Parallel simulation of ROMS killed after using too much RAM
rgawde
#1 Unread post by rgawde »
I am trying to run the ROMS model for the Choptank River system. It has been compiled using ifort and a test run for the year 2010 was set up. The simulation does not face any problems in serial mode but after executing it in parallel using the command line,
mpirun -np 8 ./oceanM choproms.in > myrun.log &
the model runs successfully upto about 24,000 timesteps. However, after this point, the run is simply killed giving the error:
24778 11051.86782 1.087116E-02 5.255789E+01 5.256876E+01 9.304978E+09 0
24779 11051.86794 1.088490E-02 5.255786E+01 5.256874E+01 9.304784E+09 0
24780 11051.86806 1.089875E-02 5.255783E+01 5.256873E+01 9.304592E+09 0
mpirun noticed that process rank 1 with PID 25824 on node cbeps2 exited on signal 9 (Killed).
This was accompanied by a message - "memory space (RAM) on server exceeded". The server actually supports 128GB of RAM with 24 processors. It seems to be a problem with processing in parallel mode but I'm not sure where to go with this. Could anyone please help with this error? Has anyone else experienced this before?
Thanks!
