Problems on converting *.mat file to *.nc file
jerry19890126
#1 Unread post by jerry19890126 »
I've just encountered a problem on converting *.mat file to *.nc file.
The *.mat(say,seagrid.mat) file was created by seagrid.
So I used the command:
seagrid2roms('seagrid.mat',grdfile);
However,the converting process went wrong.Here are the error message:
## SeaGrid Source File : ~/tools/test-data/seagrid.mat
## ROMS Destination File: ../test-data/test-grid.nc
Error in ==> mexnc at 1
function [varargout] = mexnc ( varargin )
??? Error using ==> feval
Output argument "varargout" (and maybe others) not assigned during call to
"/home/jerry/tools/Roms_tools_3/mexnc/mexnc.m>mexnc".
Error in ==> mexcdf53 at 9
[varargout{:}] = feval('mexnc', varargin{:});
Error in ==> ncmex at 139
[varargout{:}] = feval(fcn, varargin{:});
Error in ==> netcdf.create at 13
[theNCid, status] = ncmex('create', name(self), thePermission);
Error in ==> netcdf.netcdf at 413
result = create(result, thePermission);
Error in ==> seagrid2roms at 152
nc = netcdf(theRomsFile, 'clobber');
Someone help me!
Thank you!
justina0622
Re: Problems on converting *.mat file to *.nc file
#2 Unread post by justina0622 »
Have you installed the tools for netcdf successfully? For my MATLAB (R2011a), the tools needed are mexcdf (mexnc and snctools) and netcdf_toolbox.
Hope this can help you.
Qian
Qianqian@URI
Gabriel_Carvalho
#3 Unread post by Gabriel_Carvalho »
try to use the script "seagrid2roms_new.m", instead of the "seagrid2roms.m" that you are using.
When I downloaded the seagrid, this script came together and is more compatible with my netcdf matlab packages.
good luck,
Gabriel Carvalho
Oceanographer - Rio de Janeiro
P.S: In case you don't have it:
function seagrid2roms_ML(theSeagridFile, theRomsFile,...
theGridTitle,theInterpMethod,FLIPPING)
% seagrid2roms -- Output ROMS format from SeaGrid file.
% Usage: seagrid2roms(theSeagridFile, theRomsFile,...
% theGridTitle, theInterpMethod);
% Inputs:
% theSeagridFile = name of seagrid output file (string)
% theRomsFile = name of Roms Grid file to be created (string)
% theGridTitle = title of grid (string)
% theInterpMethod = interp2d method used to double grid (string)
% Can be "linear" or "spline" (default is spline)
% Use "linear" for seagrid.mat files originating
% from Delft grids, which have info only on
% the wet cells.
% FLIPPING = should be 1 (default) for files produced by seagrid
% or 0 for files converted from Delft3D grids
% If '*' is input for theSeagridFile or theRomsFile, dialog boxes are
% invoked.
% NOTE: this routine does not employ _FillValue attributes
% in the output NetCDF variables.
% Disclosure without explicit written consent from the
% copyright owner does not constitute publication.
% Version of 18-Jun-1999 17:11:59. by Chuck Denham
% Updated 28-Oct-2002 10:12:55.
% Updated 14-Apr-2004 10:12:55. by Rich Signell
% - grid doubling now only in projected coordinate
% - distances between grid points now calculated from lon/lat values on spherical earth
% The default earth radius is
% assumed to be 6371*1000 meters, the radius for
% a sphere of equal-volume, the same default as "earthdist.m".
RADIAN_CONVERSION_FACTOR = 180/pi;
EARTH_RADIUS_METERS = 6371*1000; % Equatorial radius.
if nargin < 1, theSeagridFile = '*.mat'; end
if nargin < 2, theRomsFile = 'roms_grd.nc'; end
if nargin < 3, theGridTitle = char(zeros(1, 128)+abs(' ')); end
if isempty(theSeagridFile) | any(theSeagridFile == '*')
[f, p] = uigetfile(theSeagridFile, 'Select SeaGrid File:');
if ~any(f), return, end
if p(end) ~= filesep, p(end+1) = filesep; end
theSeagridFile = [p f]
end
if nargin < 2 | isempty(theSeagridFile) | any(theRomsFile == '*')
[f, p] = uiputfile(theRomsFile, 'Save to Roms File:');
theRomsFile = [p f]
end
disp([' ## SeaGrid Source File : ' theSeagridFile])
disp([' ## ROMS Destination File: ' theRomsFile])
% Load the SeaGrid file and get parameters.
try
theSeagridData = load(theSeagridFile, 's');
catch
disp([' ## Unable to load: "' theSeagridFile '"'])
return
end
% With grid_x of size [m, n], the grid itself has
% [m-1, n-1] cells. The latter size corresponds
% to the size of the mask and bathymetry. These
% cell-centers are called the "rho" points.
s = theSeagridData.s;
grid_x = s.grids{1} * EARTH_RADIUS_METERS;
grid_y = s.grids{2} * EARTH_RADIUS_METERS;
[m, n] = size(grid_x);
geogrid_lon = s.geographic_grids{1};
geogrid_lat = s.geographic_grids{2};
geometry = s.geometry;
mask = s.mask; % land = 1; water = 0.
if ~isequal(size(mask), size(grid_x)-1)
if ~isempty(mask)
disp(' ## Wrong size mask.')
end
mask = zeros(m-1, n-1);
end
mask = ~~mask;
land = mask;
water = ~land;
bathymetry = s.gridded_bathymetry;
projection = s.projection;
ang = s.orientation * pi / 180; % ROMS needs radians.
min_depth = s.clipping_depths(1);
max_depth = s.clipping_depths(2);
% Clip Bathymetry
bathymetry(find(isnan(bathymetry))) = min_depth;
bathymetry(bathymetry<min_depth) = min_depth;
bathymetry(bathymetry>max_depth) = max_depth;
% Double the grid-size before proceeding.
% The grid-cell-centers are termed the "rho" points.
theInterpFcn = 'interp2';
if nargin<4,
theInterpMethod = 'spline';
%theInterpMethod = 'linear';
end
grid_x = feval(theInterpFcn, grid_x, 1, theInterpMethod);
grid_y = feval(theInterpFcn, grid_y, 1, theInterpMethod);
geogrid_lon = feval(theInterpFcn, geogrid_lon, 1, theInterpMethod);
geogrid_lat = feval(theInterpFcn, geogrid_lat, 1, theInterpMethod);
% The present size of the grid nodes.
[n, m] = size(grid_x);
% Flip arrays top for bottom.
if (nargin<5)
FLIPPING = 1; % for files from Seagrid
%FLIPPING = 0; % for files from Delft3D conversion
end
if FLIPPING
grid_x = flipud(grid_x);
grid_y = flipud(grid_y);
geogrid_lon = flipud(geogrid_lon);
geogrid_lat = flipud(geogrid_lat);
geometry{1} = flipud(geometry{1});
geometry{2} = flipud(geometry{2});
mask = flipud(mask);
bathymetry = flipud(bathymetry);
ang = flipud(ang);
end
xl = max(grid_x(:)) - min(grid_x(:));
el = max(grid_y(:)) - min(grid_y(:));
% Create the Roms NetCDF file.
% nc = netcdf(theRomsFile, 'clobber');
ncid = netcdf.create(theRomsFile,'NC_CLOBBER');
if isempty(ncid), return, end
%% Global attributes:
disp(' ## Defining Global Attributes...')
% nc.type = ncchar('Gridpak file');
% nc.gridid = theGridTitle;
% nc.history = ncchar(['Created by "' mfilename '" on ' datestr(now)]);
% nc.CPP_options = ncchar('DCOMPLEX, DBLEPREC, NCARG_32, PLOTS,');
% name(nc.CPP_options, 'CPP-options')
% The SeaGrid is now a full array, whose height
% and width are odd-valued. We extract staggered
% sub-grids for the Roms scheme, ignoring the
% outermost rows and columns. Thus, the so-called
% "rho" points correspond to the even-numbered points
% in an (i, j) Matlab array. The "psi" points begin
% at i = 3 and j = 3. The whole set is indexed as
% follows:
% rho (2:2:end-1, 2:2:end-1), i.e. (2:2:m, 2:2:n), etc.
% psi (3:2:end-2, 3:2:end-2)
% u (2:2:end-1, 3:2:end-2)
% v (3:2:end-2, 2:2:end-1)
if ~rem(m, 2), m = m-1; end % m, n must be odd.
if ~rem(n, 2), n = n-1; end
i_rho = 2:2:m-1; j_rho = 2:2:n-1;
i_psi = 3:2:m-2; j_psi = 3:2:n-2;
i_u = 3:2:m-2; j_u = 2:2:n-1;
i_v = 2:2:m-1; j_v = 3:2:n-2;
% The xi direction (left-right):
Lp = (m-1)/2; % The rho dimension.
L = Lp-1; % The psi dimension.
% The eta direction (up-down):
Mp = (n-1)/2; % The rho dimension.
M = Mp-1; % The psi dimension.
disp(' ## Defining Dimensions...')
xi_rho_ID = netcdf.defDim(ncid,'xi_rho',Lp);
xi_u_ID = netcdf.defDim(ncid,'xi_u',L);
xi_psi_ID = netcdf.defDim(ncid,'xi_psi',L);
xi_v_ID = netcdf.defDim(ncid,'xi_v',Lp);
eta_rho_ID = netcdf.defDim(ncid,'eta_rho',Mp);
eta_u_ID = netcdf.defDim(ncid,'eta_u',Mp);
eta_v_ID = netcdf.defDim(ncid,'eta_v',M);
eta_psi_ID = netcdf.defDim(ncid,'eta_psi',M);
one_ID = netcdf.defDim(ncid,'one',1);
two_ID = netcdf.defDim(ncid,'two',2);
bath_ID = netcdf.defDim(ncid,'bath',netcdf.getConstant('NC_UNLIMITED'));
% bath_ID = netcdf.defDim(ncid,'bath',0);
%% Variables and attributes:
disp(' ## Defining Variables and Attributes...')
xl_var_ID = netcdf.defVar(ncid,'xl','double',one_ID);
netcdf.putAtt(ncid,xl_var_ID,'long_name','domain length in the XI-direction')
netcdf.putAtt(ncid,xl_var_ID,'units','meter')
el_var_ID = netcdf.defVar(ncid,'el','double',one_ID);
netcdf.putAtt(ncid,el_var_ID,'long_name','domain length in the ETA-direction')
netcdf.putAtt(ncid,el_var_ID,'units','meter')
JPRJ_var_ID = netcdf.defVar(ncid,'JPRJ','char',two_ID);
netcdf.putAtt(ncid,JPRJ_var_ID,'long_name','Map projection type')
netcdf.putAtt(ncid,JPRJ_var_ID,'option_ME_','Mercator')
netcdf.putAtt(ncid,JPRJ_var_ID,'option_ST_','Stereographic')
netcdf.putAtt(ncid,JPRJ_var_ID,'option_LC_','Lambert conformal conic')
netcdf.renameAtt(ncid,JPRJ_var_ID,'option_ME_','option(ME)')
netcdf.renameAtt(ncid,JPRJ_var_ID,'option_ST_','option(ST)')
netcdf.renameAtt(ncid,JPRJ_var_ID,'option_LC_','option(LC)')
PLAT_var_ID = netcdf.defVar(ncid,'PLAT','float',two_ID);
netcdf.putAtt(ncid,PLAT_var_ID,'long_name','Reference latitude(s) for map projection')
netcdf.putAtt(ncid,PLAT_var_ID,'units','degree_north')
PLONG_var_ID = netcdf.defVar(ncid,'PLONG','float',one_ID);
netcdf.putAtt(ncid,PLONG_var_ID,'long_name','Reference longitude for map projection')
netcdf.putAtt(ncid,PLONG_var_ID,'units','degree_east')
ROTA_var_ID = netcdf.defVar(ncid,'ROTA','float',one_ID);
netcdf.putAtt(ncid,ROTA_var_ID,'long_name','Rotation angle for map projection')
netcdf.putAtt(ncid,ROTA_var_ID,'units','degree')
JLTS_var_ID = netcdf.defVar(ncid,'JLTS','char',two_ID);
netcdf.putAtt(ncid,JLTS_var_ID,'long_name','How limits of map are chosen')
netcdf.putAtt(ncid,JLTS_var_ID,'option_CO_','P1, .. P4 define two opposite corners')
netcdf.putAtt(ncid,JLTS_var_ID,'option_MA_','Maximum (whole world)')
netcdf.putAtt(ncid,JLTS_var_ID,'option_AN_','Angles - P1..P4 define angles to edge of domain')
netcdf.putAtt(ncid,JLTS_var_ID,'option_LI_','Limits - P1..P4 define limits in u,v space')
netcdf.renameAtt(ncid,JLTS_var_ID,'option_CO_','option(CO)')
netcdf.renameAtt(ncid,JLTS_var_ID,'option_MA_','option(MA)')
netcdf.renameAtt(ncid,JLTS_var_ID,'option_AN_','option(AN)')
netcdf.renameAtt(ncid,JLTS_var_ID,'option_LI_','option(LI)')
P1_var_ID = netcdf.defVar(ncid,'P1','float',one_ID);
netcdf.putAtt(ncid,P1_var_ID,'long_name','Map limit parameter number 1')
P2_var_ID = netcdf.defVar(ncid,'P2','float',one_ID);
netcdf.putAtt(ncid,P2_var_ID,'long_name','Map limit parameter number 2')
P3_var_ID = netcdf.defVar(ncid,'P3','float',one_ID);
netcdf.putAtt(ncid,P3_var_ID,'long_name','Map limit parameter number 3')
P4_var_ID = netcdf.defVar(ncid,'P4','float',one_ID);
netcdf.putAtt(ncid,P4_var_ID,'long_name','Map limit parameter number 4')
XOFF_var_ID = netcdf.defVar(ncid,'XOFF','float',one_ID);
netcdf.putAtt(ncid,XOFF_var_ID,'long_name','Offset in x direction')
netcdf.putAtt(ncid,XOFF_var_ID,'units','meter')
YOFF_var_ID = netcdf.defVar(ncid,'YOFF','float',one_ID);
netcdf.putAtt(ncid,YOFF_var_ID,'long_name','Offset in y direction')
netcdf.putAtt(ncid,YOFF_var_ID,'units','meter')
depthmin_var_ID = netcdf.defVar(ncid,'depthmin','short',one_ID);
netcdf.putAtt(ncid,depthmin_var_ID,'long_name','Shallow bathymetry clipping depth')
netcdf.putAtt(ncid,depthmin_var_ID,'units','meter')
depthmax_var_ID = netcdf.defVar(ncid,'depthmax','short',one_ID);
netcdf.putAtt(ncid,depthmax_var_ID,'long_name','Deep bathymetry clipping depth')
netcdf.putAtt(ncid,depthmax_var_ID,'units','meter')
spherical_var_ID = netcdf.defVar(ncid,'spherical','char',one_ID);
netcdf.putAtt(ncid,spherical_var_ID,'long_name','Grid type logical switch')
netcdf.putAtt(ncid,spherical_var_ID,'option_T_','spherical')
netcdf.putAtt(ncid,spherical_var_ID,'option_F_','cartesian')
netcdf.renameAtt(ncid,spherical_var_ID,'option_T_','option(T)')
netcdf.renameAtt(ncid,spherical_var_ID,'option_F_','option(F)')
hraw_var_ID = netcdf.defVar(ncid,'hraw','double',[xi_rho_ID eta_rho_ID bath_ID]);
netcdf.putAtt(ncid,hraw_var_ID,'long_name','Working bathymetry at RHO-points')
netcdf.putAtt(ncid,hraw_var_ID,'units','meter')
netcdf.putAtt(ncid,hraw_var_ID,'field','bath, scalar')
h_var_ID = netcdf.defVar(ncid,'h','double',[xi_rho_ID eta_rho_ID]);
netcdf.putAtt(ncid,h_var_ID,'long_name','Final bathymetry at RHO-points')
netcdf.putAtt(ncid,h_var_ID,'units','meter')
netcdf.putAtt(ncid,h_var_ID,'coordinates','lon_rho lat_rho')
netcdf.putAtt(ncid,h_var_ID,'field','bath,scalar')
f_var_ID = netcdf.defVar(ncid,'f','double',[xi_rho_ID eta_rho_ID]);
netcdf.putAtt(ncid,f_var_ID,'long_name','Coriolis parameter at RHO-points')
netcdf.putAtt(ncid,f_var_ID,'units','second-1')
netcdf.putAtt(ncid,f_var_ID,'coordinates','lon_rho lat_rho')
netcdf.putAtt(ncid,f_var_ID,'field','Coriolis,scalar')
pm_var_ID = netcdf.defVar(ncid,'pm','double',[xi_rho_ID eta_rho_ID]);
netcdf.putAtt(ncid,pm_var_ID,'long_name','curvilinear coordinate metric in XI')
netcdf.putAtt(ncid,pm_var_ID,'units','meter-1')
netcdf.putAtt(ncid,pm_var_ID,'field','pm, scalar')
pn_var_ID = netcdf.defVar(ncid,'pn','double',[xi_rho_ID eta_rho_ID]);
netcdf.putAtt(ncid,pn_var_ID,'long_name','curvilinear coordinate metric in ETA')
netcdf.putAtt(ncid,pn_var_ID,'units','meter-1')
netcdf.putAtt(ncid,pn_var_ID,'field','pn, scalar')
dndx_var_ID = netcdf.defVar(ncid,'dndx','double',[xi_rho_ID eta_rho_ID]);
netcdf.putAtt(ncid,dndx_var_ID,'long_name','xi derivative of inverse metric factor pn')
netcdf.putAtt(ncid,dndx_var_ID,'units','meter')
netcdf.putAtt(ncid,dndx_var_ID,'field','dndx, scalar')
dmde_var_ID = netcdf.defVar(ncid,'dmde','double',[xi_rho_ID eta_rho_ID]);
netcdf.putAtt(ncid,dmde_var_ID,'long_name','eta derivative of inverse metric factor pm')
netcdf.putAtt(ncid,dmde_var_ID,'units','meter')
netcdf.putAtt(ncid,dmde_var_ID,'field','dmde, scalar')
x_rho_var_ID = netcdf.defVar(ncid,'x_rho','double',[xi_rho_ID eta_rho_ID]);
netcdf.putAtt(ncid,x_rho_var_ID,'long_name','x location of RHO-points')
netcdf.putAtt(ncid,x_rho_var_ID,'units','meter')
y_rho_var_ID = netcdf.defVar(ncid,'y_rho','double',[xi_rho_ID eta_rho_ID]);
netcdf.putAtt(ncid,y_rho_var_ID,'long_name','y location of RHO-points')
netcdf.putAtt(ncid,y_rho_var_ID,'units','meter')
x_psi_var_ID = netcdf.defVar(ncid,'x_psi','double',[xi_psi_ID eta_psi_ID]);
netcdf.putAtt(ncid,x_psi_var_ID,'long_name','x location of PSI-points')
netcdf.putAtt(ncid,x_psi_var_ID,'units','meter')
y_psi_var_ID = netcdf.defVar(ncid,'y_psi','double',[xi_psi_ID eta_psi_ID]);
netcdf.putAtt(ncid,y_psi_var_ID,'long_name','y location of PSI-points')
netcdf.putAtt(ncid,y_psi_var_ID,'units','meter')
x_u_var_ID = netcdf.defVar(ncid,'x_u','double',[xi_u_ID eta_u_ID]);
netcdf.putAtt(ncid,x_u_var_ID,'long_name','x location of U-points')
netcdf.putAtt(ncid,x_u_var_ID,'units','meter')
y_u_var_ID = netcdf.defVar(ncid,'y_u','double',[xi_u_ID eta_u_ID]);
netcdf.putAtt(ncid,y_u_var_ID,'long_name','y location of U-points')
netcdf.putAtt(ncid,y_u_var_ID,'units','meter')
x_v_var_ID = netcdf.defVar(ncid,'x_v','double',[xi_v_ID eta_v_ID]);
netcdf.putAtt(ncid,x_v_var_ID,'long_name','x location of V-points')
netcdf.putAtt(ncid,x_v_var_ID,'units','meter')
y_v_var_ID = netcdf.defVar(ncid,'y_v','double',[xi_v_ID eta_v_ID]);
netcdf.putAtt(ncid,y_v_var_ID,'long_name','y location of V-points')
netcdf.putAtt(ncid,y_v_var_ID,'units','meter')
lat_rho_var_ID = netcdf.defVar(ncid,'lat_rho','double',[xi_rho_ID eta_rho_ID]);
netcdf.putAtt(ncid,lat_rho_var_ID,'long_name','latitude of RHO-points')
netcdf.putAtt(ncid,lat_rho_var_ID,'units','degree_north')
lon_rho_var_ID = netcdf.defVar(ncid,'lon_rho','double',[xi_rho_ID eta_rho_ID]);
netcdf.putAtt(ncid,lon_rho_var_ID,'long_name','longitude of RHO-points')
netcdf.putAtt(ncid,lon_rho_var_ID,'units','degree_east')
lat_psi_var_ID = netcdf.defVar(ncid,'lat_psi','double',[xi_psi_ID eta_psi_ID]);
netcdf.putAtt(ncid,lat_psi_var_ID,'long_name','latitude of PSI-points')
netcdf.putAtt(ncid,lat_psi_var_ID,'units','degree_north')
lon_psi_var_ID = netcdf.defVar(ncid,'lon_psi','double',[xi_psi_ID eta_psi_ID]);
netcdf.putAtt(ncid,lon_psi_var_ID,'long_name','longitude of PSI-points')
netcdf.putAtt(ncid,lon_psi_var_ID,'units','degree_north')
lat_u_var_ID = netcdf.defVar(ncid,'lat_u','double',[xi_u_ID eta_u_ID]);
netcdf.putAtt(ncid,lat_u_var_ID,'long_name','latitude of U-points')
netcdf.putAtt(ncid,lat_u_var_ID,'units','degree_north')
lon_u_var_ID = netcdf.defVar(ncid,'lon_u','double',[xi_u_ID eta_u_ID]);
netcdf.putAtt(ncid,lon_u_var_ID,'long_name','longitude of U-points')
netcdf.putAtt(ncid,lon_u_var_ID,'units','degree_north')
lat_v_var_ID = netcdf.defVar(ncid,'lat_v','double',[xi_v_ID eta_v_ID]);
netcdf.putAtt(ncid,lat_v_var_ID,'long_name','latitude of V-points')
netcdf.putAtt(ncid,lat_v_var_ID,'units','degree_north')
lon_v_var_ID = netcdf.defVar(ncid,'lon_v','double',[xi_v_ID eta_v_ID]);
netcdf.putAtt(ncid,lon_v_var_ID,'long_name','longitude of V-points')
netcdf.putAtt(ncid,lon_v_var_ID,'units','degree_east')
mask_rho_var_ID = netcdf.defVar(ncid,'mask_rho','double',[xi_rho_ID eta_rho_ID]);
netcdf.putAtt(ncid,mask_rho_var_ID,'long_name','mask on RHO-points')
netcdf.putAtt(ncid,mask_rho_var_ID,'option_0_','land')
netcdf.putAtt(ncid,mask_rho_var_ID,'option_1_','water')
netcdf.renameAtt(ncid,mask_rho_var_ID,'option_0_','option(0)')
netcdf.renameAtt(ncid,mask_rho_var_ID,'option_1_','option(1)')
mask_u_var_ID = netcdf.defVar(ncid,'mask_u','double',[xi_u_ID eta_u_ID]);
netcdf.putAtt(ncid,mask_u_var_ID,'long_name','mask on U-points')
netcdf.putAtt(ncid,mask_u_var_ID,'option_0_','land')
netcdf.putAtt(ncid,mask_u_var_ID,'option_1_','water')
netcdf.renameAtt(ncid,mask_u_var_ID,'option_0_','option(0)')
netcdf.renameAtt(ncid,mask_u_var_ID,'option_1_','option(1)')
mask_v_var_ID = netcdf.defVar(ncid,'mask_v','double',[xi_v_ID eta_v_ID]);
netcdf.putAtt(ncid,mask_v_var_ID,'long_name','mask on V-points')
netcdf.putAtt(ncid,mask_v_var_ID,'option_0_','land')
netcdf.putAtt(ncid,mask_v_var_ID,'option_1_','water')
netcdf.renameAtt(ncid,mask_v_var_ID,'option_0_','option(0)')
netcdf.renameAtt(ncid,mask_v_var_ID,'option_1_','option(1)')
mask_psi_var_ID = netcdf.defVar(ncid,'mask_psi','double',[xi_psi_ID eta_psi_ID]);
netcdf.putAtt(ncid,mask_psi_var_ID,'long_name','mask on PSI-points')
netcdf.putAtt(ncid,mask_psi_var_ID,'option_0_','land')
netcdf.putAtt(ncid,mask_psi_var_ID,'option_1_','water')
netcdf.renameAtt(ncid,mask_psi_var_ID,'option_0_','option(0)')
netcdf.renameAtt(ncid,mask_psi_var_ID,'option_1_','option(1)')
angle_var_ID = netcdf.defVar(ncid,'angle','double',[xi_rho_ID eta_rho_ID]);
netcdf.putAtt(ncid,angle_var_ID,'long_name','angle between xi axis and east')
netcdf.putAtt(ncid,angle_var_ID,'units','radian')
%end define mode
netcdf.endDef(ncid)
% Fill the variables with data.
disp(' ## Filling Variables...')
switch lower(projection)
case 'mercator'
theProjection = 'ME';
case 'stereographic'
theProjection = 'ST';
case 'lambert conformal conic'
theProjection = 'LC';
otherwise
theProjection = 'NA'; % not applicable
end
% Fill the variables.
netcdf.putVar(ncid,JPRJ_var_ID,theProjection);
netcdf.putVar(ncid,spherical_var_ID,'T');
netcdf.putVar(ncid,xl_var_ID,xl);
netcdf.putVar(ncid,el_var_ID,el);
f = 2.*7.29e-5.*sin(geogrid_lat(j_rho, i_rho).*pi./180);
f(isnan(f))=0; % doesn't like f to be NaN
netcdf.putVar(ncid,f_var_ID,f');
netcdf.putVar(ncid,x_rho_var_ID,grid_x(j_rho, i_rho)');
netcdf.putVar(ncid,y_rho_var_ID,grid_y(j_rho, i_rho)');
netcdf.putVar(ncid,x_psi_var_ID,grid_x(j_psi, i_psi)');
netcdf.putVar(ncid,y_psi_var_ID,grid_y(j_psi, i_psi)');
netcdf.putVar(ncid,x_u_var_ID,grid_x(j_u, i_u)');
netcdf.putVar(ncid,y_u_var_ID,grid_y(j_u, i_u)');
netcdf.putVar(ncid,x_v_var_ID,grid_x(j_v, i_v)');
netcdf.putVar(ncid,y_v_var_ID,grid_y(j_v, i_v)');
netcdf.putVar(ncid,lon_rho_var_ID,geogrid_lon(j_rho, i_rho)');
netcdf.putVar(ncid,lat_rho_var_ID,geogrid_lat(j_rho, i_rho)');
netcdf.putVar(ncid,lon_psi_var_ID,geogrid_lon(j_psi, i_psi)');
netcdf.putVar(ncid,lat_psi_var_ID,geogrid_lat(j_psi, i_psi)');
netcdf.putVar(ncid,lon_u_var_ID,geogrid_lon(j_u, i_u)');
netcdf.putVar(ncid,lat_u_var_ID,geogrid_lat(j_u, i_u)');
netcdf.putVar(ncid,lon_v_var_ID,geogrid_lon(j_v, i_v)');
netcdf.putVar(ncid,lat_v_var_ID,geogrid_lat(j_v, i_v)');
if ~isempty(bathymetry)
% netcdf.putVar(ncid,h_var_ID,bathymetry);
netcdf.putVar(ncid,h_var_ID,bathymetry');
end
% Masking.
mask = ~~mask;
land = mask;
water = ~land;
rmask = water;
% Calculate other masking arrays.
umask = zeros(size(rmask));
vmask = zeros(size(rmask));
pmask = zeros(size(rmask));
for i = 2:Lp
for j = 1:Mp
umask(j, i-1) = rmask(j, i) * rmask(j, i-1);
end
end
for i = 1:Lp
for j = 2:Mp
vmask(j-1, i) = rmask(j, i) * rmask(j-1, i);
end
end
for i = 2:Lp
for j = 2:Mp
pmask(j-1, i-1) = rmask(j, i) * rmask(j, i-1) * rmask(j-1, i) * rmask(j-1, i-1);
end
end
netcdf.putVar(ncid,mask_rho_var_ID,uint8(rmask'));
netcdf.putVar(ncid,mask_psi_var_ID,pmask(1:end-1, 1:end-1)');
netcdf.putVar(ncid,mask_u_var_ID,umask(1:end, 1:end-1)');
netcdf.putVar(ncid,mask_v_var_ID,vmask(1:end-1, 1:end)');
% Average angle -- We should do this via (x, y) components.
temp = 0.5*(ang(1:end-1, :) + ang(2:end, :));
ang = zeros(n, m);
ang(2:2:end, 2:2:end) = temp;
ang(isnan(ang))=0; % doesn't like NaN
% nc{'angle'}(:) = ang(j_rho, i_rho);
netcdf.putVar(ncid,angle_var_ID,ang(j_rho, i_rho)');
% Use "geometry" from seagrid file for computation of "pm", "hraw".
% "geometry" contains distances computed from lon and lat in the
% Seagrid routine "dosave.m" using the "earthdist.m" routine, which
% assumes a spherical globe with a radius of 6371 km.
gx = geometry{1}; % Spherical distances in meters.
gy = geometry{2};
sx = 0.5*(gx(1:end-1, :) + gx(2:end, :));
sy = 0.5*(gy(:, 1:end-1) + gy(:, 2:end));
pm = 1 ./ sx;
pn = 1 ./ sy;
hraw = 1 ./ sy;
% pm and hraw cannot be Inf, even if on land, so if values
% are Inf, set to an arbitrary non-zero value
pm(isinf(pm))=0.999e-3;
pn(isinf(pn))=0.999e-3;
hraw(isinf(hraw))=0.999e-3;
pm(isnan(pm))=0.999e-3;
pn(isnan(pn))=0.999e-3;
hraw(isnan(hraw))=0.999e-3;
netcdf.putVar(ncid,pm_var_ID,pm');
netcdf.putVar(ncid,pn_var_ID,pn');
count = [1 Lp Mp];
start = [0 0 0];
hraw_data(:,:,1) = hraw;
netcdf.putVar(ncid,hraw_var_ID,start,count,hraw_data');
dmde = zeros(size(pm));
dndx = zeros(size(hraw));
dmde(2:end-1, :) = 0.5*(1./pm(3:end, :) - 1./pm(1:end-2, :));
dndx(:, 2:end-1) = 0.5*(1./hraw(:, 3:end) - 1./hraw(:, 1:end-2));
dmde(isinf(dmde))=0;
dndx(isinf(dndx))=0;
dmde(isnan(dmde))=0;
dndx(isnan(dndx))=0;
netcdf.putVar(ncid,dmde_var_ID,dmde');
netcdf.putVar(ncid,dndx_var_ID,dndx');
% Final size of file:
% s = size(nc);
% disp([' ## Dimensions: ' int2str(s(1))])
% disp([' ## Variables: ' int2str(s(2))])
% disp([' ## Global Attributes: ' int2str(s(3))])
% disp([' ## Record Dimension: ' name(recdim(nc))])
% disp([char(13),char(13),char(13)])
disp(['SCREEN DISPLAY:',char(13)])
disp('COPY-PASTE the following parameters into your ocean.in file')
disp('----------------------------------------------------------------------------------------------')
disp(char(13))
disp([' Lm == ' num2str(Lp-2) ' ! Number of I-direction INTERIOR RHO-points'])
disp([' Mm == ' num2str(Mp-2) ' ! Number of J-direction INTERIOR RHO-points'])
% disp([' N == ' num2str(N) ' ! Number of vertical levels'])
disp(char(13))
% disp(['Make sure the Baroclinic time-step (DT) in your ocean.in file is less than: ' num2str(sqrt(((min(min(dx))^2)+(min(min(dy))^2)) / (9.8 * (min(min(h))^2)))) ' seconds'])
fprintf('\n Done. Grid written to %s!\n', theRomsFile)
netcdf.close(ncid);
lwblayman
#4 Unread post by lwblayman »
I have the same problem.when i use "seagrid2roms",it happens the errors as follows.
??? Undefined function or method 'name' for input arguments of type 'double'.
## SeaGrid Source File : D:\lwb\model\seagrid\seagrid.mat
## ROMS Destination File: D:\lwb\model\seagrid\roms_grd.nc
Error in ==> seagrid2roms at 231
name(nc{'JPRJ'}.option_ME_, 'option(ME)')
gmaze
#5 Unread post by gmaze »
I am using the seagrid2roms_new file provided here and I am getting the following errors.
theSeagridFile =
/Users/gracemaze/ROMS/Projects/Upwelling/MyDir/wfs_seagrid.mat
theRomsFile =
/Users/gracemaze/ROMS/Projects/Upwelling/MyDir/roms_grd.nc
## SeaGrid Source File : /Users/gracemaze/ROMS/Projects/Upwelling/MyDir/wfs_seagrid.mat
## ROMS Destination File: /Users/gracemaze/ROMS/Projects/Upwelling/MyDir/roms_grd.nc
??? Error using ==> netcdflib
Library failure "NetCDF: Start+count exceeds dimension bound".
Error in ==> putVar at 102
netcdflib(funcstr,ncid,varid,varargin{:});
Error in ==> seagrid2roms_new at 574
Can anyone help?
#6 Unread post by arango »
The only seagrid2roms.m that we support is distributed in the ROMS matlab repository. This file was updated couple of months ago to be consistent with ROMS new developments about nesting. I also made changes to SeaGrid. This works well for me...
:idea: We are not responsible for the scripts developed by third parties. I have checked these scripts from time to time and I usually find several mistakes due to the lack of familiarity with ROMS numerical kernel options, Matlab, NetCDF, and NetCDF interface to Matlab. I do not have the time to correct the scripts that are distributed by others.
In WikiROMS, we provide :arrow: instructions how to download of the various ROMS repository codes. All the Matlab scripts are self-consistent and tested.
gmxwx
#7 Unread post by gmxwx »
Hi, I got the error as you did on the Matlab2011a platform. I changed the 'count' array into the following format in the seagrid2roms_new.m file :
count = [ Lp Mp 1];
and the error did not come out again
gmaze wrote:Hi,
theSeagridFile =
theRomsFile =
Can anyone help?
