MPDATA Adjoint
Discussion about tangent linear and adjoint models, variational data assimilation, and other related issues.
austinctodd
MPDATA Adjoint
#1 Unread post by austinctodd »
I've been doing some modeling of passive tracers, and I want to use the Adjoint to look at the backward advection of the passive tracers. Since my main interest lies in evaluating the tracer concentrations, I am using MPDATA for the forward integration to reduce overshoots. With other tracer advection schemes, I get values O(10^7-10^11) in both the positive and negative side for a tracer that should range from 0 to 1. MPDATA works well, with only small overshoots.
My problem then lies with the adjoint calculations, for which MPDATA routines are not yet coded. As I think about this more, I wonder if it is even possible to code an adjoint algorithm for a predictor-corrector tracer advection scheme like MPDATA? For example, how would we know the error of the first-pass a priori, if the adjoint requires calculating the anti-diffusive velocities first?
I noticed a track ticket posted a LONG time ago that referred to the difficulty of this calculation (https://www.myroms.org/projects/src/ticket/74), but haven't found any further discussion since. In this ticket, it is said:
The tangent linear and adjoint linearization of the MPDATA algorithm is not trivial. MPDATA, as implemented, is highly nonlinear and we don't know if the tangent linear approximation will hold. The adjoint is a sensitivity operator and it is likely that the TLM, RPM, and ADM will go unstable
Have there been any advances in ways to try to code the adjoint for MPDATA-type advection? It seems that the MPDATA code has been pretty extensively used since this 6-yr old post. If not, are there any thoughts on what the next best method would be to try to reduce the overshoots with the adjoint calculation?
Austin
