online nesting test problem
simion1232006
#1 Unread post by simion1232006 »
I am working on testing the newest nesting scheme for my application. It seems that the model start to ran, while stop at the initialization and configuration step. Does any of you have experiences on that? Also I found a problem to run the nesting model:The tiles specified for the coarse grid should be the same as the refined grid, otherwise the model will stop. Any comments are appreciated.
The log file is attached as follow:
Tuesday - February 18, 2014 - 9:34:50 AM
Wind-Driven Upwelling/Downwelling : nesting test
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/local/MPI/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script :
SVN Revision : 714
Local Root : /home/tao/Desktop/ROMS4
Header Dir : /home/tao/Nesting_model_test
Header file : ningaloo.h
Analytical Dir: /home/tao/Nesting_model_test
Resolution, Grid 01: 0536x0228x040, Parallel Nodes: 4, Tiling: 002x002
3600 ntimes Number of timesteps for 3-D equations.
120.000 dt Timestep size (s) for 3-D equations.
into restart fields.
10 ninfo Number of timesteps between print of information
to standard output.
into history file.
14400 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
720 nAVG Number of timesteps between the writing of
14400 ndefAVG Number of timesteps between creation of new
time-averaged file.
1.0000E-05 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
1.0000E-05 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
1.0000E-05 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
1.0000E-05 Akt_bak(01) Background vertical mixing coefficient (m2/s)
1.0000E-05 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
1.0000E-05 Akk_bak Background vertical mixing coefficient (m2/s)
for turbulent energy.
1.0000E-05 Akp_bak Background vertical mixing coefficient (m2/s)
2.000 gls_p GLS stability exponent.
1.000 gls_m GLS turbulent kinetic energy exponent.
-0.670 gls_n GLS turbulent length scale exponent.
1.0000E-08 gls_Kmin GLS minimum value of turbulent kinetic energy.
1.0000E-08 gls_Pmin GLS minimum value of dissipation.
5.5440E-01 gls_cmu0 GLS stability coefficient.
1.0000E+00 gls_c1 GLS shear production coefficient.
1.2200E+00 gls_c2 GLS dissipation coefficient.
1.0000E-01 gls_c3m GLS stable buoyancy production coefficient.
8.0000E-01 gls_sigk GLS constant Schmidt number for TKE.
1.0700E+00 gls_sigp GLS constant Schmidt number for PSI.
2.0000E-03 Zos Surface roughness (m).
1.0000E+01 blk_ZQ Height (m) of surface air humidity measurement.
2.0000E+00 blk_ZT Height (m) of surface air temperature measurement.
10.000 Tcline S-coordinate surface/bottom layer width (m) used
1024.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
40116.000 dstart Time-stamp assigned to model initialization (days).
19000101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
5.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
5.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
1.0000E+02 Znudg Nudging/relaxation time scale (days)
1.0000E+02 M2nudg Nudging/relaxation time scale (days)
1.0000E+02 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.0000E+02 obcfac Factor between passive and active
of State.
T Hout(idBott) Write out bottom property 01: grain_diameter
T Hout(idBott) Write out bottom property 02: grain_density
T Hout(idBott) Write out bottom property 03: settling_vel
T Hout(idBott) Write out bottom property 04: erosion_stress
T Hout(idBott) Write out bottom property 05: ripple_length
T Hout(idBott) Write out bottom property 06: ripple_height
T Hout(idBott) Write out bottom property 07: bed_wave_amp
T Hout(idBott) Write out bottom property 08: Zo_def
T Hout(idBott) Write out bottom property 09: Zo_app
T Hout(idBott) Write out bottom property 17: ero_flux
T Hout(idBott) Write out bottom property 18: dep_net
Prefix for History Files: Ningaloo_WAC_2009_his
Prefix for Averages Files: Ningaloo_WAC_2009_avg
Input Grid File: Ningaloo_WAC_grid.nc
Nesting grid connectivity File: Ningaloo_WAC_ngc.nc
Input Nonlinear Initial File: Ningaloo_WAC_2009_INI.nc
Input Forcing File 01: Ningaloo_WAC_2009_heat.nc
Input Forcing File 02: Ningaloo_WAC_2009_wind.nc
Input Forcing File 03: Ningaloo_NF_2009_heat.nc
Input Forcing File 04: Ningaloo_NF_2009_wind.nc
Input Boundary File: Ningaloo_WAC_2009_BC.nc
Resolution, Grid 02: 0177x0084x040, Parallel Nodes: 4, Tiling: 002x002
Physical Parameters, Grid: 02
7200 ntimes Number of timesteps for 3-D equations.
60.000 dt Timestep size (s) for 3-D equations.
1440 nRST Number of timesteps between the writing of data
to standard output.
1440 nHIS Number of timesteps between the writing fields
into history file.
28800 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
time-averaged file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
Prefix for History Files: Ningaloo_NF_2009_his
Prefix for Averages Files: Ningaloo_NF_2009_avg
Input Grid File: Ningaloo_NF_grid2.nc
Input Nonlinear Initial File: Ningaloo_NF_2009_INI.nc
Tile partition information for Grid 01: 0536x0228x0040 tiling: 002x002
tile Istr Iend Jstr Jend Npts
0 1 268 1 114 1222080
1 269 536 1 114 1222080
2 1 268 115 228 1222080
3 269 536 115 228 1222080
Tile partition information for Grid 02: 0177x0084x0040 tiling: 002x002
0 1 89 1 42 149520
1 90 177 1 42 147840
2 1 89 43 84 149520
3 90 177 43 84 147840
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 268.50 0.50 114.50 RHO-points
1 268.50 536.50 0.50 114.50 RHO-points
2 0.50 268.50 114.50 228.50 RHO-points
3 268.50 536.50 114.50 228.50 RHO-points
0 1.00 268.50 0.50 114.50 U-points
1 268.50 536.00 0.50 114.50 U-points
2 1.00 268.50 114.50 228.50 U-points
3 268.50 536.00 114.50 228.50 U-points
0 0.50 268.50 1.00 114.50 V-points
1 268.50 536.50 1.00 114.50 V-points
2 0.50 268.50 114.50 228.00 V-points
3 268.50 536.50 114.50 228.00 V-points
Tile minimum and maximum fractional coordinates for Grid 02:
0 0.50 89.50 0.50 42.50 RHO-points
1 89.50 177.50 0.50 42.50 RHO-points
2 0.50 89.50 42.50 84.50 RHO-points
3 89.50 177.50 42.50 84.50 RHO-points
0 1.00 89.50 0.50 42.50 U-points
1 89.50 177.00 0.50 42.50 U-points
2 1.00 89.50 42.50 84.50 U-points
3 89.50 177.00 42.50 84.50 U-points
0 0.50 89.50 1.00 42.50 V-points
1 89.50 177.50 1.00 42.50 V-points
2 0.50 89.50 42.50 84.00 V-points
3 89.50 177.50 42.50 84.00 V-points
HaloSizeI(1) = 843
HaloSizeJ(1) = 381
TileSide(1) = 275
TileSize(1) = 33275
HaloSizeI(2) = 312
HaloSizeJ(2) = 171
TileSide(2) = 98
TileSize(2) = 4998
zeta 1 Chapman Imp Closed Chapman Imp Chapman Imp
2 Nested Nested Nested Nested
ubar 1 Flather Closed Flather Flather
vbar 1 Flather Closed Flather Flather
u 1 Rad + Nud Closed Rad + Nud Rad + Nud
v 1 Rad + Nud Closed Rad + Nud Rad + Nud
temp 1 Rad + Nud Closed Rad + Nud Rad + Nud
salt 1 Rad + Nud Closed Rad + Nud Rad + Nud
tke 1 Rad + Nud Closed Rad + Nud Rad + Nud
NINGALOO Wind-Driven Upwelling/Downwelling : nesting test
BULK_FLUXES Surface bulk fluxes parameterization.
DIURNAL_SRFLUX Modulate shortwave radiation by the local diurnal cycle.
LONGWAVE_OUT Compute outgoing longwave radiation internally.
MASKING Land/Sea masking.
MB_BBL Blaas Bottom Boundary Layer.
NESTING Nesting grids: Composite and Refinement.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
SPHERICAL Spherical grid configuration.
SPONGE Enhanced horizontal mixing in the sponge areas.
TS_A4HADVECTION Fourth-order Akima horizontal advection of tracers.
TS_A4VADVECTION Fourth-order Akima vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
CHECKDEFS - only one bottom stress formulation is allowed.
ROMS/TOMS - Output NetCDF summary for Grid 02:
simion1232006
Re: online nesting test problem
#2 Unread post by simion1232006 »
Problem solved. I should not define the uv_logdrag and MB_BBL at the same time.
kee
Location: Nanjing Uni. of Info. Sci. & Tech. (nanjing institute of meterology)
#3 Unread post by kee »
hi simion,
which tools did you use to create your datasets to start your 2-way nesting model?
I want to use it. Could you tell me about it?
thanks.
Cheer!
