stability criterion
nmichelet
stability criterion
#1 Unread post by nmichelet »
I have a question about the stability criterion in ROMS. I have found that there is a CFL criterion which is calculate with 2D time step like :
CFL = sqrt(gh)*Delta_t2d*sqrt(Delta_x^-2+Delta_y^-2)
And this CFL has to be lower than 1/2. But is there a stability criterion which is calculated with 3D time step? If yes, what is it's formulation?
lfparejar
Re: stability criterion
#2 Unread post by lfparejar »
As far as I know, the CFL criterion (or C) is calculated for u, v and w in ROMS.
This is a somewhat old page on that topic but I think it's the same now?
https://www.myroms.org/projects/src/ticket/486
C = Cu + Cv + Cw
where
Cu = ABS(u(i,j,k) + u(i+1,j,k)) * dt * pm(i,j)
Cv = ABS(v(i,j,k) + v(i,j+1,k)) * dt * pn(i,j)
Cw = ABS(wvel(i,j,k-1) + wvel(i,j,k)) * dt * Hz(i,j,k)
You can see the maximum Cu, Cv and Cw it in the log file and also the (i,j,k) location for said Cs:
960 40 00:00:00 8.657897E-04 1.948261E+04 1.948261E+04 2.182663E+17
(096,125,01) 9.919103E-03 4.299619E-03 1.211318E-02 1.049095E+00
nmichelet
#3 Unread post by nmichelet »
Thanks a lot this is very helpfull
