problem while forcing QuickScat Wind stress
murali
#1 Unread post by murali »
When I am trying to run REGIONAL application for Northern Indian Ocena with Real time forcing of Quickscat Monthly winds data (for Taux and Tauy instead of Coads data), the program is blowing up after the secong time step. Please help me to ocercome this problem.Thanks in advance.
I am pasting the error in Brief:
Spherical grid detected.
hmin hmax grdmin grdmax Cu_min Cu_max
10.000000 5634.449497 .336030738E+05 .370440568E+05 0.04501432 0.90897506
volume=5.596180442850068800000E+16 open_cross=2.637626090509115219116E+10
Vertical S-coordinate System:
32 0.0000000 0.0000000 0.000 0.000 0.000
31 -0.0312500 -0.0004021 -0.158 -1.289 -2.420
30 -0.0625000 -0.0008236 -0.317 -2.633 -4.949
29 -0.0937500 -0.0012846 -0.475 -4.088 -7.700
28 -0.1250000 -0.0018074 -0.634 -5.717 -10.799
27 -0.1562500 -0.0024169 -0.793 -7.590 -14.387
26 -0.1875000 -0.0031426 -0.953 -9.791 -18.629
25 -0.2187500 -0.0040193 -1.114 -12.417 -23.720
24 -0.2500000 -0.0050891 -1.275 -15.587 -29.899
23 -0.2812500 -0.0064033 -1.438 -19.446 -37.453
22 -0.3125000 -0.0080252 -1.603 -24.171 -46.740
21 -0.3437500 -0.0100327 -1.769 -29.983 -58.197
20 -0.3750000 -0.0125221 -1.938 -37.153 -72.368
19 -0.4062500 -0.0156131 -2.109 -46.017 -89.925
18 -0.4375000 -0.0194543 -2.285 -56.995 -111.704
17 -0.4687500 -0.0242300 -2.465 -70.605 -138.745
16 -0.5000000 -0.0301699 -2.651 -87.495 -172.340
15 -0.5312500 -0.0375592 -2.844 -108.469 -214.094
14 -0.5625000 -0.0467529 -3.046 -134.526 -266.005
13 -0.5937500 -0.0581927 -3.260 -166.911 -330.562
12 -0.6250000 -0.0724283 -3.487 -207.172 -410.857
11 -0.6562500 -0.0901436 -3.732 -257.236 -510.740
10 -0.6875000 -0.1121896 -3.998 -319.501 -635.003
9 -0.7187500 -0.1396254 -4.292 -396.950 -789.608
8 -0.7500000 -0.1737693 -4.619 -493.297 -981.976
7 -0.7812500 -0.2162615 -4.988 -613.164 -1221.339
6 -0.8125000 -0.2691435 -5.408 -762.300 -1519.192
5 -0.8437500 -0.3349558 -5.894 -947.865 -1889.836
4 -0.8750000 -0.4168604 -6.459 -1178.764 -2351.069
3 -0.9062500 -0.5187920 -7.125 -1466.085 -2925.045
2 -0.9375000 -0.6456478 -7.916 -1823.622 -3639.329
1 -0.9687500 -0.8035222 -8.861 -2268.546 -4528.231
0 -1.0000000 -1.0000000 -10.000 -2822.225 -5634.449
Time splitting: ndtfast = 54 nfast = 80
Maximum grid stiffness ratios: rx0 =0.1713276319 rx1 = 1.6042196177
GET_INITIAL -- Processing data for time = 15.00 record = 1
GET_TCLIMA -- Read climatology of tracer 1 for time = 15.00
GET_TCLIMA -- Read climatology of tracer 1 for time = 45.00
GET_TCLIMA -- Read climatology of tracer 2 for time = 15.00
GET_TCLIMA -- Read climatology of tracer 2 for time = 45.00
GET_UCLIMA -- Read momentum climatology for time = 15.00
GET_UCLIMA -- Read momentum climatology for time = 45.00
GET_SSH - Read SSH for time = 15.00
GET_SSH - Read SSH for time = 45.00
GET_SMFLUX -- Read surface momentum stresses for time = 15.00
GET_SMFLUX -- Read surface momentum stresses for time = 45.00
GET_STFLUX -- Read surface flux of tracer 1 for time = 15.00
GET_STFLUX -- Read surface flux of tracer 1 for time = 45.00
GET_STFLUX -- Read surface flux of tracer 2 for time = 15.00
GET_STFLUX -- Read surface flux of tracer 2 for time = 45.00
GET_SST -- Read SST and dQdSST fields for time = 15.00
GET_SST -- Read SST and dQdSST fields for time = 45.00
GET_SSS -- Read SSS fields for time = 15.00
GET_SSS -- Read SSS fields for time = 45.00
GET_SRFLUX -- Read solar shortwave radiation for time = 15.00
GET_SRFLUX -- Read solar shortwave radiation for time = 45.00
DEF_HIS/AVG - Created new netCDF file 'test1_his.nc'.
WRT_GRID -- wrote grid data into file 'test1_his.nc'.
WRT_HIS -- wrote history fields into time record = 1 / 1
MAIN: started time-steping.
STEP time[DAYS] KINETIC_ENRG POTEN_ENRG TOTAL_ENRG NET_VOLUME trd
0 15.00000 0.000000000E+00 2.1582955E+01 2.1582955E+01 5.5961804E+16 0
1 15.06250 3.374198928E-01 2.1582064E+01 2.1919484E+01 5.5961804E+16 0
ABNORMAL JOB END
USER TERMINATED
VMAX = 0.457E+03 IMAX,JMAX = 154 98
IINT,IEXT = 2 28
MAIN - number of records written into history file(s): 1
number of records written into restart file(s): 0
number of records written into averages file(s): 0
MAIN: Abnormal termination: BLOWUP
With Regards,
Murali
ahocean
Re: problem while forcing QuickScat Wind stress
#2 Unread post by ahocean »
Read this helpful topic:
viewtopic.php?f=17&t=77&hilit=VMAX
