I guess someone in this group has experienced this same problem. I'm compiling the model's last version with gfortran in Centos and I get this error (I include only the last part):
cd /home/ROMS_MODEL/RUN_ROMS/Build; /usr/bin/gfortran -c -frepack-arrays -fopenmp -O3 -ffast-math mod_eclight.f90
dateclock.f90:137.8:
DateNumber=Rclock.Dnumber+CurrentTime ! fractional days
1
Error: Unclassifiable statement at (1)
dateclock.f90:154.8:
1
dateclock.f90:171.8:
1
dateclock.f90:211.33:
IF (CurrentTime.ge.Rclock.Dnumber) THEN
1
Error: Syntax error in IF-expression at (1)
dateclock.f90:214.25:
jday=INT(Rclock.Dnumber+CurrentTime) ! Truncated Julian Day
1
Error: Syntax error in argument list at (1)
dateclock.f90:241.9:
Error: Expecting END SUBROUTINE statement at (1)
dateclock.f90:816.6:
Rclock.yday =yday
1
dateclock.f90:817.6:
Rclock.year =iyear
1
dateclock.f90:818.6:
Rclock.month =month
1
dateclock.f90:819.6:
Rclock.day =iday
1
dateclock.f90:820.6:
Rclock.hour =ihour
1
dateclock.f90:821.6:
Rclock.minutes =minute
1
dateclock.f90:822.6:
Rclock.seconds =isec
1
dateclock.f90:823.6:
Rclock.base =r_time
1
dateclock.f90:824.6:
Rclock.Dnumber =DateNumber(1)
1
dateclock.f90:825.6:
Rclock.Snumber =DateNumber(2)
1
dateclock.f90:826.6:
Rclock.string =string
1
dateclock.f90:827.6:
Rclock.calendar=TRIM(calendar)
1
dateclock.f90:888.6:
ClockTime=DateNumber(2)-Rclock.Snumber
1
make: *** [/home/ROMS_MODEL/RUN_ROMS/Build/dateclock.o] Error 1
Any thought?
DAVID
Compiling error: dateclock?
Re: Compiling error: dateclock?
Right you are - it fails with gfortran, compiles with ifort. Reading the errors, I don't understand why it doesn't compile.
Greetings
FYI I am also experiencing the same
problem after updating to version 841.
I am using gfortran 4.9.2 on Debian.
Giannis
Giannis
The correct syntax for structure components in Fortran is:
not . Fixing that in dateclock.F allows it to compile, only to fail on:
It compiles with one less zero there.
There are other Rclock.xx things in def_*.F.
Rclock%Dnumber
Rclock.Dnumber
diag.f90:355.55:
WRITE (stdout,30) MOD(iic(ng)-1,10000000000), time_code(ng),&
1
Error: Integer too big for its kind at (1). This check can be disabled with the option -fno-range-check
make: *** [Build_up/diag.o] Error 1
Yes, thank you for reporting this one. The weird thing is that I ran and debugged (TotalView) this version several times with the ifort compiler and didn't report any errors or warnings. It seems to be happy with the dot syntax. Of course, the correct syntax in Fortran is to use Rclock %. This happens for coding some of the functions in module dateclock.F in both Fortran and Matlab. The dot syntax is correct in Matlab.
Please update your code. Check the following
trak ticket for details.
Thanks for your comments, guys. I replaced the newest version by the one I downloaded by the end of the last year and it's now working. I'll update it soon.
Regards,
David
Regards,
David
