hi,
I have run roms successfully first time, then i make nrrec = -1,and use ocean_rst file instead of inifile,
it stop,and do not output data,when i check the log message, i can not find any error!
I am very confused,Can you give me some advice?
log file:
Tuesday - February 25, 2014 - 9:03:29 PM
SHIYF
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /lustre/inspur/mpi/openmpi-intel/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free -free
Input Script : ocean_shiyf.in
SVN Revision : Unversioned directory
Local Root : /lustre/home/shiyongfangWKJ/roms/trunk
Header Dir : /lustre/home/shiyongfangWKJ/roms/projects/roms_shiyf
Header file : shiyf.h
Analytical Dir: /lustre/home/shiyongfangWKJ/roms/projects/roms_shiyf
Resolution, Grid 01: 0459x0235x016, Parallel Nodes: 40, Tiling: 004x010
518400 ntimes Number of timesteps for 3-D equations.
60.000 dt Timestep size (s) for 3-D equations.
15 ndtfast Number of timesteps for 2-D equations between
-1 nrrec Number of restart records to read from disk.
43200 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
43200 nHIS Number of timesteps between the writing fields
into history file.
518400 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
43200 nAVG Number of timesteps between the writing of
518400 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1 lmd_Jwt Jerlov water type.
7.0000E+00 theta_s S-coordinate surface control parameter.
2.0000E-01 theta_b S-coordinate bottom control parameter.
30.000 Tcline S-coordinate surface/bottom layer width (m) used
2.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
2.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
for 3D momentum.
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
Prefix for History Files: ocean_his
Prefix for Averages Files: ocean_avg
Input Grid File: roms_grid.nc
Input Nonlinear Initial File: ocean_rst.nc
Input Forcing File 01: roms_frc.nc
Input Boundary File: roms_bry.nc
Tile partition information for Grid 01: 0459x0235x0016 tiling: 004x010
tile Istr Iend Jstr Jend Npts
0 1 115 1 22 40480
1 116 230 1 22 40480
2 231 345 1 22 40480
3 346 459 1 22 40128
4 1 115 23 46 44160
5 116 230 23 46 44160
6 231 345 23 46 44160
7 346 459 23 46 43776
8 1 115 47 70 44160
9 116 230 47 70 44160
10 231 345 47 70 44160
11 346 459 47 70 43776
12 1 115 71 94 44160
13 116 230 71 94 44160
14 231 345 71 94 44160
15 346 459 71 94 43776
16 1 115 95 118 44160
17 116 230 95 118 44160
18 231 345 95 118 44160
19 346 459 95 118 43776
20 1 115 119 142 44160
21 116 230 119 142 44160
22 231 345 119 142 44160
23 346 459 119 142 43776
24 1 115 143 166 44160
25 116 230 143 166 44160
26 231 345 143 166 44160
27 346 459 143 166 43776
28 1 115 167 190 44160
29 116 230 167 190 44160
30 231 345 167 190 44160
31 346 459 167 190 43776
32 1 115 191 214 44160
33 116 230 191 214 44160
34 231 345 191 214 44160
35 346 459 191 214 43776
36 1 115 215 235 38640
37 116 230 215 235 38640
38 231 345 215 235 38640
39 346 459 215 235 38304
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 115.50 0.50 22.50 RHO-points
1 115.50 230.50 0.50 22.50 RHO-points
2 230.50 345.50 0.50 22.50 RHO-points
3 345.50 459.50 0.50 22.50 RHO-points
4 0.50 115.50 22.50 46.50 RHO-points
5 115.50 230.50 22.50 46.50 RHO-points
6 230.50 345.50 22.50 46.50 RHO-points
7 345.50 459.50 22.50 46.50 RHO-points
8 0.50 115.50 46.50 70.50 RHO-points
9 115.50 230.50 46.50 70.50 RHO-points
10 230.50 345.50 46.50 70.50 RHO-points
11 345.50 459.50 46.50 70.50 RHO-points
12 0.50 115.50 70.50 94.50 RHO-points
13 115.50 230.50 70.50 94.50 RHO-points
14 230.50 345.50 70.50 94.50 RHO-points
15 345.50 459.50 70.50 94.50 RHO-points
16 0.50 115.50 94.50 118.50 RHO-points
17 115.50 230.50 94.50 118.50 RHO-points
18 230.50 345.50 94.50 118.50 RHO-points
19 345.50 459.50 94.50 118.50 RHO-points
20 0.50 115.50 118.50 142.50 RHO-points
21 115.50 230.50 118.50 142.50 RHO-points
22 230.50 345.50 118.50 142.50 RHO-points
23 345.50 459.50 118.50 142.50 RHO-points
24 0.50 115.50 142.50 166.50 RHO-points
25 115.50 230.50 142.50 166.50 RHO-points
26 230.50 345.50 142.50 166.50 RHO-points
27 345.50 459.50 142.50 166.50 RHO-points
28 0.50 115.50 166.50 190.50 RHO-points
29 115.50 230.50 166.50 190.50 RHO-points
30 230.50 345.50 166.50 190.50 RHO-points
31 345.50 459.50 166.50 190.50 RHO-points
32 0.50 115.50 190.50 214.50 RHO-points
33 115.50 230.50 190.50 214.50 RHO-points
34 230.50 345.50 190.50 214.50 RHO-points
35 345.50 459.50 190.50 214.50 RHO-points
36 0.50 115.50 214.50 235.50 RHO-points
37 115.50 230.50 214.50 235.50 RHO-points
38 230.50 345.50 214.50 235.50 RHO-points
39 345.50 459.50 214.50 235.50 RHO-points
0 1.00 115.50 0.50 22.50 U-points
1 115.50 230.50 0.50 22.50 U-points
2 230.50 345.50 0.50 22.50 U-points
3 345.50 459.00 0.50 22.50 U-points
4 1.00 115.50 22.50 46.50 U-points
5 115.50 230.50 22.50 46.50 U-points
6 230.50 345.50 22.50 46.50 U-points
7 345.50 459.00 22.50 46.50 U-points
8 1.00 115.50 46.50 70.50 U-points
9 115.50 230.50 46.50 70.50 U-points
10 230.50 345.50 46.50 70.50 U-points
11 345.50 459.00 46.50 70.50 U-points
12 1.00 115.50 70.50 94.50 U-points
13 115.50 230.50 70.50 94.50 U-points
14 230.50 345.50 70.50 94.50 U-points
15 345.50 459.00 70.50 94.50 U-points
16 1.00 115.50 94.50 118.50 U-points
17 115.50 230.50 94.50 118.50 U-points
18 230.50 345.50 94.50 118.50 U-points
19 345.50 459.00 94.50 118.50 U-points
20 1.00 115.50 118.50 142.50 U-points
21 115.50 230.50 118.50 142.50 U-points
22 230.50 345.50 118.50 142.50 U-points
23 345.50 459.00 118.50 142.50 U-points
24 1.00 115.50 142.50 166.50 U-points
25 115.50 230.50 142.50 166.50 U-points
26 230.50 345.50 142.50 166.50 U-points
27 345.50 459.00 142.50 166.50 U-points
28 1.00 115.50 166.50 190.50 U-points
29 115.50 230.50 166.50 190.50 U-points
30 230.50 345.50 166.50 190.50 U-points
31 345.50 459.00 166.50 190.50 U-points
32 1.00 115.50 190.50 214.50 U-points
33 115.50 230.50 190.50 214.50 U-points
34 230.50 345.50 190.50 214.50 U-points
35 345.50 459.00 190.50 214.50 U-points
36 1.00 115.50 214.50 235.50 U-points
37 115.50 230.50 214.50 235.50 U-points
38 230.50 345.50 214.50 235.50 U-points
39 345.50 459.00 214.50 235.50 U-points
0 0.50 115.50 1.00 22.50 V-points
1 115.50 230.50 1.00 22.50 V-points
2 230.50 345.50 1.00 22.50 V-points
3 345.50 459.50 1.00 22.50 V-points
4 0.50 115.50 22.50 46.50 V-points
5 115.50 230.50 22.50 46.50 V-points
6 230.50 345.50 22.50 46.50 V-points
7 345.50 459.50 22.50 46.50 V-points
8 0.50 115.50 46.50 70.50 V-points
9 115.50 230.50 46.50 70.50 V-points
10 230.50 345.50 46.50 70.50 V-points
11 345.50 459.50 46.50 70.50 V-points
12 0.50 115.50 70.50 94.50 V-points
13 115.50 230.50 70.50 94.50 V-points
14 230.50 345.50 70.50 94.50 V-points
15 345.50 459.50 70.50 94.50 V-points
16 0.50 115.50 94.50 118.50 V-points
17 115.50 230.50 94.50 118.50 V-points
18 230.50 345.50 94.50 118.50 V-points
19 345.50 459.50 94.50 118.50 V-points
20 0.50 115.50 118.50 142.50 V-points
21 115.50 230.50 118.50 142.50 V-points
22 230.50 345.50 118.50 142.50 V-points
23 345.50 459.50 118.50 142.50 V-points
24 0.50 115.50 142.50 166.50 V-points
25 115.50 230.50 142.50 166.50 V-points
26 230.50 345.50 142.50 166.50 V-points
27 345.50 459.50 142.50 166.50 V-points
28 0.50 115.50 166.50 190.50 V-points
29 115.50 230.50 166.50 190.50 V-points
30 230.50 345.50 166.50 190.50 V-points
31 345.50 459.50 166.50 190.50 V-points
32 0.50 115.50 190.50 214.50 V-points
33 115.50 230.50 190.50 214.50 V-points
34 230.50 345.50 190.50 214.50 V-points
35 345.50 459.50 190.50 214.50 V-points
36 0.50 115.50 214.50 235.00 V-points
37 115.50 230.50 214.50 235.00 V-points
38 230.50 345.50 214.50 235.00 V-points
39 345.50 459.50 214.50 235.00 V-points
HaloSizeI(1) = 254
HaloSizeJ(1) = 72
TileSide(1) = 121
TileSize(1) = 3630
zeta 1 Closed Clamped Clamped Closed
ubar 1 Closed Clamped Clamped Closed
vbar 1 Closed Clamped Clamped Closed
u 1 Closed Clamped Clamped Closed
v 1 Closed Clamped Clamped Closed
temp 1 Closed Clamped Clamped Closed
salt 1 Closed Clamped Clamped Closed
tke 1 Closed Clamped Clamped Closed
SHIYF SHIYF
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NO_WRITE_GRID Not Writing grid arrays into NetCDF ouput files.
RST_SINGLE Single precision fields in restart NetCDF file.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 4 (pid= 9874) is active.
Node # 8 (pid= 9878) is active.
Node # 0 (pid= 9870) is active.
Node # 9 (pid= 9879) is active.
Node # 7 (pid= 9877) is active.
Node # 1 (pid= 9871) is active.
Node # 39 (pid= 4196) is active.
Node # 31 (pid= 4176) is active.
Node # 32 (pid= 4189) is active.
Node # 33 (pid= 4190) is active.
Node # 36 (pid= 4193) is active.
Node # 14 (pid= 21829) is active.
Node # 16 (pid= 21831) is active.
Node # 10 (pid= 21825) is active.
Node # 11 (pid= 21826) is active.
Node # 24 (pid= 9146) is active.
Node # 12 (pid= 21827) is active.
Node # 25 (pid= 9147) is active.
Node # 13 (pid= 21828) is active.
Node # 28 (pid= 9150) is active.
Node # 15 (pid= 21830) is active.
Node # 23 (pid= 9145) is active.
Node # 17 (pid= 21832) is active.
Node # 20 (pid= 9142) is active.
Node # 6 (pid= 9876) is active.
Node # 22 (pid= 9144) is active.
Node # 30 (pid= 4175) is active.
Node # 38 (pid= 4195) is active.
Node # 5 (pid= 9875) is active.
Node # 37 (pid= 4194) is active.
Node # 21 (pid= 9143) is active.
Node # 29 (pid= 9151) is active.
Node # 2 (pid= 9872) is active.
Node # 26 (pid= 9148) is active.
Node # 34 (pid= 4191) is active.
Node # 18 (pid= 21833) is active.
Node # 3 (pid= 9873) is active.
Node # 27 (pid= 9149) is active.
Node # 35 (pid= 4192) is active.
Node # 19 (pid= 21834) is active.
Vertical S-coordinate System:
15 -0.0625000 -0.0009137 -2.030 -1.875 -4.223 -6.416
14 -0.1250000 -0.0023093 -4.143 -3.750 -9.685 -15.227
13 -0.1875000 -0.0048224 -6.445 -5.625 -18.019 -29.592
12 -0.2500000 -0.0097619 -9.160 -7.500 -32.588 -56.016
11 -0.3125000 -0.0197716 -12.736 -9.375 -60.188 -107.640
10 -0.3750000 -0.0394986 -17.965 -11.250 -112.761 -207.558
9 -0.4375000 -0.0743313 -25.761 -13.125 -204.156 -382.551
8 -0.5000000 -0.1241359 -36.103 -15.000 -334.029 -631.955
7 -0.5625000 -0.1786344 -47.243 -16.875 -475.966 -904.688
6 -0.6250000 -0.2284617 -57.588 -18.750 -605.897 -1154.205
5 -0.6875000 -0.2764002 -67.613 -20.625 -730.974 -1394.334
4 -0.7500000 -0.3333248 -79.165 -22.500 -879.145 -1679.124
3 -0.8125000 -0.4130065 -94.586 -24.375 -1085.802 -2077.017
2 -0.8750000 -0.5326249 -116.796 -26.250 -1395.096 -2673.396
1 -0.9375000 -0.7162634 -149.890 -28.125 -1868.922 -3587.954
0 -1.0000000 -1.0000000 -200.000 -30.000 -2600.000 -5000.000
Time Splitting Weights: ndtfast = 15 nfast = 22
1-0.0006740978872509 0.0666666666666667-0.0006740978872509 0.0666666666666667
2-0.0001913161153518 0.0667116065258167-0.0008654140026027 0.1333782731924834
3 0.0014472038369421 0.0667243609335069 0.0005817898343395 0.2001026341259903
4 0.0042370228855824 0.0666278806777107 0.0048188127199218 0.2667305148037010
5 0.0081665994120431 0.0663454124853385 0.0129854121319649 0.3330759272890396
6 0.0132119623624627 0.0658009725245357 0.0261973744944276 0.3988768998135752
7 0.0193298623751124 0.0649201750337048 0.0455272368695400 0.4637970748472801
8 0.0264494009361902 0.0636315175420307 0.0719766378057303 0.5274285923893107
9 0.0344621375639418 0.0618682241462847 0.1064387753696720 0.5892968165355954
10 0.0432106750211074 0.0595707483086885 0.1496494503907794 0.6488675648442840
11 0.0524757225556949 0.0566900366406147 0.2021251729464743 0.7055576014848987
12 0.0619616371700794 0.0531916551369017 0.2640868101165537 0.7587492566218004
13 0.0712804429184289 0.0490608793255631 0.3353672530349826 0.8078101359473635
14 0.0799343282324558 0.0443088497976678 0.4153015812674384 0.8521189857450313
15 0.0872966212754959 0.0389798945821708 0.5025982025429343 0.8910988803272021
16 0.0925912433249121 0.0331601198304711 0.5951894458678464 0.9242590001576731
17 0.0948706401828253 0.0269873702754769 0.6900600860506717 0.9512463704331501
18 0.0929921916151718 0.0206626609299552 0.7830522776658435 0.9719090313631054
19 0.0855930988190858 0.0144631814889438 0.8686453764849293 0.9863722128520491
20 0.0710637499186094 0.0087569749010047 0.9397091264035388 0.9951291877530538
21 0.0475195634887281 0.0040193915730974 0.9872286898922669 0.9991485793261512
22 0.0127713101077333 0.0008514206738489 1.0000000000000002 1.0000000000000000
ndtfast, nfast = 15 22 nfast/ndtfast = 1.46667
1.000000000000 1.070450639131 0.535225319565 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.09467
Minimum X-grid spacing, DXmin = 2.33372303E+01 km
Maximum X-grid spacing, DXmax = 5.55664199E+01 km
Minimum Y-grid spacing, DYmin = 2.36170777E+01 km
Maximum Y-grid spacing, DYmax = 5.55654002E+01 km
Minimum Z-grid spacing, DZmin = 2.03032458E+00 m
Maximum Z-grid spacing, DZmax = 1.41204579E+03 m
Minimum barotropic Courant Number = 4.50937506E-03
Maximum barotropic Courant Number = 3.91802145E-02
Maximum Coriolis Courant Number = 7.91968582E-03
Horizontal mixing scaled by grid size, GRDMAX = 5.55658718E+01 km
NLM: GET_STATE - Read state initial conditions, t = 360 00:00:00
(File: ocean_rst.nc, Rec=0002, Index=1)
- free-surface
(Min = -9.21388030E-01 Max = 9.34340298E-01)
(Min = -4.59825516E-01 Max = 8.06407392E-01)
(Min = -7.90307343E-01 Max = 7.75139153E-01)
- u-momentum component
(Min = -1.26890314E+00 Max = 1.62352765E+00)
- v-momentum component
(Min = -1.65238345E+00 Max = 1.39365602E+00)
- potential temperature
(Min = -1.82950630E+01 Max = 3.57503929E+01)
- salinity
(Min = 1.71523914E+01 Max = 4.05895386E+01)
- vertical viscosity coefficient
(Min = 0.00000000E+00 Max = 4.28411903E+01)
- temperature vertical diffusion coefficient
(Min = 0.00000000E+00 Max = 5.81563568E+01)
- salinity vertical diffusion coefficient
GET_2DFLD - surface u-momentum stress, t = 345 00:00:00
(Rec=0012, Index=1, File: roms_frc.nc)
(Min = -1.68432195E-04 Max = 1.68611613E-04)
GET_2DFLD - surface v-momentum stress, t = 345 00:00:00
(Min = -2.30955021E-04 Max = 1.16607114E-04)
GET_2DFLD - solar shortwave radiation flux, t = 345 00:00:00
(Min = 7.14978554E-08 Max = 8.99074356E-05)
GET_2DFLD - surface net heat flux, t = 345 00:00:00
(Min = -1.22467813E-04 Max = 4.19740098E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 345 00:00:00
(Min = -3.01856720E-07 Max = 1.76678856E-07)
GET_2DFLD - sea surface salinity climatology, t = 345 00:00:00
(Min = 1.65167007E+01 Max = 4.11551018E+01)
(Rec=0012, Index=2, File: roms_bry.nc)
(Min = -3.73167685E-01 Max = 0.00000000E+00)
(Min = -3.58965313E-01 Max = 7.52205844E-02)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 345 00:00:00
(Min = -1.42503950E-02 Max = 3.94072602E-02)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 345 00:00:00
(Min = -5.20802142E-03 Max = 4.08989435E-03)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 345 00:00:00
(Min = -3.78351520E-02 Max = 4.50582498E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 345 00:00:00
(Min = -3.93825337E-02 Max = 3.05695320E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 345 00:00:00
(Min = -3.85696218E-01 Max = 2.46939123E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 345 00:00:00
(Min = -8.50273120E-02 Max = 5.58325617E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 345 00:00:00
(Min = -3.58550369E-02 Max = 6.04781091E-03)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 345 00:00:00
(Min = -8.92719773E-02 Max = 3.66097382E-02)
GET_NGFLD - temperature eastern boundary condition, t = 345 00:00:00
(Min = 1.76033770E+00 Max = 2.89773041E+01)
GET_NGFLD - salinity eastern boundary condition, t = 345 00:00:00
(Min = 3.33907192E+01 Max = 3.59697255E+01)
GET_NGFLD - temperature southern boundary condition, t = 345 00:00:00
(Min = 9.74252701E-01 Max = 2.43833026E+01)
GET_NGFLD - salinity southern boundary condition, t = 345 00:00:00
(Min = 3.42717653E+01 Max = 3.59174246E+01)
Maximum grid stiffness ratios: rx0 = 2.035143E-01 (Beckmann and Haidvogel)
rx1 = 2.174199E+00 (Haney)
Initial basin volumes: TotVolume = 5.9777232065E+17 m3
MinVolume = 1.1279533624E+09 m3
MaxVolume = 4.3597847185E+12 m3
Max/Min = 3.8652171834E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00518401 - 00518400)
(Rec=0001, Index=2, File: roms_frc.nc)
(Min = -1.40968276E-04 Max = 1.81788799E-04)
(Min = -2.30423325E-04 Max = 1.34807913E-04)
(Min = 3.81343152E-07 Max = 8.01640752E-05)
GET_2DFLD - surface net heat flux, t = 15 00:00:00
(Min = -1.28903545E-04 Max = 3.81661335E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 15 00:00:00
(Min = -2.56888076E-07 Max = 1.34596601E-07)
(Min = 1.77527008E+01 Max = 4.05689011E+01)
(Rec=0001, Index=1, File: roms_bry.nc)
(Min = -3.50576890E-01 Max = 0.00000000E+00)
(Min = -3.25712829E-01 Max = 9.00352100E-02)
(Min = -5.39048305E-03 Max = 3.10402664E-02)
(Min = -1.49644176E-02 Max = 5.50461100E-03)
(Min = -6.44210545E-03 Max = 3.25296741E-02)
(Min = -2.90746580E-02 Max = 4.79667278E-03)
(Min = -2.40916645E-01 Max = 2.03545932E-01)
(Min = -6.73175687E-02 Max = 6.65828306E-02)
(Min = -4.22836036E-02 Max = 2.35178151E-03)
(Min = -6.42212231E-02 Max = 2.90233429E-02)
(Min = 1.76033770E+00 Max = 2.83225178E+01)
(Min = 3.36186304E+01 Max = 3.60024570E+01)
(Min = 9.74252701E-01 Max = 2.58425064E+01)
(Min = 3.42761201E+01 Max = 3.58729397E+01)
518400 360 00:00:00 1.925411E-03 2.095307E+04 2.095307E+04 6.117299E+17
(149,064,16) 8.596160E-04 1.439332E-03 0.000000E+00 1.630741E+00
Elapsed CPU time (seconds):
Node # 1 CPU: 2.740
Node # 5 CPU: 2.623
Node # 8 CPU: 2.632
Node # 0 CPU: 2.244
Node # 4 CPU: 2.744
Node # 2 CPU: 2.753
Node # 6 CPU: 2.634
Node # 9 CPU: 2.341
Node # 3 CPU: 2.748
Node # 10 CPU: 2.208
Node # 24 CPU: 2.542
Node # 37 CPU: 2.558
Node # 13 CPU: 2.543
Node # 26 CPU: 2.563
Node # 34 CPU: 2.548
Node # 17 CPU: 2.526
Node # 21 CPU: 2.545
Node # 33 CPU: 2.538
Node # 30 CPU: 2.272
Node # 36 CPU: 2.517
Node # 39 CPU: 2.556
Analytical header files used:
ROMS/Functionals/ana_btflux.h
Node # 32 CPU: 2.531
Node # 16 CPU: 2.530
Node # 22 CPU: 2.552
Node # 35 CPU: 2.562
Node # 12 CPU: 2.543
Node # 20 CPU: 2.206
Node # 38 CPU: 2.562
Node # 14 CPU: 2.552
ROMS/TOMS: DONE... Tuesday - February 25, 2014 - 9:03:32 PM
Node # 28 CPU: 2.536
Node # 31 CPU: 2.529
Node # 11 CPU: 2.538
Node # 27 CPU: 2.557
Node # 19 CPU: 2.202
Node # 29 CPU: 2.217
Node # 15 CPU: 2.534
Node # 23 CPU: 2.546
Node # 18 CPU: 2.534
Node # 25 CPU: 2.558
Node # 7 CPU: 2.624
my roms stop,but can not find error message
Re: my roms stop,but can not find error message
You have told it to run some NTIMES steps from the beginning. It knows it already did that and doesn't need to run longer. I suggest you add to NTIMES for more timesteps.
thanks a lot! I do not know if I understand correctly .when i run the first time making nrrec =0 for one year, NTIMES steps * dt equals one year, then i make nrrec = -1,and use ocean_rst file instead of inifile,kate wrote:You have told it to run some NTIMES steps from the beginning. It knows it already did that and doesn't need to run longer. I suggest you add to NTIMES for more timesteps.
is the model starting from the second year? and my NTIMES steps*dt should equal The length of the two years? the output data continue to write in his avg file from 13 months to 24 months,and so on?
Yes, that's right, try it out.
Thanks a lot,it is ok!kate wrote:Yes, that's right, try it out.
