Hello all
I am working on Lagrangian particle tracking (tracpy) and i decided to use soda as input file. But I don't know how to find vertical grid parameters such as hc, Cs_r,
Cs_w, theta_b, theta_s, hmin, tcline.
I have the same problem with my old roms history file.
Thanx in advance.
How to extract vertical grid from soda/history file.
Re: How to extract vertical grid from soda/history file.
SODA is not a ROMS run and therefore has a z-coordinate vertical grid. Its grid file has:
For an old ROMS run, those parameters should be in the history file. You can run "ncdump" on the file, pipe to more (or less) and see:
then further down:
DEPTH = 5.01, 15.07, 25.28, 35.76, 46.61, 57.98, 70.02, 82.92, 96.92,
112.32, 129.49, 148.96, 171.4, 197.79, 229.48, 268.46, 317.65, 381.39,
465.91, 579.31, 729.35, 918.37, 1139.15, 1378.57, 1625.7, 1875.11,
2125.01, 2375, 2625, 2875, 3125, 3375, 3625, 3875, 4125, 4375, 4625,
4875, 5125, 5375 ;
int Vtransform ;
Vtransform:long_name = "vertical terrain-following transformation equation" ;
int Vstretching ;
Vstretching:long_name = "vertical terrain-following stretching function" ;
double theta_s ;
theta_s:long_name = "S-coordinate surface control parameter" ;
double theta_b ;
theta_b:long_name = "S-coordinate bottom control parameter" ;
double Tcline ;
Tcline:long_name = "S-coordinate surface/bottom layer width" ;
Tcline:units = "meter" ;
double hc ;
hc:long_name = "S-coordinate parameter, critical depth" ;
hc:units = "meter" ;
Vtransform = 2 ;
Vstretching = 4 ;
theta_s = 7 ;
theta_b = 2 ;
Tcline = 250 ;
hc = 250 ;
Great, I think I have to make some changes to tracpy to recieve z-coordinate.
