Help!
Because my history results takes a long time and output is too much, I run ROMS from his_0001.nc to his_10000.nc.
But history result can only give his_9999.nc. SO how to change hisfile for his_****.nc to his_*****.nc?
Which fortran program can easily solved this problem ?
Thank you!
Re: how to change hisfile for his_****.nc to his_*****.nc
The change is in output.F:
@@ -103,7 +110,12 @@
ifile=(iic(ng)-1)/ndefHIS(ng)+1
IF (Master) THEN
WRITE (HIS(ng)%name,10) TRIM(HIS(ng)%base), ifile
+#if defined NEP5 || defined NEP6 || defined CASPIAN || defined CHUKCHI \
+ || defined CORAL || defined NWA || defined ARC_NATL
+ 10 FORMAT (a,'_',i5.5,'.nc')
+#else
10 FORMAT (a,'_',i4.4,'.nc')
+#endif
# ifdef DISTRIBUTE
CALL mp_bcasts (ng, iNLM, HIS(ng)%name)
