My model is blowing and I don't know why. I tried to change the time step but the only thing it does is to delay the
blowing up.
if i do not add river files its work fine. But if i add river transport, i am getting error..
I need help on this one
Wednesday - March 29, 2017 - 11:38:05 PM
NSCS ONLY TIDE RUN,Baipeng @ OUC on 20150704
Operating system : Linux
CPU/hardware : x86_64
Compiler system : pgi
Compiler command : /soft/ompi133-pgi714/bin/mpif90
Compiler flags : -O3 -Mfree
Input Script :
SVN Revision : exported
Local Root : /public/home/zhoujian/zhaoqin/src/roms37-n
Header Dir : /public/home/zhoujian/zhaoqin/river/zhujiang/ini
Header file : zhujiang.h
Analytical Dir: /public/home/zhoujian/zhaoqin/river/zhujiang/ini
Resolution, Grid 01: 0249x0215x010, Parallel Nodes: 16, Tiling: 004x004
8640 ntimes Number of timesteps for 3-D equations.
60.000 dt Timestep size (s) for 3-D equations.
60 ndtfast Number of timesteps for 2-D equations between
12 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
12 nHIS Number of timesteps between the writing fields
into history file.
0 ntsAVG Starting timestep for the accumulation of output
time-averaged data.
12 nAVG Number of timesteps between the writing of
5.0000E+00 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
5.0000E+00 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1.8000E-03 rdrg2 Quadratic bottom drag coefficient.
1 lmd_Jwt Jerlov water type.
2.0000E+00 theta_s S-coordinate surface control parameter.
8.0000E-01 theta_b S-coordinate bottom control parameter.
5.000 Tcline S-coordinate surface/bottom layer width (m) used
20160101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
3.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
3.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
1.8000E+02 Znudg Nudging/relaxation time scale (days)
1.8000E+02 M2nudg Nudging/relaxation time scale (days)
1.8000E+02 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.2000E+02 obcfac Factor between passive and active
T LuvSrc Turning ON momentum point Sources/Sinks.
T LwSrc Turning ON volume influx point Sources/Sinks.
T LtracerSrc(01) Turning ON point Sources/Sinks on tracer 01: temp
T LtracerSrc(02) Turning ON point Sources/Sinks on tracer 02: salt
T Hout(idu2dE) Write out 2D U-eastward at RHO-points.
T Hout(idv2dN) Write out 2D V-northward at RHO-points.
T Aout(idu2dE) Write out averaged 2D U-eastward at RHO-points.
T Aout(idv2dN) Write out averaged 2D V-northward at RHO-points.
T Aout(idVvis) Write out averaged vertical viscosity: AKv.
Output Restart File: ./out/zhujiang_tide_rst.nc
Output History File: ./out/zhujiang_tide_his.nc
Output Averages File: ./out/zhujiang_tide_avg.nc
Input Grid File: ./nc/zhujiang_grd.nc
Input Nonlinear Initial File: ./nc/zhujiang_ini.nc
Input Sources/Sinks File: ./nc/zhujiang_river.nc
Input Forcing File 01: ./nc/zhujiang_frc.nc
Tile partition information for Grid 01: 0249x0215x0010 tiling: 004x004
tile Istr Iend Jstr Jend Npts
0 1 62 1 54 33480
1 63 125 1 54 34020
2 126 188 1 54 34020
3 189 249 1 54 32940
4 1 62 55 108 33480
5 63 125 55 108 34020
6 126 188 55 108 34020
7 189 249 55 108 32940
8 1 62 109 162 33480
9 63 125 109 162 34020
10 126 188 109 162 34020
11 189 249 109 162 32940
12 1 62 163 215 32860
13 63 125 163 215 33390
14 126 188 163 215 33390
15 189 249 163 215 32330
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 62.50 0.50 54.50 RHO-points
1 62.50 125.50 0.50 54.50 RHO-points
2 125.50 188.50 0.50 54.50 RHO-points
3 188.50 249.50 0.50 54.50 RHO-points
4 0.50 62.50 54.50 108.50 RHO-points
5 62.50 125.50 54.50 108.50 RHO-points
6 125.50 188.50 54.50 108.50 RHO-points
7 188.50 249.50 54.50 108.50 RHO-points
8 0.50 62.50 108.50 162.50 RHO-points
9 62.50 125.50 108.50 162.50 RHO-points
10 125.50 188.50 108.50 162.50 RHO-points
11 188.50 249.50 108.50 162.50 RHO-points
12 0.50 62.50 162.50 215.50 RHO-points
13 62.50 125.50 162.50 215.50 RHO-points
14 125.50 188.50 162.50 215.50 RHO-points
15 188.50 249.50 162.50 215.50 RHO-points
0 1.00 62.50 0.50 54.50 U-points
1 62.50 125.50 0.50 54.50 U-points
2 125.50 188.50 0.50 54.50 U-points
3 188.50 249.00 0.50 54.50 U-points
4 1.00 62.50 54.50 108.50 U-points
5 62.50 125.50 54.50 108.50 U-points
6 125.50 188.50 54.50 108.50 U-points
7 188.50 249.00 54.50 108.50 U-points
8 1.00 62.50 108.50 162.50 U-points
9 62.50 125.50 108.50 162.50 U-points
10 125.50 188.50 108.50 162.50 U-points
11 188.50 249.00 108.50 162.50 U-points
12 1.00 62.50 162.50 215.50 U-points
13 62.50 125.50 162.50 215.50 U-points
14 125.50 188.50 162.50 215.50 U-points
15 188.50 249.00 162.50 215.50 U-points
0 0.50 62.50 1.00 54.50 V-points
1 62.50 125.50 1.00 54.50 V-points
2 125.50 188.50 1.00 54.50 V-points
3 188.50 249.50 1.00 54.50 V-points
4 0.50 62.50 54.50 108.50 V-points
5 62.50 125.50 54.50 108.50 V-points
6 125.50 188.50 54.50 108.50 V-points
7 188.50 249.50 54.50 108.50 V-points
8 0.50 62.50 108.50 162.50 V-points
9 62.50 125.50 108.50 162.50 V-points
10 125.50 188.50 108.50 162.50 V-points
11 188.50 249.50 108.50 162.50 V-points
12 0.50 62.50 162.50 215.00 V-points
13 62.50 125.50 162.50 215.00 V-points
14 125.50 188.50 162.50 215.00 V-points
15 188.50 249.50 162.50 215.00 V-points
HaloSizeI(1) = 150
HaloSizeJ(1) = 132
TileSide(1) = 69
TileSize(1) = 4140
zeta 1 Chapman Imp Chapman Imp Chapman Imp Closed
ubar 1 Flather Flather Flather Closed
vbar 1 Flather Flather Flather Closed
u 1 Radiation Radiation Radiation Closed
v 1 Radiation Radiation Radiation Closed
temp 1 Radiation Radiation Radiation Closed
salt 1 Radiation Radiation Radiation Closed
tke 1 Gradient Gradient Gradient Closed
zhujiang NSCS ONLY TIDE RUN,Baipeng @ OUC on 20150704
ADD_FSOBC Adding tidal elevation to processed OBC data.
FSOBC_REDUCED Using free-surface data in reduced physics conditions
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
QCORRECTION Surface net heat flux correction.
K_C2ADVECTION Second-order centered differences advection of TKE fields.
RAMP_TIDES Ramping tidal forcing for one day.
SALINITY Using salinity.
SPHERICAL Spherical grid configuration.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 12 (pid= 21000) is active.
Node # 0 (pid= 20988) is active.
Node # 1 (pid= 20989) is active.
Node # 2 (pid= 20990) is active.
Node # 3 (pid= 20991) is active.
Node # 4 (pid= 20992) is active.
Node # 5 (pid= 20993) is active.
Node # 6 (pid= 20994) is active.
Node # 7 (pid= 20995) is active.
Node # 8 (pid= 20996) is active.
Node # 9 (pid= 20997) is active.
Node # 10 (pid= 20998) is active.
Node # 11 (pid= 20999) is active.
Node # 13 (pid= 21001) is active.
Node # 14 (pid= 21002) is active.
Node # 15 (pid= 21003) is active.
10 0.0000000 0.0000000 0.000 0.000 0.000 0.000
9 -0.1000000 -0.0105235 -0.276 -0.276 -0.961 -1.478
8 -0.2000000 -0.0421432 -0.605 -0.605 -2.933 -4.966
7 -0.3000000 -0.0949716 -0.987 -0.987 -5.922 -10.473
6 -0.4000000 -0.1690770 -1.423 -1.423 -9.931 -18.007
5 -0.5000000 -0.2643019 -1.911 -1.911 -14.952 -27.553
4 -0.6000000 -0.3800088 -2.450 -2.450 -20.955 -39.048
3 -0.7000000 -0.5147634 -3.037 -3.037 -27.871 -52.358
2 -0.8000000 -0.6659856 -3.665 -3.665 -35.576 -67.237
1 -0.9000000 -0.8296305 -4.324 -4.324 -43.877 -83.298
0 -1.0000000 -1.0000000 -5.000 -5.000 -52.500 -100.000
Time Splitting Weights for Grid 01: ndtfast = 60 nfast = 83
ndtfast, nfast = 60 83 nfast/ndtfast = 1.38333
1.000000000000 1.029032332991 0.514516166496 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.23667
Minimum X-grid spacing, DXmin = 1.02296327E+00 km
Maximum X-grid spacing, DXmax = 1.03751445E+00 km
Minimum Y-grid spacing, DYmin = 1.02306790E+00 km
Maximum Y-grid spacing, DYmax = 1.03748200E+00 km
Minimum Z-grid spacing, DZmin = 2.76308681E-01 m
Maximum Z-grid spacing, DZmax = 1.67018536E+01 m
Minimum barotropic Courant Number = 9.58445839E-03
Maximum barotropic Courant Number = 4.27857443E-02
Maximum Coriolis Courant Number = 3.40239443E-03
(Grid 01, File: zhujiang_ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 2.05085800E+01 Max = 2.16111430E+01)
- salinity
(Min = 3.42318397E+01 Max = 3.45099590E+01)
GET_NGFLD - tidal period
(Min = 4.32000000E+04 Max = 9.29494789E+04)
(Min = 7.21237057E-02 Max = 6.59631946E-01)
(Min = 5.00965909E-01 Max = 5.53049352E+00)
GET_NGFLD - river runoff XI-positions at RHO-points
(Min = 5.60000000E+01 Max = 1.12000000E+02)
GET_NGFLD - river runoff ETA-positions at RHO-points
(Min = 1.15000000E+02 Max = 2.10000000E+02)
GET_NGFLD - river runoff direction
(Min = 0.00000000E+00 Max = 1.00000000E+00)
GET_NGFLD - river runoff mass transport vertical profile
(Min = 1.00000000E-01 Max = 1.00000000E-01)
GET_NGFLD - river runoff mass transport, t = 345 00:00:00
(Rec=0000012, Index=2, File: zhujiang_river.nc)
(Min = -1.22557870E+03 Max = 7.27970679E+02)
GET_NGFLD - river runoff potential temperature, t = 345 00:00:00
(Min = 1.96000000E+01 Max = 1.96000000E+01)
GET_NGFLD - river runoff salinity, t = 345 00:00:00
(Min = 2.00000000E+00 Max = 2.00000000E+00)
GET_2DFLD - solar shortwave radiation flux, t = 345 00:00:00
(Rec=0000012, Index=1, File: zhujiang_frc.nc)
(Min = 2.89871352E-05 Max = 3.06551132E-05)
GET_2DFLD - surface net heat flux, t = 345 00:00:00
(Min = -5.25836503E-05 Max = -4.18047617E-05)
GET_2DFLD - sea surface temperature climatology, t = 345 00:00:00
(Min = 2.18230925E+01 Max = 2.30666757E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 345 00:00:00
(Min = -1.23753182E-05 Max = -1.10841986E-05)
Maximum grid stiffness ratios: rx0 = 2.061283E-01 (Beckmann and Haidvogel)
rx1 = 2.722997E+00 (Haney)
Initial basin volumes: TotVolume = 1.6586264838E+12 m3
MinVolume = 2.8939061026E+05 m3
MaxVolume = 1.7968182750E+07 m3
Max/Min = 6.2089722724E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00008640)
GET_NGFLD - river runoff mass transport, t = 15 00:00:00
(Rec=0000001, Index=1, File: zhujiang_river.nc)
(Min = -8.22955247E+02 Max = 5.76581790E+02)
GET_NGFLD - river runoff potential temperature, t = 15 00:00:00
(Min = 1.71000000E+01 Max = 1.71000000E+01)
GET_NGFLD - river runoff salinity, t = 15 00:00:00
GET_2DFLD - solar shortwave radiation flux, t = 15 00:00:00
(Rec=0000001, Index=2, File: zhujiang_frc.nc)
(Min = 2.94819529E-05 Max = 3.11401733E-05)
GET_2DFLD - surface net heat flux, t = 15 00:00:00
(Min = -5.04445284E-05 Max = -3.61466074E-05)
GET_2DFLD - sea surface temperature climatology, t = 15 00:00:00
(Min = 1.95655146E+01 Max = 2.18864341E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 15 00:00:00
(Min = -1.11153567E-05 Max = -9.94507060E-06)
0 0 00:00:00 0.000000E+00 2.727146E+02 2.727146E+02 1.752388E+12
DEF_HIS - creating history file, Grid 01: ./out/zhujiang_tide_his.nc
DEF_AVG - creating average file, Grid 01: ./out/zhujiang_tide_avg.nc
1 0 00:01:00 1.897242E-07 2.727146E+02 2.727146E+02 1.752388E+12
(082,141,02) 9.016881E-04 4.150491E-03 6.738187E-03 2.543850E-01
2 0 00:02:00 2.967674E-07 2.727145E+02 2.727145E+02 1.752387E+12
(082,141,10) 3.280183E-03 9.954998E-03 1.573697E-01 2.780806E-01
3 0 00:03:00 5.751378E-07 2.727144E+02 2.727144E+02 1.752386E+12
(099,191,10) 6.656703E-03 0.000000E+00 1.254497E-01 3.288212E-01
4 0 00:04:00 9.548240E-07 2.727142E+02 2.727142E+02 1.752385E+12
(112,210,10) 2.177691E-04 1.055854E-02 2.238568E-01 3.773203E-01
5 0 00:05:00 1.322166E-06 2.727139E+02 2.727139E+02 1.752384E+12
(112,210,10) 6.919126E-04 1.054579E-02 3.604228E-01 3.977519E-01
6 0 00:06:00 1.634702E-06 2.727136E+02 2.727136E+02 1.752382E+12
(112,210,10) 1.510198E-03 1.052249E-02 4.088143E-01 4.071458E-01
7 0 00:07:00 1.905340E-06 2.727132E+02 2.727132E+02 1.752380E+12
(112,210,10) 2.594927E-03 1.050589E-02 3.791894E-01 4.586531E-01
8 0 00:08:00 2.154239E-06 2.727128E+02 2.727128E+02 1.752378E+12
(112,210,10) 3.731831E-03 1.050462E-02 3.112280E-01 5.028766E-01
9 0 00:09:00 2.388576E-06 2.727123E+02 2.727123E+02 1.752376E+12
(082,141,10) 1.425698E-02 1.012145E-02 2.858029E-01 5.313119E-01
10 0 00:10:00 2.602124E-06 2.727118E+02 2.727118E+02 1.752373E+12
(082,141,10) 1.436687E-02 1.013395E-02 2.796520E-01 5.481975E-01
11 0 00:11:00 2.778816E-06 2.727112E+02 2.727112E+02 1.752370E+12
(082,141,10) 1.469163E-02 1.014998E-02 2.774342E-01 5.594477E-01
12 0 00:12:00 2.899308E-06 2.727106E+02 2.727106E+02 1.752367E+12
(082,141,10) 1.519298E-02 1.016249E-02 2.828070E-01 5.686807E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000002
WRT_AVG - wrote averaged fields into time record = 0000001
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000001
13 0 00:13:00 2.959693E-06 2.727099E+02 2.727099E+02 1.752363E+12
(082,141,10) 1.573780E-02 1.016330E-02 2.946449E-01 5.754105E-01
14 0 00:14:00 2.986870E-06 2.727092E+02 2.727092E+02 1.752359E+12
(082,141,10) 1.614624E-02 1.014687E-02 3.085484E-01 5.756701E-01
15 0 00:15:00 3.022363E-06 2.727085E+02 2.727085E+02 1.752355E+12
(082,141,10) 1.623994E-02 1.011283E-02 3.185470E-01 5.645989E-01
16 0 00:16:00 3.085689E-06 2.727077E+02 2.727077E+02 1.752351E+12
(082,141,10) 1.588196E-02 1.006624E-02 3.185969E-01 5.390086E-01
17 0 00:17:00 3.161895E-06 2.727069E+02 2.727069E+02 1.752347E+12
(082,141,10) 1.501752E-02 1.001589E-02 3.039338E-01 4.991701E-01
18 0 00:18:00 3.228920E-06 2.727060E+02 2.727060E+02 1.752342E+12
(082,141,10) 1.370654E-02 9.971554E-03 2.724041E-01 4.492981E-01
19 0 00:19:00 3.289104E-06 2.727051E+02 2.727051E+02 1.752337E+12
(082,141,10) 1.213604E-02 9.941416E-03 2.256397E-01 3.969182E-01
20 0 00:20:00 3.363775E-06 2.727042E+02 2.727042E+02 1.752332E+12
(112,210,10) 2.710379E-03 1.045590E-02 1.997440E-01 3.528436E-01
21 0 00:21:00 3.466781E-06 2.727032E+02 2.727032E+02 1.752327E+12
(112,210,10) 3.040080E-03 1.046153E-02 2.085324E-01 3.531451E-01
22 0 00:22:00 3.600193E-06 2.727023E+02 2.727023E+02 1.752321E+12
(112,210,10) 3.369754E-03 1.046238E-02 2.017284E-01 3.498029E-01
23 0 00:23:00 3.773735E-06 2.727013E+02 2.727013E+02 1.752316E+12
(100,191,10) 1.625508E-02 4.605347E-03 2.004197E-01 3.467233E-01
24 0 00:24:00 4.006130E-06 2.727002E+02 2.727002E+02 1.752310E+12
(100,191,10) 1.547079E-02 4.960476E-03 1.902454E-01 3.538465E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000003
WRT_AVG - wrote averaged fields into time record = 0000002
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000002
25 0 00:25:00 4.298696E-06 2.726992E+02 2.726992E+02 1.752304E+12
(100,191,10) 1.466230E-02 5.082429E-03 1.608097E-01 3.929607E-01
26 0 00:26:00 4.626425E-06 2.726981E+02 2.726981E+02 1.752297E+12
(112,210,10) 3.712249E-03 1.042380E-02 1.799255E-01 4.334513E-01
27 0 00:27:00 4.960693E-06 2.726970E+02 2.726970E+02 1.752291E+12
(082,141,10) 1.531529E-02 9.981744E-03 2.165780E-01 4.669828E-01
28 0 00:28:00 5.284591E-06 2.726959E+02 2.726959E+02 1.752284E+12
(082,141,10) 1.602298E-02 9.964845E-03 2.633784E-01 4.878008E-01
29 0 00:29:00 5.583272E-06 2.726948E+02 2.726948E+02 1.752278E+12
(082,141,10) 1.590495E-02 9.954630E-03 2.848546E-01 4.949517E-01
30 0 00:30:00 5.839293E-06 2.726936E+02 2.726936E+02 1.752271E+12
(112,210,10) 1.912469E-03 1.039424E-02 3.152769E-01 4.922601E-01
31 0 00:31:00 6.049230E-06 2.726925E+02 2.726925E+02 1.752264E+12
(112,210,10) 1.954354E-03 1.039598E-02 3.088747E-01 4.853924E-01
32 0 00:32:00 6.233282E-06 2.726913E+02 2.726913E+02 1.752256E+12
(112,210,10) 2.323458E-03 1.039583E-02 2.763280E-01 4.783610E-01
33 0 00:33:00 6.419342E-06 2.726901E+02 2.726901E+02 1.752249E+12
(112,210,10) 2.877860E-03 1.039317E-02 2.251070E-01 4.727515E-01
34 0 00:34:00 6.625266E-06 2.726889E+02 2.726889E+02 1.752242E+12
(082,141,10) 1.337303E-02 1.005281E-02 1.612745E-01 4.698028E-01
35 0 00:35:00 6.858134E-06 2.726877E+02 2.726877E+02 1.752234E+12
(082,141,10) 1.418596E-02 1.006520E-02 1.698133E-01 4.708301E-01
36 0 00:36:00 7.120740E-06 2.726865E+02 2.726865E+02 1.752226E+12
(082,141,10) 1.509565E-02 1.006054E-02 1.947691E-01 4.749503E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000004
WRT_AVG - wrote averaged fields into time record = 0000003
37 0 00:37:00 7.414524E-06 2.726853E+02 2.726853E+02 1.752218E+12
(082,141,10) 1.571158E-02 1.003948E-02 2.236237E-01 4.779684E-01
38 0 00:38:00 7.737670E-06 2.726840E+02 2.726840E+02 1.752210E+12
(082,141,10) 1.577494E-02 1.000791E-02 2.428259E-01 4.750101E-01
39 0 00:39:00 8.081284E-06 2.726828E+02 2.726828E+02 1.752202E+12
(082,141,10) 1.525379E-02 9.975111E-03 2.432665E-01 4.641594E-01
40 0 00:40:00 8.431525E-06 2.726816E+02 2.726816E+02 1.752194E+12
(082,141,10) 1.434160E-02 9.950511E-03 2.235010E-01 4.476733E-01
41 0 00:41:00 8.779947E-06 2.726803E+02 2.726803E+02 1.752185E+12
(112,210,10) 2.204950E-03 1.044856E-02 2.379481E-01 4.306364E-01
42 0 00:42:00 9.130580E-06 2.726791E+02 2.726791E+02 1.752177E+12
(112,210,10) 2.429503E-03 1.044706E-02 2.497040E-01 4.188542E-01
43 0 00:43:00 9.493361E-06 2.726779E+02 2.726779E+02 1.752168E+12
(112,210,10) 2.776261E-03 1.044564E-02 2.457460E-01 4.171452E-01
44 0 00:44:00 9.872413E-06 2.726766E+02 2.726766E+02 1.752159E+12
(112,210,10) 3.136312E-03 1.044732E-02 2.324927E-01 4.281598E-01
45 0 00:45:00 1.026431E-05 2.726754E+02 2.726754E+02 1.752150E+12
(112,210,10) 3.425537E-03 1.045211E-02 2.177108E-01 4.512559E-01
46 0 00:46:00 1.066302E-05 2.726741E+02 2.726741E+02 1.752142E+12
(112,210,10) 3.601602E-03 1.045699E-02 2.067479E-01 4.821239E-01
47 0 00:47:00 1.105858E-05 2.726729E+02 2.726729E+02 1.752132E+12
(082,141,10) 1.655074E-02 9.981477E-03 2.020774E-01 5.139038E-01
48 0 00:48:00 1.143674E-05 2.726717E+02 2.726717E+02 1.752123E+12
(082,141,10) 1.748858E-02 9.960645E-03 2.421128E-01 5.394607E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000005
WRT_AVG - wrote averaged fields into time record = 0000004
49 0 00:49:00 1.178992E-05 2.726704E+02 2.726704E+02 1.752114E+12
(082,141,10) 1.793031E-02 9.938018E-03 2.714508E-01 5.537325E-01
50 0 00:50:00 1.212783E-05 2.726692E+02 2.726692E+02 1.752105E+12
(082,141,10) 1.783212E-02 9.919974E-03 2.834750E-01 5.551042E-01
51 0 00:51:00 1.246978E-05 2.726680E+02 2.726680E+02 1.752095E+12
(082,141,10) 1.729795E-02 9.910087E-03 2.764584E-01 5.455305E-01
52 0 00:52:00 1.282694E-05 2.726668E+02 2.726668E+02 1.752086E+12
(082,141,10) 1.654397E-02 9.908242E-03 2.537870E-01 5.295350E-01
53 0 00:53:00 1.319702E-05 2.726655E+02 2.726656E+02 1.752076E+12
(082,141,10) 1.583255E-02 9.911285E-03 2.228248E-01 5.125861E-01
54 0 00:54:00 1.357506E-05 2.726643E+02 2.726643E+02 1.752067E+12
(082,141,10) 1.539468E-02 9.914633E-03 1.927097E-01 4.994989E-01
55 0 00:55:00 1.396120E-05 2.726631E+02 2.726631E+02 1.752057E+12
(112,210,10) 1.730444E-03 1.050347E-02 2.037223E-01 4.933365E-01
56 0 00:56:00 1.435701E-05 2.726619E+02 2.726620E+02 1.752047E+12
(112,210,10) 2.083881E-03 1.051570E-02 2.056895E-01 5.189267E-01
57 0 00:57:00 1.476202E-05 2.726608E+02 2.726608E+02 1.752038E+12
(112,210,10) 2.682071E-03 1.051908E-02 1.980431E-01 5.375121E-01
58 0 00:58:00 1.517613E-05 2.726596E+02 2.726596E+02 1.752028E+12
(082,141,10) 1.710450E-02 9.878233E-03 1.884050E-01 5.457852E-01
59 0 00:59:00 1.560037E-05 2.726585E+02 2.726585E+02 1.752018E+12
(082,141,10) 1.767456E-02 9.861183E-03 2.075313E-01 5.453758E-01
60 0 01:00:00 1.603410E-05 2.726573E+02 2.726573E+02 1.752008E+12
(082,141,10) 1.794723E-02 9.846349E-03 2.214102E-01 5.413086E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000006
WRT_AVG - wrote averaged fields into time record = 0000005
61 0 01:01:00 1.647466E-05 2.726562E+02 2.726562E+02 1.751998E+12
(082,141,10) 1.788999E-02 9.835072E-03 2.247058E-01 5.415850E-01
62 0 01:02:00 1.692064E-05 2.726551E+02 2.726551E+02 1.751988E+12
(082,141,10) 1.759607E-02 9.827084E-03 2.161009E-01 5.479753E-01
63 0 01:03:00 1.737467E-05 2.726540E+02 2.726541E+02 1.751978E+12
(112,210,10) 4.564231E-03 1.050235E-02 2.244676E-01 5.558243E-01
64 0 01:04:00 1.783961E-05 2.726530E+02 2.726530E+02 1.751967E+12
(112,210,10) 4.170328E-03 1.049951E-02 2.495433E-01 5.694688E-01
65 0 01:05:00 1.831004E-05 2.726519E+02 2.726520E+02 1.751957E+12
(112,210,10) 3.835279E-03 1.049378E-02 2.590906E-01 5.843420E-01
66 0 01:06:00 1.877349E-05 2.726509E+02 2.726509E+02 1.751947E+12
(112,210,10) 3.695192E-03 1.048722E-02 2.490357E-01 5.947115E-01
67 0 01:07:00 1.922669E-05 2.726499E+02 2.726499E+02 1.751937E+12
(112,210,10) 3.807812E-03 1.048268E-02 2.233428E-01 5.984546E-01
68 0 01:08:00 1.968399E-05 2.726489E+02 2.726489E+02 1.751927E+12
(082,141,10) 1.927963E-02 9.815190E-03 1.825267E-01 5.965541E-01
69 0 01:09:00 2.016224E-05 2.726479E+02 2.726479E+02 1.751916E+12
(082,141,10) 2.010863E-02 9.819463E-03 2.037293E-01 5.965822E-01
70 0 01:10:00 2.066117E-05 2.726469E+02 2.726469E+02 1.751906E+12
(082,141,10) 2.071188E-02 9.822258E-03 2.226794E-01 6.048425E-01
71 0 01:11:00 2.116657E-05 2.726460E+02 2.726460E+02 1.751896E+12
(082,141,10) 2.099581E-02 9.821559E-03 2.337690E-01 6.169258E-01
72 0 01:12:00 2.166724E-05 2.726450E+02 2.726450E+02 1.751885E+12
(082,141,10) 2.095479E-02 9.816990E-03 2.337806E-01 6.325329E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000007
WRT_AVG - wrote averaged fields into time record = 0000006
73 0 01:13:00 2.216288E-05 2.726441E+02 2.726441E+02 1.751875E+12
(082,141,10) 2.066244E-02 9.810355E-03 2.224061E-01 6.500189E-01
74 0 01:14:00 2.265712E-05 2.726432E+02 2.726432E+02 1.751864E+12
(112,210,10) 5.049485E-03 1.043328E-02 2.301587E-01 6.667334E-01
75 0 01:15:00 2.315014E-05 2.726423E+02 2.726423E+02 1.751854E+12
(112,210,10) 4.957289E-03 1.041677E-02 2.413791E-01 6.799867E-01
76 0 01:16:00 2.363973E-05 2.726414E+02 2.726414E+02 1.751844E+12
(112,210,10) 4.915385E-03 1.040577E-02 2.420984E-01 6.883095E-01
77 0 01:17:00 2.412683E-05 2.726405E+02 2.726405E+02 1.751833E+12
(112,210,10) 4.914340E-03 1.040189E-02 2.347467E-01 6.921412E-01
78 0 01:18:00 2.461755E-05 2.726396E+02 2.726397E+02 1.751823E+12
(112,210,10) 4.927008E-03 1.040412E-02 2.235084E-01 6.934256E-01
79 0 01:19:00 2.512023E-05 2.726388E+02 2.726388E+02 1.751812E+12
(112,210,10) 4.932722E-03 1.040908E-02 2.120622E-01 6.945821E-01
80 0 01:20:00 2.564129E-05 2.726380E+02 2.726380E+02 1.751802E+12
(112,210,10) 4.931373E-03 1.041251E-02 2.023092E-01 6.976940E-01
81 0 01:21:00 2.618121E-05 2.726372E+02 2.726372E+02 1.751792E+12
(112,210,10) 4.935057E-03 1.041132E-02 1.941433E-01 7.040949E-01
82 0 01:22:00 2.673279E-05 2.726364E+02 2.726364E+02 1.751781E+12
(082,141,10) 2.371533E-02 9.848760E-03 1.857793E-01 7.140693E-01
83 0 01:23:00 2.728529E-05 2.726357E+02 2.726357E+02 1.751771E+12
(082,141,10) 2.415486E-02 9.838633E-03 2.019379E-01 7.267194E-01
84 0 01:24:00 2.783325E-05 2.726349E+02 2.726349E+02 1.751760E+12
(082,141,10) 2.422579E-02 9.831763E-03 2.064273E-01 7.404151E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000008
WRT_AVG - wrote averaged fields into time record = 0000007
85 0 01:25:00 2.838076E-05 2.726342E+02 2.726342E+02 1.751750E+12
(082,141,10) 2.404364E-02 9.832298E-03 1.978636E-01 7.536703E-01
86 0 01:26:00 2.893537E-05 2.726335E+02 2.726335E+02 1.751739E+12
(082,141,10) 2.383242E-02 9.841545E-03 1.798246E-01 7.656659E-01
87 0 01:27:00 2.949987E-05 2.726328E+02 2.726328E+02 1.751729E+12
(082,141,10) 2.384115E-02 9.857437E-03 1.599424E-01 7.761128E-01
88 0 01:28:00 3.007094E-05 2.726321E+02 2.726321E+02 1.751719E+12
(082,141,10) 2.423876E-02 9.875288E-03 1.471207E-01 7.849947E-01
89 0 01:29:00 3.064330E-05 2.726314E+02 2.726314E+02 1.751708E+12
(112,210,10) 3.847908E-03 1.046687E-02 1.713654E-01 7.925752E-01
90 0 01:30:00 3.121240E-05 2.726307E+02 2.726308E+02 1.751698E+12
(112,210,10) 4.337573E-03 1.047308E-02 1.915915E-01 7.993291E-01
91 0 01:31:00 3.177244E-05 2.726301E+02 2.726301E+02 1.751688E+12
(082,141,10) 2.709232E-02 9.892767E-03 1.878258E-01 8.056122E-01
92 0 01:32:00 3.231536E-05 2.726295E+02 2.726295E+02 1.751678E+12
(082,141,10) 2.778389E-02 9.881899E-03 2.124846E-01 8.114855E-01
93 0 01:33:00 3.283680E-05 2.726289E+02 2.726289E+02 1.751667E+12
(082,141,10) 2.799066E-02 9.867488E-03 2.271633E-01 8.169859E-01
94 0 01:34:00 3.334335E-05 2.726283E+02 2.726283E+02 1.751657E+12
(082,141,10) 2.773039E-02 9.854628E-03 2.254914E-01 8.225899E-01
95 0 01:35:00 3.384901E-05 2.726277E+02 2.726277E+02 1.751647E+12
(082,141,10) 2.719937E-02 9.847523E-03 2.073048E-01 8.291808E-01
96 0 01:36:00 3.436465E-05 2.726271E+02 2.726271E+02 1.751637E+12
(082,141,10) 2.669110E-02 9.848169E-03 1.787903E-01 8.375315E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000009
WRT_AVG - wrote averaged fields into time record = 0000008
97 0 01:37:00 3.489418E-05 2.726266E+02 2.726266E+02 1.751627E+12
(082,141,10) 2.647772E-02 9.855823E-03 1.500082E-01 8.478146E-01
98 0 01:38:00 3.543819E-05 2.726260E+02 2.726261E+02 1.751617E+12
(112,210,10) 5.468679E-03 1.047420E-02 1.740525E-01 8.594760E-01
99 0 01:39:00 3.599431E-05 2.726255E+02 2.726256E+02 1.751607E+12
(112,210,10) 5.170762E-03 1.046788E-02 1.987352E-01 8.713821E-01
100 0 01:40:00 3.655346E-05 2.726250E+02 2.726251E+02 1.751597E+12
(112,210,10) 5.151008E-03 1.045741E-02 2.195895E-01 8.820811E-01
101 0 01:41:00 3.710158E-05 2.726245E+02 2.726246E+02 1.751587E+12
(112,210,10) 5.416885E-03 1.044882E-02 2.272063E-01 8.902207E-01
102 0 01:42:00 3.762842E-05 2.726241E+02 2.726241E+02 1.751577E+12
(112,210,10) 5.899692E-03 1.044736E-02 2.181747E-01 8.950951E-01
103 0 01:43:00 3.813268E-05 2.726236E+02 2.726236E+02 1.751568E+12
(082,141,10) 3.027602E-02 9.866865E-03 1.974376E-01 8.969787E-01
104 0 01:44:00 3.861925E-05 2.726231E+02 2.726232E+02 1.751558E+12
(082,141,10) 3.039535E-02 9.856924E-03 2.038631E-01 8.968976E-01
105 0 01:45:00 3.909494E-05 2.726227E+02 2.726228E+02 1.751548E+12
(082,141,10) 3.031410E-02 9.852192E-03 2.001235E-01 8.959867E-01
106 0 01:46:00 3.956661E-05 2.726223E+02 2.726223E+02 1.751539E+12
(082,141,10) 3.016135E-02 9.855435E-03 1.891257E-01 8.950126E-01
107 0 01:47:00 4.003905E-05 2.726219E+02 2.726220E+02 1.751529E+12
(082,141,10) 3.005444E-02 9.866807E-03 1.752006E-01 8.943662E-01
108 0 01:48:00 4.051115E-05 2.726215E+02 2.726216E+02 1.751520E+12
(082,141,10) 3.005292E-02 9.883842E-03 1.622952E-01 8.942752E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000010
WRT_AVG - wrote averaged fields into time record = 0000009
109 0 01:49:00 4.098001E-05 2.726212E+02 2.726212E+02 1.751510E+12
(082,141,10) 3.019457E-02 9.902472E-03 1.534719E-01 8.948106E-01
110 0 01:50:00 4.144106E-05 2.726208E+02 2.726209E+02 1.751501E+12
(112,210,10) 7.707256E-03 1.047902E-02 1.887951E-01 8.957461E-01
111 0 01:51:00 4.189342E-05 2.726205E+02 2.726206E+02 1.751492E+12
(112,210,10) 7.904893E-03 1.047205E-02 1.993864E-01 8.965600E-01
112 0 01:52:00 4.233723E-05 2.726202E+02 2.726203E+02 1.751482E+12
(112,210,10) 8.224876E-03 1.046808E-02 2.047908E-01 8.966507E-01
113 0 01:53:00 4.276980E-05 2.726199E+02 2.726200E+02 1.751473E+12
(112,210,10) 8.639430E-03 1.046654E-02 2.060991E-01 8.955442E-01
114 0 01:54:00 4.318462E-05 2.726197E+02 2.726197E+02 1.751464E+12
(112,210,10) 9.110108E-03 1.046528E-02 2.052207E-01 8.929835E-01
115 0 01:55:00 4.357602E-05 2.726194E+02 2.726195E+02 1.751455E+12
(112,210,10) 9.588678E-03 1.046150E-02 2.039210E-01 8.890117E-01
116 0 01:56:00 4.394525E-05 2.726192E+02 2.726192E+02 1.751446E+12
(112,210,10) 1.001679E-02 1.045301E-02 2.033917E-01 8.839702E-01
117 0 01:57:00 4.430187E-05 2.726189E+02 2.726190E+02 1.751437E+12
(112,210,10) 1.032721E-02 1.043943E-02 2.040363E-01 8.783044E-01
118 0 01:58:00 4.465791E-05 2.726187E+02 2.726188E+02 1.751429E+12
(112,210,10) 1.045600E-02 1.042260E-02 2.055305E-01 8.723223E-01
119 0 01:59:00 4.502003E-05 2.726185E+02 2.726186E+02 1.751420E+12
(112,210,10) 1.036335E-02 1.040589E-02 2.070140E-01 8.661640E-01
120 0 02:00:00 4.538770E-05 2.726183E+02 2.726184E+02 1.751411E+12
(112,210,10) 1.005976E-02 1.039279E-02 2.073331E-01 8.600547E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000011
WRT_AVG - wrote averaged fields into time record = 0000010
121 0 02:01:00 4.575757E-05 2.726181E+02 2.726182E+02 1.751403E+12
(112,210,10) 9.615450E-03 1.038547E-02 2.054942E-01 8.545355E-01
122 0 02:02:00 4.612770E-05 2.726180E+02 2.726180E+02 1.751394E+12
(112,210,10) 9.152256E-03 1.038404E-02 2.011090E-01 8.503728E-01
123 0 02:03:00 4.649677E-05 2.726178E+02 2.726179E+02 1.751386E+12
(112,210,10) 8.812495E-03 1.038689E-02 1.947180E-01 8.601642E-01
124 0 02:04:00 4.686209E-05 2.726177E+02 2.726177E+02 1.751378E+12
(082,141,10) 3.387848E-02 9.991272E-03 1.796374E-01 8.770390E-01
125 0 02:05:00 4.722001E-05 2.726176E+02 2.726176E+02 1.751370E+12
(082,141,10) 3.427822E-02 9.986136E-03 2.000595E-01 8.888766E-01
126 0 02:06:00 4.756836E-05 2.726174E+02 2.726175E+02 1.751362E+12
(082,141,10) 3.438279E-02 9.980093E-03 2.135007E-01 8.942947E-01
127 0 02:07:00 4.790806E-05 2.726174E+02 2.726174E+02 1.751354E+12
(082,141,10) 3.421781E-02 9.973938E-03 2.171634E-01 8.937108E-01
128 0 02:08:00 4.824295E-05 2.726173E+02 2.726173E+02 1.751346E+12
(082,141,10) 3.388867E-02 9.968366E-03 2.114808E-01 8.890065E-01
129 0 02:09:00 4.857771E-05 2.726172E+02 2.726173E+02 1.751338E+12
(082,141,10) 3.353673E-02 9.963933E-03 1.998055E-01 8.827456E-01
130 0 02:10:00 4.891553E-05 2.726172E+02 2.726172E+02 1.751331E+12
(082,141,10) 3.328462E-02 9.960948E-03 1.870053E-01 8.772904E-01
131 0 02:11:00 4.925618E-05 2.726172E+02 2.726172E+02 1.751323E+12
(082,141,10) 3.319345E-02 9.959334E-03 1.775525E-01 8.741146E-01
132 0 02:12:00 4.959663E-05 2.726172E+02 2.726172E+02 1.751316E+12
(082,141,10) 3.324802E-02 9.958564E-03 1.739073E-01 8.734660E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000012
WRT_AVG - wrote averaged fields into time record = 0000011
133 0 02:13:00 4.993280E-05 2.726172E+02 2.726172E+02 1.751309E+12
(082,141,10) 3.337297E-02 9.957756E-03 1.758469E-01 8.744002E-01
134 0 02:14:00 5.026092E-05 2.726172E+02 2.726173E+02 1.751302E+12
(082,141,10) 3.346998E-02 9.955956E-03 1.809206E-01 8.752389E-01
135 0 02:15:00 5.057638E-05 2.726173E+02 2.726173E+02 1.751295E+12
(082,141,10) 3.345867E-02 9.952502E-03 1.857057E-01 8.743232E-01
136 0 02:16:00 5.087389E-05 2.726173E+02 2.726174E+02 1.751288E+12
(112,210,10) 1.192970E-02 1.040969E-02 2.203715E-01 8.707224E-01
137 0 02:17:00 5.114966E-05 2.726174E+02 2.726174E+02 1.751281E+12
(112,210,10) 1.216125E-02 1.040077E-02 2.345000E-01 8.646146E-01
138 0 02:18:00 5.140427E-05 2.726175E+02 2.726175E+02 1.751274E+12
(112,210,10) 1.241348E-02 1.039365E-02 2.374864E-01 8.572733E-01
139 0 02:19:00 5.164217E-05 2.726175E+02 2.726176E+02 1.751268E+12
(112,210,10) 1.266020E-02 1.038981E-02 2.289294E-01 8.506757E-01
140 0 02:20:00 5.186856E-05 2.726176E+02 2.726177E+02 1.751261E+12
(112,210,10) 1.283894E-02 1.038963E-02 2.123656E-01 8.469249E-01
141 0 02:21:00 5.208870E-05 2.726178E+02 2.726178E+02 1.751255E+12
(112,210,10) 1.296609E-02 1.039230E-02 1.935197E-01 8.476503E-01
142 0 02:22:00 5.230832E-05 2.726179E+02 2.726179E+02 1.751249E+12
(112,210,10) 1.302283E-02 1.039632E-02 1.777075E-01 8.535096E-01
143 0 02:23:00 5.253270E-05 2.726180E+02 2.726181E+02 1.751243E+12
(082,141,10) 3.238433E-02 9.903959E-03 1.565194E-01 8.639891E-01
144 0 02:24:00 5.276420E-05 2.726182E+02 2.726182E+02 1.751237E+12
(082,141,10) 3.272522E-02 9.896383E-03 1.677418E-01 8.774339E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000013
WRT_AVG - wrote averaged fields into time record = 0000012
145 0 02:25:00 5.300056E-05 2.726183E+02 2.726184E+02 1.751231E+12
(082,141,10) 3.309103E-02 9.886571E-03 1.831767E-01 8.914031E-01
146 0 02:26:00 5.323897E-05 2.726185E+02 2.726186E+02 1.751225E+12
(082,141,10) 3.339226E-02 9.874346E-03 2.002533E-01 9.032267E-01
147 0 02:27:00 5.347576E-05 2.726187E+02 2.726187E+02 1.751220E+12
(082,141,10) 3.354559E-02 9.860185E-03 2.158616E-01 9.106370E-01
148 0 02:28:00 5.370246E-05 2.726189E+02 2.726190E+02 1.751214E+12
(082,141,10) 3.349487E-02 9.845246E-03 2.269826E-01 9.123066E-01
149 0 02:29:00 5.391751E-05 2.726191E+02 2.726192E+02 1.751209E+12
(082,141,10) 3.322807E-02 9.831156E-03 2.314141E-01 9.081164E-01
150 0 02:30:00 5.411543E-05 2.726193E+02 2.726194E+02 1.751204E+12
(082,141,10) 3.278357E-02 9.819609E-03 2.284043E-01 8.991298E-01
151 0 02:31:00 5.430118E-05 2.726196E+02 2.726196E+02 1.751199E+12
(082,141,10) 3.224071E-02 9.811849E-03 2.189582E-01 8.871750E-01
152 0 02:32:00 5.448416E-05 2.726198E+02 2.726199E+02 1.751194E+12
(082,141,10) 3.169608E-02 9.808241E-03 2.056276E-01 8.742675E-01
153 0 02:33:00 5.467147E-05 2.726201E+02 2.726201E+02 1.751190E+12
(082,141,10) 3.123192E-02 9.808133E-03 1.917545E-01 8.619746E-01
154 0 02:34:00 5.486468E-05 2.726203E+02 2.726204E+02 1.751185E+12
(112,210,10) 1.693741E-02 1.045530E-02 1.964657E-01 8.510579E-01
155 0 02:35:00 5.506130E-05 2.726206E+02 2.726207E+02 1.751181E+12
(112,210,10) 1.701307E-02 1.044774E-02 2.009154E-01 8.413887E-01
156 0 02:36:00 5.525684E-05 2.726209E+02 2.726209E+02 1.751176E+12
(112,210,10) 1.690889E-02 1.044028E-02 2.057818E-01 8.321868E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000014
WRT_AVG - wrote averaged fields into time record = 0000013
157 0 02:37:00 5.544554E-05 2.726211E+02 2.726212E+02 1.751172E+12
(112,210,10) 1.672658E-02 1.043192E-02 2.131690E-01 8.224761E-01
158 0 02:38:00 5.562181E-05 2.726214E+02 2.726215E+02 1.751168E+12
(112,210,10) 1.657278E-02 1.042130E-02 2.236235E-01 8.116390E-01
159 0 02:39:00 5.578322E-05 2.726217E+02 2.726218E+02 1.751164E+12
(112,210,10) 1.652716E-02 1.040798E-02 2.351277E-01 7.998872E-01
160 0 02:40:00 5.593268E-05 2.726220E+02 2.726221E+02 1.751160E+12
(112,210,10) 1.662895E-02 1.039319E-02 2.434858E-01 7.883859E-01
161 0 02:41:00 5.607708E-05 2.726224E+02 2.726224E+02 1.751157E+12
(112,210,10) 1.687978E-02 1.037950E-02 2.441169E-01 7.790265E-01
162 0 02:42:00 5.622479E-05 2.726227E+02 2.726227E+02 1.751153E+12
(112,210,10) 1.725456E-02 1.036955E-02 2.343838E-01 7.783561E-01
163 0 02:43:00 5.638351E-05 2.726230E+02 2.726231E+02 1.751150E+12
(112,210,10) 1.771063E-02 1.036478E-02 2.154808E-01 7.815439E-01
164 0 02:44:00 5.655904E-05 2.726234E+02 2.726234E+02 1.751147E+12
(112,210,10) 1.819408E-02 1.036481E-02 1.922100E-01 7.844858E-01
165 0 02:45:00 5.675267E-05 2.726237E+02 2.726238E+02 1.751144E+12
(112,210,10) 1.863751E-02 1.036777E-02 1.713949E-01 7.915250E-01
166 0 02:46:00 5.696043E-05 2.726241E+02 2.726241E+02 1.751142E+12
(112,210,10) 1.896890E-02 1.037133E-02 1.589579E-01 8.058358E-01
167 0 02:47:00 5.717563E-05 2.726245E+02 2.726245E+02 1.751139E+12
(082,141,10) 2.918816E-02 9.888014E-03 1.595760E-01 8.206670E-01
168 0 02:48:00 5.739305E-05 2.726249E+02 2.726249E+02 1.751137E+12
(082,141,10) 2.945754E-02 9.885478E-03 1.788598E-01 8.334845E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000015
WRT_AVG - wrote averaged fields into time record = 0000014
169 0 02:49:00 5.761104E-05 2.726253E+02 2.726253E+02 1.751135E+12
(082,141,10) 2.955442E-02 9.880271E-03 1.950194E-01 8.423474E-01
170 0 02:50:00 5.782953E-05 2.726257E+02 2.726257E+02 1.751133E+12
(082,141,10) 2.946057E-02 9.875176E-03 2.055500E-01 8.463590E-01
171 0 02:51:00 5.804854E-05 2.726261E+02 2.726262E+02 1.751131E+12
(082,141,10) 2.920412E-02 9.872613E-03 2.095562E-01 8.457328E-01
172 0 02:52:00 5.826758E-05 2.726266E+02 2.726266E+02 1.751129E+12
(082,141,10) 2.884555E-02 9.873756E-03 2.077795E-01 8.415332E-01
173 0 02:53:00 5.848700E-05 2.726270E+02 2.726271E+02 1.751128E+12
(112,210,10) 1.829282E-02 1.036586E-02 2.129022E-01 8.351848E-01
174 0 02:54:00 5.870820E-05 2.726275E+02 2.726276E+02 1.751127E+12
(112,210,10) 1.856700E-02 1.036569E-02 2.108992E-01 8.279407E-01
175 0 02:55:00 5.893330E-05 2.726280E+02 2.726281E+02 1.751126E+12
(112,210,10) 1.894916E-02 1.036661E-02 2.065924E-01 8.204882E-01
176 0 02:56:00 5.916445E-05 2.726285E+02 2.726286E+02 1.751125E+12
(112,210,10) 1.932324E-02 1.036864E-02 2.011747E-01 8.128253E-01
177 0 02:57:00 5.940280E-05 2.726291E+02 2.726291E+02 1.751125E+12
(112,210,10) 1.958062E-02 1.037159E-02 1.957664E-01 8.044407E-01
178 0 02:58:00 5.964796E-05 2.726296E+02 2.726297E+02 1.751124E+12
(112,210,10) 1.965477E-02 1.037504E-02 1.913826E-01 7.946621E-01
179 0 02:59:00 5.989879E-05 2.726302E+02 2.726303E+02 1.751124E+12
(082,141,10) 2.671600E-02 9.885339E-03 1.824777E-01 7.843583E-01
180 0 03:00:00 6.015637E-05 2.726308E+02 2.726308E+02 1.751124E+12
(112,210,10) 1.927396E-02 1.038182E-02 1.874361E-01 7.868821E-01
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000016
WRT_AVG - wrote averaged fields into time record = 0000015
181 0 03:01:00 6.042319E-05 2.726314E+02 2.726314E+02 1.751124E+12
(112,210,10) 1.894734E-02 1.038502E-02 1.869362E-01 7.890049E-01
182 0 03:02:00 6.070212E-05 2.726320E+02 2.726321E+02 1.751125E+12
(112,210,10) 1.865415E-02 1.038867E-02 1.861691E-01 7.901968E-01
Node # 9 CPU: 84.043
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000003
Node # 0 CPU: 84.079
Node # 15 CPU: 84.044
Node # 1 CPU: 84.043
Node # 2 CPU: 84.043
Node # 3 CPU: 84.044
Node # 4 CPU: 84.044
Node # 5 CPU: 84.044
Node # 6 CPU: 84.044
Node # 7 CPU: 84.044
Node # 8 CPU: 84.044
Node # 10 CPU: 84.043
Node # 12 CPU: 84.044
Node # 11 CPU: 84.044
Node # 13 CPU: 84.043
Node # 14 CPU: 84.043
number of time records written in HISTORY file = 00000016
number of time records written in RESTART file = 00000016
number of time records written in AVERAGE file = 00000015
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_fsobc.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
ROMS/TOMS: DONE... Wednesday - March 29, 2017 - 11:39:30 PM
blowing up.
Input Script :
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
0 1 62 1 54 33480
1 63 125 1 54 34020
4 1 62 55 108 33480
HaloSizeI(1) = 150
HaloSizeJ(1) = 132
TileSide(1) = 69
TileSize(1) = 4140
- free-surface
- salinity
Re: Blowing-up: Saving latest model state into RESTART file
This falls under this FAQ. How is it going bad?
Dear Kate sir,kate wrote:This falls under this FAQ. How is it going bad?
I tried to change the discharge, and I find the small discharge would not occer with this problem, but the trend of the salinity is not correct like it should be.
the first picture is the location of 8 rivers, and the second picture is the gif I make from MATLAB.
Frame 1 of the movie is different, but it goes by so fast I can't tell what's in it.
When the rivers are full strength, how does it actually go bad? Too strong a velocity? How deep are the river inflow locations? What is the vertical profile of the inflow? Are you providing an inflow temperature as well?
Thank you for your answer, the depth of the river inflow location is 5m, and I define 10 layers in the whole vertical depth. I make a temperature gif also.kate wrote:Frame 1 of the movie is different, but it goes by so fast I can't tell what's in it.
Now I want to know that, if I use the make_bry.m to make a boundary file, what parameter should I define in the .h file, because when I run this model, I couldn't find the 'bry.nc' in the list of input files. Thank you very much!
- 温度s.gif (1.47 MiB) Viewed 12991 times
The model will read the boundary file (or not) based on the value of the LBC boundary options. I use RadNud for 3d fields and a combination of Cha/Fla or Che/Shc for the 2d fields. Those will need boundary values.
Thank you very much, and I want you to check that how I set of the boundary condition, and what I write in that 'zhujiang.in' file. But my program blowing up , and I couldn't find the 'bry.nc' file in the log file. I don't know why. So I think if I had missed define something in the '.h' file.kate wrote:The model will read the boundary file (or not) based on the value of the LBC boundary options. I use RadNud for 3d fields and a combination of Cha/Fla or Che/Shc for the 2d fields. Those will need boundary values.
The Cha/Fla combo won't read your boundary file with these:
because you are using analytic fsobc and m2obc.Analytical header files used:
Yes, I had thought that reation, but if I delete the #define ana_btflux , it would error, and mention missing btflux.kate wrote:The Cha/Fla combo won't read your boundary file with these:because you are using analytic fsobc and m2obc.Analytical header files used:
So, if I don't define ana_btflux, what should I define in '.h' file?
Sorry, yes, you need ana_btflux for bottom temperature fluxes. What open boundary fields are you providing?
Sorry to bother you. This is my '.h' file, please help me check out if it is reasonable! Thank you very much!kate wrote:Sorry, yes, you need ana_btflux for bottom temperature fluxes. What open boundary fields are you providing?
#define UV_ADV /* Advection of momentum */
#define UV_COR /* Coriolis term */
#define UV_QDRAG /* Use quadratic bottom drag law */
#define UV_VIS2 /* Harmonic mixing of momentum */
#define DJ_GRADPS /* Splines Density Jacobian */
#define MIX_S_TS /* Mixing of tracers along constant S-surfaces */
#define TS_DIF2 /* Harmonic mixing of tracers */
#define TS_U3HADVECTION /* Third-order upstream horizontal advection of tracers */
#define TS_C4VADVECTION /* Fourth-order centered vertical advection of tracers */
#define NONLINEAR
#define SOLVE3D /* Solving 3D Primitive Equations */
#define SALINITY /* Using salinity */
#define NONLIN_EOS /* Nonlinear Equation of State for seawater */
#define SPHERICAL /* Define if lat/lon coordinates rather than x/y */
#define SPLINES
#define MASKING /* Land/Sea masking */
#define AVERAGES /* ?Define to write out time-averaged model fields */
/*#define RADIATION_2D */
/*#define FULL_GRID */
** Vertical Mixing parameterization
#define MY25_MIXING
/*#define LMD_MIXING*/
#ifdef LMD_MIXING
# define LMD_RIMIX /* LMD diffusivity due to shear instability */
# define LMD_CONVEC /* LMD convective mixing due to shear instability */
# define LMD_SKPP /* KPP surface boundary layer mixing */
# define LMD_NONLOCAL /* LMD convective nonlocal transport */
#if defined GLS_MIXING
# define CHARNOK /* Charnok Surface Roughness From Wind Stress */
# define CRAIG_BANNER /* Craig and Banner Wave Breaking Surface Flux */
# define KANTHA_CLAYSON /* Kantha and Clayson stability function */
# define N2S2_HORAVG /* Horizontal Smoothing of Buoyancy/Shea */
# define CANUTO_A
#if defined MY25_MIXING
# define KANTHA_CLAYSON /* Define for Kantha and Clayson stability function. */
# define K_C2ADVECTION /* Define for 2th-order centered advection. */
# define K_C4ADVECTION /* Define for 4th-order centered advection. */
**Bottom boundary condition settings
#define ANA_BTFLUX / Analytical kinematic bottom temperature flux
#define ANA_BSFLUX / Analytical kinematic bottom salinity flux
#undef RADITION 2D
#define ANA_SMFLUX
/* Analytical kinematic surface temperature flux */
#define ANA_SSFLUX /* analytical surface salt flux defaults to zero */
#define QCORRECTION
#define SOLAR_SOURCE
/*#undef PSOURCE
/* #define ANA_PSOURCE
/* #define TS_PSOURCE
#define UV_PROURCE
**define UV_TIDES to specify boundary tidal currents from data e.g. ADCIRC
** undef UV_TIDES to compute tidal currents using reduced physics
#define RAMP_TIDES
#define SSH_TIDES /* read tidal SSH from file */
#undef UV_TIDES /* read tidal U and V from file */
#define FSOBC_REDUCED
#define ANA_FSOBC
#define ANA_M2OBC
#ifdef SSH_TIDES
# define ADD_FSOBC
#ifdef UV_TIDES
# undef FSOBC_REDUCED /* boundary pg is calculated using bounday zeta */
# define ADD_M2OBC
/* If you define SPONGE or allow for a nudging layer at the boundaries,
** you need to provide the appropriate "ana_hmixcoef.h" and "ana_nudgcoef.h"
** for your application. See examples in ROMS/Func
#undef SPONGE /* Define to use SSH climatology as 2D inflow */
And, what should I set without CHA/FLA to the boundary condition, then it will read the boundary file?kate wrote:The Cha/Fla combo won't read your boundary file with these:because you are using analytic fsobc and m2obc.Analytical header files used:
Or, I still change the '.h' file to fix it?
How to change it?
Thank you!
Again, what do you want it to be doing? For which fields are you providing boundary values?
I see you have tidal elevations but not tidal currents. Better to provide both if you can - the tidal models I use have the currents.
This is likely to ask for a forcing file:because you dropped ANA_STFLUX. You also don't have ANA_DQDSST - the QCORRECTION will be wanting a dqdsst, whether analytically or via a file.
This is not from the latest version of ROMS. Not a big deal, but make sure you are consistent.
So, there's no spell checker on these things. You commented out RADIATION_2D already (why?). This line is not doing anything because RADITION is not checked and the 2D will be a separate token here.
#define ANA_SMFLUX
#define QCORRECTION
#define SPLINES
#undef RADITION 2D
[quote="kate"]Again, what do you want it to be doing? For which fields are you providing boundary values?
I changed my definition of the boundary condition from 'Rad' to 'RadNud', then it will read the boundary file.
And it blew up because the position of the river is incorrect, and it's okay now.
Thank you again.
Now, I have a question, how to run the ROMS from the last step I had the last test? Like I had 20160101-20160107, I want to start from 20160107 or 20160108 directly.
Thank you again.
This should be a FAQ - maybe later.
You need to change several things in the ocean.in file:
* NTIMES for a later end time.
* NRREC to one of 1, 2, -1, depending - read up on it at the bottom of ocean.in.
* Maybe LDEFOUT, depending.
* ININAME to point to the restart file.
Dear kate;
These days I met a problem, this is what in the log file, and there apper 'nan', I want to know if this is the point cause the blew up. and, what should I do to get it good?
Thank you very much.
0 0 00:00:00 NaN 2.766056E+02 NaN 1.696651E+12
(249,155,10) 5.357870E-08 0.000000E+00 0.000000E+00 0.000000E+00
Node # 0 CPU: 0.654
Node # 1 CPU: 0.634
Node # 5 CPU: 0.614
Node # 7 CPU: 0.612
Node # 12 CPU: 0.612
Node # 9 CPU: 0.614
Node # 10 CPU: 0.614
Node # 11 CPU: 0.612
Node # 13 CPU: 0.614
Node # 0 CPU: 0.654
Node # 1 CPU: 0.634
Node # 5 CPU: 0.614
Node # 7 CPU: 0.612
Node # 9 CPU: 0.614
This is happening before your first timestep. You need to look at your initial conditions file.
Thank you, very much, I noticed that,'KINETIC_ENRG' and 'TOTAL_ENRG' are 'NAN', so what should I do to aviod that?kate wrote:This is happening before your first timestep. You need to look at your initial conditions file.
[imgh=][/imgh]kate wrote:This is happening before your first timestep. You need to look at your initial conditions file.
Dear kate;
Sorry to bother you so much.
I check my '.in' file, and when I changed the boundary condition from 'RADNUD' to 'Rad', it would be ok, but that would not read 'bry.nc' file. So, I think that the 'bry' I made was wrong, if you could send me some '.m' file to make 'bry.nc' file. Thank you very much!
My email is lizhaoqin@stu.ouc.edu.cn
- QQ截图20170511220544.jpg (25.36 KiB) Viewed 12644 times
Do you have the official ROMS Matlab tools? There are actually two sets, one from myroms.org, one from the French croco team. I can't help you with either, however.
