I want to know if it is possible to generate momentum in a particular point of my mesh without having a source, that is to say without adding mass. Because with UV_PSOURCE, I add for instance 1m3/s, whereas I want to conserve my initial volume of my basin.
Hi kate
Its a feasible way that you said,but in my mind it suitable in the situation with incoming flow on one side and outgoing flow on the other side.Like the ECS Black-Tide or the Gulf-Stream.I dont know how to keep the net volume of a modeling domain and at the same time apply the incoming and outgoing source points on a closed basin or domain.Im doubt.
Finally, it works. The problem did'nt come from the UV_PSOURCE, but I think it came from my grid which had problems with its mask. And Tony, I can generate momentum by keeping en constant net volume with UV_PSOURCE.
