Problem about yellow_sea case
I try to learn pyroms tools to generate grid ,initial and boundary file .
I download yellow_sea case files from http://www.people.arsc.edu/~kate/ROMS/HK/Yellow_Sea/.
I compile it well, but I get some error when I run it. Could someone give me some help?
run log
Process Information:
Node # 0 (pid= 19125) is active.
Model Input Parameters: ROMS/TOMS version 3.4
Wednesday - June 18, 2014 - 8:15:16 PM
Node # 1 (pid= 19126) is active.
Yellow Sea
Operating system : Linux
CPU/hardware : i686
Compiler system : gfortran
Compiler command : /home/chenzhen/install/mpich2-1.5/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none
Input Script : cal/ocean_yellow.in
SVN Root URL : https://www.myroms.org/svn/omlab/branches/jcwarner
SVN Revision : 已导出
Local Root : /home/chenzhen/COAWST
Header Dir : /home/chenzhen/COAWST/Projects/chenzhen/Yellow/ROMS/Include
Header file : yellow.h
Analytical Dir: /home/chenzhen/COAWST/Projects/chenzhen/Yellow/ROMS/Functionals
Resolution, Grid 01: 0080x0080x040, Parallel Nodes: 2, Tiling: 001x002
1080 ntimes Number of timesteps for 3-D equations.
800.000 dt Timestep size (s) for 3-D equations.
108 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
108 nHIS Number of timesteps between the writing fields
into history file.
0.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
1.0000E-05 Akt_bak(01) Background vertical mixing coefficient (m2/s)
1.0000E-05 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
1.0000E-04 Akv_bak Background vertical mixing coefficient (m2/s)
0.0000E+00 Zob Bottom roughness (m).
1.0000E+01 blk_ZQ Height (m) of surface air humidity measurement.
1.0000E+01 blk_ZT Height (m) of surface air temperature measurement.
5.000 Tcline S-coordinate surface/bottom layer width (m) used
1000.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
for tracer 02: salt
for 3D momentum.
0.000 T0 Background potential temperature (C) constant.
0.000 S0 Background salinity (PSU) constant.
Output Restart File: result/ocean_rst.nc
Output History File: result/ocean_his.nc
Input Grid File: Data/yellow_sea_grid.nc
Input Nonlinear Initial File: Data/Yellow_Sea_ini_SODA.nc
Input Forcing File 01: Data/tides_yellow_sea.nc
Input Boundary File: Data/Yellow_Sea_bdry_SODA.nc
Tile partition information for Grid 01: 0080x0080x0040 tiling: 001x002
tile Istr Iend Jstr Jend Npts
0 1 80 1 40 128000
1 1 80 41 80 128000
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 80.50 0.50 40.50 RHO-points
1 0.50 80.50 40.50 80.50 RHO-points
0 1.00 80.00 0.50 40.50 U-points
1 1.00 80.00 40.50 80.50 U-points
0 0.50 80.50 1.00 40.50 V-points
1 0.50 80.50 40.50 80.00 V-points
HaloSizeI(1) = 182
HaloSizeJ(1) = 104
TileSide(1) = 85
TileSize(1) = 3910
YELLOW_SEA Yellow Sea
ADD_FSOBC Adding tidal elevation to proccesed OBC data.
ADD_M2OBC Adding tidal currents to proccesed OBC data.
BULK_FLUXES Surface bulk fluxes parametererization.
EMINUSP Compute Salt Flux using E-P.
LONGWAVE_OUT Compute outgoing longwave radiation internally.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
SOUTH_FSCHAPMAN Southern edge, free-surface, Chapman condition.
SOUTH_M2FLATHER Southern edge, 2D momentum, Flather condition.
SOUTH_M3NUDGING Southern edge, 3D momentum, passive/active outflow/inflow.
SOUTH_M3RADIATION Southern edge, 3D momentum, radiation condition.
SOUTH_TNUDGING Southern edge, tracers, passive/active outflow/inflow.
SOUTH_TRADIATION Southern edge, tracers, radiation condition.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= EXIT CODE: 11
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11)
This typically refers to a problem with your application.
Please see the FAQ page for debugging suggestions
yellow_sea.h
#define ROMS_MODEL
#undef STATIONS
#undef FLOATS
#undef DIAGNOSTICS_UV
#define UV_LDRAG
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#undef MY25_MIXING
# if defined GLS_MIXING || defined MY25_MIXING
#undef LMD_MIXING
#ifdef LMD_MIXING
# define LMD_CONVEC
# define LMD_NONLOCAL
# define LMD_RIMIX
# define LMD_SKPP
#undef ANA_SMFLUX
#undef ANA_STFLUX
#undef ANA_SSFLUX
#define BULK_FLUXES
#define LONGWAVE_OUT
#define EMINUSP
#define SOUTH_FSCHAPMAN
#define SOUTH_M2FLATHER
#define SOUTH_M3RADIATION
#define SOUTH_M3NUDGING
#define SOUTH_TRADIATION
#define SOUTH_TNUDGING
#undef ANA_FSOBC
#undef ANA_M2OBC
#define UV_TIDES
#define SSH_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
run log
Yellow Sea
CPU/hardware : i686
SVN Revision : 已导出
to standard output.
into history file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
0 1 80 1 40 128000
1 1 80 41 80 128000
HaloSizeI(1) = 182
HaloSizeJ(1) = 104
TileSide(1) = 85
TileSize(1) = 3910
= EXIT CODE: 11
yellow_sea.h
#define ROMS_MODEL
#undef STATIONS
#undef FLOATS
#define UV_LDRAG
#undef MY25_MIXING
#undef LMD_MIXING
#ifdef LMD_MIXING
# define LMD_CONVEC
# define LMD_RIMIX
# define LMD_SKPP
#undef ANA_SMFLUX
#undef ANA_STFLUX
#undef ANA_SSFLUX
#define BULK_FLUXES
#define EMINUSP
#undef ANA_FSOBC
#undef ANA_M2OBC
#define UV_TIDES
#define SSH_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
Re: Problem about yellow_sea case
I wrote this with what I know of segmentation faults. In your case, you should carefully compare the ocean_yellow.in from my site with an ocean.in from COAWST. Each ROMS version needs to be run with a compatible ocean.in. Ditto the list of cppdefs.
Hi katekate wrote:I wrote this with what I know of segmentation faults. In your case, you should carefully compare the ocean_yellow.in from my site with an ocean.in from COAWST. Each ROMS version needs to be run with a compatible ocean.in. Ditto the list of cppdefs.
I set wrong MyAppCPP in ocean.in, so it shows an error .
I changed it, and get another error.It seems I didn't have wind components in the forcing file.
Does this case need wind condition ?
--chenzhen
run log
Node # 0 (pid= 3374) is active.
Node # 1 (pid= 3375) is active.
Thursday - June 19, 2014 - 7:33:15 AM
Yellow Sea
CPU/hardware : i686
SVN Revision : 已导出
to standard output.
into history file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
0 1 80 1 40 128000
1 1 80 41 80 128000
HaloSizeI(1) = 182
HaloSizeJ(1) = 104
TileSide(1) = 85
TileSize(1) = 3910
YELLOW Yellow Sea
Vertical S-coordinate System:
40 0.0000000 0.0000000 0.000 0.000 0.000 0.000
39 -0.0250000 -0.0017775 -0.067 -0.067 -0.108 -0.132
38 -0.0500000 -0.0037835 -0.134 -0.134 -0.217 -0.268
37 -0.0750000 -0.0060921 -0.203 -0.203 -0.330 -0.409
36 -0.1000000 -0.0087922 -0.272 -0.272 -0.446 -0.557
35 -0.1250000 -0.0119914 -0.342 -0.342 -0.568 -0.714
34 -0.1500000 -0.0158197 -0.415 -0.415 -0.695 -0.882
33 -0.1750000 -0.0204330 -0.489 -0.489 -0.830 -1.063
32 -0.2000000 -0.0260168 -0.565 -0.565 -0.974 -1.261
31 -0.2250000 -0.0327879 -0.644 -0.644 -1.129 -1.479
30 -0.2500000 -0.0409944 -0.727 -0.727 -1.298 -1.722
29 -0.2750000 -0.0509117 -0.815 -0.815 -1.483 -1.995
28 -0.3000000 -0.0628318 -0.907 -0.907 -1.688 -2.303
27 -0.3250000 -0.0770446 -1.005 -1.005 -1.914 -2.650
26 -0.3500000 -0.0938098 -1.110 -1.110 -2.165 -3.042
25 -0.3750000 -0.1133185 -1.221 -1.221 -2.442 -3.481
24 -0.4000000 -0.1356491 -1.339 -1.339 -2.746 -3.968
23 -0.4250000 -0.1607245 -1.464 -1.464 -3.076 -4.504
22 -0.4500000 -0.1882840 -1.596 -1.596 -3.430 -5.082
21 -0.4750000 -0.2178817 -1.732 -1.732 -3.804 -5.695
20 -0.5000000 -0.2489214 -1.872 -1.872 -4.191 -6.334
19 -0.5250000 -0.2807264 -2.014 -2.014 -4.585 -6.986
18 -0.5500000 -0.3126323 -2.157 -2.157 -4.981 -7.639
17 -0.5750000 -0.3440788 -2.298 -2.298 -5.372 -8.285
16 -0.6000000 -0.3746809 -2.437 -2.437 -5.755 -8.916
15 -0.6250000 -0.4042644 -2.573 -2.573 -6.128 -9.529
14 -0.6500000 -0.4328656 -2.707 -2.707 -6.492 -10.125
13 -0.6750000 -0.4607052 -2.839 -2.839 -6.849 -10.708
12 -0.7000000 -0.4881475 -2.970 -2.970 -7.201 -11.285
11 -0.7250000 -0.5156591 -3.102 -3.102 -7.555 -11.862
10 -0.7500000 -0.5437741 -3.234 -3.234 -7.914 -12.450
9 -0.7750000 -0.5730691 -3.370 -3.370 -8.285 -13.058
8 -0.8000000 -0.6041494 -3.510 -3.510 -8.672 -13.697
7 -0.8250000 -0.6376434 -3.657 -3.657 -9.083 -14.378
6 -0.8500000 -0.6742046 -3.811 -3.811 -9.523 -15.112
5 -0.8750000 -0.7145184 -3.974 -3.974 -9.999 -15.911
4 -0.9000000 -0.7593114 -4.148 -4.148 -10.517 -16.788
3 -0.9250000 -0.8093643 -4.336 -4.336 -11.086 -17.756
2 -0.9500000 -0.8655258 -4.539 -4.539 -11.713 -18.829
1 -0.9750000 -0.9287272 -4.759 -4.759 -12.408 -20.024
0 -1.0000000 -1.0000000 -5.000 -5.000 -13.179 -21.359
Time Splitting Weights: ndtfast = 20 nfast = 29
3-0.0011514592651645 0.0501156998674241-0.0034654566136461 0.1501639558342180
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649003
6 0.0029141799764308 0.0501428056118168 0.0000580677400948 0.3006719858911027
7 0.0054132615310267 0.0499970966129953 0.0054713292711215 0.3506690825040980
8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405419
9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876602
10 0.0161716623600090 0.0486998273761630 0.0421751148367487 0.4983983377638232
11 0.0207585511322367 0.0478912442581626 0.0629336659689854 0.5462895820219857
12 0.0257765478740990 0.0468533167015507 0.0887102138430844 0.5931428987235364
13 0.0311633730493853 0.0455644893078458 0.1198735868924698 0.6387073880313822
14 0.0368391158442262 0.0440063206553765 0.1567127027366960 0.6827137086867586
15 0.0427031802506397 0.0421643648631652 0.1994158829873357 0.7248780735499238
16 0.0486309868367616 0.0400292058506332 0.2480468698240973 0.7649072794005570
17 0.0544704302037592 0.0375976565087951 0.3025173000278565 0.8025049359093521
18 0.0600380921294286 0.0348741349986072 0.3625553921572851 0.8373790709079593
19 0.0651152103984763 0.0318722303921357 0.4276706025557614 0.8692513013000950
20 0.0694434033194840 0.0286164698722119 0.4971140058752453 0.8978677711723069
21 0.0727201499285570 0.0251442997062377 0.5698341558038024 0.9230120708785446
22 0.0745940258796570 0.0215082922098099 0.6444281816834594 0.9445203630883545
23 0.0746596950216180 0.0177785909158270 0.7190878767050775 0.9622989540041815
24 0.0724526566618460 0.0140456061647461 0.7915405333669234 0.9763445601689277
25 0.0674437485167025 0.0104229733316538 0.8589842818836260 0.9867675335005816
26 0.0590334053485720 0.0070507859058187 0.9180176872321980 0.9938183194064003
27 0.0465456732896125 0.0040991156383901 0.9645633605218105 0.9979174350447904
28 0.0292219798521905 0.0017718319739095 0.9937853403740009 0.9996892670186999
29 0.0062146596259991 0.0003107329813000 1.0000000000000000 0.9999999999999998
Minimum X-grid spacing, DXmin = 8.88372172E+00 km
Maximum X-grid spacing, DXmax = 1.16654601E+01 km
Minimum Y-grid spacing, DYmin = 7.65876935E+00 km
Maximum Y-grid spacing, DYmax = 1.00685906E+01 km
Minimum Z-grid spacing, DZmin = 6.69436342E-02 m
Maximum Z-grid spacing, DZmax = 1.33482535E+00 m
Minimum barotropic Courant Number = 3.67539224E-02
Maximum barotropic Courant Number = 8.79350377E-02
Maximum Coriolis Courant Number = 7.65944146E-02
NLM: GET_STATE - Read state initial conditions, t = 39451 12:00:00
(File: Yellow_Sea_ini_SODA.nc, Rec=0001, Index=1)
- free-surface
(Min = 8.77033105E-02 Max = 2.54816829E-01)
(Min = -6.69384175E+33 Max = 1.03453879E-01)
(Min = -1.45373899E+33 Max = 6.30954578E-02)
- u-momentum component
(Min = -9.98603466E+33 Max = 1.03502824E-01)
- v-momentum component
(Min = -4.06589696E+33 Max = 7.96828220E-02)
- potential temperature
(Min = -8.20340958E+33 Max = 1.87979098E+01)
- salinity
(Min = -8.20340958E+33 Max = 3.38521819E+01)
GET_NGFLD - tidal period
(Min = 4.30820446E+04 Max = 9.67260841E+04)
(Min = 0.00000000E+00 Max = 6.20000029E+00)
(Min = 0.00000000E+00 Max = 6.26344809E+00)
(Min = -1.53817380E+00 Max = 3.14159265E+00)
(Min = 0.00000000E+00 Max = 6.24788031E+00)
(Min = 0.00000000E+00 Max = 7.62899017E+00)
(Min = -6.62547231E-01 Max = 1.86996365E+00)
GET_2DFLD - unable to find requested variable: Uwind
in file:
in file:
Node # 0 CPU: 0.912
Node # 1 CPU: 1.108
Total: 2.020
Reading of input data ............................ 0.220 (10.8911 %)
2D/3D coupling, vertical metrics ................. 0.024 ( 1.1881 %)
Omega vertical velocity .......................... 0.020 ( 0.9901 %)
Equation of state for seawater ................... 0.224 (11.0891 %)
Total: 0.488 24.1584
Message Passage: 2D halo exchanges ............... 0.004 ( 0.1980 %)
Message Passage: 3D halo exchanges ............... 0.028 ( 1.3862 %)
Message Passage: data broadcast .................. 0.400 (19.8020 %)
Message Passage: data scattering.................. 0.268 (13.2672 %)
Total: 0.700 34.6534
All percentages are with respect to total time = 2.020
Analytical header files used:
REASON: No error
Yes, you have selected BULK_FLUXES which needs winds. Here are your choices:
https://www.myroms.org/wiki/index.php/F ... forcing.3F
#define ANA_SMFLUX and #undef BULK_FLUX. Otherwise it needs to read in the heat flux and wind forcing.
Thank you for your reply !simion1232006 wrote:#define ANA_SMFLUX and #undef BULK_FLUX. Otherwise it needs to read in the heat flux and wind forcing.
I #define ANA_SMFLUX and ANA_STFLUX.h ,#undef BULK_FLUX . Still get an error !
I couldn't find zeta_time in Yellow_Sea_bdry_SODA.nc. I also check make_bdry_file.py , also couldn't find some aboult 'zeta_time'.
RUN LOG
Node # 0 (pid= 14858) is active.
Node # 1 (pid= 14859) is active.
Saturday - June 21, 2014 - 10:14:49 AM
Yellow Sea
CPU/hardware : i686
SVN Revision : 已导出
to standard output.
into history file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
0 1 80 1 40 128000
1 1 80 41 80 128000
HaloSizeI(1) = 182
HaloSizeJ(1) = 104
TileSide(1) = 85
TileSize(1) = 3910
YELLOW Yellow Sea
- free-surface
- salinity
NETCDF_GET_FVAR_1D - error while inquiring ID for variable: zeta_time
in input file: Data/Yellow_Sea_bdry_SODA.nc
call from: get_cycle.F
Node # 0 CPU: 0.848
Node # 1 CPU: 0.844
Total: 1.692
Reading of input data ............................ 0.212 (12.5295 %)
2D/3D coupling, vertical metrics ................. 0.020 ( 1.1821 %)
Omega vertical velocity .......................... 0.020 ( 1.1820 %)
Equation of state for seawater ................... 0.136 ( 8.0378 %)
Total: 0.388 22.9314
Message Passage: 2D halo exchanges ............... 0.020 ( 1.1820 %)
Message Passage: 3D halo exchanges ............... 0.020 ( 1.1820 %)
Message Passage: data broadcast .................. 0.180 (10.6384 %)
Message Passage: data scattering.................. 0.288 (17.0210 %)
Total: 0.508 30.0234
All percentages are with respect to total time = 1.692
REASON: NetCDF: Variable not found
That python script probably called it "ocean_time" instead of "zeta_time". One choice is to modify the appropriate entries in the varinfo.dat file. Another choice is to modify the python script so that the "time" attribute gets added to fields like "zeta_south", set to "ocean_time". A third choice is to run ncatted to do the same thing.
Best choice would be using the ROMS official input file generating scripts (Matlab). You can modified it for your own purpose. Those scripts guarantee an standard input and usually would not make any mistake. I personally don't recommend change anything in varinfo.dat, as it might cause confusion later.
Varinfo.dat is the way it is to allow users the freedom to modify it for our particular needs (even naming variables in French if so desired). You can also have a different varinfo.dat for each domain, for instance when changing forcing fields requires a change of scaling. Those using pyroms must be bold enough to do a little customization.
Thank you for your suggestion !kate wrote:That python script probably called it "ocean_time" instead of "zeta_time". One choice is to modify the appropriate entries in the varinfo.dat file. Another choice is to modify the python script so that the "time" attribute gets added to fields like "zeta_south", set to "ocean_time". A third choice is to run ncatted to do the same thing.
I am a newer in python and ROMS model. I have a try to change the dimensions 'ocean_time' to 'zeta_time'.
Scrip:
import netCDF4
fname='/home/chenzhen/COAWST/Projects/chenzhen/Yellow/Data/Yellow_Sea_bdry_SODA.nc'
f=netCDF4.Dataset(fname,'r+')
f.renameDimension('ocean_time','zeta_time')
I can find the dimensions is changed from 'ocean_time' to 'zeta_time'.
But when I run it ,it still show a same error .
Could you give me some help ? You can find Yellow_Sea_bdry_SODA.nc in attachment.
- Yellow_Sea_bdry_SODA.nc
- (5.3 MiB) Downloaded 302 times
double ocean_time(zeta_time) ;
ocean_time:long_name = "time" ;
ocean_time:units = "days since 1900-01-01 00:00:00" ;
ocean_time:field = " " ;
OK, so you changed the dimension name from ocean_time to zeta_time, but you didn't change the variable name. The reason I didn't suggest changing the variable/dimension names is that varinfo.dat points to zeta_time for zeta, v2d_time for ubar/vbar, v3d_time for u/v, and so on. You would need to duplicate the ocean_time variable, renaming it to each of these things.
Better would be to add the time attributes, to get:
double v_west(zeta_time, s_rho, eta_v) ;
v_west:_FillValue = -9.98999971057742e+33 ;
v_west:long_name = "3D v-momentum west boundary condition" ;
v_west:units = "meter second-1" ;
v_west:field = "v_east, scalar, series" ;
v_west:time = "ocean_time" ;
Thank you kate !kate wrote:Next time, please just include the "ncdump -h" from the file, not the entire binary file.Code: Select all
double ocean_time(zeta_time) ; ocean_time:long_name = "time" ; ocean_time:units = "days since 1900-01-01 00:00:00" ; ocean_time:field = " " ;
Better would be to add the time attributes, to get:Code: Select all
double v_west(zeta_time, s_rho, eta_v) ; v_west:_FillValue = -9.98999971057742e+33 ; v_west:long_name = "3D v-momentum west boundary condition" ; v_west:units = "meter second-1" ; v_west:field = "v_east, scalar, series" ; v_west:time = "ocean_time" ;
I modified varinfo.dat file. The error about "zeta_time" disappered. But I get another error ,when I run it. And I couldn't find any infomation about it. Could you give me some advice?
--chenzhen
run log
Node # 0 (pid= 3851) is active.
Node # 1 (pid= 3852) is active.
Sunday - June 29, 2014 - 11:51:58 PM
Yellow Sea
CPU/hardware : i686
SVN Revision : 已导出
to standard output.
into history file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
0 1 80 1 40 128000
1 1 80 41 80 128000
HaloSizeI(1) = 182
HaloSizeJ(1) = 104
TileSide(1) = 85
TileSize(1) = 3910
YELLOW Yellow Sea
- free-surface
- salinity
GET_NGFLD - free-surface southern boundary condition, t = 39451 12:00:00
(Rec=0001, Index=2, File: Yellow_Sea_bdry_SODA.nc)
(Tmin= 39451.5000 Tmax= 39501.5000)
(Min = 0.00000000E+00 Max = 2.46359504E-01)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 39451 12:00:00
(Min = -4.58702028E-02 Max = 1.06274266E-01)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 39451 12:00:00
(Min = -9.42163486E-02 Max = 3.96214616E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 39451 12:00:00
(Min = -4.67661370E-02 Max = 1.02964423E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 39451 12:00:00
(Min = -1.00452846E-01 Max = 6.09981780E-02)
GET_NGFLD - temperature southern boundary condition, t = 39451 12:00:00
(Min = 0.00000000E+00 Max = 1.88157837E+01)
GET_NGFLD - salinity southern boundary condition, t = 39451 12:00:00
(Min = 0.00000000E+00 Max = 3.41110077E+01)
Maximum grid stiffness ratios: rx0 = 3.500000E-01 (Beckmann and Haidvogel)
rx1 = 1.504617E+01 (Haney)
Initial basin volumes: TotVolume = 1.2341359223E+12 m3
MinVolume = 4.8927290410E+06 m3
MaxVolume = 1.1700882170E+08 m3
Max/Min = 2.3914837859E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 04260763 - 00001080)
Node # 0 CPU: 0.876
Node # 1 CPU: 0.892
Total: 1.768
Initialization ................................... 1.172 (66.2896 %)
OI data assimilation ............................. 0.004 ( 0.2262 %)
Reading of input data ............................ 0.300 (16.9684 %)
2D/3D coupling, vertical metrics ................. 0.024 ( 1.3574 %)
Omega vertical velocity .......................... 0.020 ( 1.1312 %)
Equation of state for seawater ................... 0.140 ( 7.9186 %)
Total: 1.660 93.8914
Message Passage: 2D halo exchanges ............... 0.012 ( 0.6787 %)
Message Passage: 3D halo exchanges ............... 0.012 ( 0.6788 %)
Message Passage: data broadcast .................. 0.260 (14.7060 %)
Message Passage: data reduction .................. 0.004 ( 0.2263 %)
Message Passage: data scattering.................. 0.256 (14.4795 %)
Total: 0.544 30.7693
All percentages are with respect to total time = 1.768
ROMS/TOMS: DONE... Sunday - June 29, 2014 - 11:51:59 PM
These minimum values are worrisome. I'd look into where they are coming from.NLM: GET_STATE - Read state initial conditions, t = 39451 12:00:00
- free-surface
- salinity
