More than one river
caking
More than one river
#1 Unread post by caking »
I am a new user to ROMS. I am having trouble turning on multiple rivers. I believe that I have the correct positioning. However, when I look at my output I only see salinity decreases near the mouth of 1 river. I should have 12 different rivers coming into my model. I was wondering if there is any specific setting in the ocean.in file I need to change such as the
LuvSrc == T ! horizontal momentum transport
LtracerSrc == T T ! temperature, salinity, inert
or is there a CPPdefs.h header I need to add for sources and sinks so that multiple sources are turned on. Or is there a variable some where that specifies the number of rivers?
Thank you,
Christina
Re: More than one river
#2 Unread post by wilkin »
Last year I wrote a Wiki ROMS entry about rivers because a number of people were having trouble getting them to work easily. That entry is here:
https://www.myroms.org/wiki/index.php/River_Runoff
The most common mistake that users make (we have all done it) is to misplace a source with the respect to the land/sea mask because of the way ROMS indexes u- and v-points on the C-grid. The diagram in the Wiki entry might help.
#3 Unread post by kate »
I have a domain with over 5000 rivers, so I didn't want to do it all by hand. I converted the last bit of code from C++ to Python, so it is now here.
caking
#4 Unread post by caking »
You were right, I had a majority of the rivers in wrong location. Seems to be working now.
