comparion
pooran
Location: Khoramshahr Marine Science and Technology Universi
comparion
#1 Unread post by pooran »
Dear friends
i need to use your experience to correct my results. I used wind stress, shflux, swflux and swrad as input force files which provided from ECMWF-Interim. After running model for about 20 days, model 's currents speed and measurement did not have same trends :cry: that is while meansurment and ecmwf wind data are not so different :?: . measurement point is in deep water (about 700 m) and compare current is surface current.
I don't know what could be its difference source. i become really really appreciate if you help me to fix my problem with your excellent experience.
My heard file contains:
#define SPLINES
#undef WET_DRY
#define OUT_DOUBLE
#undef UV_SADVECTION
#define TS_U3HADVECTION
#define TS_C4VADVECTION
!#define TS_MPDATA
#define MIX_S_TS
#define EASTERN_WALL
#define WESTERN_WALL
#define NORTHERN_WALL
#define SOUTHERN_WALL
#define DIAGNOSTICS_UV
#define DIAGNOSTICS_TS
#undef ANA_GRID
#undef ANA_INITIAL
# undef ANA_SMFLUX
# undef ANA_STFLUX
# undef ANA_SSFLUX
# define ANA_BTFLUX
# define ANA_BSFLUX
#define UV_PSOURCE
#define TS_PSOURCE
#undef Q_PSOURCE
#define GLS_MIXING /*Generic Length-Scale mixing */
#if defined GLS_MIXING
# undef CANUTO_A
#else
# define ANA_VMIX
#define PERFECT_RESTART
#define SOLAR_SOURCE
ocean.in
(80.64 KiB) Downloaded 510 times
Re: comparion
Are those diurnal oscillations tidal or inertial in the observations? I see you don't have tides turned on.
