Coupled ROMS SWAN stops with 'blow up' but output looks fine
robjenkinsiii
#1 Unread post by robjenkinsiii »
Hi All,
I've been working with a coupled ROMS/SWAN application. I had initially tested the application for over a 1 month period forcing ROMS with river, tide, and wind while forcing SWAN with wind at 2hr intervals. This worked fine on 6,12, & 24 cpu's for each model.
I recently moved on to extending the simulation to a 4 year period, and increasing SWAN wind forcing to hourly intervals. The model runs but ROMS quits after 1.5 months stating that the model is blowing up. What's curious to me is that ROMS output looks healthy, as does SWAN, although, throughout, the SWAN does report warnings for the wave height at the boundary being >10% different than the imposed.
      0     0 00:00:00  0.000000E+00  2.566465E+02  2.566465E+02  1.657367E+12
          (000,000,00)  0.000000E+00  0.000000E+00  0.000000E+00  0.000000E+00
      DEF_HIS   - creating history file, Grid 01: Output/ocean_his_0001.nc
      1     0 00:02:30  1.072500E-06  2.714058E+02  2.714058E+02  1.566991E+12
          (047,186,10)  1.016723E-02  2.227676E-03  0.000000E+00  5.021956E-02
      2     0 00:05:00  3.545184E-06  2.714064E+02  2.714064E+02  1.566992E+12
          (062,185,10)  6.898552E-03  1.458758E-03  4.373714E-02  6.960201E-02
  26355    45 18:07:30  1.090714E-02  2.701372E+02  2.701481E+02  1.554365E+12
          (002,256,10)  2.582380E-01  0.000000E+00  1.243842E+03  4.186573E+00
  26356    45 18:10:00  1.086319E-02  2.701226E+02  2.701335E+02  1.554063E+12
          (002,256,10)  2.498994E-01  0.000000E+00  1.283567E+03  4.076820E+00
  26357    45 18:12:30  1.081451E-02  2.701087E+02  2.701195E+02  1.553765E+12
          (002,256,10)  2.432082E-01  0.000000E+00  1.315139E+03  3.982541E+00
  26358    45 18:15:00  1.076116E-02  2.700955E+02  2.701062E+02  1.553473E+12
          (002,256,10)  2.376432E-01  0.000000E+00  1.340432E+03  3.940091E+00
  26359    45 18:17:30  1.070618E-02  2.700829E+02  2.700936E+02  1.553185E+12
          (002,256,10)  2.329951E-01  0.000000E+00  1.361434E+03  5.304341E+00
  26360    45 18:20:00  1.065577E-02  2.700709E+02  2.700816E+02  1.552904E+12
          (002,256,10)  2.292045E-01  0.000000E+00  1.378942E+03  6.378915E+00
  26361    45 18:22:30  1.062528E-02  2.700597E+02  2.700703E+02  1.552627E+12
          (002,256,10)  2.260064E-01  0.000000E+00  1.393181E+03  9.145987E+00
  26362    45 18:25:00  1.073788E-02  2.700490E+02  2.700598E+02  1.552357E+12
          (002,256,10)  2.231079E-01  0.000000E+00  1.405163E+03  1.773106E+01
  26363    45 18:27:30  1.304447E-02  2.700391E+02  2.700521E+02  1.552092E+12
          (002,256,10)  2.204189E-01  0.000000E+00  1.416003E+03  6.036142E+01
 Node   #  5 CPU:   16131.372
 Node   #  1 CPU:   16131.371
 Node   #  2 CPU:   16131.371
 Node   #  3 CPU:   16131.371
 Node   #  4 CPU:   16131.371
      WRT_RST   - wrote re-start fields (Index=1,2) into time record = 0000003
 Node   #  0 CPU:   16131.372
             number of time records written in HISTORY file = 00000368
             number of time records written in RESTART file = 00000046
 Analytical header files used:
     ROMS/Functionals/ana_btflux.h
     ROMS/Functionals/ana_fsobc.h
     ROMS/Functionals/ana_m2obc.h
     ROMS/Functionals/ana_stflux.h
 ROMS/TOMS: DONE... Thursday - April 24, 2014 -  5:55:30 PM
 Time of computation ->  20060211.200000      in sec:    3614400.
 accuracy OK in   1.41 % of wet grid points ( 98.00 % required)
  ** WARNING : Differences in wave height at the boundary
 Relative difference between input and computation >=   0.10
                         Hs[m]      Hs[m]      Hs[-]
     ix    iy  index   (input) (computed) (relative)
   150   252   4062       1.00       0.63       0.37
   150   251   4061       1.00       0.62       0.37
   150   250   4060       1.00       0.62       0.38
   150   249   4059       1.00       0.62       0.38
   150   248   4058       1.00       0.62       0.38
   150   247   4057       1.00       0.62       0.38
   150   246   4056       1.00       0.62       0.38
   150   245   4055       1.00       0.62       0.38
   150   244   4054       1.00       0.62       0.38
   150   243   4053       1.00       0.62       0.38
   150   242   4052       1.00       0.62       0.38
   150   241   4051       1.00       0.62       0.38
   150   240   4050       1.00       0.62       0.38
   150   239   4049       1.00       0.62       0.38
   150   238   4048       1.00       0.62       0.38
   150   237   4047       1.00       0.62       0.38
   150   236   4046       1.00       0.62       0.38
   150   235   4045       1.00       0.62       0.38
   150   234   4044       1.00       0.62       0.37
   150   233   4043       1.00       0.62       0.37
   150   232   4042       1.00       0.63       0.37
   150   231   4041       1.00       0.63       0.37
   150   230   4040       1.00       0.63       0.37
   150   229   4039       1.00       0.63       0.36
   150   228   4038       1.00       0.63       0.36
   150   227   4037       1.00       0.64       0.36
   150   226   4036       1.00       0.64       0.36
   150   225   4035       1.00       0.64       0.36
   150   224   4034       1.00       0.64       0.36
   150   223   4033       1.00       0.64       0.36
   150   222   4032       1.00       0.64       0.36
   150   221   4031       1.00       0.64       0.35
   150   220   4030       1.00       0.64       0.35
   150   219   4029       1.00       0.64       0.35
 Time of computation ->  20060211.203000      in sec:    3616200.
 accuracy OK in   1.52 % of wet grid points ( 98.00 % required)
                         Hs[m]      Hs[m]      Hs[-]
   150   251   4061       1.00       0.63       0.37
   150   250   4060       1.00       0.62       0.37
   150   249   4059       1.00       0.62       0.37
   150   236   4046       1.00       0.62       0.37
   150   235   4045       1.00       0.62       0.37
   150   234   4044       1.00       0.63       0.37
   150   233   4043       1.00       0.63       0.37
   150   230   4040       1.00       0.63       0.36
   150   229   4039       1.00       0.64       0.36
   150   228   4038       1.00       0.64       0.36
   150   224   4034       1.00       0.64       0.35
   150   223   4033       1.00       0.64       0.35
Looking in the forum, I found this post. I thought it could be related to my issue, however, I have set SWAN to write output to .mat files.
Any suggestions would be greatly appreciated.
swan.in
(1.64 KiB) Downloaded 593 times
