Error Restarting ROMS with additional forcing
robjenkinsiii
#1 Unread post by robjenkinsiii »
Good Evening, ROMS users,
I've had some success running cases with different individual forcing files. I've also been able to restart simulations in the past. This restart is the first time I've tried using more than 1 forcing file.
The original run only has a river forcing NetCDF file. The restart includes the river & an additional forcing file for wind stress.
Is it bad form or illegal to add a forcing file when doing a restart?
When I run the restart I get this information about the error:
call from:  inquire.F
ROMS/TOMS - Output error ............ exit_flag:   3
REASON: Invalid argument
Seems strange that it doesn't list the file it can't open.
For the curious, the nc_dump -h for my forcing files are below:
Wind-
NetCDF-3 64bit wind_frc10.nc {
  dimensions:
    sms_time = 8640 ;
    eta_rho = 100 ;
    xi_rho = 81 ;
River -
NetCDF-3 64bit riverdb_frc.nc {
  dimensions:
    xi_rho = 81 ;
    xi_u = 80 ;
    xi_v = 81 ;
    eta_rho = 100 ;
    eta_u = 100 ;
    eta_v = 99 ;
    s_rho = 16 ;
    river = 1 ;
    time = UNLIMITED ; (1 currently)
ocean_rst.nc -
NetCDF-3 64bit ocean_rst4.nc {
  dimensions:
    xi_rho = 81 ;
    xi_u = 80 ;
    xi_v = 81 ;
    xi_psi = 80 ;
    eta_rho = 100 ;
    eta_u = 100 ;
    eta_v = 99 ;
    eta_psi = 99 ;
    N = 16 ;
    s_rho = 16 ;
    s_w = 17 ;
    tracer = 2 ;
    boundary = 4 ;
    ocean_time = UNLIMITED ; (2 currently)
A few other threads (namely this one: https://myroms.org/forum/viewtopic.php?f=19&t=2735)
Seem to face similar problems but none are quite the same with this call to inquire.F
it's my understanding that this utility function is meant to check the NetCDF files being used in a run but I have no idea what it doesn't like.
Any input is appreciated.
Re: Error Restarting ROMS with additional forcing
It is not illegal to add a forcing file on restart. You would have to recompile ROMS, though, after changing something in the cppdefs file.
Perhaps your best clue is the "Invalid argument" error. Though if it failed to have a filename, that could be an invalid argument. Did you change your ocean.in to have NFFILES == 2 when you added the new file to FRCNAME?
For me, the best way to figure these things out is to run in a debugger. Your grid size is small enough that you should be able to run in serial mode in a debugger like gdb.
#3 Unread post by kate »
I got very nearly the same error when falling off the end of my forcing file:
               ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@1^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@°^AG^B^@^@^@^@p^K^@^@h^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@A^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@à^AG^B^@^@^@^@^@^@^@^@â^^á@^@^@^@^@¢Lá@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@A^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@ ^BG^B^@^@^@^@^@^@^@^@<9e>Lá@^@^@^@^@>zá@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^A^O^@^@^@^@^@^@^@^@^@^@^@^@^@^@`^BG^B^@^@^@^@ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
 NetCDF: Invalid argument
I had given it:
     NFFILES == 5                          ! number of forcing files
    FRCNAME == /center/w/kate/MERRA/MERRA_Uwind_3hours_1997.nc |
               /center/w/kate/MERRA/MERRA_Uwind_3hours_1998.nc \
               /center/w/kate/MERRA/MERRA_Qair_3hours_1997.nc |
               /center/w/kate/MERRA/MERRA_Qair_3hours_1998.nc \
               /center/w/kate/MERRA/MERRA_Tair_3hours_1997.nc |
               /center/w/kate/MERRA/MERRA_Tair_3hours_1998.nc \
               /center/w/kate/MERRA/MERRA_Pair_3hours_1997.nc |
               /center/w/kate/MERRA/MERRA_Pair_3hours_1998.nc \
               /center/w/kate/MERRA/MERRA_Vwind_3hours_1997.nc |
               /center/w/kate/MERRA/MERRA_Vwind_3hours_1998.nc
My run had started at the very end of 1997 and tried to go beyond the end of 1998. It knows to go beyond the end of the second files, but doesn't know that there are no third year files.
Anyway, check your ocean.in.
robjenkinsiii
#4 Unread post by robjenkinsiii »
Update:
I combed through my ocean.in pretty carefully. I wasn't making that simple, silly mistake but I really wish I had.
     NFFILES == 3                          ! number of unique forcing files
     FRCNAME == delbayfrc2006.nc\              ! forcing file 1, grid 1
		          delriv7_frc.nc\
	 	         delwnd_frc9.nc
I am now getting a new error. By changing NRREC == 0 to NRREC == 1, a hopefully more telling error comes up.
Fortran runtime error: Attempting to allocate already allocated array 'frc'
At line 1067 of file read_phypar.f90
I open read_phypar.f90 and see that line 1067 is the near the start of a block that handles forcing files.
 mFfiles=MAXVAL(nFfiles)
              allocate ( FRC(mFfiles,Ngrids) )  !!(line 1067)
              allocate ( FRCids(mFfiles,Ngrids) )
              allocate ( Ncount(mFfiles,Ngrids) )
              FRCids(1:mFfiles,1:Ngrids)=-1
              Ncount(1:mFfiles,1:Ngrids)=0
            CASE ('FRCNAME')
              label='FRC - forcing fields'
              Npts=load_s2d(Nval, Cval, line, label, ifile, igrid,      &
     &                      Ncount, mFfiles, FRC)
I'm trying it again now, with a print statement to check 'mFfiles' and 'nFfiles' in this script.
Is there any known reason why it would fail?
EDIT: Searching, the forum as well but not finding any references to this problem.
