Variable not initialized in OA package compiled with f77
RubenDiez-Lazaro
#1 Unread post by RubenDiez-Lazaro »
In the input "oa.in" file, the "iclima" variable can get values from 0 to 3.
Nevertheless in the "oamain.F" source file only is considered this possibility:
if((iclima.eq.1).or.(iclima.eq.2))then
.......some_code_that_initialize_"nclm"........
so, when "iclima" is 0 or 3, the nclm variable is not initialized, at least when compile with f77...
It usually return a segmentation fault.
I avoid the problem inserting the line
nclm=0
in the "oamain.F" file, at line 63...
