blowing up after run 4285 time-steps
fannyzhang
#1 Unread post by fannyzhang »
Hi everyone!
I run a Gulf of Mexico case. It is blowing-up at the 4285th time-step. And I have no idea why it blew up.
Here is the running log file:
Resolution, Grid 01: 0179x0134x015, Parallel Nodes: 2, Tiling: 002x001
8640 ntimes Number of timesteps for 3-D equations.
600.000 dt Timestep size (s) for 3-D equations.
F LcycleRST Switch to recycle time-records in restart file.
144 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
144 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
1440 nAVG Number of timesteps between the writing of
5.0000E+01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
5.0000E+01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
1.0000E+02 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
1 lmd_Jwt Jerlov water type.
2 Vstretching S-coordinate stretching function.
7.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E-01 theta_b S-coordinate bottom control parameter.
100.000 Tcline S-coordinate surface/bottom layer width (m) used
20130801.00 time_ref Reference time for units attribute (yyyymmdd.dd)
1.2000E+02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
for 3D momentum.
T VolCons(1) NLM western edge boundary volume conservation.
T VolCons(2) NLM southern edge boundary volume conservation.
T LtracerCLM(01) Turning ON processing of climatology tracer 01: temp
T LtracerCLM(02) Turning ON processing of climatology tracer 02: salt
T Hout(idTsur) Write out surface net heat flux.
T Hout(idTsur) Write out surface net salt flux.
T Hout(idSrad) Write out shortwave radiation flux.
T Hout(idHsbl) Write out depth of surface boundary layer.
Output Restart File: output_data/mexico_rst_03.nc
Output History File: output_data/mexico_his_03.nc
Output Averages File: output_data/mexico_avg_03.nc
Input Grid File: input_data/t0303_smth9_grid.nc
Input Nonlinear Initial File: input_data/t0303_ini.nc
Input Forcing File 01: input_data/gom_shflux_era_12.nc
Input Forcing File 02: input_data/gom_sms_era_12.nc
Input Forcing File 03: input_data/gom_swflux_era_12.nc
Input Forcing File 04: input_data/gom_swrad_era_12.nc
Input Forcing File 05: input_data/gom_SST_era.nc
Input Climatology File: input_data/t0303_clm.nc
Input Boundary File: input_data/t0303_bry.nc
Tile partition information for Grid 01: 0179x0134x0015 tiling: 002x001
tile Istr Iend Jstr Jend Npts
0 1 90 1 134 180900
1 91 179 1 134 178890
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 90.50 0.50 134.50 RHO-points
1 90.50 179.50 0.50 134.50 RHO-points
0 1.00 90.50 0.50 134.50 U-points
1 90.50 179.00 0.50 134.50 U-points
0 0.50 90.50 1.00 134.00 V-points
1 90.50 179.50 1.00 134.00 V-points
HaloSizeI(1) = 306
HaloSizeJ(1) = 435
TileSide(1) = 139
TileSize(1) = 13344
zeta 1 Closed Gradient Gradient Closed
ubar 1 Closed Clamped Clamped Closed
vbar 1 Closed Clamped Clamped Closed
u 1 Closed Clamped Clamped Closed
v 1 Closed Clamped Clamped Closed
temp 1 Closed Clamped Clamped Closed
salt 1 Closed Clamped Clamped Closed
MEXICO Mexico
ANA_DQDSST Analytical surface heat flux sensitivity to SST.
DIFF_GRID Horizontal diffusion coefficient scaled by grid size.
DIURNAL_SRFLUX Modulate shortwave radiation by the local diurnal cycle.
LMD_CONVEC LMD convective mixing due to shear instability.
LMD_MIXING Large/McWilliams/Doney interior mixing.
LMD_NONLOCAL LMD convective nonlocal transport.
LMD_RIMIX LMD diffusivity due to shear instability.
LMD_SKPP KPP surface boundary layer mixing.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
PERFECT_RESTART Processing perfect restart variables.
QCORRECTION Surface net heat flux correction.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
VISC_GRID Horizontal viscosity coefficient scaled by grid size.
Process Information:
Node # 0 (pid= 19663) is active.
Node # 1 (pid= 19664) is active.
15 0.0000000 0.0000000 0.000 0.000 0.000 0.000
14 -0.0666667 -0.0004989 2.218 -3.358 -7.756 -9.254
13 -0.1333333 -0.0032168 4.418 -6.828 -21.397 -30.545
12 -0.2000000 -0.0100379 6.583 -10.502 -45.920 -74.091
11 -0.2666667 -0.0229247 8.698 -14.480 -86.531 -150.539
10 -0.3333333 -0.0439342 10.745 -18.863 -148.685 -271.046
9 -0.4000000 -0.0752335 12.706 -23.762 -238.129 -447.365
8 -0.4666667 -0.1191055 14.563 -29.289 -360.919 -691.881
7 -0.5333333 -0.1779212 16.295 -35.563 -523.342 -1017.453
6 -0.6000000 -0.2540303 17.883 -42.702 -731.630 -1436.828
5 -0.6666667 -0.3494770 19.310 -50.807 -991.205 -1961.091
4 -0.7333333 -0.4653579 20.566 -59.935 -1304.976 -2596.193
3 -0.8000000 -0.6004851 21.663 -70.024 -1669.791 -3335.689
2 -0.8666667 -0.7487245 22.650 -80.770 -2069.383 -4146.308
1 -0.9333333 -0.8938704 23.662 -91.360 -2460.770 -4940.147
0 -1.0000000 -1.0000000 25.000 -100.000 -2748.678 -5522.356
12 0.0043042707117221 0.0335513677379153-0.0022367614257356 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864348 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001213 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565097 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906204 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716643 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402368 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399432 0.6603333185976138
21 0.0256737146312911 0.0297153720153352 0.1342125541712342 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524359 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729578 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236653 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893981 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886213 0.8237939964192927
27 0.0432936737565710 0.0230872677537126 0.3506756411451924 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772280 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880565 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442384 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256415 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325521 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348098 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479478 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213239 0.9738247715198165
36 0.0503158038019030 0.0080591141492892 0.8085423793232269 0.9818838856691057
37 0.0473537721847154 0.0063819206892258 0.8558961515079423 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497611 0.9930692679747334
39 0.0376397765791564 0.0033640675316746 0.9367177506289175 0.9964333355064080
40 0.0305543017255206 0.0021094083123694 0.9672720523544381 0.9985427438187774
41 0.0217382098544504 0.0010909315881854 0.9890102622088885 0.9996336754069628
42 0.0109897377911118 0.0003663245930371 1.0000000000000000 0.9999999999999999
Minimum X-grid spacing, DXmin = 9.53173644E+00 km
Maximum X-grid spacing, DXmax = 1.06053729E+01 km
Minimum Y-grid spacing, DYmin = 1.11200424E+01 km
Maximum Y-grid spacing, DYmax = 1.11200424E+01 km
Minimum Z-grid spacing, DZmin = -2.21806494E+00 m
Maximum Z-grid spacing, DZmax = 8.10618752E+02 m
Minimum barotropic Courant Number = 3.66226057E-02
Maximum barotropic Courant Number = 6.06729077E-01
Maximum Coriolis Courant Number = 4.45309430E-02
Horizontal mixing scaled by grid size, GRDMAX = 1.08596592E+01 km
(Grid 01, File: t0303_ini.nc, Rec=0001, Index=1)
- free-surface
(Min = -9.41191056E-02 Max = 5.66728856E-01)
(Min = -1.53128034E-01 Max = 3.58059365E-01)
(Min = -4.51806903E-02 Max = 5.25055491E-01)
- u-momentum component
(Min = -3.83800638E-01 Max = 3.66731936E-01)
- v-momentum component
(Min = -1.24178428E-01 Max = 5.96819757E-01)
- potential temperature
(Min = 0.00000000E+00 Max = 3.00954853E+01)
- salinity
(Min = 0.00000000E+00 Max = 3.68432644E+01)
GET_2DFLD - surface u-momentum stress, t = 0 **:**:00
(Rec=0000248, Index=1, File: gom_sms_era_12.nc)
(Tmin= -30.9375 Tmax= 91.9375)
(Min = -6.28735473E-04 Max = 1.13510756E-04)
GET_2DFLD - surface v-momentum stress, t = 0 **:**:00
(Min = -3.79535163E-04 Max = 3.32130543E-04)
GET_2DFLD - solar shortwave radiation flux, t = 0 **:**:00
(Rec=0000248, Index=1, File: gom_swrad_era_12.nc)
(Min = 1.74109873E-05 Max = 1.17213358E-04)
GET_2DFLD - surface net heat flux, t = 0 **:**:00
(Rec=0000248, Index=1, File: gom_shflux_era_12.nc)
(Min = -1.49345902E-05 Max = 8.47850475E-05)
GET_2DFLD - sea surface temperature climatology, t = 0 00:00:00
(Rec=0000063, Index=1, File: gom_SST_era.nc)
(Tmin= -31.0000 Tmax= 92.0000)
(Min = 5.01014471E+00 Max = 3.08119125E+01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 0 00:00:00
(Rec=0000002, Index=2, File: t0303_bry.nc)
(Tmin= -31.0000 Tmax= 61.0000)
(Min = -8.05667788E-03 Max = 2.80851156E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 0 00:00:00
(Min = -2.07083095E-02 Max = 5.28398715E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 0 00:00:00
(Min = -1.15728527E-01 Max = 1.95017345E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 0 00:00:00
(Min = -2.07083095E-02 Max = 7.89264739E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 0 00:00:00
(Min = -1.46516804E-02 Max = 3.48577231E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 0 00:00:00
(Min = -1.23747356E-01 Max = 8.88440236E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 0 00:00:00
(Min = -3.88944149E-01 Max = 5.51934391E-02)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 0 00:00:00
(Min = -1.17037132E-01 Max = 2.46601552E-01)
GET_NGFLD - temperature eastern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 3.00768490E+01)
GET_NGFLD - salinity eastern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 3.66071701E+01)
GET_NGFLD - temperature southern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 2.94918575E+01)
GET_NGFLD - salinity southern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 3.66492538E+01)
GET_3DFLD - potential temperature climatology, t = 0 00:00:00
(Rec=0000002, Index=1, File: t0303_clm.nc)
GET_3DFLD - salinity climatology, t = 0 00:00:00
Maximum grid stiffness ratios: rx0 = 5.842748E-01 (Beckmann and Haidvogel)
rx1 = 1.225403E+01 (Haney)
Initial basin volumes: TotVolume = 3.4707308962E+15 m3
MinVolume = 1.1843849025E+08 m3
MaxVolume = 9.5545296460E+10 m3
Max/Min = 8.0670815931E+02
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00008640)
GET_2DFLD - surface u-momentum stress, t = 0 01:30:00
(Rec=0000249, Index=2, File: gom_sms_era_12.nc)
(Min = -3.73395788E-04 Max = 4.19573827E-05)
GET_2DFLD - surface v-momentum stress, t = 0 01:30:00
(Min = -8.77013259E-05 Max = 2.52759311E-04)
GET_2DFLD - solar shortwave radiation flux, t = 0 01:30:00
(Rec=0000249, Index=2, File: gom_swrad_era_12.nc)
(Min = 0.00000000E+00 Max = 6.80798259E-06)
GET_2DFLD - surface net heat flux, t = 0 01:30:00
(Rec=0000249, Index=2, File: gom_shflux_era_12.nc)
(Min = -6.63252940E-05 Max = -5.63216467E-06)
GET_2DFLD - sea surface temperature climatology, t = 0 12:00:00
(Rec=0000064, Index=2, File: gom_SST_era.nc)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 31 00:00:00
(Rec=0000003, Index=1, File: t0303_bry.nc)
(Min = -4.73714434E-03 Max = 2.51743019E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 31 00:00:00
(Min = -2.11681854E-02 Max = 5.89200519E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 31 00:00:00
(Min = -1.27171963E-01 Max = 1.79775469E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 31 00:00:00
(Min = -2.11681854E-02 Max = 8.94291550E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 31 00:00:00
(Min = -1.62272770E-02 Max = 3.11885953E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 31 00:00:00
(Min = -1.14472292E-01 Max = 7.79567361E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 31 00:00:00
(Min = -3.80327731E-01 Max = 3.59288864E-02)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 31 00:00:00
(Min = -1.13985889E-01 Max = 2.92329460E-01)
GET_NGFLD - temperature eastern boundary condition, t = 31 00:00:00
(Min = 0.00000000E+00 Max = 2.99025517E+01)
GET_NGFLD - salinity eastern boundary condition, t = 31 00:00:00
(Min = 0.00000000E+00 Max = 3.65748367E+01)
GET_NGFLD - temperature southern boundary condition, t = 31 00:00:00
(Min = 0.00000000E+00 Max = 2.96639423E+01)
GET_NGFLD - salinity southern boundary condition, t = 31 00:00:00
(Min = 0.00000000E+00 Max = 3.66007767E+01)
GET_3DFLD - potential temperature climatology, t = 31 00:00:00
(Rec=0000003, Index=2, File: t0303_clm.nc)
(Min = 0.00000000E+00 Max = 2.99627298E+01)
GET_3DFLD - salinity climatology, t = 31 00:00:00
(Min = 0.00000000E+00 Max = 3.66464908E+01)
0 0 00:00:00 8.373425E-04 1.555623E+04 1.555623E+04 3.450651E+15
(130,029,14) 1.440493E-02 2.934347E-02 0.000000E+00 6.239570E-01
DEF_HIS - creating history file, Grid 01: output_data/mexico_his_03.nc
DEF_AVG - creating average file, Grid 01: output_data/mexico_avg_03.nc
1 0 00:10:00 8.201037E-04 1.555612E+04 1.555612E+04 3.450642E+15
(123,038,01) 1.015407E-02 2.403806E-02 1.050709E-01 6.799810E-01
2 0 00:20:00 8.348257E-04 1.555605E+04 1.555605E+04 3.450632E+15
(109,009,15) 3.478563E-02 1.430757E-02 4.279355E-01 7.247020E-01
3 0 00:30:00 8.549379E-04 1.555599E+04 1.555599E+04 3.450623E+15
(108,009,15) 1.662098E-02 7.813799E-03 6.510960E-01 6.572079E-01
4 0 00:40:00 8.785594E-04 1.555595E+04 1.555595E+04 3.450613E+15
(109,009,15) 9.408465E-03 2.974762E-04 8.512362E-01 6.707246E-01
5 0 00:50:00 9.006629E-04 1.555594E+04 1.555595E+04 3.450604E+15
(108,009,15) 1.312489E-02 2.784656E-03 8.825336E-01 6.965441E-01
6 0 01:00:00 9.237621E-04 1.555593E+04 1.555594E+04 3.450595E+15
(109,009,15) 3.017856E-03 2.323845E-03 7.446584E-01 7.146092E-01
7 0 01:10:00 9.415762E-04 1.555588E+04 1.555588E+04 3.450585E+15
(108,010,15) 9.267883E-03 2.859104E-03 1.083121E+00 7.439257E-01
8 0 01:20:00 9.525200E-04 1.555583E+04 1.555583E+04 3.450576E+15
(109,010,15) 8.705311E-03 2.679885E-02 1.039416E+00 7.574351E-01
9 0 01:30:00 9.649829E-04 1.555580E+04 1.555580E+04 3.450566E+15
(108,009,15) 8.934994E-03 3.190377E-03 7.714740E-01 8.540037E-01
GET_2DFLD - surface u-momentum stress, t = 0 04:30:00
(Rec=0000250, Index=1, File: gom_sms_era_12.nc)
(Min = -1.73625312E-04 Max = 7.04354789E-05)
GET_2DFLD - surface v-momentum stress, t = 0 04:30:00
(Min = -6.42496638E-05 Max = 2.49396039E-04)
GET_2DFLD - solar shortwave radiation flux, t = 0 04:30:00
(Rec=0000250, Index=1, File: gom_swrad_era_12.nc)
(Min = -9.60765239E-09 Max = 9.60765239E-09)
GET_2DFLD - surface net heat flux, t = 0 04:30:00
(Rec=0000250, Index=1, File: gom_shflux_era_12.nc)
(Min = -6.87354444E-05 Max = -4.80841693E-06)
10 0 01:40:00 9.780003E-04 1.555577E+04 1.555578E+04 3.450557E+15
(109,011,15) 0.000000E+00 3.552180E-02 9.788387E-01 7.747634E-01
11 0 01:50:00 9.900710E-04 1.555575E+04 1.555575E+04 3.450547E+15
(109,012,15) 0.000000E+00 1.793685E-02 5.304011E-01 7.786198E-01
12 0 02:00:00 1.005203E-03 1.555573E+04 1.555573E+04 3.450538E+15
(109,010,15) 4.731156E-03 2.215677E-02 8.174260E-01 7.803961E-01
13 0 02:10:00 1.023734E-03 1.555570E+04 1.555571E+04 3.450528E+15
(109,009,15) 2.256130E-02 7.324817E-03 5.892840E-01 7.804574E-01
14 0 02:20:00 1.043117E-03 1.555569E+04 1.555569E+04 3.450519E+15
(108,009,15) 1.160801E-02 2.009693E-03 9.553634E-01 7.780441E-01
15 0 02:30:00 1.063154E-03 1.555569E+04 1.555570E+04 3.450509E+15
(108,009,15) 1.509686E-03 1.154925E-02 4.800190E-01 7.810754E-01
16 0 02:40:00 1.085991E-03 1.555571E+04 1.555571E+04 3.450500E+15
(108,010,15) 2.713017E-03 4.185126E-03 6.845616E-01 7.843168E-01
17 0 02:50:00 1.110530E-03 1.555572E+04 1.555572E+04 3.450490E+15
(108,009,15) 2.063445E-04 1.150062E-02 4.048985E-01 7.844606E-01
18 0 03:00:00 1.136734E-03 1.555572E+04 1.555572E+04 3.450481E+15
(112,041,15) 3.718473E-03 9.559786E-03 5.115687E-01 7.928745E-01
19 0 03:10:00 1.163579E-03 1.555572E+04 1.555573E+04 3.450471E+15
(108,010,15) 1.479228E-03 1.621168E-03 5.293445E-01 7.972300E-01
20 0 03:20:00 1.190078E-03 1.555573E+04 1.555573E+04 3.450462E+15
(108,009,15) 1.727800E-02 2.088589E-03 4.869233E-01 8.068215E-01
21 0 03:30:00 1.215185E-03 1.555574E+04 1.555574E+04 3.450452E+15
(108,009,15) 8.085104E-03 8.416320E-03 8.837520E-01 8.152721E-01
22 0 03:40:00 1.239452E-03 1.555577E+04 1.555577E+04 3.450443E+15
(112,041,15) 7.628623E-03 2.022114E-03 4.900574E-01 8.178964E-01
23 0 03:50:00 1.262438E-03 1.555581E+04 1.555581E+04 3.450433E+15
(108,010,15) 3.770898E-03 7.659892E-03 4.374833E-01 8.187403E-01
24 0 04:00:00 1.284244E-03 1.555583E+04 1.555583E+04 3.450424E+15
(109,010,15) 2.293186E-03 2.664022E-02 3.373776E-01 8.203904E-01
25 0 04:10:00 1.305861E-03 1.555585E+04 1.555585E+04 3.450414E+15
(109,011,15) 0.000000E+00 2.003550E-02 5.976586E-01 8.206311E-01
26 0 04:20:00 1.327647E-03 1.555587E+04 1.555587E+04 3.450405E+15
(109,011,15) 0.000000E+00 8.889696E-03 2.976321E-01 8.193659E-01
27 0 04:30:00 1.348737E-03 1.555589E+04 1.555589E+04 3.450396E+15
(108,009,15) 3.058606E-04 3.479753E-03 3.581366E-01 8.190006E-01
GET_2DFLD - surface u-momentum stress, t = 0 07:30:00
(Rec=0000251, Index=2, File: gom_sms_era_12.nc)
(Min = -9.72893724E-05 Max = 1.01963000E-04)
GET_2DFLD - surface v-momentum stress, t = 0 07:30:00
(Min = -5.81437140E-05 Max = 2.07357974E-04)
GET_2DFLD - solar shortwave radiation flux, t = 0 07:30:00
(Rec=0000251, Index=2, File: gom_swrad_era_12.nc)
GET_2DFLD - surface net heat flux, t = 0 07:30:00
(Rec=0000251, Index=2, File: gom_shflux_era_12.nc)
(Min = -7.06396773E-05 Max = -4.15281741E-06)
28 0 04:40:00 1.368938E-03 1.555592E+04 1.555592E+04 3.450386E+15
(165,043,01) 2.518856E-03 1.492532E-02 3.080648E-01 8.203019E-01
29 0 04:50:00 1.388507E-03 1.555594E+04 1.555595E+04 3.450377E+15
(109,010,15) 2.165899E-03 1.716650E-02 3.928882E-01 8.287412E-01
30 0 05:00:00 1.407890E-03 1.555597E+04 1.555597E+04 3.450367E+15
(169,093,15) 8.336025E-03 0.000000E+00 3.667059E-01 8.379802E-01
31 0 05:10:00 1.426798E-03 1.555598E+04 1.555598E+04 3.450358E+15
(109,011,15) 0.000000E+00 2.375041E-02 4.790941E-01 8.448549E-01
32 0 05:20:00 1.445477E-03 1.555599E+04 1.555599E+04 3.450348E+15
GET_2DFLD - surface u-momentum stress, t = 29 19:30:00
(Rec=0000487, Index=2, File: gom_sms_era_12.nc)
(Min = -3.60897617E-04 Max = 2.34752478E-04)
GET_2DFLD - surface v-momentum stress, t = 29 19:30:00
(Min = -3.65916023E-04 Max = 1.55999981E-04)
GET_2DFLD - solar shortwave radiation flux, t = 29 19:30:00
(Rec=0000487, Index=2, File: gom_swrad_era_12.nc)
(Min = 9.19471533E-05 Max = 2.16037668E-04)
GET_2DFLD - surface net heat flux, t = 29 19:30:00
(Rec=0000487, Index=2, File: gom_shflux_era_12.nc)
(Min = 1.73041981E-06 Max = 1.72706021E-04)
4276 29 16:40:00 4.002859E-03 1.553041E+04 1.553041E+04 3.414685E+15
(165,044,02) 1.140422E-02 3.158231E-02 1.546675E+00 1.438609E+00
4277 29 16:50:00 4.002749E-03 1.553040E+04 1.553040E+04 3.414677E+15
(165,044,02) 1.142009E-02 3.155711E-02 1.547802E+00 1.443782E+00
4278 29 17:00:00 4.002648E-03 1.553039E+04 1.553040E+04 3.414670E+15
(165,044,02) 1.145702E-02 3.149749E-02 1.550760E+00 1.448547E+00
4279 29 17:10:00 4.002553E-03 1.553039E+04 1.553039E+04 3.414663E+15
(165,044,02) 1.150741E-02 3.142819E-02 1.550801E+00 1.453797E+00
4280 29 17:20:00 4.002445E-03 1.553038E+04 1.553039E+04 3.414655E+15
(165,044,02) 1.151194E-02 3.140673E-02 1.549692E+00 1.459217E+00
4281 29 17:30:00 4.002351E-03 1.553038E+04 1.553038E+04 3.414648E+15
(165,044,02) 1.151461E-02 3.129309E-02 1.548540E+00 1.464030E+00
4282 29 17:40:00 4.002256E-03 1.553037E+04 1.553038E+04 3.414640E+15
(165,044,02) 1.149941E-02 3.123923E-02 1.550050E+00 1.468305E+00
4283 29 17:50:00 4.002154E-03 1.553037E+04 1.553037E+04 3.414633E+15
(165,044,02) 1.149261E-02 3.130889E-02 1.549774E+00 1.473229E+00
4284 29 18:00:00 4.002066E-03 1.553036E+04 1.553036E+04 3.414626E+15
(165,044,02) 1.141509E-02 3.147300E-02 1.553077E+00 1.477975E+00
4285 29 18:10:00 4.001982E-03 1.553035E+04 1.553036E+04 3.414618E+15
(165,044,02) 1.139055E-02 3.141720E-02 1.555586E+00 1.481969E+00
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000030
Elapsed CPU time (seconds):
Node # 0 CPU: 3746.068
Node # 1 CPU: 3746.068
Total: 7492.137
Allocation and array initialization .............. 0.186 ( 0.0025 %)
Ocean state initialization ....................... 0.036 ( 0.0005 %)
Reading of input data ............................ 82.362 ( 1.0993 %)
Processing of input data ......................... 48.700 ( 0.6500 %)
Processing of output time averaged data .......... 165.235 ( 2.2054 %)
Computation of vertical boundary conditions ...... 5.068 ( 0.0676 %)
Computation of global information integrals ...... 46.541 ( 0.6212 %)
Writing of output data ........................... 53.405 ( 0.7128 %)
Model 2D kernel .................................. 2339.978 (31.2324 %)
2D/3D coupling, vertical metrics ................. 107.025 ( 1.4285 %)
Omega vertical velocity .......................... 60.200 ( 0.8035 %)
Equation of state for seawater ................... 232.204 ( 3.0993 %)
KPP vertical mixing parameterization ............. 707.888 ( 9.4484 %)
3D equations right-side terms .................... 165.593 ( 2.2102 %)
3D equations predictor step ...................... 422.083 ( 5.6337 %)
Pressure gradient ................................ 156.037 ( 2.0827 %)
Harmonic mixing of tracers, geopotentials ........ 198.626 ( 2.6511 %)
Harmonic stress tensor, S-surfaces ............... 76.380 ( 1.0195 %)
Corrector time-step for 3D momentum .............. 236.618 ( 3.1582 %)
Corrector time-step for tracers .................. 2330.753 (31.1093 %)
Total: 7434.917 99.2363
Nonlinear model message Passage profile:
Message Passage: 2D halo exchanges ............... 204.467 ( 2.7291 %)
Message Passage: 3D halo exchanges ............... 39.737 ( 0.5304 %)
Message Passage: 4D halo exchanges ............... 105.957 ( 1.4142 %)
Message Passage: data broadcast .................. 58.253 ( 0.7775 %)
Message Passage: data reduction .................. 47.260 ( 0.6308 %)
Message Passage: data gathering .................. 7.963 ( 0.1063 %)
Message Passage: data scattering.................. 0.099 ( 0.0013 %)
Total: 463.737 6.1897
All percentages are with respect to total time = 7492.137
number of time records written in HISTORY file = 00000030
number of time records written in RESTART file = 00000030
number of time records written in AVERAGE file = 00000002
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_srflux.h
ROMS/Functionals/ana_stflux.h
I really appreciate your help on this.
Thanks in advance.
Re: blowing up after run 4285 time-steps
Can you look at record 30 of your restart file and see where things are bad? That should give you a better clue than we can.
When the model blows up in diag like that, the default is to not give you very much information. I changed my code to tell me whether u/v or rho went bad first and at which location. Your grid is fairly small so you can probably just find the bad spot using ncview. For larger grids, I've got a python tool to tell me where on the grid the min/max of some field is.
rtopper
#3 Unread post by rtopper »
Your bathymetry seems to contain some negative depth values. Unless you specify the WET_DRY CPP option, the bathymetry cannot have values of 0 or negative values.
Furthermore, you may want to consider smoothing your bathymetry; the rx0 and rx1 values are too high.
