I happened to notice that (at least with version 3.7) ROMS did not write out the name of the tidal forcing file for a purely tidal-forced run until I changed line 4597 in read_phypar.F
from
#if defined FRC_FILE
to
#if defined FRC_FILE || defined TIMELESS_DATA
Not sure if that was the best fix but it worked.
Looking at the lines in globaldefs.h where FRC_FILE is defined it seemed like this could arise for other cases besides purely tidal.
Of course the program ran fine, it just didn't write out properly.
TIMELESS_DATA
Re: TIMELESS_DATA
Yes, that would work for your particular set-up. However, the correct way is to modify the internal definition for FRC_FILE in globaldefs.h to:
Thank you for bringing this to my attention. I will load this correction today.
** Define internal flag indicating processing of input forcing
** NetCDF file.
#ifdef SOLVE3D
# ifdef BULK_FLUXES
# ifdef ANA_SMFLUX
# undef ANA_SMFLUX
# ifdef ANA_STFLUX
# undef ANA_STFLUX
# if !defined ANA_BTFLUX || \
(!defined AIR_OCEAN && \
!defined BULK_FLUXES && !defined ANA_SMFLUX) || \
(!defined BULK_FLUXES && !defined ANA_STFLUX) || \
( defined BIOLOGY && !defined ANA_SPFLUX) || \
( defined BIOLOGY && !defined ANA_BPFLUX) || \
( defined BULK_FLUXES && !defined LONGWAVE) || \
( defined BULK_FLUXES && !defined ANA_PAIR) || \
( defined BULK_FLUXES && !defined ANA_TAIR) || \
( defined BULK_FLUXES && !defined ANA_HUMIDITY) || \
( defined BULK_FLUXES && !defined ANA_CLOUD) || \
( defined BULK_FLUXES && !defined ANA_RAIN) || \
( defined BULK_FLUXES && !defined ANA_WINDS) || \
( defined BULK_FLUXES && !defined ANA_SRFLUX) || \
( defined LMD_SKPP && !defined ANA_SRFLUX) || \
( defined SALINITY && !defined ANA_SSFLUX) || \
( defined SOLAR_SOURCE && !defined ANA_SRFLUX) || \
(( defined TS_PSOURCE || defined UV_PSOURCE || \
defined Q_PSOURCE) && !defined ANA_PSOURCE) || \
( defined SSH_TIDES || defined UV_TIDES) || \
( defined BBL_MODEL && (!defined ANA_WWAVE && \
!defined WAVES_OCEAN)) || \
( defined SEDIMENT && !defined ANA_SPFLUX) || \
( defined SEDIMENT && !defined ANA_BPFLUX) || \
( defined WAVE_DATA && (!defined ANA_WWAVE && \
# define FRC_FILE
#else
# if !defined ANA_SMFLUX || \
# define FRC_FILE
