I have recently used a new version of fortran compiler. The ROMS compilation succeed but when i run:
mpirun -np 4 ./oceanM ocean3gridnest.in
the following error occurs:
At line 919 of file inp_par.f90
Fortran runtime error: Bad integer for item 1 in list input
This line corresponds to :
READ (Vstring(is:Imul(ic)-1),*) copies
in inp_par.f90
The inp_par.F is compiled as follow :
cd Build; /usr/bin/mpif90 -c -frepack-arrays -O3 -ffast-math inp_par.f90
It seems that it can't read string character from input file!
has anyone an idea to resolve this problem?
Fortran error after succeeding roms compilation
Re: Fortran error after succeeding roms compilation
Can you go back to an older compiler? Which compiler is it exactly? What version number?
If the compiler really is failing on good input, I would want to know which input line it is failing on and what it contains. Is this a problem only with multiple grids?
- Location: Institut Préparatoire aux études d'ingénieurs de T
Thanks kate for your reply!
Unfortunately I can't go back on previous version of compiler. I've changed the opensuse kerf's version (from 11.3 to 13.1)and within this change comes an upgraded version of gfortran,gcc and gcc-fortran (the oldest version of gcc, gcc-fortran and gfortran are 4.6.2 and now the newest ones are 4.8.2).
I get the same error message and in the same line in inp_par.F. Even if I use mpi or openmp , simple or multiple grid. The error message is the same and occurs always in this line of the code:
inp_par.f90
- the errot occurs in line 919
- (72.56 KiB) Downloaded 536 times
It's probably failing the first time through. Can you have it print Vstring, is, lmul and copies before that line? (I would of course run in the debugger...) Have you tried a lower level of compiler optimization?
HEllo kate!
Thanks again for your reply. I 've just discovered that the new version of compiler recognize differently space and tab in my input file ocean.in.
I replaced tab by spaces and it works now!!
Thanks again for your help
