Dear All,
I have successfully run the INLET_TEST case provided with ROMS 3.6 using MPICH2.
Now to try some other application of ROMS+SWAN coupling, I have simply done following things:
(1) ROMS_APPLICATION=IO
(1) Successfully generated grids using Seagrid (provided from ROMS svn, latest) ("io_grid.nc" grid file is attached here)[FLAT BOTTOM BATHYMETRY WITH VALUE 4.0M HAS BEEN USED FOLLOWING THE INLET_TEST CASE]
(2) made modifications to the required ana_*.h header files (attached here) following INLET_TEST case
(3) Modified *.in files (attached here)
(4) Modified build.bash (attached here)
The difference between my setup (IO) and INLET_TEST case is the number of grid points; in INLET_TEST case the ocean grid is 75*70 and in my case(IO) it is 98*148.Also I have changed the time interval of coupling from 120 sec (original INLET_TEST case) to 300 sec and NINFO=1000 to run faster (Hope these changes have no issues with "NaN" values).
The compilation of the IO case ended successfully. But when I ran the case I got error (NaN values etc). The command "mpiexec -n 16 ./oceanM coupling_io.in" gives the following error and stops
Coupled Input File name = coupling_io.in
Model Coupling Parallel Threads:
Ocean Model MPI nodes: 000 - 011
Waves Model MPI nodes: 012 - 015
Waves Export: Wdir:Wamp:Wlen:Wptop:Wpbot:Wubot
Monday - January 30, 2012 - 12:38:45 PM
IO Case
Operating system : Linux
CPU/hardware : ia64
Compiler system : ifort
Compiler command : /usr1/home/abhisek1984/LIB/mpich2-install/bin/mpif90
Compiler flags : -heap-arrays -fp-model source -ip -O3 -I/usr1/home/abhisek1984/LIB/MCT/mct -free -free -free
Input Script : ocean_io.in
SVN Revision :
Local Root : /usr1/home/abhisek1984/ROMS-3.6
Header Dir : /usr1/home/abhisek1984/ROMS-3.6/Projects/io
Header file : io.h
Analytical Dir: /usr1/home/abhisek1984/ROMS-3.6/Projects/io
Resolution, Grid 01: 0098x0148x001, Parallel Nodes: 12, Tiling: 004x003
34560 ntimes Number of timesteps for 3-D equations.
5.000 dt Timestep size (s) for 3-D equations.
into restart fields.
1000 ninfo Number of timesteps between print of information
to standard output.
into history file.
1.0000E-03 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1.5000E-02 Zob Bottom roughness (m).
5.0000E-01 Zos Surface roughness (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E+00 theta_b S-coordinate bottom control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
T Hout(idBath) Write out time-dependent bathymetry.
T Hout(idUbrs) Write out bottom U-current stress.
T Hout(idVbrs) Write out bottom V-current stress.
T Hout(idUbws) Write out wind-induced, bottom U-wave stress.
T Hout(idVbws) Write out wind-induced, bottom V-wave stress.
T Hout(idUbcs) Write out max wind + current, bottom U-wave stress.
T Hout(idVbcs) Write out max wind + current, bottom V-wave stress.
T Hout(idW2xx) Write out 2D radiation stress, Sxx.
T Hout(idW2xy) Write out 2D radiation stress, Sxy.
T Hout(idW2yy) Write out 2D radiation stress, Syy.
T Hout(idWamp) Write out wave height.
T Hout(idWlen) Write out wavelength.
T Hout(idWdir) Write out wave direction.
T Hout(idBott) Write out bottom property 01: grain_diameter
T Hout(idBott) Write out bottom property 02: grain_density
T Hout(idBott) Write out bottom property 03: settling_vel
T Hout(idBott) Write out bottom property 04: erosion_stress
T Hout(idBott) Write out bottom property 05: ripple_length
T Hout(idBott) Write out bottom property 06: ripple_height
T Hout(idBott) Write out bottom property 07: bed_wave_amp
T Hout(idBott) Write out bottom property 08: Zo_def
T Hout(idBott) Write out bottom property 09: Zo_app
Physical parameters File: ocean_io.in
Input Grid File: Data/io_grid.nc
SWAN is preparing computation ...
Tile partition information for Grid 01: 0098x0148x0001 tiling: 004x003
tile Istr Iend Jstr Jend Npts
0 1 24 1 49 1176
1 25 49 1 49 1225
2 50 74 1 49 1225
3 75 98 1 49 1176
4 1 24 50 99 1200
5 25 49 50 99 1250
6 50 74 50 99 1250
7 75 98 50 99 1200
8 1 24 100 148 1176
9 25 49 100 148 1225
10 50 74 100 148 1225
11 75 98 100 148 1176
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 24.50 0.50 49.50 RHO-points
1 24.50 49.50 0.50 49.50 RHO-points
2 49.50 74.50 0.50 49.50 RHO-points
3 74.50 98.50 0.50 49.50 RHO-points
4 0.50 24.50 49.50 99.50 RHO-points
5 24.50 49.50 49.50 99.50 RHO-points
6 49.50 74.50 49.50 99.50 RHO-points
7 74.50 98.50 49.50 99.50 RHO-points
8 0.50 24.50 99.50 148.50 RHO-points
9 24.50 49.50 99.50 148.50 RHO-points
10 49.50 74.50 99.50 148.50 RHO-points
11 74.50 98.50 99.50 148.50 RHO-points
0 1.00 24.50 0.50 49.50 U-points
1 24.50 49.50 0.50 49.50 U-points
2 49.50 74.50 0.50 49.50 U-points
3 74.50 98.00 0.50 49.50 U-points
4 1.00 24.50 49.50 99.50 U-points
5 24.50 49.50 49.50 99.50 U-points
6 49.50 74.50 49.50 99.50 U-points
7 74.50 98.00 49.50 99.50 U-points
8 1.00 24.50 99.50 148.50 U-points
9 24.50 49.50 99.50 148.50 U-points
10 49.50 74.50 99.50 148.50 U-points
11 74.50 98.00 99.50 148.50 U-points
0 0.50 24.50 1.00 49.50 V-points
1 24.50 49.50 1.00 49.50 V-points
2 49.50 74.50 1.00 49.50 V-points
3 74.50 98.50 1.00 49.50 V-points
4 0.50 24.50 49.50 99.50 V-points
5 24.50 49.50 49.50 99.50 V-points
6 49.50 74.50 49.50 99.50 V-points
7 74.50 98.50 49.50 99.50 V-points
8 0.50 24.50 99.50 148.00 V-points
9 24.50 49.50 99.50 148.00 V-points
10 49.50 74.50 99.50 148.00 V-points
11 74.50 98.50 99.50 148.00 V-points
HaloSizeI(1) = 117
HaloSizeJ(1) = 192
TileSide(1) = 58
TileSize(1) = 1914
Sediment Parameters, Grid: 01
1 1.0000E-01 0.0000E+00 2.6500E+03 1.0000E+01 5.0000E-03 0.0000E+00
1 1.0000E-01 1.0000E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+01
New bed layer formed when deposition exceeds 0.10000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.00000E+00 (m).
Rate coefficient for bed load transport = 0.15000E+00
T Hout(idTvar) Write out sediment01: mud_01
T Hout(idfrac) Write out bed fraction, sediment 01: mudfrac_01
T Hout(idfrac) Write out mass, sediment 01: mudmass_01
zeta 1 Gradient Closed Gradient Gradient
ubar 1 Gradient Closed Gradient Reduced
vbar 1 Gradient Closed Gradient Reduced
u 1 Gradient Closed Gradient Gradient
v 1 Gradient Closed Gradient Gradient
temp 1 Gradient Closed Gradient Gradient
salt 1 Gradient Closed Gradient Gradient
mud_01 1 Gradient Closed Gradient Gradient
tke 1 Gradient Closed Gradient Gradient
IO IO Case
ANA_SEDIMENT Analytical sediment initial conditions.
FSOBC_REDUCED Using free-surface data in reduced physics condtions
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
NEARSHORE_MELLOR05 Nearshore Radiation Stress Terms (Mellor 2005).
NONLINEAR Nonlinear Model.
SED_MORPH Allow bottom model elevation to evolve.
SSW_BBL Styles and Glenn Bottom Boundary Layer - modified.
SSW_CALC_ZNOT Internal computation of bottom roughness.
SWAN_COUPLING Two-way SWAN/ROMS coupling.
UV_ADV Advection of momentum.
WAVES_OCEAN Two-way wave-ocean models coupling.
Process Information:
Node # 0 (pid= 8703) is active.
Node # 2 (pid= 8705) is active.
Node # 4 (pid= 8707) is active.
Node # 5 (pid= 8708) is active.
Node # 6 (pid= 8709) is active.
Node # 7 (pid= 8710) is active.
Node # 8 (pid= 8711) is active.
Node # 9 (pid= 8712) is active.
Node # 10 (pid= 8713) is active.
Node # 11 (pid= 8714) is active.
Node # 1 (pid= 8704) is active.
Node # 3 (pid= 8706) is active.
Vertical S-coordinate System:
1 0.0000000 0.0000000 0.000 0.000 0.000 0.000
0 -1.0000000 -1.0000000 0.000 0.000 -2.000 -4.000
Time Splitting Weights: ndtfast = 20 nfast = 29
3-0.0011514592651644 0.0501156998674241-0.0034654566136460 0.1501639558342180
4-0.0003735756740661 0.0501732728306823-0.0038390322877121 0.2003372286649003
6 0.0029141799764308 0.0501428056118168 0.0000580677400949 0.3006719858911027
7 0.0054132615310267 0.0499970966129953 0.0054713292711215 0.3506690825040980
8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405419
9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876602
10 0.0161716623600090 0.0486998273761630 0.0421751148367487 0.4983983377638232
11 0.0207585511322367 0.0478912442581626 0.0629336659689854 0.5462895820219857
12 0.0257765478740990 0.0468533167015507 0.0887102138430844 0.5931428987235364
13 0.0311633730493853 0.0455644893078458 0.1198735868924697 0.6387073880313822
14 0.0368391158442262 0.0440063206553765 0.1567127027366959 0.6827137086867586
15 0.0427031802506397 0.0421643648631652 0.1994158829873356 0.7248780735499238
16 0.0486309868367616 0.0400292058506332 0.2480468698240972 0.7649072794005570
17 0.0544704302037592 0.0375976565087951 0.3025173000278564 0.8025049359093521
18 0.0600380921294286 0.0348741349986072 0.3625553921572849 0.8373790709079593
19 0.0651152103984763 0.0318722303921357 0.4276706025557612 0.8692513013000950
20 0.0694434033194839 0.0286164698722119 0.4971140058752452 0.8978677711723069
21 0.0727201499285570 0.0251442997062377 0.5698341558038021 0.9230120708785446
22 0.0745940258796570 0.0215082922098099 0.6444281816834592 0.9445203630883545
23 0.0746596950216180 0.0177785909158270 0.7190878767050772 0.9622989540041815
24 0.0724526566618460 0.0140456061647461 0.7915405333669232 0.9763445601689277
25 0.0674437485167025 0.0104229733316538 0.8589842818836257 0.9867675335005816
26 0.0590334053485720 0.0070507859058187 0.9180176872321977 0.9938183194064003
27 0.0465456732896124 0.0040991156383901 0.9645633605218101 0.9979174350447905
28 0.0292219798521903 0.0017718319739095 0.9937853403740005 0.9996892670187000
29 0.0062146596259994 0.0003107329813000 0.9999999999999999 1.0000000000000000
Minimum X-grid spacing, DXmin = 6.78538812E+00 km
Maximum X-grid spacing, DXmax = 1.26749281E+01 km
Minimum Y-grid spacing, DYmin = 2.58717153E+00 km
Maximum Y-grid spacing, DYmax = 5.49612987E+00 km
Minimum Z-grid spacing, DZmin = NaN m
Maximum Z-grid spacing, DZmax = NaN m
Minimum barotropic Courant Number = 0.00000000E+00
Maximum barotropic Courant Number = 6.04195128E-04
Maximum Coriolis Courant Number = 2.76954677E-04
Maximum grid stiffness ratios: rx0 = NaN (Beckmann and Haidvogel)
rx1 = NaN (Haney)
Initial basin volumes: TotVolume = NaN m3
MinVolume = NaN m3
MaxVolume = NaN m3
Max/Min = NaN
OCN2WAV - (06) imported and (05) exported fields, t = 0 00:00:00
- ROMS coupling exchanges wait clock (s):
(Recv= 2.45320000E+01 Send= 4.00000000E-03)
- ROMS Import: wave direction
(Min= 0.00000000E+00 Max= 0.00000000E+00)
- ROMS Import: significant wave height
(Min= 0.00000000E+00 Max= 2.00687833E-02)
- ROMS Import: average wave length
(Min= 0.00000000E+00 Max= 3.11754012E+00)
- ROMS Import: surface wave relative peak period
(Min= 0.00000000E+00 Max= 1.90365362E+00)
- ROMS Import: bottom wave period
- ROMS Import: wave bottom orbital velocity
- ROMS Export: bathymetry
(Min= 0.00000000E+00 Max= 4.00000000E+00)
- ROMS Export: free-surface
- ROMS Export: vertically integrated u-momentum component
- ROMS Export: vertically integrated v-momentum component
- ROMS Export: bottom roughness
(Min= 1.00000000E-04 Max= 1.00000000E-04)
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00034560)
WAV2OCN - (05) imported and (06) exported fields, t = 20000101.000000
- SWAN coupling exchanges wait clock (s):
(Recv= 5.56000000E-01 Send= 0.00000000E+00)
0 0 00:00:00 NaN NaN NaN NaN
(00,000,0) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
Node # 0 CPU: 2.280
Node # 1 CPU: 2.236
Node # 8 CPU: 2.280
Node # 10 CPU: 2.284
Node # 2 CPU: 2.280
Node # 3 CPU: 2.284
Node # 4 CPU: 2.268
Node # 5 CPU: 2.268
Node # 6 CPU: 2.280
Node # 7 CPU: 2.284
Node # 9 CPU: 2.276
Node # 11 CPU: 2.284
Total: 27.304
Allocation and array initialization .............. 0.056 ( 0.2051 %)
Ocean state initialization ....................... 25.288 (92.6165 %)
Processing of input data ......................... 0.004 ( 0.0146 %)
Computation of global information integrals ...... 0.004 ( 0.0146 %)
2D/3D coupling, vertical metrics ................. 0.012 ( 0.0439 %)
Omega vertical velocity .......................... 0.004 ( 0.0146 %)
Equation of state for seawater ................... 0.004 ( 0.0146 %)
Total: 25.372 92.9241
Message Passage: 2D halo exchanges ............... 0.096 ( 0.3516 %)
Message Passage: 3D halo exchanges ............... 0.016 ( 0.0586 %)
Message Passage: 4D halo exchanges ............... 0.008 ( 0.0293 %)
Message Passage: data broadcast .................. 0.216 ( 0.7911 %)
Message Passage: data reduction .................. 0.704 ( 2.5784 %)
Message Passage: data scattering.................. 0.448 ( 1.6408 %)
Message Passage: multi-model coupling ............ 25.244 (92.4553 %)
Total: 26.732 97.9051
All percentages are with respect to total time = 27.304
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_fsobc.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_sediment.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
I adjusted ROMS to run on 12 processors and SWAN on 4 pros,(this is what I have already done with INLET_TEST case which ended successfully).
I suspect there must be something wrong the specification of the number of grids. Can anyone please help me in identifying the error?
(all the required files are attached here)
Thanks in advance,
Abhisek
Coupling ROMS+SWAN
Coupling ROMS+SWAN
- IO.rar
- Required Files
- (3.32 MiB) Downloaded 1395 times
