wrong choice of domain 01 partition error?
longmtm
Location: Univ of Maryland Center for Environmental Science
#1 Unread post by longmtm »
I start to work with ROMS in the last few days.
I used ifort to install ROMS and MPICH-1.2.6 . After the compile, I do get a oceanM executable, it runs with the following case:
mpirun -np 4 ./oceanM ocean_upw.in
But when I looked at the output, it says wrong choice of domain 01 partition, and it actually elected to run on only one node. I did change the ocean_upw.in so that NtileI=NtileJ=2,
The machine is a Microway 10 nodes cluster. Linux_x_86 system.
Can any of you tell me why?
Wen
longmtm
#2 Unread post by longmtm »
The problem is solved, reason is that I put the run mpirun directory in the PATH. The machine has two copies of mpich, and they are not the same.
