the focing file problems of roms3.5
rainbowbluegz
#1 Unread post by rainbowbluegz »
hi, everybody
the error occurs when define BULK_FLUXES in *.h
GET_VARCOORDS - Cannot find "coordinates" attribute for variable: Uwind
in file: roms_frc_NCEP2_Y2010M2.nc
This attribute is needed to interpolate input data
to model grid. Following CF compliance, we need:
float my_var(time, lat, lon) ;
my_var:long_name = "my variable long name" ;
my_var:units = "my variable units" ;
my_var:coordinates = "lon lat" ;
my_var:time = "my_var_time" ;
GET_2DFLD - error while reading variable: uwnd at TIME index = 192
The forcing file are already in the grid of Roms, so it neednot to use "coordinates ", then how to avoid regriding and not use get_varcoords??? or has some other methods?
If I add "coordinates" in forcing file.
then ncdump it will appear:
%% ncdump('roms_frc_NCEP2_Y2010M2.nc') %% Generated 16-Dec-2011 11:24:20
nc = netcdf('roms_frc_NCEP2_Y2010M2.nc', 'noclobber');
if isempty(nc), return, end
%% Global attributes:
nc.title = ncchar(''SCS Model'');
nc.date = ncchar(''15-Dec-2011'');
nc.grd_file = ncchar(''roms_grd.nc'');
nc.type = ncchar(''ROMS forcing file'');
nc.start_tide_mjd = ncdouble(55287);
nc.components = ncchar(''M2 S2 N2 K2 K1 O1 P1 Q1 Mf Mm '');
%% Dimensions:
nc('xi_u') = 68;
nc('eta_u') = 60;
nc('xi_v') = 69;
nc('eta_v') = 59;
nc('xi_rho') = 69;
nc('eta_rho') = 60;
nc('xi_psi') = 68;
nc('eta_psi') = 59;
nc('sms_time') = 192;
nc('shf_time') = 192;
nc('swf_time') = 192;
nc('sst_time') = 192;
nc('srf_time') = 192;
nc('sss_time') = 192;
nc('wind_time') = 192;
nc('tide_period') = 10;
%% Variables and attributes:
nc{'sms_time'} = ncdouble('sms_time'); %% 192 elements.
nc{'sms_time'}.long_name = ncchar(''surface momentum stress time'');
nc{'sms_time'}.units = ncchar(''days'');
nc{'sms_time'}.cycle_length = ncdouble(1);
nc{'shf_time'} = ncdouble('shf_time'); %% 192 elements.
nc{'shf_time'}.long_name = ncchar(''surface heat flux time'');
nc{'shf_time'}.units = ncchar(''days'');
nc{'shf_time'}.cycle_length = ncdouble(1);
nc{'swf_time'} = ncdouble('swf_time'); %% 192 elements.
nc{'swf_time'}.long_name = ncchar(''surface freshwater flux time'');
nc{'swf_time'}.units = ncchar(''days'');
nc{'swf_time'}.cycle_length = ncdouble(1);
nc{'sst_time'} = ncdouble('sst_time'); %% 192 elements.
nc{'sst_time'}.long_name = ncchar(''sea surface temperature time'');
nc{'sst_time'}.units = ncchar(''days'');
nc{'sst_time'}.cycle_length = ncdouble(1);
nc{'sss_time'} = ncdouble('sss_time'); %% 192 elements.
nc{'sss_time'}.long_name = ncchar(''sea surface salinity time'');
nc{'sss_time'}.units = ncchar(''days'');
nc{'sss_time'}.cycle_length = ncdouble(1);
nc{'srf_time'} = ncdouble('srf_time'); %% 192 elements.
nc{'srf_time'}.long_name = ncchar(''solar shortwave radiation time'');
nc{'srf_time'}.units = ncchar(''days'');
nc{'srf_time'}.cycle_length = ncdouble(1);
nc{'wind_time'} = ncdouble('wind_time'); %% 192 elements.
nc{'wind_time'}.long_name = ncchar(''surface wind time'');
nc{'wind_time'}.units = ncchar(''days'');
nc{'wind_time'}.cycle_length = ncdouble(1);
nc{'sustr'} = ncdouble('sms_time', 'eta_u', 'xi_u'); %% 783360 elements.
nc{'sustr'}.long_name = ncchar(''surface u-momentum stress'');
nc{'sustr'}.units = ncchar(''Newton meter-2'');
nc{'svstr'} = ncdouble('sms_time', 'eta_v', 'xi_v'); %% 781632 elements.
nc{'svstr'}.long_name = ncchar(''surface v-momentum stress'');
nc{'svstr'}.units = ncchar(''Newton meter-2'');
nc{'Uwind'} = ncdouble('wind_time', 'eta_u', 'xi_u'); %% 783360 elements.
nc{'Uwind'}.long_name = ncchar(''surface u component'');
nc{'Uwind'}.units = ncchar(''Meter day-1'');
nc{'Uwind'}.coordinates = ncchar(''lon lat'');
nc{'Uwind'}.time = ncchar(''days'');
nc{'Vwind'} = ncdouble('wind_time', 'eta_v', 'xi_v'); %% 781632 elements.
nc{'Vwind'}.long_name = ncchar(''surface v component'');
nc{'Vwind'}.units = ncchar(''Meter day-1'');
nc{'Vwind'}.coordinates = ncchar(''lon lat'');
nc{'Vwind'}.time = ncchar(''days'');
nc{'lon'} = ncdouble('eta_u', 'xi_u'); %% 4080 elements.
nc{'lon'}.units = ncchar(''degree'');
nc{'lon'}.point_spacing = ncchar(''even'');
nc{'lon'}.axis = ncchar(''X'');
nc{'lat'} = ncdouble('eta_v', 'xi_v'); %% 4071 elements.
nc{'lat'}.units = ncchar(''degree'');
nc{'lat'}.point_spacing = ncchar(''even'');
nc{'lat'}.axis = ncchar(''Y'');
nc{'shflux'} = ncdouble('shf_time', 'eta_rho', 'xi_rho'); %% 794880 elements.
nc{'shflux'}.long_name = ncchar(''surface net heat flux'');
nc{'shflux'}.units = ncchar(''Watts meter-2'');
nc{'swflux'} = ncdouble('swf_time', 'eta_rho', 'xi_rho'); %% 794880 elements.
nc{'swflux'}.long_name = ncchar(''surface freshwater flux (E-P)'');
nc{'swflux'}.units = ncchar(''centimeter day-1'');
nc{'swflux'}.positive = ncchar(''net evaporation'');
nc{'swflux'}.negative = ncchar(''net precipitation'');
nc{'SST'} = ncdouble('sst_time', 'eta_rho', 'xi_rho'); %% 794880 elements.
nc{'SST'}.long_name = ncchar(''sea surface temperature'');
nc{'SST'}.units = ncchar(''Celsius'');
nc{'SSS'} = ncdouble('sss_time', 'eta_rho', 'xi_rho'); %% 794880 elements.
nc{'SSS'}.long_name = ncchar(''sea surface salinity'');
nc{'SSS'}.units = ncchar(''PSU'');
nc{'dQdSST'} = ncdouble('sst_time', 'eta_rho', 'xi_rho'); %% 794880 elements.
nc{'dQdSST'}.long_name = ncchar(''surface net heat flux sensitivity to SST'');
nc{'dQdSST'}.units = ncchar(''Watts meter-2 Celsius-1'');
nc{'swrad'} = ncdouble('srf_time', 'eta_rho', 'xi_rho'); %% 794880 elements.
nc{'swrad'}.long_name = ncchar(''solar shortwave radiation'');
nc{'swrad'}.units = ncchar(''Watts meter-2'');
nc{'swrad'}.positive = ncchar(''downward flux, heating'');
nc{'swrad'}.negative = ncchar(''upward flux, cooling'');
nc{'bwflux'} = ncdouble('swf_time', 'eta_rho', 'xi_rho'); %% 794880 elements.
nc{'bwflux'}.long_name = ncchar(''bottom freshwater flux (E-P)'');
nc{'bwflux'}.units = ncchar(''centimeter day-1'');
nc{'bwflux'}.positive = ncchar(''net evaporation'');
nc{'bwflux'}.negative = ncchar(''net precipitation'');
nc{'tide_period'} = ncdouble('tide_period'); %% 10 elements.
nc{'tide_period'}.long_name = ncchar(''Tide angular period'');
nc{'tide_period'}.units = ncchar(''Hours'');
nc{'tide_Ephase'} = ncdouble('tide_period', 'eta_rho', 'xi_rho'); %% 41400 elements.
nc{'tide_Ephase'}.long_name = ncchar(''Tidal elevation phase angle'');
nc{'tide_Ephase'}.units = ncchar(''Degrees'');
nc{'tide_Eamp'} = ncdouble('tide_period', 'eta_rho', 'xi_rho'); %% 41400 elements.
nc{'tide_Eamp'}.long_name = ncchar(''Tidal elevation amplitude'');
nc{'tide_Eamp'}.units = ncchar(''Meter'');
nc{'tide_Cmin'} = ncdouble('tide_period', 'eta_rho', 'xi_rho'); %% 41400 elements.
nc{'tide_Cmin'}.long_name = ncchar(''Tidal current ellipse semi-minor axis'');
nc{'tide_Cmin'}.units = ncchar(''Meter second-1'');
nc{'tide_Cmax'} = ncdouble('tide_period', 'eta_rho', 'xi_rho'); %% 41400 elements.
nc{'tide_Cmax'}.long_name = ncchar(''Tidal current, ellipse semi-major axis'');
nc{'tide_Cmax'}.units = ncchar(''Meter second-1'');
nc{'tide_Cangle'} = ncdouble('tide_period', 'eta_rho', 'xi_rho'); %% 41400 elements.
nc{'tide_Cangle'}.long_name = ncchar(''Tidal current inclination angle'');
nc{'tide_Cangle'}.units = ncchar(''Degrees between semi-major axis and East'');
nc{'tide_Cphase'} = ncdouble('tide_period', 'eta_rho', 'xi_rho'); %% 41400 elements.
nc{'tide_Cphase'}.long_name = ncchar(''Tidal current phase angle'');
nc{'tide_Cphase'}.units = ncchar(''Degrees'');
endef(nc)
then run model , it shows:
2016 ntimes Number of timesteps for 3-D equations.
1200.000 dt Timestep size (s) for 3-D equations.
2016 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
144 nHIS Number of timesteps between the writing fields
into history file.
7200 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
144 nAVG Number of timesteps between the writing of
7200 nDIA Number of timesteps between the writing of
0.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
5.0000E-03 Zob Bottom roughness (m).
1.0000E+01 blk_ZQ Height (m) of surface air humidity measurement.
1.0000E+01 blk_ZT Height (m) of surface air temperature measurement.
2.5000E+00 theta_s S-coordinate surface control parameter.
8.0000E-01 theta_b S-coordinate bottom control parameter.
10.000 Tcline S-coordinate surface/bottom layer width (m) used
12538.000 dstart Time-stamp assigned to model initialization (days).
12538.000 tide_start Reference time origin for tidal forcing (days).
-2.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
T Hout(idTsur) Write out surface net heat flux.
T Hout(idTsur) Write out surface net salt flux.
T Hout(idSrad) Write out shortwave radiation flux.
T Hout(idLrad) Write out longwave radiation flux.
T Hout(idLhea) Write out latent heat flux.
T Hout(idShea) Write out sensible heat flux.
T Hout(idEmPf) Write out E-P flux.
T Aout(idUsms) Write out averaged surface U-momentum stress.
T Aout(idVsms) Write out averaged surface V-momentum stress.
Output Restart File: roms_rst.nc
Prefix for History Files: roms_his
Output Averages File: roms_avg.nc
Output Diagnostics File: roms_dia.nc
Input Grid File: roms_grd.nc
Input Nonlinear Initial File: roms_ini_ECCO_Y2010M2.nc
Input Forcing File 01: roms_frc_NCEP2_Y2010M2.nc
Input Forcing File 02: roms_blk_NCEP2_Y2010M2.nc
Input Climatology File: roms_clm_ECCO_Y2010M2.nc
Biology Parameters File: /home/xie/roms-3.5/User/External/bio_Fennel_scs.in
Tile partition information for Grid 01: 0067x0058x0020 tiling: 001x008
tile Istr Iend Jstr Jend Npts
0 1 67 1 5 6700
1 1 67 6 13 10720
2 1 67 14 21 10720
3 1 67 22 29 10720
4 1 67 30 37 10720
5 1 67 38 45 10720
6 1 67 46 53 10720
7 1 67 54 58 6700
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 67.50 0.50 60.50 RHO-points
1 0.50 67.50 -0.50 60.50 RHO-points
2 0.50 67.50 -0.50 60.50 RHO-points
3 0.50 67.50 -0.50 60.50 RHO-points
4 0.50 67.50 -0.50 60.50 RHO-points
5 0.50 67.50 -0.50 60.50 RHO-points
6 0.50 67.50 -0.50 60.50 RHO-points
7 0.50 67.50 -0.50 59.50 RHO-points
0 0.00 67.00 0.50 60.50 U-points
1 0.00 67.00 -0.50 60.50 U-points
2 0.00 67.00 -0.50 60.50 U-points
3 0.00 67.00 -0.50 60.50 U-points
4 0.00 67.00 -0.50 60.50 U-points
5 0.00 67.00 -0.50 60.50 U-points
6 0.00 67.00 -0.50 60.50 U-points
7 0.00 67.00 -0.50 59.50 U-points
0 0.50 67.50 0.00 60.50 V-points
1 0.50 67.50 -0.50 60.50 V-points
2 0.50 67.50 -0.50 60.50 V-points
3 0.50 67.50 -0.50 60.50 V-points
4 0.50 67.50 -0.50 60.50 V-points
5 0.50 67.50 -0.50 60.50 V-points
6 0.50 67.50 -0.50 60.50 V-points
7 0.50 67.50 -0.50 59.00 V-points
Fennel Model Parameters, Grid: 01
1 BioIter Number of iterations for nonlinear convergence.
4.0000E-02 AttSW Light attenuation of seawater (m-1).
2.4860E-02 AttChl Light attenuation by chlorophyll (1/(mg_Chl m-2)).
4.3000E-01 PARfrac Fraction of shortwave radiation that is
photosynthetically active (nondimensional).
1.0000E+00 Vp0 Eppley temperature-limited growth parameter
(nondimensional).
9.5000E-03 I_thNH4 Radiation threshold for nitrification (W/m2).
1.0000E-01 D_p5NH4 Half-saturation radiation for nitrification (W/m2).
5.0000E-02 NitriR Nitrification rate (day-1).
2.0000E+00 K_NO3 Inverse half-saturation for phytoplankton NO3
uptake (1/(mmol_N m-3)).
2.0000E+00 K_NH4 Inverse half-saturation for phytoplankton NH4
2.0000E+00 K_Phy Zooplankton half-saturation constant for ingestion
(mmol_N m-3)^2.
5.3500E-02 Chl2C_m Maximum chlorophyll to carbon ratio (mg_Chl/mg_C).
1.0000E-03 ChlMin Chlorophyll minimum threshold (mg_Chl/m3).
6.6250E+00 PhyCN Phytoplankton Carbon:Nitrogen ratio (mol_C/mol_N).
1.5000E+00 PhyIP Phytoplankton NH4 inhibition parameter (1/mmol_N).
2.5000E-02 PhyIS Phytoplankton growth, initial slope of P-I curve
(mg_C/(mg_Chl Watts m-2 day)).
1.0000E-03 PhyMin Phytoplankton minimum threshold (mmol_N/m3).
1.5000E-01 PhyMR Phytoplankton mortality rate (day-1).
7.5000E-01 ZooAE_N Zooplankton nitrogen assimilation efficiency
(nondimensional).
1.0000E-01 ZooBM Rate for zooplankton basal metabolism (1/day).
6.6250E+00 ZooCN Zooplankton Carbon:Nitrogen ratio (mol_C/mol_N).
1.0000E-01 ZooER Zooplankton specific excretion rate (day-1).
6.0000E-01 ZooGR Zooplankton maximum growth rate (day-1).
1.0000E-03 ZooMin Zooplankton minimum threshold (mmol_N/m3).
2.5000E-02 ZooMR Zooplankton mortality rate (day-1).
1.0000E-02 LDeRRN Large detritus N re-mineralization rate (day-1).
1.0000E-02 LDeRRC Large detritus C re-mineralization rate (day-1).
5.0000E-03 CoagR Coagulation rate (day-1).
3.0000E-02 SDeRRN Remineralization rate for small detritus N (day-1).
3.0000E-02 SDeRRC Remineralization rate for small detritus C (day-1).
1.0000E-01 wPhy Phytoplankton sinking velocity (m/day).
1.0000E+00 wLDet Large detritus sinking velocity (m/day).
1.0000E-01 wSDet Small detritus sinking velocity (m/day).
1.0000E-06 Akt_bak(03) Background vertical mixing coefficient (m2/s)
for tracer 03: NO3
1.0000E-06 Akt_bak(04) Background vertical mixing coefficient (m2/s)
for tracer 04: NH4
1.0000E-06 Akt_bak(05) Background vertical mixing coefficient (m2/s)
for tracer 05: chlorophyll
1.0000E-06 Akt_bak(06) Background vertical mixing coefficient (m2/s)
for tracer 06: phytoplankton
1.0000E-06 Akt_bak(07) Background vertical mixing coefficient (m2/s)
for tracer 07: zooplankton
1.0000E-06 Akt_bak(08) Background vertical mixing coefficient (m2/s)
for tracer 08: LdetritusN
1.0000E-06 Akt_bak(09) Background vertical mixing coefficient (m2/s)
for tracer 09: SdetritusN
1.0000E-06 Akt_bak(10) Background vertical mixing coefficient (m2/s)
for tracer 10: LdetritusC
1.0000E-06 Akt_bak(11) Background vertical mixing coefficient (m2/s)
for tracer 11: SdetritusC
1.0000E-06 Akt_bak(12) Background vertical mixing coefficient (m2/s)
for tracer 12: TIC
1.0000E-06 Akt_bak(13) Background vertical mixing coefficient (m2/s)
for tracer 13: alkalinity
0.0000E+00 Tnudg(03) Nudging/relaxation time scale (days)
for tracer 03: NO3
0.0000E+00 Tnudg(04) Nudging/relaxation time scale (days)
for tracer 04: NH4
0.0000E+00 Tnudg(05) Nudging/relaxation time scale (days)
0.0000E+00 Tnudg(06) Nudging/relaxation time scale (days)
0.0000E+00 Tnudg(07) Nudging/relaxation time scale (days)
0.0000E+00 Tnudg(08) Nudging/relaxation time scale (days)
0.0000E+00 Tnudg(09) Nudging/relaxation time scale (days)
0.0000E+00 Tnudg(10) Nudging/relaxation time scale (days)
0.0000E+00 Tnudg(11) Nudging/relaxation time scale (days)
0.0000E+00 Tnudg(12) Nudging/relaxation time scale (days)
for tracer 12: TIC
0.0000E+00 Tnudg(13) Nudging/relaxation time scale (days)
T Hout(idTvar) Write out tracer 03: NO3
T Hout(idTvar) Write out tracer 04: NH4
T Hout(idTvar) Write out tracer 05: chlorophyll
T Hout(idTvar) Write out tracer 06: phytoplankton
T Hout(idTvar) Write out tracer 07: zooplankton
T Hout(idTvar) Write out tracer 08: LdetritusN
T Hout(idTvar) Write out tracer 09: SdetritusN
T Hout(idTvar) Write out tracer 10: LdetritusC
T Hout(idTvar) Write out tracer 11: SdetritusC
T Hout(idTvar) Write out tracer 12: TIC
T Hout(idTvar) Write out tracer 13: alkalinity
T Aout(idTvar) Write out averaged tracer 03: NO3
T Aout(idTvar) Write out averaged tracer 04: NH4
T Aout(idTvar) Write out averaged tracer 05: chlorophyll
T Aout(idTvar) Write out averaged tracer 06: phytoplankton
T Aout(idTvar) Write out averaged tracer 07: zooplankton
T Aout(idTvar) Write out averaged tracer 08: LdetritusN
T Aout(idTvar) Write out averaged tracer 09: SdetritusN
T Aout(idTvar) Write out averaged tracer 10: LdetritusC
T Aout(idTvar) Write out averaged tracer 11: SdetritusC
T Aout(idTvar) Write out averaged tracer 12: TIC
T Aout(idTvar) Write out averaged tracer 13: alkalinity
T Hout(iDbio3) Write out diagnostics for P_Production
T Hout(iDbio3) Write out diagnostics for NO3_uptake
SCS SCS, scs1/5
ANA_BIOLOGY Analytical biology initial conditions.
ANA_RAIN Analytical rain fall rate.
BIO_FENNEL Fennel et al. (2006) nitrogen-based model.
BIO_SEDIMENT Restore fallen particulate material to the nutrient pool.
BULK_FLUXES Surface bulk fluxes parametererization.
CARBON Add Carbon constituents.
DENITRIFICATION Add denitrification processes.
DIAGNOSTICS_BIO Computing and writing biological diagnostic terms.
EAST_FSCHAPMAN Eastern edge, free-surface, Chapman condition.
EAST_M2FLATHER Eastern edge, 2D momentum, Flather condition.
EAST_M3RADIATION Eastern edge, 3D momentum, radiation condition.
EAST_TRADIATION Eastern edge, tracers, radiation condition.
EMINUSP Compute Salt Flux using E-P.
LONGWAVE_OUT Compute outgoing longwave radiation internally.
M2CLIMATOLOGY Processing 2D momentum climatology data.
M3CLIMATOLOGY Processing 3D momentum climatology data.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTH_FSGRADIENT Northern edge, free-surface, gradient condition.
NORTH_M2RADIATION Northern edge, 2D momentum, radiation condition.
NORTH_M3RADIATION Northern edge, 3D momentum, radiation condition.
NORTH_TRADIATION Northern edge, tracers, radiation condition.
PERFECT_RESTART Processing perfect restart variables.
RAMP_TIDES Ramping tidal forcing for one day.
SOUTH_FSGRADIENT Southern edge, free-surface, gradient condition.
SOUTH_M2RADIATION Southern edge, 2D momentum, radiation condition.
SOUTH_M3RADIATION Southern edge, 3D momentum, radiation condition.
SOUTH_TRADIATION Southern edge, tracers, radiation condition.
SPONGE Enhanced horizontal mixing in the sponge areas.
!TALK_PROGNOSTIC Diagnostic computation of alkalinity.
TCLIMATOLOGY Processing tracer climatology data.
TS_A4HADVECTION Fourth-order Akima horizontal advection of tracers.
TS_A4VADVECTION Fourth-order Akima vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
WESTERN_WALL Wall boundary at Western edge.
ZCLIMATOLOGY Processing sea surface height climatology data.
Process Information:
Thread # 0 (pid= 24836) is active.
Vertical S-coordinate System:
20 0.0000000 0.0000000 0.000 0.000 0.000 0.000
19 -0.0500000 -0.0225247 -4.780 -0.500 -58.839 -112.898
18 -0.1000000 -0.0492281 -10.353 -1.000 -128.501 -246.648
17 -0.1500000 -0.0807689 -16.846 -1.500 -210.692 -404.537
16 -0.2000000 -0.1177273 -24.368 -2.000 -306.914 -589.459
15 -0.2500000 -0.1605159 -32.998 -2.500 -418.236 -803.474
14 -0.3000000 -0.2092762 -42.762 -3.000 -545.025 -1047.288
13 -0.3500000 -0.2637795 -53.618 -3.500 -686.689 -1319.759
12 -0.4000000 -0.3233593 -65.438 -4.000 -841.501 -1617.563
11 -0.4500000 -0.3869075 -78.012 -4.500 -1006.590 -1935.169
10 -0.5000000 -0.4529542 -91.061 -5.000 -1178.151 -2265.242
9 -0.5500000 -0.5198294 -104.268 -5.500 -1351.858 -2599.449
8 -0.6000000 -0.5858761 -117.316 -6.000 -1523.419 -2929.522
7 -0.6500000 -0.6496633 -129.936 -6.500 -1689.128 -3248.320
6 -0.7000000 -0.7101489 -141.928 -7.000 -1846.286 -3550.643
5 -0.7500000 -0.7667600 -153.184 -7.500 -1993.408 -3833.632
4 -0.8000000 -0.8193905 -163.684 -8.000 -2130.222 -4096.759
3 -0.8500000 -0.8683362 -173.484 -8.500 -2257.491 -4341.498
2 -0.9000000 -0.9141971 -182.697 -9.000 -2376.771 -4570.844
1 -0.9500000 -0.9577775 -191.478 -9.500 -2490.144 -4788.810
0 -1.0000000 -1.0000000 -200.000 -10.000 -2600.000 -5000.000
Time Splitting Weights: ndtfast = 20 nfast = 29
3-0.0011514592651645 0.0501156998674241-0.0034654566136460 0.1501639558342179
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649002
5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792858
6 0.0029141799764308 0.0501428056118168 0.0000580677400948 0.3006719858911026
7 0.0054132615310267 0.0499970966129952 0.0054713292711215 0.3506690825040978
8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405417
9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876600
10 0.0161716623600090 0.0486998273761630 0.0421751148367486 0.4983983377638230
11 0.0207585511322367 0.0478912442581626 0.0629336659689853 0.5462895820219856
12 0.0257765478740990 0.0468533167015507 0.0887102138430843 0.5931428987235363
13 0.0311633730493853 0.0455644893078458 0.1198735868924696 0.6387073880313821
14 0.0368391158442262 0.0440063206553765 0.1567127027366958 0.6827137086867585
15 0.0427031802506397 0.0421643648631652 0.1994158829873354 0.7248780735499237
16 0.0486309868367616 0.0400292058506332 0.2480468698240970 0.7649072794005569
17 0.0544704302037591 0.0375976565087951 0.3025173000278562 0.8025049359093520
18 0.0600380921294285 0.0348741349986072 0.3625553921572847 0.8373790709079592
19 0.0651152103984763 0.0318722303921358 0.4276706025557610 0.8692513013000949
20 0.0694434033194839 0.0286164698722119 0.4971140058752449 0.8978677711723068
21 0.0727201499285569 0.0251442997062377 0.5698341558038018 0.9230120708785445
22 0.0745940258796570 0.0215082922098099 0.6444281816834588 0.9445203630883544
23 0.0746596950216180 0.0177785909158270 0.7190878767050768 0.9622989540041814
24 0.0724526566618460 0.0140456061647461 0.7915405333669228 0.9763445601689276
25 0.0674437485167025 0.0104229733316538 0.8589842818836253 0.9867675335005814
26 0.0590334053485720 0.0070507859058187 0.9180176872321973 0.9938183194064002
27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447904
28 0.0292219798521905 0.0017718319739095 0.9937853403740005 0.9996892670186999
29 0.0062146596259994 0.0003107329813000 0.9999999999999999 0.9999999999999999
Minimum X-grid spacing, DXmin = 4.89227532E+01 km
Maximum X-grid spacing, DXmax = 5.55664205E+01 km
Minimum Y-grid spacing, DYmin = 4.92244448E+01 km
Maximum Y-grid spacing, DYmax = 5.55653626E+01 km
Minimum Z-grid spacing, DZmin = 4.77969624E+00 m
Maximum Z-grid spacing, DZmax = 3.34207169E+02 m
Minimum barotropic Courant Number = 6.76406017E-02
Maximum barotropic Courant Number = 3.67413174E-01
Maximum Coriolis Courant Number = 8.27567575E-02
NLM: GET_STATE - Read state initial conditions, t = 31 00:00:00
(File: roms_ini_ECCO_Y2010M2.nc, Rec=0001, Index=1)
- free-surface
(Min = 2.40833945E-01 Max = 9.12962079E-01)
(Min = -5.48634745E-01 Max = 3.04510668E-01)
(Min = -7.64609595E-01 Max = 1.87634051E-01)
- u-momentum component
(Min = -1.25016059E+00 Max = 6.91072106E-01)
- v-momentum component
(Min = -1.42649664E+00 Max = 3.71314483E-01)
- potential temperature
(Min = 1.21492100E+00 Max = 2.98439578E+01)
- salinity
(Min = 3.02197781E+01 Max = 3.56948882E+01)
GET_NGFLD - tidal period
(Min = 4.30819210E+04 Max = 2.38071599E+06)
(Min = 1.14676386E-04 Max = 1.84815601E+01)
(Min = 5.29610642E-05 Max = 6.28166889E+00)
(Min = 8.00838154E-05 Max = 6.28310852E+00)
(Min = 8.43458278E-05 Max = 6.28311432E+00)
(Min = 3.42173542E-06 Max = 2.59553102E+00)
(Min = -2.10984642E-01 Max = 3.62902895E-01)
NETCDF_GET_FVAR_2D - error while reading variable: lat
in input file: roms_frc_NCEP2_Y2010M2.nc
call from: get_varcoords.F
GET_2DFLD - error while reading variable: Uwind at TIME index = 192
Thread # 0 CPU: 0.595
Total: 0.595
Allocation and array initialization .............. 0.429 (72.1008 %)
Reading of input data ............................ 0.030 ( 5.0419 %)
2D/3D coupling, vertical metrics ................. 0.016 ( 2.6892 %)
Omega vertical velocity .......................... 0.007 ( 1.1763 %)
Equation of state for seawater ................... 0.047 ( 7.8994 %)
Total: 0.529 88.9075
All percentages are with respect to total time = 0.595
Analytical header files used:
ROMS/Functionals/ana_biology.h
ROMS/Functionals/ana_hmixcoef.h
REASON: NetCDF: Start+count exceeds dimension bound
Then what's the problem?? Thanks for any help.
