 AM
ocean.in
- (119.74 KiB) Downloaded 575 times
Re: Blowing-up: Saving latest model state into RESTART file
This is the next step. Learn to view the ROMS output.
Thank you very much kate!kate wrote:This is the next step. Learn to view the ROMS output.
The problem has been solved which is caused by steep depth in some special regions(see figure below),
I was even more smooth the deep, and the model runs smoothly!
