Bug in nesting when MASKING not defined
jpringle
#1 Unread post by jpringle »
In the latest ROMS, the model does not compile when NESTING is defined but MASKING is not. The error is minor; mask_hweights is always defined at the top of nesting.F even when MASKING is on. The fix is straightforward:
*** nesting.F_old	2015-08-18 10:49:28.000000000 -0400
--- nesting.F	2015-08-18 10:40:01.000000000 -0400
*** 119,125 ****
--- 119,127 ----
        PRIVATE :: get_metrics
        PRIVATE :: get_persisted2d
        PRIVATE :: get_refine
+ # ifdef MASKING
        PRIVATE :: mask_hweights
+ # endif
        PRIVATE :: put_composite
        PRIVATE :: put_refine
        PRIVATE :: put_refine2d
Jamie
Re: Bug in nesting when MASKING not defined
Yep, good catch. Thank yTo be precise we need instead:
# if defined MASKING || defined WET_DRY
I will update the code today.
