roms blow up
gmxwx
roms blow up
#1 Unread post by gmxwx »
can anybody help me with the problem of blowing up? I've check whether there is any nan data in the init and grid file and find none. following is the output of the model
Monday - April 9, 2012 - 10:16:06 PM
Operating system : Linux
CPU/hardware : i686
Compiler system : ifort
Compiler command : /opt/intel/composer_xe_2011_sp1.6.233/bin/ia32/ifort
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free
SVN Revision : 571M
Local Root : /home/zh/roms
Header Dir : /home/zh/roms/ROMS/Include
Header file : scs.h
Analytical Dir: /home/zh/roms/ROMS/Functionals
Resolution, Grid 01: 0108x0088x020, Parallel Threads: 1, Tiling: 001x001
5.000 dt Timestep size (s) for 3-D equations.
1 ndtfast Number of timesteps for 2-D equations between
into restart fields.
to standard output.
into history file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
2.0000E+01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
2.0000E+01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
200.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
Input Grid File: /home/zh/roms/Data/ROMS/Grid/scs-grid.nc
Input Nonlinear Initial File: /home/zh/roms/Data/ROMS/Initial/scs-init.nc
Tile partition information for Grid 01: 0108x0088x0020 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 108 1 88 190080
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -2.50 111.50 0.50 89.50 RHO-points
0 -3.00 111.00 0.50 89.50 U-points
0 -2.50 111.50 0.00 89.00 V-points
zeta 1 Periodic Closed Closed Closed
ubar 1 Periodic Closed Closed Closed
vbar 1 Periodic Closed Closed Closed
u 1 Periodic Closed Closed Closed
v 1 Periodic Closed Closed Closed
temp 1 Periodic Closed Closed Closed
salt 1 Periodic Closed Closed Closed
tke 1 Periodic Closed Closed Closed
scs Wind-Driven Upwelling/Downwelling over a Periodic Channel
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Thread # 0 (pid= 6893) is active.
anger
anger
Vertical S-coordinate System:
20 0.0000000 0.0000000 0.000 0.000 0.000 0.000
19 -0.0500000 -0.0005206 -1.670 -5.052 -9.755 -11.110
18 -0.1000000 -0.0021144 -3.347 -10.211 -21.160 -25.656
17 -0.1500000 -0.0048798 -5.033 -15.488 -34.364 -43.953
16 -0.2000000 -0.0089871 -6.727 -20.899 -49.629 -66.546
15 -0.2500000 -0.0146880 -8.431 -26.469 -67.342 -94.242
14 -0.3000000 -0.0223307 -10.149 -32.233 -88.039 -128.155
13 -0.3500000 -0.0323782 -11.883 -38.238 -112.429 -169.767
12 -0.4000000 -0.0454338 -13.636 -44.543 -141.441 -221.011
11 -0.4500000 -0.0622719 -15.415 -51.227 -176.263 -284.365
10 -0.5000000 -0.0838752 -17.226 -58.388 -218.406 -362.977
9 -0.5500000 -0.1114783 -19.077 -66.148 -269.765 -460.798
8 -0.6000000 -0.1466152 -20.977 -74.662 -332.697 -582.740
7 -0.6500000 -0.1911684 -22.941 -84.117 -410.095 -734.831
6 -0.7000000 -0.2474113 -24.983 -94.741 -505.451 -924.349
5 -0.7500000 -0.3180318 -27.120 -106.803 -622.892 -1159.901
4 -0.8000000 -0.4061157 -29.374 -120.612 -767.161 -1451.366
3 -0.8500000 -0.5150586 -31.767 -136.506 -943.474 -1809.615
2 -0.9000000 -0.6483588 -34.322 -154.836 -1157.203 -2245.851
1 -0.9500000 -0.8092347 -37.062 -175.923 -1413.294 -2770.377
0 -1.0000000 -1.0000000 -40.000 -200.000 -1715.301 -3390.601
Time Splitting Weights: ndtfast = 1 nfast = 1
1 1.0000000000000000 1.0000000000000000 1.0000000000000000 1.0000000000000000
ndtfast, nfast = 1 1 nfast/ndtfast = 1.00000
1.000000000000 1.000000000000 0.500000000000 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.00000
WARNING: unstable weights, reduce parameter Fgamma in mod_scalars.F
Minimum X-grid spacing, DXmin = 8.87477211E+00 km
Maximum X-grid spacing, DXmax = 9.26788230E+00 km
Minimum Y-grid spacing, DYmin = 8.87477016E+00 km
Maximum Y-grid spacing, DYmax = 9.26788047E+00 km
Minimum Z-grid spacing, DZmin = 1.67013707E+00 m
Maximum Z-grid spacing, DZmax = 6.20224083E+02 m
Minimum barotropic Courant Number = 1.53987519E-02
Maximum barotropic Courant Number = 1.40354848E-01
Maximum Coriolis Courant Number = 2.77679662E-04
(File: scs-init.nc, Rec=0001, Index=1)
- free-surface
(Min = -6.98092580E-02 Max = 7.27420375E-02)
(Min = -1.14098065E-01 Max = 9.99023467E-02)
(Min = -1.14831105E-01 Max = 6.89553097E-02)
- u-momentum component
(Min = -3.37402552E-01 Max = 3.89305800E-01)
- v-momentum component
(Min = -2.69870967E-01 Max = 2.58325964E-01)
- potential temperature
(Min = 2.31640267E+00 Max = 2.56121807E+01)
- salinity
(Min = 3.20656319E+01 Max = 3.47536621E+01)
GET_NGFLD - tidal period
(Min = 4.47141600E+04 Max = 4.47141600E+04)
(Min = 0.00000000E+00 Max = 9.88685411E-01)
(Min = 1.13879643E-03 Max = 6.27210680E+00)
(Min = 0.00000000E+00 Max = 6.28312514E+00)
(Min = 0.00000000E+00 Max = 6.28312211E+00)
(Min = 0.00000000E+00 Max = 1.03878503E+00)
(Min = -6.22284517E-01 Max = 1.89027231E-01)
Maximum grid stiffness ratios: rx0 = 1.843809E-01 (Beckmann and Haidvogel)
rx1 = 3.465886E+00 (Haney)
Initial basin volumes: TotVolume = 2.8176580971E+14 m3
MinVolume = 1.3190158927E+08 m3
MaxVolume = 5.2417501928E+10 m3
Max/Min = 3.9739856219E+02
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00001440)
0 0 00:00:00 NaN NaN NaN NaN
(088,39,01) 1.932417E-04 9.216514E-05 0.000000E+00 NaN
Thread # 0 CPU: 0.172
Total: 0.172
Allocation and array initialization .............. 0.060 (34.8836 %)
Ocean state initialization ....................... 0.016 ( 9.3023 %)
Reading of input data ............................ 0.004 ( 2.3260 %)
Computation of global information integrals ...... 0.012 ( 6.9768 %)
2D/3D coupling, vertical metrics ................. 0.016 ( 9.3017 %)
Omega vertical velocity .......................... 0.004 ( 2.3254 %)
Equation of state for seawater ................... 0.028 (16.2791 %)
Total: 0.140 81.3949
All percentages are with respect to total time = 0.172
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
and my cpp file is shown as follows:
#define UV_ADV /* use to turn ON or OFF advection terms */
#define UV_COR /* use to turn ON or OFF Coriolis term */
#define UV_QDRAG /* use to turn ON or OFF quadratic bottom friction */
#define UV_VIS2 /* use to turn ON or OFF harmonic horizontal mixing */
#define DJ_GRADPS /* use if splines density Jacobian (Shchepetkin, 2000) */
#define MIX_S_UV /* momentum mixing on s-surfaces */
#define MIX_GEO_TS /* tracer mixing on constant z surfaces */
#define TS_DIF2 /* use to turn ON or OFF harmonic horizontal mixing */
#undef TS_U3HADVECTION /* use if 3rd-order upstream horiz. advection */
#undef TS_C4VADVECTION /* use if 4th-order centered vertical advection */
#define TS_MPDATA /* use if recursive MPDATA 3D advection */
#undef SOLAR_SOURCE /* use if solar radiation source term */
#define NONLIN_EOS /* use if using nonlinear equation of state */
#undef SALINITY /* use if having salinity */
#define SPLINES /* use to activate parabolic splines reconstruction */
#define AVERAGES /* use if writing out time-averaged data */
#define AVERAGES_FLUXES /* use if writing out time-averaged fluxes */
#define AVERAGES_AKV /* use if writing out time-averaged AKv */
#define AVERAGES_AKT /* use if writing out time-averaged AKt */
#define SOLVE3D /* use if solving 3D primitive equations */
#define WESTERN_WALL
#undef EW_PERIODIC /* use if East-West periodic boundaries */
#undef NS_PERIODIC /* use if North-South periodic boundaries */
#define EAST_FSCHAPMAN
#define NORTH_FSCHAPMAN
#define SOUTH_FSCHAPMAN
#define EAST_M2FLATHER
#define NORTH_M2FLATHER
#define SOUTH_M2FLATHER
#define SSH_TIDES
#define UV_TIDES
#define MY25_MIXING /* use if Mellor/Yamada Level-2.5 closure */
#ifdef MY25_MIXING
# define N2S2_HORAVG /* use if Large et al. (1994) interior closure */
# define KANTHA_CLAYSON /* use if Kantha and Clayson stability function */
#undef ECOSIM
#if defined ECOSIM || defined BIO_FASHAM
# undef ANA_BIOLOGY /* use if analytical biology initial conditions */
# define ANA_SPFLUX /* use if analytical surface passive tracers fluxes */
# define ANA_BPFLUX /* use if analytical bottom passive tracers fluxes */
# define ANA_CLOUD /* use if analytical cloud fraction */
#undef BULK_FLUXES /* use if bulk fluxes computation */
#ifdef BULK_FLUXES
# define EMINUSP /* use if computing E-P */
# define LONGWAVE /* use if computing net longwave radiation */
# undef ANA_RAIN /* use if analytical rain fall rate */
#else
# define ANA_SMFLUX /* use if analytical surface momentum stress */
# define ANA_STFLUX /* use if analytical surface temperature flux */
#if defined BULK_FLUXES || defined ECOSIM
# undef ANA_CLOUD
# undef PAPA_CLM /* ? */
#undef ANA_SSFLUX /* use if analytical surface salinity flux */
#undef ANA_BSFLUX /* use if analytical bottom salinity flux */
#define ANA_BTFLUX /* use if analytical bottom temperature flux */
Re: roms blow up
At a glance, this needs fixing:
so that it is either period for both columns 1 and 3 or for neither of them. Also, you can get rid of the WESTERN_WALL business in your cpp file - it is being ignored now.
Also, what did you do to gamma?
I have:
 Power filter parameters, Fgamma, gamma =  0.28400   0.14200
Oooh, I found it:
      gamma=Fgamma*MAX(0.0_r8, 1.0_r8-10.0_r8/REAL(ndtfast(ng),r8))
It appears that ndtfast of 1 is not a well-behaved choice - unless you are running a 2-D problem for which it has to be 1. Try something that's rather larger than ten.
