River direction (Dsrc)
peisach
#1 Unread post by peisach »
This is not really a bug, but perhaps an inconsistency between the code and comments describing the code:
In mod_sources.F it is stated that the direction of rivers (SOURCES % Dsrc) should be zero for river flow along the xi-direction and larger than zero for flow along the eta-direction. And in pre_step3d.F, step2d.F and step3d_uv.F the IF-test roughly follows this convention:
          IF (INT(Dsrc(is)).eq.0) THEN
          ELSE
But in step3d_t.F Dsrc = 1 also receives special attention while any other positive (or negative) value of Dsrc is ignored:
            ELSE IF (INT(Dsrc(is)).eq.1) THEN
Not a big deal, but somewhat confusing. By the comments in mod_sources.F (and also analytical.F) one might be tempted to specify any old value for Dsrc.
This seems to be the case for roms-2.1, 2.2 and 3.0.
Sorry if I overlooked some logic of the code.
Paal Erik
