Blow up problem before start
Hi friends~~
I have same problem.
In my case, I wanna start with stable condition. So I set all values(u,v,ubar,vbar,zeta) as zero except salt(32 psu), temp(10 Celcious)in initial condition.
and set same condition in boundary file.
These values can occur error???
I attach my log file for model..
Thanks a lot!
Thanks a lot!
log_File.txt
- (37.83 KiB) Downloaded 540 times
Re: Blow up problem before start
There are several scary values here:
Also here:
The second set is doubtless due to the first set. DXmin and DYmin are really, really small. What do you think your grid spacing is? You'll need a much smaller timestep if that really is your grid spacing. You don't want to have DXmax and DYmax of Inf. You also don't want a negative DZmin unless you are playing with wetting and drying.
Here is your vertical coordinate:Is five levels enough for what you are trying to do?
Minimum X-grid spacing, DXmin = 2.27035279E-07 km
Maximum X-grid spacing, DXmax = Inf km
Minimum Y-grid spacing, DYmin = 3.30415286E-07 km
Maximum Y-grid spacing, DYmax = Inf km
Minimum Z-grid spacing, DZmin = -3.59640000E+02 m
Maximum Z-grid spacing, DZmax = 2.26800000E+01 m
Minimum barotropic Courant Number = 0.00000000E+00
Maximum barotropic Courant Number = 9.08002235E+04
Maximum Coriolis Courant Number = 1.03698266E-02
0 0 00:00:00 NaN NaN NaN NaN
(000,000,0) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
5 0.0000000 0.0000000 0.000 0.000 0.000 0.000
4 -0.2000000 -0.0400000 39.960 0.000 18.720 -2.520
3 -0.4000000 -0.1600000 159.840 0.000 74.880 -10.080
2 -0.6000000 -0.3600000 359.640 0.000 168.480 -22.680
1 -0.8000000 -0.6400000 639.360 0.000 299.520 -40.320
0 -1.0000000 -1.0000000 999.000 0.000 468.000 -63.000
I always thank for your reply, Kate.
I think, DX(DZ) problems occur because my grid file didn't have domain length and get negative value of bathymetry data.
So I revised grid data and blows up in 2nd step.
this error has been seen many topics in forum. So I try to run the model in short time step, but didn't change.
(the file I attach is set as ntimes=720, dt=120)
Is it input file(tides or boundary)problem or others?
log_8.txt
- (26.8 KiB) Downloaded 502 times
u 1 Flather Closed Closed Flather
v 1 Flather Closed Closed Flather
temp 1 Radiation Closed Closed Radiation
salt 1 Radiation Closed Closed Radiation
4 -0.2000000 -0.0400000 0.000 0.000 -1.260 -2.520
3 -0.4000000 -0.1600000 0.000 0.000 -5.040 -10.080
2 -0.6000000 -0.3600000 0.000 0.000 -11.340 -22.680
1 -0.8000000 -0.6400000 0.000 0.000 -20.160 -40.320
0 -1.0000000 -1.0000000 0.000 0.000 -31.500 -63.000
Minimum X-grid spacing, DXmin = 6.28611591E-02 km
Maximum X-grid spacing, DXmax = 1.40051290E+04 km
Minimum Y-grid spacing, DYmin = 8.16982139E-02 km
Maximum Y-grid spacing, DYmax = 1.40051877E+04 km
Minimum Z-grid spacing, DZmin = 4.00000000E-18 m
Still, you need to develop some skills for looking at the model output, especially the netcdf files. It wrote all the fields into the restart file - where are they bad?
hi Kate.
My model keeps blowing up. The one who posted this topic is actually my friend and now his model runs. I compared my .in and header files with his, still my model blows up. I'm looking closer into my input files because I have a strong feeling that the problem is in them. It cannot calculate the Kinetic and Potential energies in the first step. (See below)
I'm trying to look for any aspect where the error could've possibly been caused. In my grid input file, I have negative h values because I have barrier islands in the middle of my grid. From what I understood, I need to activate Wetting and Drying in my header file if one has to have negative h values. Is my understanding correct?
As a result, I have the following log:
and
My grid stiffness ratios are Inf and I have negative DZmin. I also have a negative volume which is very unrealistic. Does that pose an error on my model? If yes, what's the best thing to do to the bathymetry of my barrier islands?
By the way the other input files that I have are river, tide, and initial conditions. I just set my initial conditions to zeros except for the salinity (all 33.29) and temp (all 8 degrees).
0 0 00:00:00 0.000000E+00 3.637960E+02 3.637960E+02 6.806820E+10
DEF_HIS - creating history file, Grid 01: Results/nakdong_his_0001.nc
WRT_HIS - wrote history fields (Index=1,1) in record = 0000001
1 0 00:00:05 NaN NaN NaN NaN
Minimum X-grid spacing, DXmin = 6.96509153E-02 km
Maximum X-grid spacing, DXmax = 8.00000000E-01 km
Minimum Y-grid spacing, DYmin = 8.04500000E-02 km
Maximum Y-grid spacing, DYmax = 1.09658561E+00 km
Minimum Z-grid spacing, DZmin = -1.90909095E-01 m
Maximum Z-grid spacing, DZmax = 2.07639668E+01 m
Minimum barotropic Courant Number = 1.38420216E-05
Maximum barotropic Courant Number = 7.42650581E-02
Maximum Coriolis Courant Number = 4.19916072E-04
Maximum grid stiffness ratios: rx0 = Inf (Beckmann and Haidvogel)
rx1 = Inf (Haney)
Initial basin volumes: TotVolume = 6.8064832647E+10 m3
MinVolume = -2.4500359567E+03 m3
MaxVolume = 1.2914617809E+07 m3
Max/Min = -5.2711952140E+03
I have a domain with wetting and drying and my minimum dz is negative. My Beckmann and Haney numbers are not Inf, but rather 1e2 and 1e5, respectively. I can't tell from here why your job is blowing up. Can you tell from the restart record it saved which field is going NaN and where?
Thanks for the reply Kate. I realized the problem was in my "f" variable (grid file). The land cells all have NaN values as their f so I set them to 0, and the model ran. My Beckmann and Haney numbers are still Inf though.
