what's wrong with Roms3.2?
hi, everyone:
The following is the output information:
Process Information:
Thread # 0 (pid= 13726) is active.
Model Input Parameters: ROMS/TOMS version 3.2
Wednesday - September 28, 2011 - 9:56:04 AM
SCS, 1/6 degree resolution
Operating system : Linux
CPU/hardware : i686
Compiler system : ifort
Compiler command : /opt/intel/Compiler/11.1/073/bin/ia32/ifort
Compiler flags : -heap-arrays -fp-model precise -g -check uninit -ftrapuv -traceback -free
SVN Root URL :
SVN Revision :
Local Root : /home/xie/roms-3.3
Header Dir : /home/xie/roms3_3_project/scs
Header file : scs.h
Analytical Dir: /home/xie/roms3_3_project/scs
Resolution, Grid 01: 0155x0137x028, Parallel Threads: 1, Tiling: 001x001
2976 ntimes Number of timesteps for 3-D equations.
900.000 dt Timestep size (s) for 3-D equations.
60 ndtfast Number of timesteps for 2-D equations between
2976 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
180 nHIS Number of timesteps between the writing fields
into history file.
2976 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
144 nAVG Number of timesteps between the writing of
5.0000E+00 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
5.0000E+00 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
0.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
5.0000E-03 Zob Bottom roughness (m).
2.5000E+00 theta_s S-coordinate surface control parameter.
8.0000E-01 theta_b S-coordinate bottom control parameter.
10.000 Tcline S-coordinate surface/bottom layer width (m) used
12538.000 dstart Time-stamp assigned to model initialization (days).
12538.000 tide_start Reference time origin for tidal forcing (days).
-2.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
T Hout(idVbms) Write out bottom V-momentum stress.
T Hout(idTsur) Write out surface net heat flux.
T Hout(idTsur) Write out surface net salt flux.
T Hout(idVvis) Write out vertical viscosity coefficient.
Output Restart File: roms_rst.nc
Prefix for History Files: roms_his
Output Averages File: roms_avg.nc
Input Grid File: roms_grd.nc
Input Nonlinear Initial File: roms_ini.nc
Input Forcing File 01: roms_frc.nc
Input Climatology File: roms_clm.nc
Tile partition information for Grid 01: 0155x0137x0028 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 155 1 137 594580
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -0.50 156.50 -0.50 138.50 RHO-points
0 -0.50 156.50 -0.50 138.50 U-points
0 -0.50 156.50 -0.50 138.50 V-points
AVERAGES Writing out time-averaged fields.
EAST_FSCHAPMAN Eastern edge, free-surface, Chapman condition.
EAST_M2FLATHER Eastern edge, 2D momentum, Flather condition.
EAST_M3RADIATION Eastern edge, 3D momentum, radiation condition.
EAST_TRADIATION Eastern edge, tracers, radiation condition.
M2CLIMATOLOGY Processing 2D momentum climatology data.
M3CLIMATOLOGY Processing 3D momentum climatology data.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTH_FSGRADIENT Northern edge, free-surface, gradient condition.
NORTH_M2RADIATION Northern edge, 2D momentum, radiation condition.
NORTH_M3RADIATION Northern edge, 3D momentum, radiation condition.
NORTH_TRADIATION Northern edge, tracers, radiation condition.
RAMP_TIDES Ramping tidal forcing for one day.
SALINITY Using salinity.
SOUTH_FSGRADIENT Southern edge, free-surface, gradient condition.
SOUTH_M2RADIATION Southern edge, 2D momentum, radiation condition.
SOUTH_M3RADIATION Southern edge, 3D momentum, radiation condition.
SOUTH_TRADIATION Southern edge, tracers, radiation condition.
SPONGE Enhanced horizontal mixing in the sponge areas.
TCLIMATOLOGY Processing tracer climatology data.
TS_A4HADVECTION Fourth-order Akima horizontal advection of tracers.
TS_A4VADVECTION Fourth-order Akima vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
WESTERN_WALL Wall boundary at Western edge.
ZCLIMATOLOGY Processing sea surface height climatology data.
Vertical S-coordinate System:
28 0.0000000 0.0000000 0.000 0.000 0.000
27 -0.0357143 -0.0156922 -1.769 -40.215 -78.661
26 -0.0714286 -0.0334181 -3.722 -85.596 -167.470
25 -0.1071429 -0.0534230 -5.880 -136.766 -267.652
24 -0.1428571 -0.0759436 -8.263 -194.325 -380.387
23 -0.1785714 -0.1011932 -10.893 -258.816 -506.740
22 -0.2142857 -0.1293455 -13.784 -330.680 -647.577
21 -0.2500000 -0.1605159 -16.946 -410.210 -803.474
20 -0.2857143 -0.1947408 -20.384 -497.499 -974.614
19 -0.3214286 -0.2319599 -24.091 -592.393 -1160.694
18 -0.3571429 -0.2720013 -28.052 -694.455 -1360.858
17 -0.3928571 -0.3145746 -32.240 -802.948 -1573.656
16 -0.4285714 -0.3592742 -36.620 -916.842 -1797.064
15 -0.4642857 -0.4055940 -41.146 -1034.852 -2028.557
14 -0.5000000 -0.4529542 -45.766 -1155.504 -2265.242
13 -0.5357143 -0.5007368 -50.423 -1277.229 -2504.034
12 -0.5714286 -0.5483273 -55.064 -1398.466 -2741.868
11 -0.6071429 -0.5951560 -59.635 -1517.768 -2975.900
10 -0.6428571 -0.6407336 -64.095 -1633.892 -3203.689
9 -0.6785714 -0.6846786 -68.407 -1745.869 -3423.332
8 -0.7142857 -0.7267318 -72.549 -1853.042 -3633.535
7 -0.7500000 -0.7667600 -76.508 -1955.070 -3833.632
6 -0.7857143 -0.8047488 -80.285 -2051.919 -4023.553
5 -0.8214286 -0.8407893 -83.885 -2143.819 -4203.753
4 -0.8571429 -0.8750596 -87.327 -2231.223 -4375.119
3 -0.8928571 -0.9078056 -90.631 -2314.755 -4538.878
2 -0.9285714 -0.9393221 -93.825 -2395.164 -4696.503
1 -0.9642857 -0.9699374 -96.937 -2473.284 -4849.631
0 -1.0000000 -1.0000000 -100.000 -2550.000 -5000.000
Time Splitting Weights: ndtfast = 60 nfast = 83
1-0.0003540175431531 0.0166666666666667-0.0003540175431531 0.0166666666666667
2-0.0006728864853186 0.0166725669590526-0.0010269040284716 0.0333392336257192
3-0.0009566069754562 0.0166837817338079-0.0019835110039279 0.0500230153595271
4-0.0012051795928536 0.0166997251833988-0.0031886905967814 0.0667227405429259
5-0.0014186058436584 0.0167198115099464-0.0046072964404399 0.0834425520528722
6-0.0015968888560238 0.0167434549406740-0.0062041852964637 0.1001860069935462
7-0.0017400342738662 0.0167700697549411-0.0079442195703299 0.1169560767484873
8-0.0018480513492362 0.0167990703261722-0.0097922709195661 0.1337551470746595
9-0.0019209542333024 0.0168298711819928-0.0117132251528686 0.1505850182566522
10-0.0019587634659484 0.0168618870858811-0.0136719886188169 0.1674469053425334
11-0.0019615076639817 0.0168945331436469-0.0156334962827987 0.1843414384861803
12-0.0019292254079571 0.0169272249380466-0.0175627216907558 0.2012686634242269
13-0.0018619673276114 0.0169593786948459-0.0194246890183672 0.2182280421190729
14-0.0017597983859117 0.0169904114836395-0.0211844874042789 0.2352184536027123
15-0.0016228003617172 0.0170197414567380-0.0228072877659961 0.2522381950594503
16-0.0014510745310524 0.0170467881294333-0.0242583622970485 0.2692849831888836
17-0.0012447445469948 0.0170709727049508-0.0255031068440433 0.2863559558938343
18-0.0010039595181742 0.0170917184474007-0.0265070663622175 0.3034476743412350
19-0.0007288972858858 0.0171084511060370-0.0272359636481033 0.3205561254472720
20-0.0004197678998158 0.0171205993941351-0.0276557315479191 0.3376767248414071
21-0.0000768172923796 0.0171275955257987-0.0277325488402987 0.3548043203672058
22 0.0002996688483262 0.0171288758140050-0.0274328799919725 0.3719331961812107
23 0.0007093610069602 0.0171238813331995-0.0267235189850123 0.3890570775144103
24 0.0011518815707581 0.0171120586497502-0.0255716374142542 0.4061691361641604
25 0.0016268003607435 0.0170928606235709-0.0239448370535106 0.4232619967877314
26 0.0021336299643244 0.0170657472842252-0.0218112070891863 0.4403277440719565
27 0.0026718208692771 0.0170301867848198-0.0191393862199091 0.4573579308567763
28 0.0032407563991181 0.0169856564369985-0.0158986298207911 0.4743435872937748
29 0.0038397474498617 0.0169316438303465-0.0120588823709294 0.4912752311241213
30 0.0044680270281659 0.0168676480395155-0.0075908553427635 0.5081428791636368
31 0.0051247445908649 0.0167931809223794-0.0024661107518986 0.5249360600860161
32 0.0058089601858883 0.0167077685125316 0.0033428494339897 0.5416438285985478
33 0.0065196383945684 0.0166109525094335 0.0098624878285581 0.5582547811079812
34 0.0072556420753336 0.0165022918695240 0.0171181299038917 0.5747570729775052
35 0.0080157259087899 0.0163813645016018 0.0251338558126816 0.5911384374791070
36 0.0087985297441882 0.0162477690697886 0.0339323855568698 0.6073862065488956
37 0.0096025717472802 0.0161011269073855 0.0435349573041500 0.6234873334562812
38 0.0104262413495604 0.0159410840449308 0.0539611986537104 0.6394284175012119
39 0.0112677919988951 0.0157673133557715 0.0652289906526054 0.6551957308569835
40 0.0121253337115396 0.0155795168224566 0.0773543243641450 0.6707752476794401
41 0.0129968254255413 0.0153774279272642 0.0903511497896863 0.6861526756067043
42 0.0138800671555305 0.0151608141701719 0.1042312169452169 0.7013134897768762
43 0.0147726919488984 0.0149294797175797 0.1190039088941153 0.7162429694944560
44 0.0156721576433617 0.0146832681850981 0.1346760665374769 0.7309262376795540
45 0.0165757384259147 0.0144220655577087 0.1512518049633916 0.7453483032372628
46 0.0174805161931688 0.0141458032506101 0.1687323211565604 0.7594941064878729
47 0.0183833717130782 0.0138544613140573 0.1871156928696386 0.7733485678019302
48 0.0192809755880535 0.0135480717855060 0.2063966684576921 0.7868966395874362
49 0.0201697790194623 0.0132267221923718 0.2265664474771545 0.8001233617798079
50 0.0210460043735164 0.0128905592087141 0.2476124518506709 0.8130139209885220
51 0.0219056355485466 0.0125397924691555 0.2695180873992175 0.8255537134576775
52 0.0227444081436646 0.0121746985433464 0.2922624955428820 0.8377284120010239
53 0.0235577994288118 0.0117956250742853 0.3158202949716938 0.8495240370753092
54 0.0243410181161952 0.0114029950838051 0.3401613130878890 0.8609270321591143
55 0.0250889939331104 0.0109973114485352 0.3652503070209994 0.8719243436076495
56 0.0257963669961522 0.0105791615496500 0.3910466740171517 0.8825035051572995
57 0.0264574769868114 0.0101492220997141 0.4175041510039630 0.8926527272570136
58 0.0270663521284594 0.0097082641499339 0.4445705031324225 0.9023609914069476
59 0.0276166979647200 0.0092571582811263 0.4721872010971425 0.9116181496880739
60 0.0281018859392274 0.0087968799817143 0.5002890870363698 0.9204150296697882
61 0.0285149417767724 0.0083285152160605 0.5288040288131421 0.9287435448858486
62 0.0288485336658351 0.0078532661864476 0.5576525624789772 0.9365968110722963
63 0.0290949602425050 0.0073724572920170 0.5867475227214822 0.9439692683643134
64 0.0292461383757876 0.0068875412879753 0.6159936610972698 0.9508568096522887
65 0.0292935907542990 0.0064001056483788 0.6452872518515688 0.9572569153006675
66 0.0292284332743468 0.0059118791358072 0.6745156851259155 0.9631687944364746
67 0.0290413622293988 0.0054247385812347 0.7035570473553143 0.9685935330177093
68 0.0287226413009382 0.0049407158774114 0.7322796886562525 0.9735342488951207
69 0.0282620883507063 0.0044620051890625 0.7605417770069588 0.9779962540841832
70 0.0276490620143322 0.0039909703832173 0.7881908390212909 0.9819872244674006
71 0.0268724480963495 0.0035301526829785 0.8150632871176404 0.9855173771503791
72 0.0259206457666001 0.0030822785480393 0.8409839328842404 0.9885996556984185
73 0.0247815535580255 0.0026502677852627 0.8657654864422659 0.9912499234836811
74 0.0234425551658447 0.0022372418926289 0.8892080416081106 0.9934871653763100
75 0.0218905050481194 0.0018465326398648 0.9110985466562300 0.9953336980161748
76 0.0201117138277064 0.0014816908890628 0.9312102604839364 0.9968153889052376
77 0.0180919334955968 0.0011464956586011 0.9493021939795332 0.9979618845638386
78 0.0158163424156430 0.0008449634336744 0.9651185363951762 0.9988068479975131
79 0.0132695301306719 0.0005813577267471 0.9783880665258481 0.9993882057242601
80 0.0104354819699857 0.0003601988912359 0.9888235484958338 0.9997484046154960
81 0.0072975634582500 0.0001862741917361 0.9961211119540838 0.9999346788072321
82 0.0038385045257686 0.0000646481340986 0.9999596164798524 0.9999993269413306
83 0.0000403835201471 0.0000006730586691 0.9999999999999994 0.9999999999999998
ndtfast, nfast = 60 83 nfast/ndtfast = 1.38333
1.000000000000 1.029032332991 0.514516166496 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.23667
Minimum X-grid spacing, DXmin = 1.66385662E+01 km
Maximum X-grid spacing, DXmax = 1.84770211E+01 km
Minimum Y-grid spacing, DYmin = 1.66703769E+01 km
Maximum Y-grid spacing, DYmax = 1.84751077E+01 km
Minimum Z-grid spacing, DZmin = 1.76944522E+00 m
Maximum Z-grid spacing, DZmax = 2.38792282E+02 m
Minimum barotropic Courant Number = 3.59609615E-02
Maximum barotropic Courant Number = 2.78404323E-01
Maximum Coriolis Courant Number = 5.75131924E-02
(File: roms_ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 1.03284264E+00 Max = 2.87353796E+01)
- salinity
(Min = 3.13632231E+01 Max = 3.50847621E+01)
GET_NGFLD - tidal period
(Min = 4.30819210E+04 Max = 2.38071599E+06)
(Min = 6.42401830E-05 Max = 1.93443811E+01)
(Min = 8.20617395E-06 Max = 6.28275310E+00)
(Min = 4.00291105E-06 Max = 6.28318364E+00)
(Min = 6.88083697E-06 Max = 6.28317974E+00)
(Min = 2.20110333E-06 Max = 2.21910980E+00)
(Min = -4.86747945E-01 Max = 3.78358049E-01)
GET_2DFLD - surface u-momentum stress, t = 345 00:00:00
(Rec=0012, Index=1, File: roms_frc.nc)
(Min = -1.69066110E-04 Max = 2.88435117E-06)
GET_2DFLD - surface v-momentum stress, t = 345 00:00:00
(Min = -2.31120433E-04 Max = -7.53048503E-06)
GET_2DFLD - surface net heat flux, t = 345 00:00:00
(Min = -8.74117223E-05 Max = 9.91936039E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 345 00:00:00
(Min = -9.18419336E-08 Max = 9.79046117E-08)
GET_2DFLD - sea surface height climatology, t = 345 00:00:00
(Rec=0012, Index=1, File: roms_clm.nc)
(Min = -3.36335665E-01 Max = 5.20850485E-01)
GET_2DFLD - vertically integrated u-momentum climatologt = 345 00:00:00
(Min = -5.68134895E+00 Max = 2.74522526E+00)
GET_2DFLD - vertically integrated v-momentum climatologt = 345 00:00:00
(Min = -3.54390195E+00 Max = 7.90076624E+00)
GET_3DFLD - potential temperature climatology, t = 345 00:00:00
(Min = 1.03284264E+00 Max = 2.92403694E+01)
Image PC Routine Line Source
oceanG 081A3E4D get_cycle_ 169 get_cycle.f90
oceanG 0819F1FE get_3dfld_ 207 get_3dfld.f90
oceanG 08138F1E get_data_ 125 get_data.f90
oceanG 0804C287 initial_ 218 initial.f90
oceanG 0804A662 ocean_control_mod 94 ocean_control.f90
oceanG 0804A370 MAIN__ 75 master.f90
oceanG 0804A2E1 Unknown Unknown Unknown
libc.so.6 009AAE9C Unknown Unknown Unknown
oceanG 0804A1D1 Unknown Unknown Unknown
I donot know what cause the problem and how to solve.
Thanks any help!
CPU/hardware : i686
SVN Root URL :
SVN Revision :
Header file : scs.h
to standard output.
into history file.
history files.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
- free-surface
- salinity
Thanks any help!
Re: what's wrong with Roms3.2?
It has given you the stack trace and even the line numbers (I think). Which field is get_data.f90 reading on line 125? What does it read after potential temperature climatology? Salt climatology perhaps? It's having trouble in get_cycle, which has to do with the time axis for said variable.rainbowbluegz wrote: GET_3DFLD - potential temperature climatology, t = 345 00:00:00
Thanks any help!
Have you considered trying again with a newer ROMS? Some of the I/O has changed since 3.2 so the bugs have changed too. In any case, a seg fault could be an array out of bounds, so I would recompile with bounds checking - just temporarily for figuring this out.
Hi to everyone,
I've got "similar" problem.My ROMS version is 3.6. Kate you suggest to recompile with bounds checking. How can i do that?
Thanks for any help and for your time.
log.txt
- (20.5 KiB) Downloaded 762 times
It will depend on your compiler so you should ideally check its man pages. Mine says:
It can give you info such as this:Debugging Options
-C Add array bounds checking; the same as -Mbounds.
0: Subscript out of range for array a (tri_exchange_2d.f90: 501)
subscript=42, lower bound=78, upper bound=123, dimension=1
subscript=42, lower bound=118, upper bound=164, dimension=1
Thanks for your advise Kate. My compiler is gfortran 4.4.3 and i used -fbounds-check flag.
The result for my current cpp definitions file (myapp.h) is:
If i undefine the ANA_BSFLUX, ANA_BTFLUX, ANA_SMFLUX and ANA_STFLUX
because i don't use an external forcing file i get again runtime error for frc array:
Any suggestion/help would be appreciated. Thanks again for your time and your help.
Yiannis
At line 74 of file get_data.f90
Fortran runtime error: Array reference out of bounds for array 'frc', upper bound of dimension 1 exceeded (1 > 0)
At line 2156 of file read_phypar.f90
Yiannis
So this is with ANA_BSFLUX and friends? What is it trying to read on line 74 of get_data.f90?ymamoutos wrote:Code: Select all
At line 74 of file get_data.f90 Fortran runtime error: Array reference out of bounds for array 'frc', upper bound of dimension 1 exceeded (1 > 0)
You want these all #defined, I believe. You need to provide a bottom salinity flux one way or another - most of us analytically set it to zero. Same for the rest, unless we're explicitly providing the surface fluxes.If i undefine the ANA_BSFLUX, ANA_BTFLUX, ANA_SMFLUX and ANA_STFLUX
Kate hi,
on line 74 get_data.f90 calls subroutine get_2dfld for surface wind stress components.
Thanks again for your patience and help.
So if am not providing an external file i have to modify ana_btflux.h and the other files if am understanding correct.You need to provide a bottom salinity flux one way or another - most of us analytically set it to zero.
Yes, you have to set ANA_SMFLUX to tell it not to read surface momentum flux from a file. For these common ones, you can probably just leave it be the default of zero. If you aren't sure, you can read the analytical.f90 file to see what got picked up during the C preprocessor phase.
Hi Kate and greetings from Greece,
My problem is solved.I modified the ana_*.h files
that i wanted for my test case following your suggestion
(i set the variables that i needed equal to zero) and
my model configuration is running smoothly until now.
Thanks again for your help and have a pleasant evening.
Yiannis
Yiannis
