make caught in infinite loop
stef
#1 Unread post by stef »
I'm trying to run the upwelling example, and make gets caught in an infinite loop.
To reproduce:
I change the compiler and netcdf paths in the makefile:
>> diff makefile path/to/original/makefile
142c142
<         FORT ?= gfortran
>         FORT ?= pgi
312,313c312,313
<    NETCDF_MODFILE := ../../include/netcdf.mod
< TYPESIZES_MODFILE := ../../include/typesizes.mod
>    NETCDF_MODFILE := netcdf.mod
> TYPESIZES_MODFILE := typesizes.mod
When I run “make”, there is an infinite loop
makefile:239: INCLUDING FILE /home/stefan/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE
DEFINITIONS
cp -f /usr/local/include/../../include/netcdf.mod Build
cp -f /usr/local/include/../../include/typesizes.mod Build
./ROMS/Bin/sfmakedepend …. > Build/MakeDepend
cp -p /home/stefan/make_macros.mk Build
makefile:235: INCLUDING FILE Build/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINIT
IONS
Note that after sfmakedepend is redirected to Build/MakeDepend, it starts from the beginning. I can fix it by commenting out the line
$(SFMAKEDEPEND) $(MDEPFLAGS) $(sources) > $(SCRATCH_DIR)/MakeDepend
in the
target, and running
make depend
make
Is there something wrong with the makefile, or with what I'm doing? I haven't worked with ROMS in ages....
Using GNU Make 4.2.1, GNU bash 4.3.46 on
Linux 4.7.4-1-ARCH x86_64 GNU/Linux
Thanks for your help, Stefan
Re: make caught in infinite loop
There is something funny about what you are doing:
This is going to copy /usr/include/netcdf.mod into Build. I guess that file exists since it didn't fail. However, make knows that you still don't have Build/../../include/netcdf.mod so it tries to create it again. This is the make rule you should be looking at:
$(SCRATCH_DIR)/$(NETCDF_MODFILE): | $(SCRATCH_DIR)
        cp -f $(NETCDF_INCDIR)/$(NETCDF_MODFILE) $(SCRATCH_DIR)
stef
#3 Unread post by stef »
That's it, thanks. Setting the right path in the platform dependent file solves it!
On a side note, this still leaves me wondering why the line after the prerequisites is executed (sfmakedepend), if the prerequisites are not fulfilled? Not urgent, though.
