I meet with blowing up at the beginning of the model, can someone help me to find the problem?
Thanks a lot.
1296000 ntimes Number of timesteps for 3-D equations.
1200.000 dt Timestep size (s) for 3-D equations.
120 ndtfast Number of timesteps for 2-D equations between
1 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
72 nHIS Number of timesteps between the writing fields
into history file.
72 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
72 nAVG Number of timesteps between the writing of
72 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
5.0000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
1 lmd_Jwt Jerlov water type.
3.0000E-01 theta_b S-coordinate bottom control parameter.
9.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
9.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
9.0000E+01 Znudg Nudging/relaxation time scale (days)
9.0000E+01 M2nudg Nudging/relaxation time scale (days)
9.0000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.0000E+01 obcfac Factor between passive and active
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
T LtracerCLM(01) Turning ON processing of climatology tracer 01: temp
T LtracerCLM(02) Turning ON processing of climatology tracer 02: salt
T Hout(idu3dE) Write out 3D U-wastward component at RHO-points.
T Hout(idv3dN) Write out 3D V-northward component at RHO-points.
T Hout(idHsbl) Write out depth of surface boundary layer.
T Aout(idu3dE) Write out averaged 3D U-eastward at RHO-points.
T Aout(idv3dN) Write out averaged 3D V-northward at RHO-points.
T Aout(idHsbl) Write out averaged depth of surface boundary layer.
Output Restart File: /public/userspace/ljd/IO_d10/IO_rst_d10.nc
Prefix for History Files: /public/userspace/ljd/IO_d10/IO_his_d10
Prefix for Averages Files: /public/userspace/ljd/IO_d10/IO_avg_d10
Input Grid File: IO_grd_d10.nc
Input Nonlinear Initial File: IO_ini_d10.nc
Input Forcing File 01: IO_frc_d10_01.nc
IO_frc_d10_02.nc
IO_frc_d10_03.nc
IO_frc_d10_04.nc
IO_frc_d10_05.nc
IO_frc_d10_06.nc
IO_frc_d10_07.nc
IO_frc_d10_08.nc
IO_frc_d10_09.nc
IO_frc_d10_10.nc
IO_frc_d10_11.nc
IO_frc_d10_12.nc
Input Climatology File: IO_clm_d10_TSUVZ.nc
Input Boundary File: IO_bry_d10.nc
Tile partition information for Grid 01: 0799x0629x0040 tiling: 016x012
tile Istr Iend Jstr Jend Npts
0 1 50 1 50 100000
1 51 100 1 50 100000
2 101 150 1 50 100000
3 151 200 1 50 100000
4 201 250 1 50 100000
5 251 300 1 50 100000
6 301 350 1 50 100000
HaloSizeI(1) = 124
HaloSizeJ(1) = 130
TileSide(1) = 59
TileSize(1) = 3304
zeta 1 Closed Chapman Imp Chapman Imp Closed
u 1 Closed Rad + Nud Rad + Nud Closed
v 1 Closed Rad + Nud Rad + Nud Closed
IO_D10 Control run for the Indian Ocean, 1/10*1/10 deg
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
40 0.0000000 0.0000000 0.000 0.000 0.000 0.000
39 -0.0250000 -0.0076503 -1.250 -1.250 -26.133 -51.016
38 -0.0500000 -0.0156736 -2.500 -2.500 -53.479 -104.459
37 -0.0750000 -0.0241410 -3.750 -3.750 -82.270 -160.790
36 -0.1000000 -0.0331262 -5.000 -5.000 -112.745 -220.490
35 -0.1250000 -0.0427053 -6.250 -6.250 -145.151 -284.053
34 -0.1500000 -0.0529559 -7.500 -7.500 -179.742 -351.984
33 -0.1750000 -0.0639559 -8.750 -8.750 -216.770 -424.791
32 -0.2000000 -0.0757823 -10.000 -10.000 -256.486 -502.972
31 -0.2250000 -0.0885086 -11.250 -11.250 -299.129 -587.009
30 -0.2500000 -0.1022034 -12.500 -12.500 -344.922 -677.345
29 -0.2750000 -0.1169269 -13.750 -13.750 -394.061 -774.373
28 -0.3000000 -0.1327288 -15.000 -15.000 -446.708 -878.416
27 -0.3250000 -0.1496453 -16.250 -16.250 -502.980 -989.710
26 -0.3500000 -0.1676968 -17.500 -17.500 -562.943 -1108.387
25 -0.3750000 -0.1868861 -18.750 -18.750 -626.608 -1234.466
24 -0.4000000 -0.2071978 -20.000 -20.000 -693.923 -1367.845
23 -0.4250000 -0.2285984 -21.250 -21.250 -764.779 -1508.309
22 -0.4500000 -0.2510387 -22.500 -22.500 -839.018 -1655.535
21 -0.4750000 -0.2744569 -23.750 -23.750 -916.437 -1809.124
20 -0.5000000 -0.2987836 -25.000 -25.000 -996.811 -1968.621
19 -0.5250000 -0.3239476 -26.250 -26.250 -1079.908 -2133.566
18 -0.5500000 -0.3498824 -27.500 -27.500 -1165.512 -2303.525
17 -0.5750000 -0.3765328 -28.750 -28.750 -1253.444 -2478.138
16 -0.6000000 -0.4038607 -30.000 -30.000 -1343.580 -2657.159
15 -0.6250000 -0.4318501 -31.250 -31.250 -1435.867 -2840.484
14 -0.6500000 -0.4605110 -32.500 -32.500 -1530.338 -3028.176
13 -0.6750000 -0.4898810 -33.750 -33.750 -1627.116 -3220.482
12 -0.7000000 -0.5200268 -35.000 -35.000 -1726.417 -3417.833
11 -0.7250000 -0.5510432 -36.250 -36.250 -1828.549 -3620.848
10 -0.7500000 -0.5830519 -37.500 -37.500 -1933.909 -3830.319
9 -0.7750000 -0.6162000 -38.750 -38.750 -2042.975 -4047.201
8 -0.8000000 -0.6506573 -40.000 -40.000 -2156.300 -4272.599
7 -0.8250000 -0.6866143 -41.250 -41.250 -2274.502 -4507.754
6 -0.8500000 -0.7242808 -42.500 -42.500 -2398.264 -4754.029
5 -0.8750000 -0.7638835 -43.750 -43.750 -2528.324 -5012.899
4 -0.9000000 -0.8056655 -45.000 -45.000 -2665.473 -5285.946
3 -0.9250000 -0.8498858 -46.250 -46.250 -2810.552 -5574.854
2 -0.9500000 -0.8968188 -47.500 -47.500 -2964.454 -5881.408
1 -0.9750000 -0.9467546 -48.750 -48.750 -3128.123 -6207.496
0 -1.0000000 -1.0000000 -50.000 -50.000 -3302.557 -6555.114
Time Splitting Weights for Grid 01: ndtfast = 120 nfast = 162
ndtfast, nfast = 120 162 nfast/ndtfast = 1.35000
1.000000000000 1.016453155986 0.508226577993 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.26033
Minimum X-grid spacing, DXmin = 9.61983482E+00 km
Maximum X-grid spacing, DXmax = 1.11132834E+01 km
Minimum Y-grid spacing, DYmin = 9.62858029E+00 km
Maximum Y-grid spacing, DYmax = 1.11132783E+01 km
Minimum Z-grid spacing, DZmin = 1.25000000E+00 m
Maximum Z-grid spacing, DZmax = 3.47617667E+02 m
Minimum barotropic Courant Number = 2.81833239E-02
Maximum barotropic Courant Number = 3.42277905E-01
Maximum Coriolis Courant Number = 8.73901467E-02
(Grid 01, File: IO_ini_d10.nc, Rec=0001, Index=1)
- free-surface
(Min = -1.65856037E-01 Max = 1.09070785E+00)
- u-momentum component
(Min = -7.12925634E-01 Max = 7.55215659E-01)
- v-momentum component
(Min = -7.72852753E-01 Max = 7.65704231E-01)
- potential temperature
(Min = 5.25969674E-02 Max = 2.98913774E+01)
- salinity
(Min = 2.12743881E+00 Max = 4.07141128E+01)
GET_2DFLD - surface u-momentum stress, t = 30 00:00:00
(Rec=0000030, Index=1, File: IO_frc_d10_01.nc)
(Tmin= 1.0000 Tmax= 30.0000)
(Min = -3.34676881E-04 Max = 4.07706802E-04)
GET_2DFLD - surface v-momentum stress, t = 30 00:00:00
(Min = -2.24989736E-04 Max = 2.88494194E-04)
GET_2DFLD - solar shortwave radiation flux, t = 30 00:00:00
(Min = 2.57790513E-05 Max = 7.66878176E-05)
GET_2DFLD - surface net heat flux, t = 30 00:00:00
(Min = -5.53345135E-05 Max = 3.85001502E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 30 00:00:00
(Min = -1.88254621E-07 Max = 9.84993660E-08)
GET_NGFLD - free-surface eastern boundary condition, t = 356 00:00:00
(Rec=0000072, Index=2, File: IO_bry_d10.nc)
(Tmin= 1.0000 Tmax= 356.0000)
(Min = 9.16177432E-02 Max = 8.75259395E-01)
GET_NGFLD - free-surface southern boundary condition, t = 356 00:00:00
(Min = 7.29231921E-02 Max = 7.42595725E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 356 00:00:00
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 356 00:00:00
(Min = -2.83704406E-01 Max = 7.63229013E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 356 00:00:00
GET_NGFLD - 2D v-momentum southern boundary condition, t = 356 00:00:00
(Min = -2.64802093E-01 Max = 6.51729572E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 356 00:00:00
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 356 00:00:00
(Min = -7.15777892E-01 Max = 1.10803898E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 356 00:00:00
GET_NGFLD - 3D v-momentum southern boundary condition, t = 356 00:00:00
(Min = -3.84782651E-01 Max = 9.38375501E-02)
GET_NGFLD - temperature eastern boundary condition, t = 356 00:00:00
(Min = 6.58606760E-01 Max = 2.96212242E+01)
GET_NGFLD - salinity eastern boundary condition, t = 356 00:00:00
(Min = 2.48901541E+01 Max = 3.57507704E+01)
GET_NGFLD - temperature southern boundary condition, t = 356 00:00:00
(Min = 4.04895103E-01 Max = 2.52432386E+01)
GET_NGFLD - salinity southern boundary condition, t = 356 00:00:00
(Min = 3.43807778E+01 Max = 3.58496595E+01)
GET_3DFLD - potential temperature climatology, t = 271 00:00:00
(Rec=0000004, Index=1, File: IO_clm_d10_TSUVZ.nc)
(Tmin= 1.0000 Tmax= 271.0000)
(Min = 5.98539002E-02 Max = 3.09193401E+01)
GET_3DFLD - salinity climatology, t = 271 00:00:00
(Min = 2.12883019E+00 Max = 4.07080536E+01)
Maximum grid stiffness ratios: rx0 = 2.087711E-01 (Beckmann and Haidvogel)
rx1 = 9.239405E+00 (Haney)
Initial basin volumes: TotVolume = 1.3422006839E+17 m3
MinVolume = 1.1592918981E+08 m3
MaxVolume = 4.1624495376E+10 m3
Max/Min = 3.5905103317E+02
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 01296000)
GET_2DFLD - surface u-momentum stress, t = 1 00:00:00
(Rec=0000001, Index=2, File: IO_frc_d10_01.nc)
(Min = -3.95970791E-04 Max = 3.27253677E-04)
GET_2DFLD - surface v-momentum stress, t = 1 00:00:00
(Min = -3.27691439E-04 Max = 2.14956658E-04)
GET_2DFLD - solar shortwave radiation flux, t = 1 00:00:00
(Min = 2.25483297E-05 Max = 7.95320454E-05)
GET_2DFLD - surface net heat flux, t = 1 00:00:00
(Min = -5.94075649E-05 Max = 4.05880867E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 1 00:00:00
(Min = -1.70621406E-07 Max = 9.32263919E-08)
GET_NGFLD - free-surface eastern boundary condition, t = 1 00:00:00
(Rec=0000001, Index=1, File: IO_bry_d10.nc)
(Min = 1.09218201E-01 Max = 8.56462430E-01)
GET_NGFLD - free-surface southern boundary condition, t = 1 00:00:00
(Min = 8.11142240E-02 Max = 7.40974584E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 1 00:00:00
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 1 00:00:00
(Min = -2.72014740E-01 Max = 8.39977933E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 1 00:00:00
GET_NGFLD - 2D v-momentum southern boundary condition, t = 1 00:00:00
(Min = -2.63939739E-01 Max = 5.91890203E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 1 00:00:00
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 1 00:00:00
(Min = -6.70640665E-01 Max = 1.22306183E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 1 00:00:00
GET_NGFLD - 3D v-momentum southern boundary condition, t = 1 00:00:00
(Min = -3.81899509E-01 Max = 8.58668860E-02)
GET_NGFLD - temperature eastern boundary condition, t = 1 00:00:00
(Min = 6.58755465E-01 Max = 2.94668588E+01)
GET_NGFLD - salinity eastern boundary condition, t = 1 00:00:00
(Min = 2.48780853E+01 Max = 3.57520208E+01)
GET_NGFLD - temperature southern boundary condition, t = 1 00:00:00
(Min = 4.08595854E-01 Max = 2.55525390E+01)
GET_NGFLD - salinity southern boundary condition, t = 1 00:00:00
(Min = 3.43756636E+01 Max = 3.58334744E+01)
GET_3DFLD - potential temperature climatology, t = 1 00:00:00
(Rec=0000001, Index=2, File: IO_clm_d10_TSUVZ.nc)
(Min = 5.79100773E-02 Max = 2.97284260E+01)
GET_3DFLD - salinity climatology, t = 1 00:00:00
(Min = 2.12750411E+00 Max = 4.07142143E+01)
0 0 00:00:00 7.816705E-04 2.102642E+04 2.102642E+04 1.351798E+17
(114,286,36) 7.585973E-02 7.725372E-02 0.000000E+00 1.001434E+00
DEF_HIS - creating history file, Grid 01: /public/userspace/ljd/IO_d10/IO_his_d10_0001.nc
1 0 00:20:00 7.853795E-04 2.102642E+04 2.102642E+04 1.351798E+17
(427,355,22) 9.046983E-03 1.832398E-02 3.615468E-01 1.001033E+00
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001
2 0 00:40:00 7.884234E-04 2.102643E+04 2.102643E+04 1.351798E+17
(093,251,40) 5.191574E-03 3.447813E-03 1.963723E+00 1.002399E+00
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000002
3 0 01:00:00 7.909288E-04 2.102643E+04 2.102643E+04 1.351798E+17
(017,011,40) 2.232034E-02 7.210791E-03 1.492642E+00 1.002914E+00
4 0 01:20:00 7.933181E-04 2.102643E+04 2.102643E+04 1.351798E+17
(017,011,40) 1.075373E-02 1.031695E-03 1.974933E+00 1.005651E+00
5 0 01:40:00 7.955499E-04 2.102643E+04 2.102643E+04 1.351798E+17
(093,238,40) 4.780234E-03 2.868451E-04 1.005678E+00 1.005552E+00
6 0 02:00:00 7.977047E-04 2.102643E+04 2.102643E+04 1.351798E+17
(090,250,40) 1.649237E-02 1.200453E-02 1.148647E+00 1.003872E+00
7 0 02:20:00 7.999087E-04 2.102643E+04 2.102643E+04 1.351798E+17
(090,250,40) 4.511523E-03 1.395434E-02 1.543594E+00 1.001765E+00
8 0 02:40:00 8.023086E-04 2.102644E+04 2.102644E+04 1.351798E+17
(090,250,40) 1.885090E-02 9.810953E-04 1.732885E+00 1.006152E+00
9 0 03:00:00 8.047665E-04 2.102644E+04 2.102644E+04 1.351798E+17
(109,294,40) 1.139387E-02 2.705044E-03 9.080376E-01 1.003519E+00
10 0 03:20:00 8.074709E-04 2.102644E+04 2.102644E+04 1.351798E+17
(088,512,06) 6.383354E-02 5.553126E-02 9.530703E-01 1.004710E+00
11 0 03:40:00 8.110126E-04 2.102644E+04 2.102644E+04 1.351798E+17
(088,512,07) 6.624754E-02 5.991228E-02 1.224564E+00 1.019313E+00
12 0 04:00:00 8.154429E-04 2.102644E+04 2.102644E+04 1.351798E+17
(088,512,07) 7.194483E-02 5.467485E-02 1.655688E+00 1.168393E+00
13 0 04:20:00 8.207404E-04 2.102644E+04 2.102644E+04 1.351798E+17
(090,512,11) 5.065749E-03 1.447481E-02 2.383933E+00 1.304853E+00
14 0 04:40:00 8.288798E-04 2.102645E+04 2.102645E+04 1.351798E+17
(090,512,12) 1.696763E-02 4.843554E-02 3.511587E+00 1.659252E+00
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000003
number of time records written in RESTART file = 00000014
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/TOMS: DONE... Thursday - April 3, 2014 - 12:23:49 PM
real 452.72
user 5805.97
sys 1272.95
+ exit 0
Blowing up at the beginning
Re: Blowing up at the beginning
Have you tried a smaller timestep? Does it run longer?
Have you looked at the restart file to see how and where it's blowing up?
