very early blowing-up
cyltby
#1 Unread post by cyltby »
Hi everyone!
I run a Northern South China Sea case. It is blowing-up at the first time-step.
Here are running log and *.in file:
Resolution, Grid 01: 0298x0160x030, Parallel Nodes: 1, Tiling: 001x001
2592 ntimes Number of timesteps for 3-D equations.
100.000 dt Timestep size (s) for 3-D equations.
864 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
864 nAVG Number of timesteps between the writing of
864 nDIA Number of timesteps between the writing of
4.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
4.2000E+01 blk_ZQ Height (m) of surface air humidity measurement.
2.0000E+00 blk_ZT Height (m) of surface air temperature measurement.
1 lmd_Jwt Jerlov water type.
2.0000E+00 theta_s S-coordinate surface control parameter.
50.000 Tcline S-coordinate surface/bottom layer width (m) used
3.6000E+02 Tnudg(01) Nudging/relaxation time scale (days)
3.6000E+02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.6000E+02 Znudg Nudging/relaxation time scale (days)
3.6000E+02 M2nudg Nudging/relaxation time scale (days)
3.6000E+02 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
3.6000E+02 obcfac Factor between passive and active
of State.
T Hout(idu3dE) Write out 3D U-wastward component at RHO-points.
T Hout(idv3dN) Write out 3D V-northward component at RHO-points.
T Aout(idu3dE) Write out averaged 3D U-eastward at RHO-points.
T Aout(idv3dN) Write out averaged 3D V-northward at RHO-points.
T Aout(idDano) Write out averaged density anomaly.
Output Restart File: ./Output/scs_rst.nc
Output History File: ./Output/scs_his.nc
Output Averages File: ./Output/scs_avg.nc
Output Diagnostics File: ./Output/scs_dia.nc
Input Grid File: ./Input/scs_grd.nc
Input Nonlinear Initial File: ./Input/scs_ini.nc
Input Forcing File 01: ./Input/scs_wind_ncep_4xday.nc
Input Forcing File 02: ./Input/scs_lwrad_ncep_4xday.nc
Input Forcing File 03: ./Input/scs_swrad_ncep_1xday.nc
Input Forcing File 04: ./Input/scs_rain_ncep_4xday.nc
Input Forcing File 05: ./Input/scs_Tair_ncep_4xday.nc
Input Forcing File 06: ./Input/scs_Qair_ncep_4xday.nc
Input Forcing File 07: ./Input/scs_Pair_ncep_4xday.nc
Input Forcing File 08: ./Input/scs_tide_otps.nc
Input Forcing File 09: ./Input/scs_river.nc
Input Boundary File: ./Input/scs_obc.nc
Input/Output USER File: ROMS/External/MyFile.dat
Generic User Parameters:
4.0000E+00 user(01) User parameter 01.
Tile partition information for Grid 01: 0298x0160x0030 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 298 1 160 1430400
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 298.50 0.50 160.50 RHO-points
0 1.00 298.00 0.50 160.50 U-points
0 0.50 298.50 1.00 160.00 V-points
HaloSizeI(1) = 618
HaloSizeJ(1) = 342
TileSide(1) = 303
TileSize(1) = 49995
zeta 1 Closed Chapman Imp Chapman Imp Closed
ubar 1 Closed Flather Flather Closed
vbar 1 Closed Flather Flather Closed
u 1 Closed Rad + Nud Rad + Nud Closed
v 1 Closed Rad + Nud Rad + Nud Closed
temp 1 Closed Rad + Nud Rad + Nud Closed
salt 1 Closed Rad + Nud Rad + Nud Closed
PRD Pearl River Delta
BULK_FLUXES Surface bulk fluxes parameterization.
LMD_BKPP KPP bottom boundary layer mixing.
LMD_DDMIX LMD double-diffusive mixing.
LONGWAVE_OUT Compute outgoing longwave radiation internally.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
SPHERICAL Spherical grid configuration.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 0 (pid= 9803) is active.
30 0.0000000 0.0000000 0.000 0.000 0.000 0.000
29 -0.0333333 -0.0009763 0.000 -0.858 -5.042 -8.499
28 -0.0666667 -0.0039077 0.000 -1.764 -16.888 -30.703
27 -0.1000000 -0.0088016 0.000 -2.720 -35.564 -66.664
26 -0.1333333 -0.0156700 0.000 -3.725 -61.114 -116.467
25 -0.1666667 -0.0245299 0.000 -4.780 -93.594 -180.231
24 -0.2000000 -0.0354029 0.000 -5.885 -133.082 -258.106
23 -0.2333333 -0.0483150 0.000 -7.041 -179.666 -350.275
22 -0.2666667 -0.0632964 0.000 -8.249 -233.453 -456.951
21 -0.3000000 -0.0803816 0.000 -9.510 -294.562 -578.373
20 -0.3333333 -0.0996084 0.000 -10.824 -363.125 -714.809
19 -0.3666667 -0.1210183 0.000 -12.192 -439.287 -866.548
18 -0.4000000 -0.1446557 0.000 -13.616 -523.201 -1033.902
17 -0.4333333 -0.1705673 0.000 -15.098 -615.031 -1217.199
16 -0.4666667 -0.1988020 0.000 -16.637 -714.947 -1416.780
15 -0.5000000 -0.2294097 0.000 -18.235 -823.122 -1632.996
14 -0.5333333 -0.2624411 0.000 -19.894 -939.732 -1866.203
13 -0.5666667 -0.2979465 0.000 -21.615 -1064.954 -2116.753
12 -0.6000000 -0.3359752 0.000 -23.399 -1198.958 -2384.990
11 -0.6333333 -0.3765740 0.000 -25.248 -1341.907 -2671.245
10 -0.6666667 -0.4197868 0.000 -27.161 -1493.955 -2975.823
9 -0.7000000 -0.4656524 0.000 -29.141 -1655.235 -3298.998
8 -0.7333333 -0.5142040 0.000 -31.188 -1825.865 -3641.002
7 -0.7666667 -0.5654672 0.000 -33.303 -2005.932 -4002.015
6 -0.8000000 -0.6194584 0.000 -35.486 -2195.494 -4382.150
5 -0.8333333 -0.6761831 0.000 -37.738 -2394.571 -4781.448
4 -0.8666667 -0.7356342 0.000 -40.058 -2603.136 -5199.858
3 -0.9000000 -0.7977897 0.000 -42.445 -2821.115 -5637.225
2 -0.9333333 -0.8626110 0.000 -44.899 -3048.371 -6093.280
1 -0.9666667 -0.9300406 0.000 -47.418 -3284.706 -6567.620
0 -1.0000000 -1.0000000 0.000 -50.000 -3529.847 -7059.694
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 8.18461090E+00 km
Maximum X-grid spacing, DXmax = 8.96932936E+00 km
Minimum Y-grid spacing, DYmin = 8.80829488E+00 km
Maximum Y-grid spacing, DYmax = 9.65281096E+00 km
Minimum Z-grid spacing, DZmin = 0.00000000E+00 m
Maximum Z-grid spacing, DZmax = 4.92073844E+02 m
Minimum barotropic Courant Number = 0.00000000E+00
Maximum barotropic Courant Number = 1.42016700E-01
Maximum Coriolis Courant Number = 6.83599627E-03
(Grid 01, File: scs_ini.nc, Rec=0001, Index=1)
- free-surface
(Min = 0.00000000E+00 Max = 1.08249939E+00)
(Min = -7.20735770E-02 Max = 1.23697765E-01)
(Min = -1.22252984E-01 Max = 1.58932775E-01)
- u-momentum component
(Min = -5.70196599E-01 Max = 5.83470370E-01)
- v-momentum component
(Min = -3.30359065E-01 Max = 1.03607355E+00)
- potential temperature
(Min = 0.00000000E+00 Max = 2.83103987E+01)
- salinity
(Min = 0.00000000E+00 Max = 3.50024795E+01)
GET_2DFLD - surface u-wind component, t = 0 00:00:00
(Rec=0000001, Index=1, File: scs_wind_ncep_4xday.nc)
(Tmin= 0.0000 Tmax= 59.0000)
(Min = -1.04356276E+01 Max = 7.75667029E+00)
GET_2DFLD - surface v-wind component, t = 0 00:00:00
(Min = -1.36977104E+01 Max = 4.79914472E-01)
GET_2DFLD - surface air pressure, t = 0 00:00:00
(Rec=0000001, Index=1, File: scs_Pair_ncep_4xday.nc)
(Min = 1.01086906E+03 Max = 1.03325957E+03)
GET_2DFLD - solar shortwave radiation flux, t = 0 00:00:00
(Rec=0000001, Index=1, File: scs_swrad_ncep_1xday.nc)
(Min = 1.94411974E-05 Max = 4.76776111E-05)
GET_2DFLD - downwelling longwave radiation flux, t = 0 00:00:00
(Rec=0000001, Index=1, File: scs_lwrad_ncep_4xday.nc)
(Min = 4.37414125E-05 Max = 1.03505545E-04)
GET_2DFLD - surface air temperature, t = 0 00:00:00
(Rec=0000001, Index=1, File: scs_Tair_ncep_4xday.nc)
(Min = 5.84000015E+00 Max = 2.69342015E+01)
GET_2DFLD - surface air relative humidity, t = 0 00:00:00
(Rec=0000001, Index=1, File: scs_Qair_ncep_4xday.nc)
(Min = 1.14241463E-01 Max = 9.35342863E-01)
GET_2DFLD - rain fall rate, t = 0 00:00:00
(Rec=0000001, Index=1, File: scs_rain_ncep_4xday.nc)
(Min = 9.98843461E-08 Max = 2.11007644E-04)
GET_NGFLD - free-surface eastern boundary condition, t = 46 00:00:00
(Rec=0000002, Index=2, File: scs_obc.nc)
(Tmin= 15.0000 Tmax= 46.0000)
(Min = 9.24790356E-01 Max = 1.04777797E+00)
GET_NGFLD - free-surface southern boundary condition, t = 46 00:00:00
(Min = 0.00000000E+00 Max = 9.89003613E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 46 00:00:00
(Min = -2.09475246E-02 Max = 9.59596862E-02)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 46 00:00:00
(Min = -2.07431682E-02 Max = 1.02132891E-01)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 46 00:00:00
(Min = -1.53495057E-01 Max = 8.78249293E-03)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 46 00:00:00
(Min = -1.25105734E-01 Max = 9.01774569E-03)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 46 00:00:00
(Min = -1.77526164E-01 Max = 2.39741412E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 46 00:00:00
(Min = -1.75050809E-01 Max = 2.44820047E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 46 00:00:00
(Min = -2.86529621E-01 Max = 1.67002977E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 46 00:00:00
(Min = -2.86693684E-01 Max = 1.73907394E-01)
GET_NGFLD - temperature eastern boundary condition, t = 46 00:00:00
(Min = 1.18212785E+00 Max = 2.79840101E+01)
GET_NGFLD - salinity eastern boundary condition, t = 46 00:00:00
(Min = 3.41160618E+01 Max = 3.49339650E+01)
GET_NGFLD - temperature southern boundary condition, t = 46 00:00:00
(Min = 0.00000000E+00 Max = 2.81557126E+01)
GET_NGFLD - salinity southern boundary condition, t = 46 00:00:00
(Min = 0.00000000E+00 Max = 3.49088138E+01)
Maximum grid stiffness ratios: rx0 = 4.295193E-01 (Beckmann and Haidvogel)
rx1 = 2.518013E+01 (Haney)
Initial basin volumes: TotVolume = 6.8155578098E+15 m3
MinVolume = 0.0000000000E+00 m3
MaxVolume = 3.7742952196E+10 m3
Max/Min = 0.0000000000E+00
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00002592)
GET_2DFLD - surface u-wind component, t = 0 06:00:00
(Rec=0000002, Index=2, File: scs_wind_ncep_4xday.nc)
(Min = -1.05988019E+01 Max = 6.24389137E+00)
GET_2DFLD - surface v-wind component, t = 0 06:00:00
(Min = -1.43952326E+01 Max = 6.79071150E-01)
GET_2DFLD - surface air pressure, t = 0 06:00:00
(Rec=0000002, Index=2, File: scs_Pair_ncep_4xday.nc)
(Min = 1.00869525E+03 Max = 1.03199308E+03)
GET_2DFLD - solar shortwave radiation flux, t = 1 00:00:00
(Rec=0000002, Index=2, File: scs_swrad_ncep_1xday.nc)
(Min = 1.78338967E-05 Max = 4.74034916E-05)
GET_2DFLD - downwelling longwave radiation flux, t = 0 06:00:00
(Rec=0000002, Index=2, File: scs_lwrad_ncep_4xday.nc)
(Min = 4.47019300E-05 Max = 1.04213820E-04)
GET_2DFLD - surface air temperature, t = 0 06:00:00
(Rec=0000002, Index=2, File: scs_Tair_ncep_4xday.nc)
(Min = -4.53555651E+00 Max = 2.71698319E+01)
GET_2DFLD - surface air relative humidity, t = 0 06:00:00
(Rec=0000002, Index=2, File: scs_Qair_ncep_4xday.nc)
(Min = 5.19250592E-02 Max = 9.69018176E-01)
GET_2DFLD - rain fall rate, t = 0 06:00:00
(Rec=0000002, Index=2, File: scs_rain_ncep_4xday.nc)
(Min = 9.98843461E-08 Max = 2.82428896E-04)
GET_NGFLD - free-surface eastern boundary condition, t = 15 00:00:00
(Rec=0000001, Index=1, File: scs_obc.nc)
(Min = 8.81700534E-01 Max = 1.05741621E+00)
GET_NGFLD - free-surface southern boundary condition, t = 15 00:00:00
(Min = 0.00000000E+00 Max = 9.61239512E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 15 00:00:00
(Min = -2.80499370E-02 Max = 9.58948328E-02)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 15 00:00:00
(Min = -2.74920671E-02 Max = 1.01171228E-01)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 15 00:00:00
(Min = -1.37050965E-01 Max = 1.76525114E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 15 00:00:00
(Min = -1.18478356E-01 Max = 1.83773497E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 15 00:00:00
(Min = -1.85639171E-01 Max = 2.39548499E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 15 00:00:00
(Min = -1.83911095E-01 Max = 2.44225845E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 15 00:00:00
(Min = -2.07122876E-01 Max = 2.37627767E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 15 00:00:00
(Min = -2.06533025E-01 Max = 2.41822979E-01)
GET_NGFLD - temperature eastern boundary condition, t = 15 00:00:00
(Min = 1.18322840E+00 Max = 2.83053961E+01)
GET_NGFLD - salinity eastern boundary condition, t = 15 00:00:00
(Min = 3.41031574E+01 Max = 3.49614090E+01)
GET_NGFLD - temperature southern boundary condition, t = 15 00:00:00
(Min = 0.00000000E+00 Max = 2.83109754E+01)
GET_NGFLD - salinity southern boundary condition, t = 15 00:00:00
(Min = 0.00000000E+00 Max = 3.49629022E+01)
0 0 00:00:00 1.653157E-03 2.170226E+04 2.170227E+04 6.821697E+15
(206,061,30) 6.463152E-03 8.904721E-03 0.000000E+00 1.090142E+00
DEF_HIS - creating history file, Grid 01: ./Output/scs_his.nc
DEF_AVG - creating average file, Grid 01: ./Output/scs_avg.nc
DEF_DIAGS - creating diagnostics file, Grid 01: ./Output/scs_dia.nc
1 0 00:01:40 NaN NaN NaN NaN
(000,000,00) 0.000000E+00 0.000000E+00 0.000000E+00 NaN
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001
! Application title.
TITLE = Pearl River Delta
! C-preprocessing Flag.
MyAppCPP = PRD
VARNAME = ./External/varinfo.dat
Ngrids = 1
Lm == 298 ! Number of I-direction INTERIOR RHO-points
Mm == 160 ! Number of J-direction INTERIOR RHO-points
N == 30 ! Number of vertical levels
Nbed = 0 ! Number of sediment bed layers
NAT = 2 ! Number of active tracers (usually, 2)
NPT = 0 ! Number of inactive passive tracers
NCS = 0 ! Number of cohesive (mud) sediment tracers
NNS = 0 ! Number of non-cohesive (sand) sediment tracers
LBC(isFsur) == Clo Cha Cha Clo ! free-surface
LBC(isUbar) == Clo Fla Fla Clo ! 2D U-momentum
LBC(isVbar) == Clo Fla Fla Clo ! 2D V-momentum
LBC(isUvel) == Clo RadNud RadNud Clo ! 3D U-momentum
LBC(isVvel) == Clo RadNud RadNud Clo ! 3D V-momentum
LBC(isMtke) == Clo Gra Gra Clo ! mixing TKE
LBC(isTvar) == Clo RadNud RadNud Clo \ ! temperature
Clo RadNud RadNud Clo ! salinity
ad_LBC(isFsur) == Clo Clo Per Clo ! free-surface
ad_LBC(isUbar) == Clo Clo Per Clo ! 2D U-momentum
ad_LBC(isVbar) == Clo Clo Per Clo ! 2D U-momentum
ad_LBC(isUvel) == Clo Clo Per Clo ! 3D U-momentum
ad_LBC(isVvel) == Clo Clo Per Clo ! 3D V-momentum
ad_LBC(isMtke) == Clo Clo Per Clo ! mixing TKE
ad_LBC(isTvar) == Clo Clo Per Clo \ ! temperature
Clo Clo Per Clo ! salinity
VolCons(west) == F ! western boundary
VolCons(east) == F ! eastern boundary
VolCons(south) == F ! southern boundary
VolCons(north) == F ! northern boundary
ad_VolCons(west) == F ! western boundary
ad_VolCons(east) == F ! eastern boundary
ad_VolCons(south) == F ! southern boundary
ad_VolCons(north) == F ! northern boundary
NTIMES == 2592
DT == 100.0d0
NDTFAST == 30
ERstr = 1
ERend = 1
Nouter = 1
Ninner = 1
Nintervals = 1
NRREC == 0
LcycleRST == T
NRST == 864
NSTA == 1
NFLT == 1
NINFO == 1
LDEFOUT == T
NHIS == 1
NDEFHIS == 0
NTSAVG == 1
! NAVG == 26298
NAVG == 864
NDEFAVG == 0
NTSDIA == 1
NDIA == 864
NDEFDIA == 0
LcycleTLM == F
NTLM == 72
NDEFTLM == 0
LcycleADJ == F
NADJ == 72
NDEFADJ == 0
NSFF == 72
NOBC == 72
LmultiGST = F ! one eigenvector per file
MaxIterGST = 500 ! maximum number of iterations
Ritz_tol = 1.0d-15
TNU2 == 4.0d0 4.0d0 ! m2/s
TNU4 == 2*0.0d0 ! m4/s
ad_TNU2 == 0.0d0 0.0d0 ! m2/s
ad_TNU4 == 0.0d0 0.0d0 ! m4/s
VISC2 == 4.0d0 ! m2/s
VISC4 == 0.0d0 ! m4/s
ad_VISC2 == 0.0d0 ! m2/s
ad_VISC4 == 0.0d0 ! m4/s
AKT_BAK == 1.0d-6 1.0d-6 ! m2/s
AKV_BAK == 1.0d-5 ! m2/s
AKK_BAK == 5.0d-6 ! m2/s
AKP_BAK == 5.0d-6 ! m2/s
TKENU2 == 0.0d0 ! m2/s
TKENU4 == 0.0d0 ! m4/s
GLS_P == -1.0d0 ! K-omega
GLS_M == 0.5d0
GLS_N == -1.0d0
GLS_Kmin == 7.6d-6
GLS_Pmin == 1.0d-12
GLS_CMU0 == 0.5477d0
GLS_C1 == 0.555d0
GLS_C2 == 0.833d0
GLS_C3M == -0.6d0
GLS_C3P == 1.0d0
GLS_SIGK == 2.0d0
GLS_SIGP == 2.0d0
CHARNOK_ALPHA == 1400.0d0 ! Charnok surface roughness
CRGBAN_CW == 100.0d0 ! Craig and Banner wave breaking
RDRG == 3.0d-04 ! m/s
RDRG2 == 3.0d-03 ! nondimensional
Zob == 0.02d0 ! m
Zos == 0.02d0 ! m
BLK_ZQ == 42.0d0 ! air humidity
BLK_ZT == 2.0d0 ! air temperature
BLK_ZW == 10.0d0 ! winds
DCRIT == 0.10d0 ! m
! Various parameters.
WTYPE == 1
LEVSFRC == 15
LEVBFRC == 1
Vtransform == 2 ! transformation equation
Vstretching == 4 ! stretching function
THETA_S == 2.0d0 ! surface stretching parameter
THETA_B == 0.4d0 ! bottom stretching parameter
TCLINE == 5.0d1 ! critical depth (m)
RHO0 = 1025.0d0 ! kg/m3
BVF_BAK = 1.0d-5 ! 1/s2
DSTART = 0.0d0 ! days
TIDE_START = 0.0d0 ! days
TIME_REF = 0.0d0 ! yyyymmdd.dd
! internally, [1:Ngrids].
TNUDG == 360.0d0 360.0d0 ! days
ZNUDG == 360.0d0 ! days
M2NUDG == 360.0d0 ! days
M3NUDG == 360.0d0 ! days
OBCFAC == 360.0d0 ! nondimensional
R0 == 1027.0d0 ! kg/m3
T0 == 14.0d0 ! Celsius
S0 == 35.0d0 ! PSU
TCOEF == 1.7d-4 ! 1/Celsius
SCOEF == 0.0d0 ! 1/PSU
GAMMA2 == 1.0d0
! Logical switches (TRUE/FALSE) to specify which variables to process for
! tracers climatology: [1:NAT+NPT,Ngrids]. See glossary below for details.
LtracerCLM == T T ! temperature, salinity, inert
LtracerSrc == T T ! temperature, salinity, inert
DstrS == 0.0d0 ! starting day
DendS == 0.0d0 ! ending day
KstrS == 1 ! starting level
KendS == 1 ! ending level
Lstate(isTvar) == F F ! NT tracers
Fstate(isFsur) == F ! free-surface
Fstate(isUbar) == F ! 2D U-momentum
Fstate(isVbar) == F ! 2D V-momentum
Fstate(isUvel) == F ! 3D U-momentum
Fstate(isVvel) == F ! 3D V-momentum
Fstate(isTvar) == F F ! NT tracers
Fstate(isUstr) == T ! surface U-stress
Fstate(isVstr) == T ! surface V-stress
Fstate(isTsur) == F F ! NT surface tracers flux
! red noise processes.
SO_decay == 2.0d0 ! days
! dimensionalization.
SO_sdev(isFsur) == 1.0d0 ! free-surface
SO_sdev(isUbar) == 1.0d0 ! 2D U-momentum
SO_sdev(isVbar) == 1.0d0 ! 2D V-momentum
SO_sdev(isUvel) == 1.0d0 ! 3D U-momentum
SO_sdev(isVvel) == 1.0d0 ! 3D V-momentum
SO_sdev(isTvar) == 1.0d0 1.0d0 ! NT tracers
SO_sdev(isUstr) == 1.0d0 ! surface U-stress
SO_sdev(isVstr) == 1.0d0 ! surface V-stress
SO_sdev(isTsur) == 1.0d0 1.0d0 ! NT surface tracers flux
! HISTORY output file.
Hout(idUvel) == F ! u 3D U-velocity
Hout(idVvel) == F ! v 3D V-velocity
Hout(idu3dE) == T ! u_eastward 3D U-eastward at RHO-points
Hout(idv3dN) == T ! v_northward 3D V-northward at RHO-points
Hout(idWvel) == F ! w 3D W-velocity
Hout(idOvel) == F ! omega omega vertical velocity
Hout(idUbar) == F ! ubar 2D U-velocity
Hout(idVbar) == F ! vbar 2D V-velocity
Hout(idu2dE) == F ! ubar_eastward 2D U-eastward at RHO-points
Hout(idv2dN) == F ! vbar_northward 2D V-northward at RHO-points
Hout(idBath) == F ! bath time-dependent bathymetry
Hout(idTvar) == T T ! temp, salt temperature and salinity
Hout(idW2xx) == F ! Sxx_bar 2D radiation stress, Sxx component
Hout(idW2xy) == F ! Sxy_bar 2D radiation stress, Sxy component
Hout(idW2yy) == F ! Syy_bar 2D radiation stress, Syy component
Hout(idU2rs) == F ! Ubar_Rstress 2D radiation U-stress
Hout(idV2rs) == F ! Vbar_Rstress 2D radiation V-stress
Hout(idW3xx) == F ! Sxx 3D radiation stress, Sxx component
Hout(idW3xy) == F ! Sxy 3D radiation stress, Sxy component
Hout(idW3yy) == F ! Syy 3D radiation stress, Syy component
Hout(idW3zx) == F ! Szx 3D radiation stress, Szx component
Hout(idW3zy) == F ! Szy 3D radiation stress, Szy component
Hout(idU3rs) == F ! u_Rstress 3D U-radiation stress
Hout(idV3rs) == F ! v_Rstress 3D V-radiation stress
Hout(idWamp) == F ! Hwave wave height
Hout(idWlen) == F ! Lwave wave length
Hout(idWdir) == F ! Dwave wave direction
Hout(idWorb) == F ! Ub_swan wave bottom orbital velocity
Hout(idWdis) == F ! Wave_dissip wave dissipation
Hout(idPair) == F ! Pair surface air pressure
Hout(idUair) == F ! Uair surface U-wind component
Hout(idVair) == F ! Vair surface V-wind component
Hout(idDano) == F ! rho density anomaly
Hout(idMtls) == F ! gls turbulent length scale
Hout(inert) == T ! dye_01, ... inert passive tracers
! Logical switches (TRUE/FALSE) to activate writing of exposed sediment
! layer properties into HISTORY output file. Currently, MBOTP properties
! are expected for the bottom boundary layer and/or sediment models:
! idBott( 1=isd50) grain_diameter mean grain diameter
! idBott( 2=idens) grain_density mean grain density
! idBott( 3=iwsed) settling_vel mean settling velocity
! idBott( 4=itauc) erosion_stres critical erosion stress
! idBott( 5=irlen) ripple_length ripple length
! idBott( 6=irhgt) ripple_height ripple height
! idBott( 7=ibwav) bed_wave_amp wave excursion amplitude
! idBott( 8=izdef) Zo_def default bottom roughness
! idBott( 9=izapp) Zo_app apparent bottom roughness
! idBott(10=izNik) Zo_Nik Nikuradse bottom roughness
! idBott(11=izbio) Zo_bio biological bottom roughness
! idBott(12=izbfm) Zo_bedform bed form bottom roughness
! idBott(13=izbld) Zo_bedload bed load bottom roughness
! idBott(14=izwbl) Zo_wbl wave bottom roughness
! idBott(15=iactv) active_layer_thickness active layer thickness
! idBott(16=ishgt) saltation saltation height
! 1 1 1 1 1 1 1
! 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6
Hout(idBott) == T T T T T T T T T F F F F F F F
Aout(idUvel) == T ! u 3D U-velocity
Aout(idVvel) == T ! v 3D V-velocity
Aout(idu3dE) == T ! u_eastward 3D U-eastward at RHO-points
Aout(idv3dN) == T ! v_northward 3D V-northward at RHO-points
Aout(idWvel) == T ! w 3D W-velocity
Aout(idOvel) == F ! omega omega vertical velocity
Aout(idUbar) == F ! ubar 2D U-velocity
Aout(idVbar) == F ! vbar 2D V-velocity
Aout(idu2dE) == F ! ubar_eastward 2D U-eastward at RHO-points
Aout(idv2dN) == F ! vbar_northward 2D V-northward at RHO-points
Aout(idFsur) == T ! zeta free-surface
Aout(idTvar) == T T ! temp, salt temperature and salinity
Aout(idUsms) == F ! sustr surface U-stress
Aout(idVsms) == F ! svstr surface V-stress
Aout(idUbms) == F ! bustr bottom U-stress
Aout(idVbms) == F ! bvstr bottom V-stress
Aout(idW2xx) == F ! Sxx_bar 2D radiation stress, Sxx component
Aout(idW2xy) == F ! Sxy_bar 2D radiation stress, Sxy component
Aout(idW2yy) == F ! Syy_bar 2D radiation stress, Syy component
Aout(idU2rs) == F ! Ubar_Rstress 2D radiation U-stress
Aout(idV2rs) == F ! Vbar_Rstress 2D radiation V-stress
Aout(idU2Sd) == F ! ubar_stokes 2D U-Stokes velocity
Aout(idV2Sd) == F ! vbar_stokes 2D V-Stokes velocity
Aout(idW3xx) == F ! Sxx 3D radiation stress, Sxx component
Aout(idW3xy) == F ! Sxy 3D radiation stress, Sxy component
Aout(idW3yy) == F ! Syy 3D radiation stress, Syy component
Aout(idW3zx) == F ! Szx 3D radiation stress, Szx component
Aout(idW3zy) == F ! Szy 3D radiation stress, Szy component
Aout(idU3rs) == F ! u_Rstress 3D U-radiation stress
Aout(idV3rs) == F ! v_Rstress 3D V-radiation stress
Aout(idU3Sd) == F ! u_stokes 3D U-Stokes velocity
Aout(idV3Sd) == F ! v_stokes 3D V-Stokes velocity
Aout(idPair) == F ! Pair surface air pressure
Aout(idUair) == F ! Uair surface U-wind component
Aout(idVair) == F ! Vair surface V-wind component
Aout(idTsur) == F F ! shflux, ssflux surface net heat and salt flux
Aout(idLhea) == F ! latent latent heat flux
Aout(idShea) == F ! sensible sensible heat flux
Aout(idLrad) == F ! lwrad longwave radiation flux
Aout(idSrad) == F ! swrad shortwave radiation flux
Aout(idevap) == F ! evaporation evaporation rate
Aout(idrain) == F ! rain precipitation rate
Aout(idDano) == T ! rho density anomaly
Aout(idVvis) == F ! AKv vertical viscosity
Aout(idTdif) == F ! AKt vertical T-diffusion
Aout(idSdif) == F ! AKs vertical Salinity diffusion
Aout(idHsbl) == F ! Hsbl depth of surface boundary layer
Aout(idHbbl) == F ! Hbbl depth of bottom boundary layer
Aout(idu3dD) == F ! u_detided detided 3D U-velocity
Aout(idv3dD) == F ! v_detided detided 3D V-velocity
Aout(idu2dD) == F ! ubar_detided detided 2D U-velocity
Aout(idv2dD) == F ! vbar_detided detided 2D V-velocity
Aout(idFsuD) == F ! zeta_detided detided free-surface
Aout(idTrcD) == F F ! temp_detided, ... detided temperature and salinity
Aout(idHUav) == F ! Huon u-volume flux, Huon
Aout(idHVav) == F ! Hvom v-volume flux, Hvom
Aout(idUUav) == F ! uu quadratic <u*u> term
Aout(idUVav) == F ! uv quadratic <u*v> term
Aout(idVVav) == F ! vv quadratic <v*v> term
Aout(idU2av) == F ! ubar2 quadratic <ubar*ubar> term
Aout(idV2av) == F ! vbar2 quadratic <vbar*vbar> term
Aout(idZZav) == F ! zeta2 quadratic <zeta*zeta> term
Aout(idTTav) == F F ! temp2, ... quadratic <t*t> tracer terms
Aout(idUTav) == F F ! utemp, ... quadratic <u*t> tracer terms
Aout(idVTav) == F F ! vtemp, ... quadratic <v*t> tracer terms
Aout(iHUTav) == F F ! Huontemp, ... tracer volume flux, <Huon*t>
Aout(iHVTav) == F F ! Hvomtemp, ... tracer volume flux, <Hvom*t>
Aout(inert) == F ! dye_01, ... inert passive tracers
Dout(M2rate) == F ! ubar_accel, ... acceleration
Dout(M2pgrd) == F ! ubar_prsgrd, ... pressure gradient
Dout(M2fcor) == F ! ubar_cor, ... Coriolis force
Dout(M2hadv) == F ! ubar_hadv, ... horizontal total advection
Dout(M2xadv) == F ! ubar_xadv, ... horizontal XI-advection
Dout(M2yadv) == F ! ubar_yadv, ... horizontal ETA-advection
Dout(M2hrad) == F ! ubar_hrad, ... horizontal total radiation stress
Dout(M2hvis) == F ! ubar_hvisc, ... horizontal total viscosity
Dout(M2xvis) == F ! ubar_xvisc, ... horizontal XI-viscosity
Dout(M2yvis) == F ! ubar_yvisc, ... horizontal ETA-viscosity
Dout(M2sstr) == F ! ubar_sstr, ... surface stress
Dout(M2bstr) == F ! ubar_bstr, ... bottom stress
Dout(M3rate) == F ! u_accel, ... acceleration
Dout(M3pgrd) == F ! u_prsgrd, ... pressure gradient
Dout(M3fcor) == F ! u_cor, ... Coriolis force
Dout(M3hadv) == F ! u_hadv, ... horizontal total advection
Dout(M3xadv) == F ! u_xadv, ... horizontal XI-advection
Dout(M3yadv) == F ! u_yadv, ... horizontal ETA-advection
Dout(M3vadv) == F ! u_vadv, ... vertical advection
Dout(M3hrad) == F ! u_hrad, ... horizontal total radiation stress
Dout(M3vrad) == F ! u_vrad, ... vertical radiation stress
Dout(M3hvis) == F ! u_hvisc, ... horizontal total viscosity
Dout(M3xvis) == F ! u_xvisc, ... horizontal XI-viscosity
Dout(M3yvis) == F ! u_yvisc, ... horizontal ETA-viscosity
Dout(M3vvis) == F ! u_vvisc, ... vertical viscosity
Dout(iTrate) == F F ! temp_rate, ... time rate of change
Dout(iThadv) == F F ! temp_hadv, ... horizontal total advection
Dout(iTxadv) == F F ! temp_xadv, ... horizontal XI-advection
Dout(iTyadv) == F F ! temp_yadv, ... horizontal ETA-advection
Dout(iTvadv) == F F ! temp_vadv, ... vertical advection
Dout(iThdif) == F F ! temp_hdiff, ... horizontal total diffusion
Dout(iTxdif) == F F ! temp_xdiff, ... horizontal XI-diffusion
Dout(iTydif) == F F ! temp_ydiff, ... horizontal ETA-diffusion
Dout(iTsdif) == F F ! temp_sdiff, ... horizontal S-diffusion
Dout(iTvdif) == F F ! temp_vdiff, ... vertical diffusion
NUSER = 1
USER = 4.d0
! NetCDF-4/HDF5 compression parameters for output files.
NC_SHUFFLE = 1 ! if non-zero, turn on shuffle filter
NC_DEFLATE = 1 ! if non-zero, turn on deflate filter
NC_DLEVEL = 1 ! deflate level [0-9]
GRDNAME == ./Input/scs_grd.nc
ININAME == ./Input/scs_ini.nc
ITLNAME == ./Input/ocean_itl.nc
IRPNAME == ./Input/ocean_irp.nc
IADNAME == ./Input/NSCS_ini.nc
FWDNAME == ./Input/ocean_fwd.nc
ADSNAME == ./Input/ocean_ads.nc
BRYNAME == ./Input/scs_obc.nc
CLMNAME == ./Input/scs_clm.nc
NFFILES == 9 ! number of unique forcing files
FRCNAME == ./Input/scs_wind_ncep_4xday.nc \ ! forcing file 1, grid 1
./Input/scs_lwrad_ncep_4xday.nc \
./Input/scs_swrad_ncep_1xday.nc \
./Input/scs_rain_ncep_4xday.nc \
./Input/scs_Tair_ncep_4xday.nc \
./Input/scs_Qair_ncep_4xday.nc \
./Input/scs_Pair_ncep_4xday.nc \
./Input/scs_tide_otps.nc \
GSTNAME == ./Output/scs_gst.nc
RSTNAME == ./Output/scs_rst.nc
HISNAME == ./Output/scs_his.nc
TLMNAME == ./Output/scs_tlm.nc
TLFNAME == ./Output/scs_tlf.nc
ADJNAME == ./Output/scs_adj.nc
AVGNAME == ./Output/scs_avg.nc
DIANAME == ./Output/scs_dia.nc
STANAME == ./Output/scs_sta.nc
FLTNAME == ./Output/scs_flt.nc
APARNAM = ROMS/External/s4dvar.in
SPOSNAM = ROMS/External/stations.in
FPOSNAM = ROMS/External/floats.in
! BPARNAM = ./External/bio_Fennel.in
SPARNAM = ROMS/External/sediment.in
USRNAME = ROMS/External/MyFile.dat
I have checked my input file and found no NaN. I suppose something wrong in my *.in file.
Any suggestions will be appreciated.
Re: very early blowing-up
Which compiler are you using? Perhaps there's a compiler option to trap for floating point exceptions like gfortran's -ffpe-trap=invalid,zero,overflow
rtopper
#3 Unread post by rtopper »
Your log file shows you are using a bathymetry file that contains at least one point with depth = 0. As far as I know depth should always be non-zero and positive.
Another thing that may cause the model to blow up is the roughness of your bathymetry. The maximum grid stiffness ratios in your log file are too high. Try smoothing your bathymetry to get these values down. Recommended values you can find in other posts in this forum are ~0.2 for rx0 and ~5-8 for rx1.
cyltby
#4 Unread post by cyltby »
Hi ,Kate.
Thank you for your suggestion. Intel Fortran 2013 is the compiler I use.
Here is my partly compiler setting:
FC := ifort
FFLAGS := -heap-arrays -fp-model source
CPP := /usr/bin/cpp
CPPFLAGS := -P -traditional
LDFLAGS :=
AR := ar
ARFLAGS := r
MKDIR := mkdir -p
RM := rm -f
RANLIB := ranlib
PERL := perl
TEST := test
MDEPFLAGS := --cpp --fext=f90 --file=- --objdir=$(SCRATCH_DIR)
Recently, I find my *grd.nc many 0. Does the wrong mask land/sea lead to the problem?
#5 Unread post by kate »
It looks like the intel option to crash on divide by zero is "-fpe-all=0". You might not need to try it though, if you have zeros in your depth. Land masking does not prevent you from having to set your depth to non-zero values everywhere. Fix your depths and try again.
cyltby
#6 Unread post by cyltby »
Hi Kate! Hi rtopper!
Thanks for the suggestions.
It is the *grd.nc file that causes the problem.
In seagrid, I load the bathymetry file, the coastline file and then the boundary file; then
<View> -> setup -> Cell_Edge_1,2 -> change MinimumDepth to 10; then <Compute> -> Depths And Land Mask; then Save. Follow the above steps can work.
I didn't follow the correct order and didn't change the MinimunDepth before.
