Error when running ./oceanO
lalvarez
#1 Unread post by lalvarez »
Hello there
I'm having a problem that has never shown before and it goes like this
lalvarez@lalvarez-H61MLV ~/roms/Projects/Leo $ ./oceanO < leo.in > Out16.txt
*** Error in `./oceanO': malloc(): memory corruption: 0x0000000005a12490 ***
Program received signal SIGABRT: Process abort signal.
Backtrace for this error:
and then it stops.
I enclose here the *.txt, *.in & *.h files....really have no clue about what happend
Can anyone give me a hint on what could it be?
leo.h
(4.33 KiB) Downloaded 608 times
leo.in
(120.18 KiB) Downloaded 602 times
Out16.txt
(7.97 KiB) Downloaded 678 times
Re: Error when running ./oceanO
I would recompile with USE_DEBUG=on and run it again (oceanG this time). You might get a more informative stack trace or you might get an array out-of-bounds error instead.
lalvarez
#3 Unread post by lalvarez »
Hello Kate t
Thanks a lot for your answer, i've try what You suggest and got this
At line 117 of file read_fltpar.f90
Fortran runtime error: Index '602' of dimension 1 of array 'fcoor' above upper bound of 601
What must I check now, shall I check my Floats File?
Have a nice weekend
Yes, check the floats file. Here is where Fcoor is allocated:
     Npts=Nfloats(1)+1
 ...         allocate ( Fcoor (Npts,Ngrids) )
Are you providing more than 600 float locations?
lalvarez
#5 Unread post by lalvarez »
Hello Kate
I found what the problem was in my floats file, after the latitude data comes the depth of the floats and one (-) was absent. When corrected it has run smothlly
Thanks a lot
